View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Greddy E-manage Q
- Spoon baby!!!!
- Vacuum Line Question (91 LS)
- New member.
- question about civic exhaust and header!
- need to find camber kit for my 87 crx all motor drag car
- Will a MSD Coil and cap for a Si motor work on ZC.
- JDM climate control question.. searched but found nothing......
- Greetings!! New Guy On the Block
- smog help please!
- EF9 midwing...for people who have them or any info, please help
- ball bearings or spindel? please help...
- 91 CRX seat into 89 DX Civic...need more info than search can provide...
- DC sway bar on EF
- morning starts on b16
- update from last nights leak question here is more pics etc
- Hasport's EF - B series header!
- Place racing hydro-conversion kit
- OT: how would you pack up a tranny to ship out?
- nsx motor in a crx?
- Need Help with motor swap
- Intake noise with aftermarket intake
- differences between 88-91 crx rear discs?
- '91 civic with JDM type-R, which aem CAI to use?
- Will ITR dropfork bushings fit in an Si?
- 98 Ex into 91 CRX SI
- Exhaust question !!!!
- Installing front GSR suspension/brakes.
- Keeping A/C with B16...got some ????
- what floor jack...car is too low now??
- what would you call the front piece
- FAILED Emissions!
- SOHC ZC Cam comparison specs here
- CRX rally car update:
- REAR WHEEL BEARING REPLACEMENT
- Swap party at my house!! Connecticut
- all wheel turning??
- anyone know how to do a 91 dx rewiring??????????
- Vision mirrors?
- code 12??
- ef swap idea
- easssy question
- are any hoods interchangeable between 90to91 efs
- how big is the y8 trottle body? is it as big as the b16a one? 60mm?
- what would i need to do a Vtec conversion
- any1 ever have
- xtd clutches
- CRX with 5 bolt
- SOHC can't decide, help?
- testing fuel pump without installing it on the car
- any1 selling a JDM rear seat
- A LS VTEC OR B20 VTEC
- eibach pro kit help
- Mini me swap info needed .
- new honda owner need some help with zc swap
- Master Cylinder Install
- efguys help me out!! i have a leak cant decide what to do i have pics!
- trying to wire up a Cd player
- Dizzy help for A6 mini me, using Z6 head. SEARCHED
- K - series motor mounts for 88-91
- b17 swap
- ANYONE KNOWS WHERE I CAN FIND A 88-91 CRX ROOF SPOILER??
- Will this head work?
- will the crx jdm front end fit on a hatch?
- clutch not relasing after replacing trans
- Has anyone purchased parts from Hparts.com
- Window replacement advice needed
- CRX Si Suspension Problems
- Engine blown CRX value?
- zc twin cam or sohc vtec u be the judge
- Is the suspension on an 87 CRX The same as the 88 crx and if not
- What sensor is this?
- Getting ready to paint interior & ZC questions
- Another Si cam into a D15 thread(PLZ help out)...
- dx civic rewiring to hf or si harness
- crx dx with d16y8 --- what are my ecu options?
- Quick Question: CRX HF
- I need help!
- WTB: 88-91crx Si or 92-95 hatch in AZ ASAP
- Hydro clutch conversion????
- Any of you guys used the Honda F4i ITB's on the ZC?...
- Wrapping Headers
- question about OBD-1 conversion
- My pics of the new Hasport kit for a Hydro trans in an EF/ED!
- brake master cylinder
- 88 SI W Blades pics!
- Crashed my newest CRX, is it saveable? (pics)
- How does 90-91 teg distributor fit 1'st gen b16 head?
- cr-x decal
- strut bar doesn clean engine !
- Anyone running European heated seats?
- Header or Exhaust manifold?
- rims
- im torn what do yall think
- brake...well....sorta...
- zc distributor
- honda radaitor fans, do they suck or blow? (nt)
- D16A6 ARP head studs???
- Timing belt cover question?
- FMU ?
- for sale- SOCAL ef parts
- zc question
- Wheels and Speedos
- WTB 88-89 CRX driver side door/driver side fender/black door panels--good condition
- allinenment problems... somebody help please....
- radiator swap eg mini into ef?
- O2 Sensor problems?
- Master Cylinder upgrade!
- Mpfi Conversion..
- Loss of Charge in battery?
- help with swap Please!!!!!!!!
- WTB : d16z6 timing belt + d16y8 head gasket
- HELP!!!!!!!!!!!!!!!! need answer asap!!!!!
- Smog and modified exhaust
- weird ecu code.. HELP!!!
- Engine go into water?
- roll cage help???
- Those who have dynoed their ZC, post results aswell as setups.
- CRX b16a Help Identify Some Parts. lots of pictures
- Whats the fastest you've had your car to?
- crx sir registration
- Question about......
- WTB- CRX Black dash and carpet in good condition...
- Need a chassis code of a CRX?
- check engine, 1 blink (oxygen sensor/content)
- ys1 into crx
- How does registering a ef8 work?
- what do you guys thinks about car-body-parts.com?
- Need h22 tranny/axle help...car wont move
- will any 88-91 crx rear bumper fit an 88
- 92-95 shift linkage the same????????????
- Pic Request: Rear Speakers in hatchbacks
- Sending unit for Autometer gauges...?
- Mini-Me Install Question
- head types
- Where Can My Friend Order This Front Bumper?????
- axle seals
- need help idling too high
- Question on Lowering Springs?
- zc tranny
- Help with vtec
- Useless engine bay materials?
- d15 to d16 mpfi
- swap
- body work help
- Battery Cable?
- d16b8 into 90 crx HF
- Brakes for a STD
- 88-91 Sir (EF8/9) Gauge Cluster
- Smog REF HELP
- First time doing body work...
- D16Y8 Head On D15B2 Block?
- K20 in CRX
- 15x7 inch wheels
- JDM CR-X SiR EMBLE....
- Please help me with my mini me swap
- 91 crx water leak?
- B20-VTEC ECU
- Slid on some ice in my B18C rex...hit curb :(
- Heater isnt working but everythign checks out...
- finally scanned my jdm b16a smog results from last summer...
- 95 ex motor in a crx
- Whats the new site name for JDMHONDAPARTS.com?
- guage cluster bulb sizes?
- ZC swap
- My Hood won't open
- Couple quick questions please help me need to pass inspection
- 88 CRX/B18c1/Skunk2 Im
- i need to kno if i can use a 88-91 si tranny with a b16 swap
- what turbo in zc?
- H22 in a CRX???
- please help with dpfi to mpfi distributer
- Brake Booster for a RHD CRX
- 89-91 civic headlights for sale
- engine swap for 1st gen CRX
- steering problems
- I need a measurement please
- AWFUL rubbing noise coming from rear tires...
- Helms manual - part #61SH302???
- Miata seats in CRX???
- Shift Knob Problem
- Eg lower control arm fitment??
- CRX 3" exhaust????
- MEGAN 4-2-1 HEADER....any good?
- mini-me update
- need 1st gen CRX info (swap, etc)
- 1990 civic cx hatchback, code 20 plz help
- one more zc pregunta
- Who's got the hybrid-brakes?
- Will this work??? (LSD)
- what are your settings for tokico illumina and GC coilovers?
- d15b turbo crx..commo guys i want ur imput
- opinions about hmotorsonline.com for zc???
- Question about my wrecked CRX
- ok, so, i wanna cut my fender wells
- RUMOR?
- Stock gauge cluster question - help!
- need to kno what i need for a d16z6 swap
- Whats A usual Price for a rex?
- how much does a stock Civic / CRX hood weigh?
- engine revs without touching gas
- ** WHich Seat Sparco Fighter or Torino 2 **
- Horn pin replacement part? I need the part name??.
- Slow blowing blower motor, any known alternatives???
- crx or civic guys with GSR motors, help needed
- Auto CRX : should I get it?
- Type R manifold on JDM B16 questions EACV
- i think this has to do with oil pan gasket?? help me
- Suspension Techniques sway bar or ES bushings
- D16A6 Camshafts - how to identify
- How do i post in the classifieds
- Who beats on their car?
- Windows a greenish tint...
- need a new gas cap...which one should i get? can i use 92-00 civic?
- price for minor body work and paint job
- Greddy Evo vs. Apexi Ws Which one to Buy?
- car wont start... think its my ignition switch. maybe??? need help ASAP
- was having some problems not getting power in my crx
- Just Bought a a EF for $100
- for those with mpfi swap and si camshaft
- 4 wire o2 sensor not reading?
- Car works, no light on ecu
- is this hasport motor mount?
- Good all motor replacement clutch?
- whats a good price?
- b16a o2 sensor, pcv valve and fuel filter.?
- d16 swap 86 crx si
- Broke bolt while switching door hinges!!! arrrgghh
- Break Lights wont turn on.... Which Fuse?? need help asap
- **what ebrake handle do you have?**
- Tire question...
- carbon fiber hood for euro spec EE8?
- DIY anyone pulled a frame?? or straightend a front end???
- thank you!!!!
- I dont understand how it wont fit, need some help
- questions 4 the x periencd/ p.s.... got a field vtec cont.
- D series header needed..
- my messed up engine
- Finding a D16Z6
- WTB: crx si 88-91 underdash and enigne harness
- GROUP BUY ON INGALLS CAMBER KIT $100 SHIPPED
- front suspension arms interchangable?
- do i need a relay to make v-tec work
- white cars with bronze or gold wheels pics?
- clutch cable and throttle cable too short perhaps? b16a crx
- what are the best tires??????
- do these radiator hoses look like the right size
- When I get my crx
- question about axles for b16a
- obd1 conversion not working
