View Full Version : Honda CRX / EF Civic (1988 - 1991)
- HELP 1999 y8 mani swap on b7
- wideband o2
- car wont start!
- How to install side markers?
- -(Help)-Integra dash into Ef hatch
- 88 CRX si wiper arms
- Help my car sounds like it has 2 step.wtf!
- B series primary lobe specs?
- intermediate shaft question
- Only the extremely experienced people please help me
- overheating problem
- do i have a vtec head
- 90 Crx HF No Power
- pac too manual rack?
- jdm/ukdm cluster interchangability
- had a bad distibutor
- Help. Broke my dizzy
- dizzy wiring question
- Help. Timing and broken bolt in head =[
- crx mini me swap help
- b18a1 dizzy problem
- Price help
- 90 crx sun roof
- 91 hatch A/C compressor and Brake pressure probs
- dx engine harness, eacv location and distributor wiring
- vfac on 90 dx obdo?
- F2D fitment answers + pics of mount kit
- seatbelt isn't reeling back up !
- Removing old intake manifold gasket. PITA
- Computer info?
- What could cause me not to boost--electrical or mech?
- will a p06 ecu run my swap?
- Missin
- Dry Ice?
- will 91 ls teg axles work...?
- 2000 si seats in 89 hf?
- Si Gauge Cluster
- burning oil-rings or valves?
- oem electrical pins?
- driver side windshield wiper rust!? help needed
- what fuel pressure regulator to buy
- gsr ef
- I need some CRX advise
- Z6 intake manifold swapped onto D15B2...Code 7
- Some check engine codes.
- stock SI (D16A6) tranny + lsd?
- car starts and turns off almost imediatly
- 4 spd manual reverse set up help
- does anyone have a write up on how to do a auto to manual converstion??
- 1st gen b16 dizzy parts and spark plugs
- B20 v-tec wiring? help please...
- B16 timing belt problem
- three simple hatch questions
- 91 lx help!!!
- Y8 manifolds vs idle
- help with d16z6 swap again
- 88 Civic
- Jdm obd0 b16
- jackson racing supercharger and questions
- jdm side makers....
- Going b20 v-tec [ef9] need help
- b16a2 ?? throttle cable
- B16a Vtec problem in my crx
- JDM Access aero mirror covers?
- code 9 wtf
- swap question
- big mess please help!!
- B16A EF Sedan Axle Help
- first swap ever
- LS or B20
- si seat fabric
- alt. belt...
- Suspension help!!!!! Please!!!!!
- new to the board just saying hi
- intake and crooked shifter
- code 20 help
- timing belt problem?
- side marker install help
- crx rear disc...
- If you have a dpfi
- d16y8 crx swap
- Windshield Wipers stopped working
- engine code n fitment ????
- Stock radio/cd player
- Time sert vs Heli Coil
- Strange mystical clicking noises
- Please help!
- A6 swap, new harnes has a squre plug
- D16z6 problems helppp!!!!
- DA ASR Subframe
- alternator selection
- photoshop my car
- intake shorted electrical...?
- Battery Relocate
- Help. What is wrong with my b16
- how to remove seatbelts?
- 88 crx si wiring schematics???
- ef9 power folding mirrors
- Best Engine Swap for REX
- D series tranny upgrade
- another timing Q
- Door Question
- who was
- EF2 Head lamps on ED6 hatch????????
- type r climate control in a crx
- OEM front brake upgrade.
- CRX Tower Brace.
- header?
- Oil out of valve cover and alot pf smoke>>???
- Please help!!!!!!
- ZC rebuilt kit..
- ZC timeing belt
- Questions about porting Mini-me head
- 88 ef with d16 question
- wtf my deck is controlling cluster and interior light
- 90 CRX Help! Changed Distr. Cap & Rotor now Engine light is ON!
- Gallery Fresh Dress up kit
- crz b16 wont start..help?
- Quarter Window Hell!!!!
- p29 pistons
- engine cut off then started with push start battery was fine
- bogging issue
- anybody know of a good shop in Atlanta for an engine rebuild?
- How to install EG half Radiator Into your EF
- help bad compression
- Ghetto traction bar: Replacing bushings with washers?
- Back door wont open on first pull
- EF back seats
- Turn signal, clock, and cluster issue... all in one!
- Steering column plastic cover removal
- crx door swap...
- Fresh Swap Wont Start....
- HKS sport exhaust for crx
- Suspension for 91 EF hatch.
- S.o.S
- no power to heater controll switch please help
- 91 STD hatch battery
- Gas/Tach Gauge Issues
- 90' CRX DX for $400?
- Best shock/spring combo, searched
- Milkshake removal tips and/or sugestions?
- Body wiring harness - '87 fit in '89?
- trans fluid change 90 crx
- 88 crx have camber wear but car not lowered
- wiring help plz...
- what are these wires?!
- Muffler vibration
- Need help a.s.a.p seats brackets????
- Calling Sunroof Experts
- obd0 harness question
- dowel pins
- picture of engine AT solenoid region
- 89 Civic SI Hatchback Sunroof Drain Clogged
- rpm, temp, fuel gauges don't work on '91 lx
- How Can You Tell Different Between CRX Si & HF By Looking At VIN?
- Parts Question
- Power steering ...comes and goes
- is there a writeup for ac removal?
- ep oem car cover on ef civic
- ignition/push start problem
- belt noise
- what do you guys recommend?
- Greddy sp2 for ef
- i have the hondata intake manifold gasket does anyone else have the same issues?
- 1988 b16 EF questions.
- Spuddering???
- Tryin to do my MPFI Conversion on my 89 crx
- helpppp!!!!p28 pin outs
- Which Mounts do i have.
- 88-91 Civic uprights
- WON'T START: Fuel Pump Dead when Parked Facing Up.
- LooKing FoR mount
- ef hatch coilovers on a sedan????????>>>HELP<<<
- Anyone Live near Dayton, Ohio?
- wiring problem
- 88 CRX HF clutch cable/pedal problem
- Skunk2 megapower vs invidia n1
- suspension problems??
- crx no starttt
- First time engine removal
- Exhaust Questions?
- were to get parts
- b20 Vtec.
- Symptoms of off timing
- Little Help please
- idle air control problem??????
- Exhaust question??
- dizzy plug help!
- 2nd gear grind
- Motor is fine cold, but knocks when hot??
- Beeping noise!!!
- Dpfi to mpfi swap
- Help with battery relocation
- please help. wont get spark
- CRX restoration
- hydralic to cable need help.
- Carpet.....
- crx
- tail/brake light connector. You guess the CRX!
- 1991 ef civic dies
- changing door locks
- 91 Hatch w/ D15b2 Auto
- Wheel bearing for Sir knuckles
- Pic request: EK Cluster in EF
- shut down problems
- Time for a new rack...but which one
- 88 ef b18b1 dizzy wiring help plz
- What is this thing attached to my intake manifold?
- Aftermarket seats for a '91 CRX DX
- pics and help please black motor and bay
- B16a in a crx.. Knock sensor code 23
- 1988 crx sunroof visor & window visors
- Who's crx?
- need help is this safe d15b2 mimi me
- WTF! crx b18 swap.Search and asked. Help!
- obd1 distributor on EF
- D16a6 help!!!
- first ef hatch build.
- Replaced Brake Piston seals + fluid, Now leaking
- !!!!!!!R My PISTON RINGS DONE?????? HELP PLEASE!
- my trunk has a leak, help me!!
- TSB for Emission Test
- Code 1 and 7?
- b16 compression test results
- Brake upgrade ?'s
- low compression
- Need tranny for my 91 hatch
- Keeping power steering when doing B series Swap
- Tranny ?
- How to remove and install Door trims. sedan
- motor build
- EG Radiator into EF Civic (aftermarket Radiator)
- ebay sway set
- Replacing main damper bushing on rear trailing arm?
- any point in trying to make power from a 91 cx d15
- Can bad bearing cause caster problem?
- injectors
- noob
- O2 sensor problem? or a good thing.
- new clutch, no spedometer??
- 1991 EF hatch
- dpfi to obd1
- 1989 CRX B16A Build
- B18a1- not full potential?
- TPS trouble....
- Will 89 si seat fit in a 92 accord??
- the car is overheating and the fan does ot kick on
- My Civic just died, help me out.
- d16y7 help
- trouble turning left only
