View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Does anyone think Hasport should make a kit to fit hydro D series Trannys in crxs/civics?
- burned rubber smell after drive
- Mini-Me fun!
- help!!!
- Y8 head onto my B1 block, what's the timing off a half tooth thing?
- okay now i've really done it, need help asap, i've searched cant find shit!
- i want to buy turbo kit for my crx with b16a1 swap, any suggestions??
- no brake lights for some reason?
- would this fit?
- d16a6 stock internals
- b16 header
- y 1 tranny...which axels?
- one cylinder wont fire and my check engine light is on?
- Spark Plug & Valve Cover Gasket for SOHC ZC?
- b18 to ef hatch? have 2 complete runnig cars... what else do i need?
- fixing rust inside of screw holes?
- CRX key question
- Sir Brake Swap.
- pr3 j00 ecu code list?
- Seized motor questions
- Can someone explain what it means when checking for code 8?
- Starting Troubles.....
- YS1 Tranny whines, what fluid to use?
- GSR cluster
- Starts and dies?
- Mini me shit
- Smog question
- "Performance" chips
- Quick Engine Swap Question (SOHC ZC into 93 Dx)
- best swap for 2nd gen CRX
- Skunk2 or Illuminas with Tokico springs?
- Rear Bumper Removal
- Picture request, any view under car, specifically the shift linkage
- What the expletive is wrong with my charging system?
- 5 Lug
- Engines...
- b18a1, wheres this hose go ?
- B18 computer??
- strong gas smell inside my 90 civic 1.5...bad enough it will make you sick!!!!!
- 90 civic 1.5 won't idle up when a/c is turned on???i have no idea
- cat to exhaust pipe gasket
- i've got a transmission problem with my 5-speed, anyone have any ideas???
- VTEC SPOOL SOLENOID
- ?? with type r, civic integra
- Hondata S300 P28 OBD1
- is this main relay broken
- 99 si motor in 88 dx hatch wiring issues
- Code 6 ECT.... what could be wrong?
- not going into third our fourth gear
- clutch/trans prob.
- i don't have a reverse light
- Starting problems
- Will this fit?
- Brake lights problem...
- 91 Crx 4 piston calipers ?
- EF sedan owners or anybody that can help for that matter...
- Saw this online, thought I'd share
- Full LHD p/window kit
- rear wiper fill plug
- Wheres my honda transmission filter.
- my d16z6 swap questions
- D15B Three Stage VTEC ready to go
- code 16 (injector)
- help: brake light problem
- JDM CRX Front END Conversion
- CAR BACKFIRES MISSES BUCKING LIKE CRAZY! Car Barely Runs When In Throttle, Out of Knowwhere what hap
- Yellow Headlights?
- Innovative Cable to Hydro Conversion
- Tach. Wiring question/problem
- Check out my STEALTHY CRX fuel cell setup!
- B16 Aftermarket Header pics
- Just double checking... (oil pans)
- seafoam on a high mileage motor?
- head gasket on ef
- roll cage
- has anybody used ebay turbo kits before?????????????
- EG to EF seat swap
- b18a w/ S1 tranny in 91 dx hatch 1/4 times....
- Code 41, o2 heater... cant shake it
- D16a1 in a 89' sedan...
- Need turbo setup pics asap please help!!!!!!!
- uberdata question
- Good place online to buy a Camber Kit for the front.
- KAAZ limited SLip
- b18 swap what exhaust
- crx b18 swap header
- emracing
- crx ZC motor starter problem
- Best corner lights? vote please
- I can't beat code 1 on ECU
- yo i got a few question my homies i need HeLP!
- DPFI, what did i disconnect from the throttle pulley?
- b16 swap what exuast?
- plug and play
- are all CRX doors the same?
- B16 TPS Question??
- New datalogging setup, tell me whatcha think?
- b16a2 in an 88 hatchback wiring help
- replaced head gasket, idles very weird?
- need exhaust help
- installing air/fuel gauge
- HELP!!!!!
- 2 day D16A6 swap in my CRX Si
- Tips on buying a used junkyard engine?
- Optima battery problem ? ANyone else? optima teh poo!
- HELP! EF GOO_ROO's needed.
- WTF: Just bought my first EF9 and it died already...HELP
- difference in 88-89 and 90-91 front upper control arms
- swap d16
- fuse #14/alternator fuse keeps blowing
- Tokico springs
- tranny breather hose important?
- headbolt sizes???
- Cleaning up/removing items from CRX engine bay (charcoal canister, PCV system, ect...)
- how much should i ask
- Problem with exhaust
- Fuel gauge not working correctly - flucates between correct reading and F
- would you buy this?
- DOHC ZC CrankShaft Question..?
- Should I pick up a crx for a prject car?
- PO6 conversion
- I need some help....
- questions about AWD wagovan transmission
- Thanks.....
- 90 crx si driver side rear caliper on a 94 integra gsr spindle
- wiretuck?
- side markers on ef9
- D15B1
- SOHC vs DOHC Gearboxes? would LSDs fit?
- DA brakes. . .Again
- Mounts problem
- exhaust
- posted at (10:30:07 PM)
- help finding somthing
- 91 CRX 4 point harness install.
- Here is what I have done and I cant figure out why my hybrid is running so rich
- Replacing rod bearings in an A6
- look at my flywheel, is it still ok? ***PICS
- OMG she passed!!
- Valve Ajustment
- Anyone tried the Prestone flush kit for the CRX
- Code 17 - VSS
- autocross poll
- close call..
- is d16z6 worth it over d15b2 thats mpfi and mini?
- Intermediate shaft?
- Best intake and Header for ITA race car???
- b16 vs. b18
- Gas Saver
- What radiator is this?
- Brake lines from a rear disc setup fit a rear drum?
- Deffrence in HF and SI
- CRX SI Custom
- Radio antenna block off plate?? ***WTF***
- pumping brakes=not working
- quick question about seats...please answer
- I TOOK MY HEAD OFF TO DO HEAD GASKET,, NEED HELP , THIRD CYLINDER PISTON IS KINDA OF L
- what dizzy?
- Has anyone started running a pair of BC (Brian Crower) camshafts?
- Newbie Help
- b16 swap into 1986 crx hf
- posted at (1:17:56 PM)
- Part identification help
- Pic request:crx w/ race springs
- EP3 seats
- crx console in a hatch
- question
- Bitch Pin Extracting Tool
- Fuel level gauge.... helpful advice.
- OT: For you CRX folks, what else is in your stable?
- AUTOMETER FUEL PRESSURE GUAGE HOW TO INSTALL ( aNY ONE DID ONE OF THESE)
- Which B18C Do I Have?
- picked up my new EF SI-previously used in STS events
- Another Suspension Question ;)
- clicking when i turn right
- i really need some help
- is this a good deal for me
- WHATS BETTER FOR THE MONEY
- Thinking of getting some cams.... any ideas...
- Are all steering wheel hubs the same?
- Cable y1 j1 grinding is this a cause for concern??
- i want to go turbo on 1989 crx si with b16 swap is it worth the money
- Sumitomo HTR 200 High Performance summer tires
- 1/2 radiator pics for anyone interested
- Sedan Fiberglass Doors
- crx and hatch glove box the same?
- sohc zc
- MAP SENSOR
- hood question
- pros and cons of buying a jdm engine?
- mini-me vacuum lines
- Fuel pressure/vacuum pressure/fuel rail Questions
- b16/b20 in crx
- B16 bogging and hesitating
- si/dx dizzy
- lowering springs...
- my car was hit???
- can someone help with this
- Will this setup work? (obd2/obd0)
- at 70mph and at 4000 rpm car will stutter a little, why?? HELP!?!?!?!?!?!?!
- car only starts with foot on gas
- Hatch weight registry
- SI tranny
- crx zc speedo cable
- Magnaflow Mufflers
- MAP Senser
- Howdy, you-all
- DPFI-MPFI good idle but erratic above 1000rpm
- 89 civic si (help)
- Alternator experts, did i fry something?
- Anyone's car been infested with Cockroaches?
- auto dx harness?
- Help Running Rich during smog
- 300k on my EF
- Hood Question
- EF9 B16A1 Clutch 250-280HP
- b18a swap into 91 civic si, crank pulley clearance problems?
- e-cutout
- i really need help
- RS*R Exmag
- dual port question
- wanted : 88-91 honda crx si complete sunroof assembly
- Stock CRX ride height?
- What do you think about these headlights?
- moderater help
- I just noticed....
- 91 EX power window nightmare...i searched...
- integra axle lengths
- 91 civic wont start
- almost finished
- request for oxygen sensor replacement *searched*
- DOHC ZC and 90-93 integra manual intermediate shafts, are they the same?
- b18b woes
- issue after rebuild
- SES light help
- Hydrolocked last night....
- ECU laptop tuning
- Fog lights on 90 hb!
- spun bearings?
- reset ecu
- Y1 major tranny questions, need help!
- What have I done.......?
- anyone have any creative ideas for making clutch cable not stretch on ef's?
- b16a Vs H23 Blue top, which is batter.
- Ugh installing alarm. Can't find correct wire.
- MPFI conversion
- pic required
- what is this in my distributor
- h22 sawp
- s2000 cluster in crx
