View Full Version : Honda CRX / EF Civic (1988 - 1991)
- B20Vtec Issue....
- Brake Booster Pin Pivot Removal after the fact
- custom ecu to engine wiring harness
- Question. Does the 89 crx have sliding automatic seat belts?
- 90 91 honda civic ef d series.
- Hello from the UK!
- Civic 91 Question
- d15b7 with 4spd tranny, what clutch and flywheel? Searched!
- 89 crx si electrical problem.
- Helping a friend...
- Engine Coolant Temp (ECT) sensor questions
- Throwout
- honda 91 crx jdm b16a abnormal vibrating after cv axle replacement.
- 88 crx hf swap info?
- broke o2 sensor... header removal???
- d15b2 disconecting an si tranny please help
- B16A/ CRX PW0 ecu and redlines @ 7300???
- Need help on my fuel pump for my crx!!!
- ef hatch radiator support
- Ex Knuckles
- 91 crx HF hub
- 90 civic dies out randomly
- b18 swap in ef help!!!
- how the hell do i remove my spare tire?
- EF2 Civic Lock Set Question
- Back in a CRX - a hillclimb project!
- Soon to be buying new motor... Leak down test better? Or compression test?
- 5th gear died while driving
- question: b7 block w/ y7 head .
- d15b2 with z6 head
- Car shuts off at full stop
- after market seats
- Would 96-00 Square EK Fogs fit on EF9?
- 88 crx si sunroof wont shut
- EF center console swap
- Muffler shop exhaust experiences?
- Auto seatbelts
- EF9 clutch cable
- Car dies when gas goes below 1/4 tank help! SEARCHED!!
- B16 Vtec isn't working.. 1500rpm idle...
- Is this a bad fuel pump? symptoms inside
- 92-95 Civic VSS
- looking at a b16b swap
- new guy
- Electrical connector identification
- retrofitting EF fog
- cluster cable?
- Exhaust Help
- Skunk2 Short Shifter
- cant start car with key but can push start?
- DA master cylinder
- Where is all the A/C guys at?
- 89 hatch with suspension/braking issue
- USDM 91 Bumper not lining up properly
- hit brakes and car dies on b18a1
- axel?
- 90 crx dx - y8 swap and still pass cali smog?
- 88 ED3 DX Power Steering stopped working
- Anyone using 5mm spacer or more with stock studs on a ef?
- New here....
- 89 si b16a swap no spark
- F20B swap mounts questions
- swap choice delma
- 89 DX HEAD GASKET QUESTION
- Power FC vs Hondata
- zc hesitates with full throttle but not when opened slowly?
- 89 Si and 90 DX
- Help!!! Car won't start, primes and cranks but not starting
- Buying a YS1 lsd trans, troubleshooting?
- DA rear LCA on EF civic.
- front end questions
- 89 crx with a blown ecu fuse
- Jdm Zc mounting
- First mod!
- 90 CRX Si B16a. First upgrades? But with a catch
- EF Civic, B18A1, 20-130 b16 transmission [Video]
- What is a good basemap for a mpfi swapped D15B2?
- Why wont Speedometer work
- crx hatch replacement/modification
- Cluster Issues
- 91 integra aftermarket sway fit 91 Civic Hatch?
- front bumper help
- cluster issue!
- Vtec wiring?
- motor mount bracket Issue
- My exhaust job
- Would it hurt to overfill my mtf a little?
- ef9 handling
- Ebay steering wheel + hub kit
- dohc zc hesitating/ rough idle
- running rich d15b
- d15b in crx
- crx HF brake upgrade question
- strange shifter buttons?
- Do 88 crx si come with neutral safety switches
- 87 CRX DX Timing Issues
- Car sputters on throttle
- fuel loss ?
- Crx wont start
- DIY Plumbing an EF8
- throwing some engine codes
- d16y7 in ef
- Passengers seat to drivers seat swap
- BrakesPros.com CRX K20-Powered Road Race Build
- 95 gsr cam cap bolt troubles?
- New to honda-tech
- Brake light issue 90 ef
- b18c1 build advice.
- 89 crx build- advice?
- 1990 CRX HF...ls swap?
- 1989 honda civic si cluster
- ef9 no power a little help
- My Mystery Mounts
- B18A1 swap; getting CEL #10 IAT
- 90 CRX Value
- TPS crx si wiring order
- poor acceleration
- b16a-91 hatch help needed
- Crx hf to si brakes ?
- Ef Hatch Build.
- Strange eletronic issue 89 ef
- problems with my new 89 civic wagon
- need a confirmed guide for d16z6 swap
- Doing a mpfi conversion on my 90 civic lx
- 95 del sol harness into crx, gas tank connector problem
- Sohc ZC help!!
- Ohh, good find but..
- 91 civic HB big turbo build
- Is there such thing as B-series hydro torque mount for traction bar?
- I need axles for my swap! Everything else is in the mail!
- 88 auto d15 crx wont shift past 4500 rpm
- short vid of my '88 Si
- Footrest ?
- 2 way valve on fuel tank needed??
- distributor
- Auto to 4 speed swap help
- A little advice
- Throttle Position Sensor?
- Moisture inside windows
- Civic wont start, weird issue.
- what kind of diy turbo kit can you do on a z6
- What all should I replace on a clutch change?
- how to tell a vtec diz?
- Extended top hat hood clearance
- Where does the '16 valve' decal go?
- Wrirng obd0 to 0bd1 problems HELPP
- differnce between hatch and sedan muffler and
- Rocker Panel Repair
- 88 Crx High Idle; Doesn't start!
- CRX jdm b16a swap
- weird front end issues.... possibly bad lsd
- Whats for dinner?! Build thread
- What Type of Motor Oil?
- wierd random sputter then o2 code
- just converted to obd1 need help!!!!
- d15 missing valve spring retainers???
- whats the best full exhaust system for the crx?
- What Different Model Rear Seat Will Fit in EF? (EG/EK/DA/DC/etc.)
- Obd0 DPFI to OBD1 MPFI conversion.
- HELP. Quick serious question..
- What should I do about my axles?
- B Series Engines
- Cluster swap problem
- will a 4-spoke steering wheel from 91 Civic Sedan LX fit on a 90 CRX Si ?
- Will Integra GSR Rear Seat Fit In EF Hatch?
- Got a CRX, Need Help With Engine
- Transmission help
- Swaps
- quick question....ef 4spd
- $how much would my ef hatch si shell be???
- wide fender kit.
- e brake cables
- wiper fuse keeps blowing
- B16 IM sensor question
- EF/DA Fork inner diameter? Threading shock into fork
- Top Mount Turbo Manifold
- Ef hatch obd1 resistor box ?s
- my 88 crx hf
- Wheel stud splines rounded
- 90 crx si
- Crx d16 y8 low rpm bog
- dash lights.
- how do i know what obd my b18b1 is sorry new to this
- Door Dash Light MAKING ME CRAZY!!!
- rebuild rack or trash it
- need to know if knuckle from 91 civic sedan (DX or LX) fit 90 Crx Si ?
- b18b1/crx wont start
- Clutch Cable?
- CR-X distributor swap
- Serious Emissions problem
- ef code 9
- eg axels in ef
- Civic 4wd Axles?
- Any single cam experts in des Moines
- Fuel pump cuts out when door is closed
- My civic smokes like crazy!
- D16A9 gauges question - newbee
- D15bvtec/s20tranny
- Quick Question About EF Sedan Interior
- Minime swap questions
- EF help!! no spark or fuel pump
- ZC swap suspension question
- D15b2 cam swap
- Question on D15b Dual vtec parts crossover
- found an SI hatch,front end damage, radiator core swap??
- EG Megan Exhaust on EF
- Car Cranks but Wont Start
- D15b2 in 90 crx Hf with stock pm8 Hf ecu yuck...ecu options?
- D15B1/D15B2 ECU and Cam
- electrical help 88 ef with b18a1 obd0
- Switched from VW to Honda..
- Anyway to convert Non-VTEC D15 to VTEC D15 WITHOUT Swap?
- Obd2 harness --> Obd0 harness question
- CRX Si driver<->passenger seat pan swap
- Intercooler Fitment
- considering b20/vtec
- Heat wont get hot enough
- DOHC ZC Question
- 91 crx si need advice/help
- CRX Si door panel paint?
- Different VSS Vehicle Speed Sensors
- Crx harness swap question
- full 0bd1 harness convertion
- 1990 Civic HB DX Wont pass emissions
- building an engine, does a spun bearing mean new crankshaft
- Roof re-skin. adding a sun roof to my dx
- Damn setback: Broken Distributor Mount on D16Z6
- Wipers dont come on same time as washer fluid ?
- Engine Harness Plugs
- crx si engine and underdash harness questions
- p72 pistons in b18a1
- Bouncing Temp Gauge?
- EF wont start.
- Need Help About This Climate Control
- Rear seat removal help
- 88 crx problems
- honda crx transmission question
- uneven power balance
- anybody got a K-CRX
- Good replacement distributor cap? Ignition problems '91 DX
- windshield wiper wiring help
- tie rod and upper ball joint help
- D16y7 ef throttle issue?
- air intakes
- crx brake question
- LS motor with A/C
- obd0 to obd1 conversion harness
- B18a1 obd0 or obd1?
- D&M Motorsports OBD0-OBD1 Conversion Harness
- EF Problems, needs help!!!
