View Full Version : Honda CRX / EF Civic (1988 - 1991)
- wtf is wrong with my car
- friend's car got stolen
- H22 CRX?
- Post your 89 Civic Hatch Only - Black Bumpers!
- crx wont start???
- D16z6, what intake manifold ?
- Knock coming from tranny, just replaced alot of stuff and still knocking.
- D15B8 block with D16A6 head
- pin differences between 88 and 89-91
- seat belt problem
- B or D series swap in 91 ef dx
- rear mudflaps.
- boosting my everyday d15 for added fun
- zc head gasket
- throttle sticks
- H22A1 vs K20A
- Opinions
- dirty IACV affect air/fuel ratio?
- mk3 lip for the 88-89 EF
- hood
- how can i check the ecu flash code?
- Rust....I hate rust!
- POPING NOISE!!!
- B16a W/auto trans Questions
- How long to do throw out bearing in 88 civic with D16a6
- filling tranny...
- Stalls when I let off the gas.
- alternator belt?
- i have a quick ?
- please help with wire tuck
- 88 crx hf w/d16y7
- ELD??? CODE!!!!
- Electrical Oil Pump Kit??? Exist?
- CRX Si Air Conditioning
- how do i remove this hose?
- chipped ecu help
- how safe to drive?
- Hasport Mounts problem.
- Adding A/C to a ef
- '89 CRX Si information
- HELP ME PLEASE BROKEN BOLTS AND DONT KNOW WHAT TO DO
- traction bar question
- MUffler
- Official N13 Niagara CRX Meet Information!
- tranny fluid leaking out the axles
- Should I run The Axis Old School Weels or Mugen MR-5 on My Red CRX??
- b20 IM clearance
- turbocharger
- keyless door handles> JDM?
- rod selection for a ITR crank in B16a?????
- A/C woes, help!!
- Va emissions...
- HELP, only running on 3 cylinders
- New shoes = I have no emergency / parking brake
- gutting my catalytic converter
- Charcoal Canister Answers- Yes, I searched
- bROKEn clutch pedal bracket (holder)...******I NEED HELP ASAP!!!********
- Compression Question.
- need help w/ Oxygen sensor
- which o2?
- +++Can Anyone tell me the Inner Diameters of the Heater Hoses+++
- IACV Help
- Are my Tie Rods bad?
- Corner light question
- my new 88 si rex
- springs,shocks with tie rod, revo camber kit?
- 1/2" wheel spacer ok on stock rear lug bolts?
- 89 EF STARTING PROBLEMS PLEASE HELP!!!
- melted coil and dizzy cap 90 si d16a6
- New addition to the civic family!
- LOOKING TO CONVERT MY 80EF FROM 4SPD TO 5SPD
- RWD CRX!
- Sway bar questions
- first honda swap ever! please help!
- Thanks But Still Need Help. D16A6 to D16Z Mini Me Swap Automatic
- got some questions and some progress
- Does anyone know where I can get the SIR rear bumper for my CRX?
- Need to know everything I need for b16A in 91 Hatch SI
- TAIL LIGHT PROBLEM
- Is this good compression for a mini me?
- ecu blinking 7 times
- K&N valve cover breather #
- 91 CRX WITH UKDM EE8 GAUGE CLUSTER SWAP........
- A6/Y7 Questions..
- 1995 GsR cam installation
- d16 dizzy on a b16
- springs
- need to find a good turbo setup
- Cost of European headlights?
- CRX Sun Roof
- Some questions
- mini me no vtec(yes i searched)
- Steering Shakes but kinda odd
- Car running like sh*t
- Help!! car wont turn over
- Where can I buy crx plastic fender well guards? (not mud guards)
- Regarding hoods...
- has anyone come up with a alter location for the wiper motor?
- almost finished just a few questions
- shocks what would you sport.
- terrable poping noise. HELP!!!!
- anyone know where to get aftermarket jdm lights?
- checking for cel's
- Best Suspension?
- A few 88-89 cosmetic questions.
- Code 9 dohc zc
- What to do with the sides.....
- megan lower control arms
- Weird Brake Problem
- 91 crx suspension?
- CEL'S CEL'S AND MORE CEL'S.
- dpfi-mpfi Pin A15?
- ex gauge cluster into dx
- 16V EDM CRX spoiler install
- knocking sound at deceleration
- B16A vacum lines diagram for DX civic
- wiring
- problem with my tail lights/seat belt light
- CRX Manual Transmission Fluid Level
- broke master cylinder mounting stud... replaceable?
- DA lip on a crx
- ecu chips
- head gasket thicknesses
- a/c compressor?
- AIR CONDITION
- gas smell in my EF HATCH
- 1900 Civic Sedan Steering Rack Leak
- DOHC ZC Cams
- earl's ss brake lines for 90-91 fit 88 si?
- code 14 on p28....on d15b.
- LS into 91 HF
- just got my car back(lots of pics)
- 90 CRX si problems
- DOHC ZC PROBLEMS
- motor mounts in a 88 crx with b18 ls hydro swap
- I mixed up spark plug wires... HELP
- Car will not start
- tach install help
- GAUGE CLUSTER
- Old Laptop plus free time = odd questions
- ZC motor mounts
- my crx vtec is actin up please help
- Getting rid of rasp (searched)
- removing moulding on quarter panel windows ???
- Half sized radiator, what are you using as a radiator stay?
- F23A ENGINE SWAP
- H22a swap
- engine swap
- A6/Y8 Mini-Me B7 T-Belt Too Loose?
- JDM SiR conversion - Can I use USDM corners?
- Side Marker question
- dohc zc code 8 (searched)
- obd0 to obd2 wiring help
- Unknown break pads and rotors...
- rex newbie
- which water pump/timing belt/ECU?
- D16Z in a 91 Si
- *b-series mounts*
- service check signal wire?
- Power windows write-up.
- ?s for the new project 89 hf crx with y8 motor si trani going to be boosted!!
- NO POWER?
- new swap and now transmission problems
- quick question....
- Help Please
- safe with cams?
- d15b swap no temp reading ?
- OK need a quick awnser....
- hasport ac bracket
- civic hb bumper on a 4 door?
- bleeding
- My 89' Civic HB si wo0t!
- dualpoint to multipoint info
- S1 problems
- Throttle body ?
- Got a sedan but stumped on ideas
- Which is the best to get?
- still not quit right
- what's a good spring and strut combo for $450.
- b16a J1 tranny clutch replacement
- intake manifold swap
- Need Help***CRX SI w/ B18B1*** How come my speedometer does not work???
- Headlight differences?
- TPS sensor question (I DID SEARCH!!!)
- cleaning lost motion assemblies?
- Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one*
- Radiator caps
- My new 91 DX
- SI Transmission
- Yet another EF swap wiring question
- Not sure if anyone has tried them......But I did - grounded plug wires
- Heres a story about a Honda CRX... that might be dead (56k)
- ZC belts
- Help On Mpfi Swap
- CRX SIR carpet
- help crx rear quarter panel window...
- Tuning Nitrous on Hondata.
- "No spark" Diagnostic Flowchart
- zc motor parts... searched
- brake fluid coming from underneath my brake booster on the fire wall.. PLEASE HELP!!
- Newbie project
- Quick Lock steering setup
- CR-X front seat HELP!!!
- ****HELP just changed head gasket LOTS OF SMOKE****
- B18 91 CRX SUSPENSION QUESTION
- PM6 ECU wiring
- clutch is getting stuck down
- Bad clutch?
- New Intake manifold problem.
- Starter Problem!
- oil pan year
- Rear suspension question - 91 Civic DX
- CRX with b18a1 won't crank, just beeps after weird hot starting problem
- altenator question
- I need and alignment, wanna help me out?
- 89 DPFI 1.5 Hatch won't start. HELP
- need help...please!!
- crx to civic front end ??
- someone in washington?
- timing belt change
- need vacuum diagram for zc motor
- Which is better??? Need help!
- code 7 i am in a rush help me out
- which TPS??
- IS THIS SAFE
- Ignition ( main relay ) cutting out when driving - please help, EXPO IN 4 DAYS!
- Need new dizzy for b16a
- help with 88crx starting problem
- JDM Front End help!!
- Cable to hydro conversion?
- Nex full coilover
- B16a camshaft oil seal?!
- Does anyone recommend ES OVAL TUNING MUFFLERS???
- OEM pressure plate with a 6 puck disc
- D16 Mini me with b16 throttle body?
- STILL in first gear, even when shifter is in NEUTRAL !!!
- Adding AC -- that's right... ADDING AC! Who's done it?
- carbon figer duck wing for ef's?
- DA carpet
- k20 axles, will the ones for 91+ civic and tegs work?
- typr r pistons
- DIY Sheetmetal reinforcement?
- torque steer issue
- is it best for my zc to go turbo or all motor
- can i put integra head lights on my crx?
- help please
- 89 CRX si low fuel warning light??
- code help
