View Full Version : Honda CRX / EF Civic (1988 - 1991)
- '89 Civic hatch failed emisions test with high HC and NOx
- honda crx blown clutch
- Misfire on cyl 1 obd0 b20 not getting spark
- Need help with mini me swap
- vin explained!
- new here...1990 civic hatchback
- How do I know if my FPR is bad
- Need help determining my ride height
- Why is my left side higher than right side
- CRX b16a swap
- power windows wierd problem
- D16y8 block with d16z6 head
- 90 EF Sedan Coolant Leak
- Coolant Leak
- Carpet
- Stock fuel injector for 89 Si
- b series starter ?
- My EF old skool build
- Building a high compression boosted b16
- Tranny seal help
- JDM OEM parts website like www.hondaautomotiveparts.com?
- Fluctuating Idle 1990 Civic Si
- Missfire?
- overriding a rev limiter
- turn signals blinking too fast
- 1991 HB si disc brake conversion
- carbon fiber roof cap?
- 89 Civic Si hard to shift into 5th gear
- Looking for schematics 88 civic hatchback
- 91 CRX Dirt Track Racecar
- Insurance Quote on a 1990 Civic Si
- 89 crx ignition lock
- Converter solenoid
- Runs Perfect With EGR Disconnected, Doesn't Run With EGR Connected
- Need some help!
- CRX Buy?
- Quick Question
- Hub and Quick Release. Any versions under $150?
- 90 DX stumble/miss when hot
- Ef b16a axle?
- Honda Civic ED7
- Ek coilovers on ef
- looking for the schematics
- 88-91 CRX undertray
- My 1990 Honda crx is idliling at zero.. i need help
- Please help AEM intake
- a real custom made rear sway bar for the civic wagon 4wd and 2wd model poll
- CRX DX TPS
- What to do with these two EF's
- J30 tb on gsr?
- Stock Si front brakes, 11" fastbrake kit rear. Would a 15/16 MC benefit?
- D series fuel pumps?
- 90Dx intro question and future hopes
- Err-3
- Problems with cable JDM b16 tranny and clutch disk.
- Are OEM muffler style the same for all EF years?
- d15b2 (91 Civic Dx Sedan) 218,000 - rebuild
- Can this vacuum dashpot be deleted?
- 91 HF SI DX Hatch Bumper Differences Clarification
- seatcovers
- FAILED EVAP
- Help Identifying This Set up, Just got Car.
- Best Oil
- B18C1 Swap Questions
- Clutch noise when not engaged
- Why Honda Civic 1990 engine does not bend valves
- Wiring Harness easy fix??
- Tachometer help
- b16 swap vacuum problem pls help
- New exhaust +cat+o2 = smoke?
- ecu numbers
- 91 civic z6
- Ef b Series help intermediate shaft?
- Thoughts on Exedy OE clutch for S1 trans?
- what are signs of your fuel pump going bad?
- 88 Crx Si Vtec swap
- screwed up obd1 mpfi conversion
- d16a6 block d15b7 head with a6 cam
- DPFI to OBD1 Problem. Pls Help
- interchangeable ecu's?
- Need help! 89 std hatch coolant system problem
- no pwer to main relau pin 7 (fuel pump)
- Recommend Tires for CRX + MR5 15x6.5
- DPFI to MPFI throttle issue
- CRX weatherstripping
- Dumb Question
- 91 crx what throttle cable bracket do i use
- HAVEN"T BEEN AROUND MUCH
- Stiffening up suspension WITHOUT much drop?
- car starts then dies......help please
- EG to EF suspension interchangable?
- 89 crx no start
- MPFI EF ? HELP
- Headliner differences between STD and DX Hatchback models
- 89 prelude fogs on 91 civic
- CRX Si with high mileage, is it worth it?
- mpfi conversion question
- Differences between p13 and pr4 ecu... Dang pesky CEL
- 88 std CA car with built na b18a and msd 6AL just shuts off randomly? Is it the msd?
- lowering springs swap
- MPFI EF ? HELP
- for those thinking about changing your inner tie rods and rack end bushing
- throttle cable issue
- No power issue
- fresh B18A1 coolant in piston #2
- 1989 honda civic wagovan with 1994 honda civic hatch short throw?
- needs a big help! ef sedan wont shift at all!
- DPFI to MPFI OBDO to OBD1 conversion question
- 88 crx siR B18 swap with integra computer
- Clutch Pedal Assembly Broke... Have another but springs are different?!?!
- Brake light switch wiring
- How long does it take the power steering to kick in after fluid change?
- Civic won't start PLZ Help
- Crx a/c addition
- MPFI New Distributor Wiring problem
- front fender ?
- 91 crx si ls vtec fuel pump question
- wheel bearings/hub 5 speed swap?
- D16z6 head timing help
- What are 88-91 civic VSS pulses per mile?
- bar question about jumpers b18b1
- Can the EACV on a 91 Civic DX be disassembled?
- '96 GSR bogs/sputters hard during WOT
- does anyone know
- Steering Wheel / Hub Upgrades. Any styles to look for or stay away from?
- Making our tail lights look modern, would LED bulbs make it brighter?
- 1991 crx rims, how big can I go?
- My RT4WD Civc Wagon build!
- Ignition issues; 1990 Honda Civic Wagon RT4wd
- HELP SPUTTERING!
- Main bearings
- CRX h22 swapped owners; pictures!
- Weird beeping
- 91 Civic Si Current and Plans
- 91 Honda civic start problems
- Opinions on what to do
- license plate lights
- ground for injectors
- CRX steering rack issue??
- OBD0 to OBD1 + DPFI to MPFI + Mini-Me
- EF8 ball joints
- 91 crx molding
- Differences 88-89 vs 90-91 EF SEDAN
- roof leak 90 crx hf (i know there are many threads on it)
- wiring a dizzy
- Help with Civic Wagon Engine Mounts
- 91 Civic Si Track Build - B18C-R|EF9 SIR Converted
- overheating due to underdriven water pump??
- 91 mpfi swap?
- 90 ef Si no crank/no start
- shift linkage ??
- obd0 to obd1 conversion
- LED climate control bulbs - dimmer still work?
- Have a weird radiator leak
- Headlight wiring HELP
- help my ef wont start just cranks!!
- are these the clips for the rear triangles
- JDM b16a 0bd0 code error(22)
- problems
- NO SPARK
- Skunk2 Alpha Radiator for 88-91 Civic/CRX/Wagovan
- CRX Side Trim
- underhood temps
- Loosing brake fluid in my rhd EF7, but I see no leak
- cars smoking
- Calling all h22 CRX owners... mpg?
- b20b swap in crx
- y8 mani on a6
- 89 Honda Civic SI
- KYB strut mount bushing arrangement.
- 89 Ciivic Si Bogs on Low RPM's
- Couple size questions about CRX speakers
- 89 Civic D15b2 upgrades
- Are these Corbeau seat brackets for a 2nd gen CRX?
- Accelerator/Throttle cable
- radar detector hardwire?
- EF9 project
- 1989 Honda Civic Engine Swap Questions
- 1990 civic hatch trouble starting
- OB1 Code 4 and 8!! Car still starts though!
- Rattling noise at Cold start up? ( Video)
- havin some suspension issues
- Low cold idle, pulsaing fast idle when hot, outdoor temperature dependent
- 1989 ED8 Needs a tune up. ...Florida...
- B-Series CRX Questions....
- R12 or R123
- seat belts stuck and won't come out..
- Swapping a d15b7 in my 89 crx si
- backfiring
- please... somebody help
- A/C question. It's getting HOT!!!
- Just bought 89 hatch what should I do
- Z6 block and Y8 head...help please!
- After REX work... no start.
- dpfi to mpfi question
- engine spinning in opposite rotation
- Wire tuck/bay question
- economic 90 crx si
- Why is my tach doing this? **video**
- running rich problems
- p28 vs p08 chipped mini me
- Suspension
- Camber Kits
- Wire Harness Adapter Help
- Brakes
- tan/black/blue/grey/red interior
- Need Help!!!
- is da rear bmpr direct fit
- bolt size references
- No crank starting issue
- quick hp question
- Starting troubles, 1991 Si, OBD1
- smoking
- Distributor Troubles
- Stage 2 clutch
- Weather-tech floor liners?
- replaced battery terminals and now no power
- how long are lca's
- Who here has recently done a auto to 5 speed?
- 89 crx axle problem
- Climate control questions
- camber kit issues
- front wheels have some drag when spinning.
- Gasket issue
- 5th Gear Question
- 89 DX Hatchback build/update thread
- confused on mpfi wiring
- 91 honda civic wont start
- ignition lock issue
- si harness questions
- First gen b16a dying problem wont stay running
- ZC DOCH HELP !
- K&N or OEM air Filter ?
- Fuel pump issue
- Trouble with Vehicle speed sensor
- Comfortable seats
- CRX Si speedometer hesitation
- jdm b18c type r CRX WONT START
- What is this white residue on my door panel?
- junkyard finds
- LCA installation trouble
- 88 ef need help asap
- a few questions
- low cold idle/warm start/fuel pressure drop after run
- 89 DX hatch questions
- code 4 on new dizzy
- Poor man's homemade $20 Car Alarm FINISHED
- CRX stalls when I coast
- CRX help
