View Full Version : Honda CRX / EF Civic (1988 - 1991)
- EF Motor swap Questions????
- Civic std. windshield wiper speed settings........
- got some idle problems ... any suggestions
- Sohc ZC swap into EF Si
- racing seat
- obd0 ecu light stays on
- vibration at 60mph+
- H22a
- Brake Caliper
- what am i lookin at
- engine question
- Would it be smart to have an daily driver with camber????
- Ef Brake upGrade Parts list
- NEED HELP
- Messed up Suspension/Alignment??
- I want a BIGGER engine; What do I use?
- 90-91 civic carpet
- ***Another Temp Guage Question***
- stock head studs... reusable or no?
- crx is out of the body shop
- What is the length of an ef hatch?
- sometimes i have to hit STARTER w/ hammer to make start, help diagnose please ?
- more mpfi help Qs......
- GOT IN WRECK! radiator pushed together...oxygen sensorHELP!
- Seems like rev limiter is kicking in at 3500-4000 rpms???
- I NEED HELP PLEASE CRX WONT START!!!!!
- CEL when shift into reverse. help needed.
- i need TPS help
- DA Steelies on CRX?
- crx not starting
- Will be replacing valve cover gaskets soon. Should I do valve adjust then?
- rear spoiler tilt?:
- Recaro SRD fitment
- can i use a cable b series VSS?
- fuel pump
- crx vs civic hatch midpipe
- octane help plz
- question about ef's?
- 91 CRX/B16 swap running funny
- b18b1 crx will not start at all, im puzzeled completly. please help!!!
- Code22(Could my chipped p28 be the problem)?
- first honda 700.00 89 hatch with z6 swap
- Do stock jdm mounts fit?????
- Help... people with nitrous chime in PLZ
- San Diego: Who needs stock catback for smog or ref? NOT A F/S F/T ad... FREE!
- msd blaster ss coil ????
- What sunroof visor to use on 91 hatch si
- Ef tint
- LS connecting rods in a D16
- wtb: 1991 crx sir hood
- Weather seal fix
- hoew do I make a universal slim fan a push?
- 1/4 throttle revs up and down continuously???---NEED HELP---
- CRX overheats at high rpm
- Anyone Reupholstered a car themselves?
- 10-30-08 civic dx wont start need help please
- y-49 CRX stolen in Brooklyn, NY
- window regulator repair?
- CRX Problem Need HELP ASAP!!!
- can running rich clog injectors?
- My ED6...a work in progress
- Racing stories?!
- prop valve question
- exhaust opinion
- need some help with dangerous braking prob.
- need help!!!!!
- Pic Request: Combo Switch for Dash Lights...what does it look like?
- b18a1 specs
- front crossmember torque specs?
- D16Z6 valve springs and retainers in a D15B2 head?
- haveing some problems with a 90 si crx
- new to the board
- passenger floor water leak????????
- engine boging
- slipping clutch?
- check engine light on PLEASE help
- Where to find wind/bug deflector for my hood?:
- running to lean
- rex is smokin bad
- what type of transmission fluid is used for 1986 civic 1.3l 4spd manual?
- 91 ef b16a breaking up in vtec
- wtf is he thinkin
- quick question
- ZC QUESTION
- CRX fuse bo wiring help!
- EF2 weight?
- Auto Y8 intake manifold questio
- dx and si speed sensor difference?
- 91 dx sedan slow buld
- car shakes like a MOFO!
- Building a motor from ground up......need info!!!!!
- OEM Civic Radio with CD Player
- None of my gauges work?
- CRX CF hood fitment
- Woo! Lets soil my name. I'm new.
- headers glowing red
- Where to get orange bumper lights?
- Need complete clarification: What seats bolt directly into a 91 hatch?
- throttle cable on b16a..???
- 90 civic hb si trouble starting when engine is a normal operating temp
- 89 dx doesnt start
- Synthetic motor oil = no go in manual trans?
- 4 wheel disk brake conversion help
- Bumper Bolts
- crx traction bar question
- Question about DBA Rotors
- Rear Passengr wheel 1/2 inch farther out than driver side, LCAs?
- crx temp guage
- When doing a wire tuck:
- HARNESS INFO PLEASE...
- Civic (1990) no heater/ac fan
- Can anyone I.D this aftermarket wing?
- coil springs help
- tranny choices
- Starting problem!!
- Irradic idle / Surging Idle
- fuel pressure question
- Tune-Up...
- Wiring problem HELP!!!!
- Engine Trouble Code - Am I reading this right?
- 7lb. Fidanza Flywheel... good or bad??
- 90 crx build
- act clutch for single cam...
- car bogging
- random antenna question
- thermo
- High NOX! New CAT, New O2 Sensor...Still no pass
- Crx Si Sunroof Problem
- Mini-me question.
- Radiator Overflow Tank is cracked, should I flush cooling the system, car is not overheating
- rear interior delete kit
- gas leak from crack on pipe, but having problems with jbweld
- Quick Wiring harness question..
- bprsk8r4272's 90 civic si Build Thread
- Skunk2 mani on D16
- *video* - 1990 Civic Si Vibrant Performance muffler exhaust
- Check Engine light on, Need some help.
- 35mpg wanting more
- obd-0 sohc zc intake manifold on a 99 y8 head will it work..? searched no results help
- Mini me swap Oil pump question
- i smell gas in my car... and not from me.
- ls swap
- converting a DOHC ZC ODB0 to a ODB1.
- Removing the front bumper
- the best d series?????
- What do i need to do a B series swap?
- Fuel injection
- crx headliner removal
- LS ecu hooked up to a D16
- dual zc head on a d15 block
- 23 to 26 spline hub swap
- ef sedan power windows in crx..? searched yielded nothing help...
- EF sedan front lip
- 90 Civic D16A6 Died today, why?
- eg air intake in a ef crx
- same problem different day
- A/C and windshield wiper plug?
- JDM HEADLIGHT Q
- Mysterious water leak :[
- code 15 > Ignitor Output Signal
- Help With Replacing the Distributor on D15B
- short in altenator
- Crank pulley hitting suspension component?
- Engine running poorly, any ideas!?
- auto to manual
- What ECU?
- 89 teg ecu
- JDM front end fender help...
- JDM and USDM EF Hood.
- d15b is smoking
- 90-91 cluster into a 88dx?
- Velocity stack. Need intake arm......
- is it pointless??
- tokico illuminas
- Pauses Or Stops Firing While Driving
- cylender positon sensor on dohc zc
- what kinda 1/4 times from d16a6?
- ZC-T or b16a/LsVtec N/A?
- Idle issue
- heres some help with code 4
- best header for b-swaped crx
- WTT for a 90 CRX
- Will HF reinforcement bar work under Si bumper?
- CRX no fuel
- b16 axles question?
- b series into a ef si help.
- HELP!!!!!!!!! And intro
- Creeking noise?
- Door speakers
- CRX Corner Light Clips
- To anyone with a 90-91 CRX
- Prepping D15Z1 for installation....need help with seals/gaskets
- ek sideskirts?
- ecu/wiring question
- i about about to cuss a blue streak or break something
- 91 civic suspension
- HELP!!!!
- timing question?
- HEADER SUGGESTION!!
- EDM hatch spoiler
- what to do!?!?!?!?!?! READ
- My car wont start!
- DPFI-MPFI users, dyno numbers?
- Distributor and ECU interchangibility among Si's
- Will it work
- Carbon Fiber hood model confusion
- Front windshield Weatherstripping
- Modified tranny mount needed for auto to manual swap?
- swap or make it clean
- 88 crx with jdm front bumper/hood/light question
- Intake manifold question.
- need help with code 43 Fuel supply system
- engine swap for 87 crx
- Quick question about armrest in my 88 rex! please read/look
- installed a skunk2 short shifter
- I NEED HELP RIGHT NOW PLZ!!!
- CRX cluster question, km/h to mph
- brake master cylinder upgrade
- Would I need to get JDM frenders if I am puting an JDM front on?
- 91 Civic no brake lights or turn signals??
- y8 intake manifold/ air injection holes.
- crx<->civic exhaust
- b20/b16 head
- obd0 B16 question
- crx si ebrake cable (for teg rear disc swap)
- 91ED6 what to do?
- can i take parts off my old motor and put on my D16a6.
- d16y8 no spark
- 1989 CRX SI B18C FOR SALE
- Bad oil leak!
- Excessive steering wheel vibration at idle
- Did the 1991 CRX dx come with sunroof stock?
- B18 in a ef newb
- Ebay control arms, ball joints, tie rod ends for a $100. Anyone have feedback?
- does my engine look crooked?
- please read and help guys!! question about fitment
- CRX swap?
- crx turs off when at a stop when only idling on its own
- help
- weird mini me idea...
- Helllllp with my Crx brakes!!
- Which master cylinder upgrade should I do?
- 1990 civic build up
- could the problem be the crx fuel pump?
- Temp Guage Failure
- loose axle nut
- CRX flooded and now it wont start. Code 0?
- mugen leather e-brake cover into an ef, from rsx or fit
- CRX dash harness is fried. What other will fit? Please look.
- turbo crx
