View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Zex hook up
- 90-93 Teg
- H22/Crx 1991 Dx
- si or dx seats?
- What do you think of this manifold?
- HASport vs. custom shift linkage...
- CRX and HB tails different sizes how?
- Radiator fan compatibility
- **Heating A/C vents**
- how to reset ECU?
- What ignitors will work in 91 Si distributor?
- CIVIC D15B VTEC ENGINE in 91 crx hf, what do i need?
- mini me possible on a zc?
- best price for 1st gen B16? with or without LSD
- on an mpfi swap if i use the tps plug from the si do i still have to switch the wires?
- Anyone with ACC carpet in their CRX.
- underdrive pully??
- *help* ef guys with seatbelt issue
- suspension damage?
- what year and type hubs/knuckles for b-series swap into a hf?
- body work
- cost of ls/vtec
- Need help finding link
- sunroof wont close on back drivers corner only???
- What do you guys think i should do now?
- Greddy MX exhaust installed, pics, flat black
- im throwing code 12,and 16 what r they help
- i need help really bad im so confused help quick im losing my mind
- B16A1 in an 88 DX Hatch . . . Wiring???
- ZC v.s. USDM parts compatability
- ZC runs hotter than my old D15 did?
- will a b16 drop into a 85 crx?
- Ls swap in crx..............look at my slip let me know what needs to be done
- CRX arm rest installation
- 1988 CRX seat belt assembly
- EACV D16a6 vs. dohc zc
- JDM ITR Recaros in a crx
- '89 crx's
- check engine
- some puzzling Zc-Si tranny, clutch, axle, questions
- pm8 pin-out...
- wagon meets curb...
- Mystery ZC distributor part?
- High idle on my B16a1 Any Suggestions>
- No Spark!! Just completed MPFI conversion...
- jdm clear corners
- Forum thread wanted....
- b16 rebuild
- NEED B16a distributer wire colors, and pinouts>>>HELP<<<<<<
- Engine info....lil help?
- Camed Mini Me..anyone done it?
- 1990 CRX Si hc head gasket? hyperground kit?
- 90 civic auto axles in a manual tranny?
- need help with seat belt conversion
- Relocated to Phoenix AZ metro.... need help locating shops!
- D16 Rods on ZC???
- bleeding brakes on a 90 civic hb
- 90 crx don't know what motor to put in it
- eg sus on ef?
- What the hell is wrong with my car, I'm near fed up with it!
- High rpm bogging problems
- Rebuilding a S1 tranny
- Rebuilding a B16A1
- pics of my ZC motor!
- do i have to change my valve springs when installing new cams?
- ZC headgasket same as D15/D16
- pullin a code 16
- can i use 88-89 teg ecu for mpfi swap?
- ??? d16z6 or ZC swap, which is cheaper
- Starter is Constantly Engaged (B16A)
- ls motor
- 89 civic 4 door with b16
- b16 tranny
- yet ANOTHER noob needs HELP.
- WTD to my 91 si
- itr cams or skunk cams??
- what stock lips fits the EF hatchback?
- what does a dashpot do?help fast
- estimate zc swap?
- Ls vtec clarification
- springs too short for my struts?..... plz help
- Crx exhaust piping?
- Possible 1st time CRX owner
- ***B20 into a CRX dx...what type of intake manifold to use?***
- Need help with doorpanels and seatbelts...
- Thermal exhaust owners with high flow.....
- how to install new SI dizzy??
- Eibach Sportline vs. Ground Control???
- help. snapped brake bleeding nipple. replaceable?
- another axle question.
- I keep getting a code for the map sensor.
- couple questions for u guys.
- any SI engine bay pics??
- I want a CRX so bad!!!
- longer or shorter gear for the tranny?
- Anyone know WHAT WIRES GO WHERE?? B16a distribuater
- Wierd hesitation at 2800-3000 RPM
- Which aftermarket gauge did you pick, and why ?
- B16a no spark, not starting??? HELP
- PArting out my Crx: Parts Available
- i cant tell which wire on dizzy is which
- is this good for my car
- what pistons would you use?
- failed emission (:<) rubbing alcohol help?
- help!
- would a cel code 9 make the car rrun any different or crappy?
- compatible exhausts for crx (other stock honda's fit?)
- putting a crx si motor in a 89 civic hatch dx
- Just sharing, let me know what you think.. still a lot to be done.
- My hatch bogs out in 3rd gear....
- what about timing?
- Intake manifold question
- ITR FD in a cable trans
- no clutch pressure on new ZC?
- whistle tip exhaust
- Where can i get this?
- jdm 1.5 redline
- MPFI question need help ASAP!!
- Whats next?
- 1st gen help please
- Bushings still work with rear disc swap?
- Dist. on mini me
- Lawrence st-john where is it?
- B16 probs, need advice !
- Tanabe S R Medallion, anybody got dyno results
- what intake to use for a JDM D15b in 91 dx hatch?
- My car is done, but only one problem....
- thermal classic catbacks for CRX
- integra shocks on a EF?
- just got done with clutch install now noises???
- a motor/turbo question
- Anyone ever try these adjustable balljoints before?
- y1 with LSD differential (bearings)
- code 43?
- Any other solutions for UCA hitting the unibody?
- Alright guys I think ive found a winner!!!!
- look what happen to my baby....
- anyone have get a map sensor code after installing a vafc? (89 crx si, b16.)
- when i changed my oil i slightly over filled and my car is smoking bad, whats a good oil to run?
- b16a1
- red line mtl??
- seat belt doesn't hold me in place???
- rubbing right rear tire anyone else got this?
- dx harness the same as SI?
- code 16 and lot of smoke and smell off gas from exhaust
- FS: CRX DC Sports Cat Back
- extended studs?
- d15b2 to sohc Zc
- info on 4th gen civic hatch
- all u turbo crx guys help????!!!!
- lower ball joint
- here's to ya'll, a little laugh
- please help codes 9,10,15,16,17,
- Scammer
- HELP!!!! Cannot budge crank pulley bolt!!!
- hearing a noise
- 1g CRX guys, that's 84-87 rexers....need to read...
- did a search, but no results. I need wiring help for a 'teg Ls swap into a 90 hatch...
- Stolen 1990 Civic Hatch
- Suspension bushings??
- my b16a 91 hatch dyno
- Which would you choose?
- axles arnt working??????
- AC in my civic
- What timing belt has 106 teeth on it
- heads up!! ZC parts
- oil cap shoots off? oil everywhere!
- Japanese CRX
- Would i make more parting out or just selling my CRX
- Why do people say ZC rods are stronger?
- I know its been asked , but h22 in CRX
- Shift Linkage
- EF Turbo
- CHEAPEST hybrid crx you can possibly imagine!
- Received my MPFI stuff....any precautions or advice for a fellow??
- Are my TPS wires in the right order?
- Miata rims: What bore size?
- HELP PLEASE-Driver's side steering rack bushing removal for ES install?
- Anything else...?
- V2 AEM intake
- Need Some Help
- the day it all fell apart...
- CRX and Si parts compatibility?
- How much is this crx worth?
- changing tranny's??
- i need some tranny help!!!!!!!!!
- i want my ac back....
- Camshaft installation on Sohc???
- help a newbie 88 hatch b16a
- 89 civic quarter mile times
- B series motor mounts for sale... (HAsport)
- Weapon R intake filter any good?
- Picking up a b18a for $550 CDN, what should i do?
- **What diameter intake for a B16?**
- lowering what to use? need help please
- I am soooo stoked
- Civic Wagon in a magazine????
- Forced induction Zdyne users...Show me your maps!...
- Distributor problem, I think. Kinda long
- front end bra, suggestions?
- ZC Cams
- Anyone have pic's/info/part # of bearing puller needed for tranny rebuild?
- MD,DC,VA Area looking for....
- ZC Torque Converter
- 89 si tach into a 91 dx
- im going to buy a car... which one? HELP IS APPRECIATED
- Who has a pic of black house. corners on a CRX?
- CAR is no longer......pics
- EF Civic hatchback for sale
- will a gsr pedals fit in a 1994 civic ex
- B16 cable clutch
- Civic Information PAGES!
- 86 crxsi swaps and cost?
- Those with EF JDM fenders...I need a favor =)
- what sized piping should i use on my exhaust?
- ECU flashing code 4 plus not reving past 4k
- Noise when turning
- Should i buy this head? for how much ?
- Which Throttle Body would be best on B16 w/ CTR Cams?
- green fluid under d car!
- will a 98 honda ex tanny
- swap not running right...i need some help????
- who has ran this mini me setup
- I NEED SOME HEAD advice for a D15, or D16
- What is a good crx swap?
- I'm confused about my engine Did i get ripped off?=/ PLEASE HELP.
- Anyone running exospeed cams?
- how to make auto to a manuel
- Anyone have a suggestion of what exhaust system i should put in?
- Valvetrain choices for D16a6, Z6 and y8
- ef bumper compatibility
- will sway bars from 90 crx fit on 91 Civc Si
- GUDE 26824 specs please
- engine code 2 & 17
- fuel pump 91dx
- I need a set of lite weight 15 inch RIMS, help me decide.
- my b16 crx is slow! WTF?!
- b16 head bolts
- might be parting
- ZC probs....
- CRX wieghts..
- Am I supposed to keep up with a camaro ss??
- some ?'s
- 90 crx si tranny input shaft ball bearings?
- how much tranny fluid?
- changing clutch...any pointers?
- Where do the 2 vacuum hoses go on the ZC?
- LS ThrottleBody with a CRX manifold port matched.....
- WTB Cleanest CRX in country
- suspension bushing kit
