- Hatchback Go-kart?
- What axle to use with B16a Y1 tranny intermediate shaft.
- 88 civic hatch trouble
- Del Sol Seats - Pan Swap
- Non vtec ecu with vtec controller
- 91 civic noise when shifting
- trunk holding water??
- Sedan Block Off Plate Fit Sedan?
- Moderate Trans Leak Shift rod boot???
- Can i make my car impossible to steal??
- d15b vtec wires Not connected!!
- EF9 HIRO WING Round 2
- 89 Rex, o2 sensor wiring... confuzzzed...
- I have a d16y8 in 89 civic hatch
- Anyone use k-sport springs?
- Bumpers need help !!
- dpfi mini me?
- steelie painting?
- Alternator.
- メインの仕方
- Rear Doors
- Need serious HELP.89 sedan
- No heat!
- Mpi swap few problems
- Non-USDM black interior door handles
- Auto vs Manual CV axles
- ecu pins
- Are d16 head bolts the same as d15
- Search EF Bumpers to switch EUDM and Fender Rightside
- Type-R or H22/23 Swap?
- my ef project with my new carbon fiber race roof cap
- car won't crank need help
- Caint find the right timing belt! HELP!
- what exhaust can i put on a ef 4door
- ef corners
- OKay.. Its so close to being done. Now doesnt want to start right away every time????
- Heater duct problem / 93 Del Sol Si
- Joining the EF4dr community!
- Testing climate control.. On 91 crx.
- UK member, B16 CRX
- Extended top hats.
- ls into sedan
- Autozone steering rack, opinions?
- Need some help
- ef best ground clearence header??
- how to get get CEL codes with obd0/1 jumper harness?
- awd
- So Cal Swap Shop?
- type R GSR with cable tranny????
- crx dash into hatchback
- Shift linkage info needed
- 1990 hf CRX rear subframe ripped
- 91 EF hatch with obd0 b18a1 swap probs.!!
- OEM Car Cover Pics and Fitment (little tech sorry)
- starting problem???
- CRX Problems!
- std front sway bar
- Fuel gauge prob on my EF
- My new EF civic (pics)
- anybody know how to line up the cranks for the timing belt?
- starter question
- mounts and hydro conversion
- WHAT WIRE ON OBD0 disty is ignitor wire?? need to know ASAP!! PUTTIN ON NOW!!
- crx problems help asap!!!!!!
- CRX B18C W/ac ?'s
- car caught on fire, now bogging.
- mini me swap
- h22 crx problems
- Igniter problems
- WTF wont my code 23 go awayyyyyyy (UHHHGGG) LOLZ
- Sunroof
- code 15 Ignition OutPut Signal!! How do I rewire?? Have a few questions
- searching crx ef hatch
- 88-89 crx seat rails
- My CRX is dead!
- CRX Positraction?
- help wiring electric VSS into my crx (searched)
- tie rod end
- D series alternator on a B series
- sir1/2 ftiv location.... IM swap
- HIRO EF Wing
- Help with me exhaust system !!
- painting my car with bed liner
- Radio/climate control wont turn on??
- Corona **951** whips
- 90 DX wiring question
- axle problem
- d-series motors
- k swap ef hatch on AEM
- koni yellows + which springs?
- Revving Issue
- LS/VTEC or B16??? please help me
- help finding this part
- becoming an enthusiast heheh
- Tri-y and RMF replica header on hatch
- ECU. help
- Cluster/Panel
- Car died going up a hill....now no start!
- b18 c1 swap trouble
- Climate Control and Radio Swap...
- 1990 Civic LX - leaking coolant
- question for auto to manual guys
- Newbie
- 1989 CRX Wiring harness into a 1990 Civic DX???
- cooling fan?
- compression woes
- OldSkool Ed2 *Ollek* Many Pics *Germany*
- CONFLICTING INFO; Y8 IM on A6 head
- Oregon ef's pictures only!!!
- So Cal Swap shop?
- Cooling system diagnosis. HELP S O S!!!!!!
- Shifter Feels Slushy
- 91 Dx help
- b7 block a6 head
- I miss the CRX
- REAR Knuckle
- crx cuts out
- AZ rage mounts
- Shift Linkage!
- MPFI done but low idle at warming up
- best spark plugs?
- Batt. Keeps Dying..
- Blue Smoke...
- Brake light stays on
- 88 civic b16 problems
- Ef Harness Bar!?
- cable tranny ??????
- Side Light Help!
- i need help can i swap a b16a in to a b18c1
- ef on basketweaves!
- Throttle cable/bracket
- how to take off gauge cluster plastic
- Brake Light / Tail-Light PROBLEM
- os super single clutch/flywheel combo
- b16 power
- b16 to gsr questions?
- dx engine dizzy plug to obd1 dizzy plug??
- EF8 OEM Colors?
- D16Z6 Swap on my EF (Need some help)
- Brake light wiring
- can i use automatic motor harness into my 5 speed car?
- Help get my car inspected!
- are 90-91 4 door and hatch bumpers the same????
- my crx 91 si..
- spring chopen
- 88 crx Si
- this seriously pisses me off (click link)
- Car not starting...No gas?? 90 crx si
- DPFI Idle surge (Searched)
- Civic Si Lip
- Upgrade advice needed
- Sleeving recommended for d16a6 overbore?
- new(ish) guy
- broke my brake?
- Valve Adjustment
- Tahitian Green
- drag pics
- CRX SI Engine, how long are they rated for (how long do they last?)
- ef with gsr fat fives
- did yall know?!?
- Problem after mpfi swap HELP.
- my hatch build
- My single cam Eats Up gass
- crx fuel cuttoff?
- fuel problem
- electric vent control in hatch...?
- First honda..... 90 Crx si b16a Want to make it a SiR
- I need doch zc parts. SO CAL ONLY! (LA area)
- How to pull a tranny
- rack and pinion interchangablitiy
- ls swap questions
- No start after mpfi swap??
- My CRX build: almost road-worthy
- illegal to sell catalytic converters?
- Anyone Have a Pic of the Newer HASport Hydro Convertor ON CAR?
- Light stuck on after swap
- '91 DX Cat-Back
- 1991 honda crx code 15.. replaced disty with known good one.. still flashing
- Quick question on crx forums
- damn crx.. Help anyone?
- whats a good interior cleaner
- Need help w/ swap!!!
- Cooling problem-I Think.<Please Read>
- b18c into a 90 civic si
- Little qustion.
- d12 upgrade i think
- California swap questions
- my pt67 gsr crx
- leak around dizzy
- I Need Help!!!!
- obd0 to obd1
- 87 crx
- crx just bought ??????
- Recharging CRX
- hardcore noob question
- 1986-1990 Acura Legend parts interchangeable with an EF?
- roll cage and roll bars
- EG/EK shocks into an EF
- 4g63 swap into 89 crx si
- Dohc zc help!!!!
- Need some EF9 and EF8 help
- passwordjdm carbon fiber intake
- heard poping died out and now it won't turn over
- help!!!!! how to convert to gsr cluster
- question.
- need help asap
- help instal gauges
- B18A1 compression
- collant hose fitting
- obd1 crx IAT
- z6 cam question??
- 102hp with vtec seems low hp
- Help !!! Where can i buy these parts
- What's this?
- pg7 vs pm6
- B16a USDM CA SMOG Parts
- d16A1 exhaust
- 89 crx gauge cluster with 91 harness
- crx problem
- battery re location
- Help me please
- ahhh whats wrong with my ef?
- AC Questions
- intake idk wat
- pixs of my new 91 ef2 dx sedan
- lets get some interior pics of cars stock or aftermarket stuff
- Should I get this CRX or just wait
- Trouble starting when its warm
- ecu specs
- just completed my mpfi swap!
- lower control arm question
- need help with my overheating b16 swapped 88 si civic!!
- EE wagon owners
- Has this been done?
- No Turn Signals?
- more dohc zc questions.
- my cluster STILL doesnt work
- clutch R&R procedure ASAP! plz.
- Block dowel pins
- climate control fix. what kind of glue?
- 88 CRX PROBLEM!! Help
- Real Quick windsheild ?
- EF won't start
- dohc zc into std hatch. bought dx spindles, they don't fit?
- RHD clip...needed asap
- Turning signal is acting wierd Need helppp
- 90 hatch with ls swap
- hatch hinges
- 91 si w/o rear sway bar?
