View Full Version : Honda CRX / EF Civic (1988 - 1991)
- anyone looking for rust free hatch?
- Where to start?
- Helms manual help pleaseeeeeeeee and info 4 u guys...
- Anyone done own window tint?
- body shop on the east coast
- Armrest?
- Upgrading brakes rotors
- 95 engine swap
- Which thermostat for B16a
- integra concel help
- distributor DX to ZC
- nitrous question????
- 90 "civic si"
- Need help with DOHC ZC
- CRX Backfire..Need Help QUICK(long)
- Mugen Spec PM7 anyone?
- 88 crx fenders
- Will an Exhaust from a 5G fit a 6G?
- OBDO throwing code 14?
- stupid o2 sensor
- ignition trouble on 1st gen b16a
- Got Some Bad News Yesterday
- What are those mufflers??
- Starter Button installation
- HELP!!! i cant get the crank shaft bolt off!
- teg seats in 4 door
- swapping ques
- frustration with clutch combo
- classifieds jammed - misc junk FS - 1G, 2G, hb, CRX, D, B...
- ?Bronze Wheels?
- stupid question..
- New crx carpet and floor mats?
- HONDATA program for B16 with OBD program please help
- DPFI to MPFI swap.
- need some info
- looking for rear bumper support...
- Simple crx question
- How much would you pay for a set of ZC stock pistons?
- Adj. Cam Gear Setting on a ZC??????
- What trany to use?
- CRX wallpapers
- In the middle of lowering my car need help!
- Front brakes: Where to buy/what to buy
- 3rd gen B16a...photos
- A nice engine problem for real tech heads!
- 91 Hatch seat q.
- jdm front radiator support
- how do you like your clutchnet clutch?
- Minor site update
- It's official!!!!
- cutting edge?
- Where can i find CRX JDM tail lights?
- Koni yellow vs ....
- CAI for z6 in 88crx
- ???D16 into a 87 CRX SI need info???
- 1991 CRX Si
- What parts to Buy when building up a ZC???
- what would do...
- sir front?
- 75 shot on a ZC?
- Anyone thought of/or have made a video that chronichles the step by step swap process?
- What causes valve guides to go out?
- Code #9 - Crank angle? Help-Suggestions
- Wiring problem!!! in 90 civic dx
- Installing tilt steering column in HF
- ZC Swap ?'s
- ITR 5-Lug
- 90-93 skunk2 integra springs on my 90 DX...same drop?
- rear bumper removal ?
- Intake Manifold Conversion Q's
- B16 tranny??
- blinker noise
- Sohc Vtec or ZC?
- 88 Si: How many temperature sender units?
- PM7 chip real or fake?
- When converting OBD0 to OBD1 what engine harn. do you use?
- will 90 crx si door panels fit in an 89 civic si hatchback?
- New here .... hi all
- my brakes suck?
- DA front sway bar?(did search)
- B16a and 75shot in a Rex, need some help...
- Question for anyone using Place Racing mounts
- Zc swap questions..
- tell me about cams on a b16...
- h22a 88si crx help??
- ZC Headgasket?
- So.... Im finnaly going to pick her up!!!!!!
- 12's in a CRX NA?? What do i have to do to run a 12.9??
- new billet hasport mounts anyone?
- ease of installation dohc vs sohc
- foglights, hood pins, indiglo's, hatchback sunroof spoiler
- 87 crx si parts
- BAD Day,Bad news!(The end or new begining?Not sure where I'm going from here!)
- ZC in an 86 carburated rex, can? how?
- Best place to pull Vaccum from ???
- If I have 224HP what 1/4 mile times are possible??
- SOHC VTEC swap??
- I'M bored tell me what you think
- help...b16 or ZC
- 90 DX wiring to 90 Si wiring
- Pic of 4dr w/ JDM Front End.
- removing front bumper light without the hyper blink?
- Civic Jitters?
- sohc
- ZC and Crower I beam's...Notching required?....
- p28 ecu chip?
- Front upper control arm ball joint
- WTB: coilovers for an 89 hatch,,, where are the cheapest?or who has some
- You think these are real or just painted?
- oil smell
- did my motor blow up?
- do you guys take out your interriot? all of it? or some of it?
- What seats will fit an EF without much mods?
- HF axles to weak for ZC?
- CRX aerodynamic front bumper?
- 3.5" drop springs for sale or trade...
- loosing power on d16z6?????
- Springs
- ED upper ball joint Q
- I have extra wiring harness for b16 into crx
- Installing new springs
- Will any D16 cams pass smog?
- CRX Si B16A tach problem (suggestions)
- ZC underhood sticker?
- What trans with ZC swap?
- What ECU with ZC swap?
- Pictures of my JDM"ish" B18C5 powered CRX
- Zc Swap Questions harness
- Anybody else's CRX sit lower on driver's side?
- Stopping Fast = Better
- installing GSR CD and Tape units?
- 1.5/1.6 interchangability questions
- about to start on the rear disc swap
- Alright, How long is this Newbie Thing Gonna Last?
- New springs are loose on new shocks.. bad??
- 14s in a DX?
- Y1 Cable Tranny for sale $450 va/md/dc area OBO
- which exhuast should i get??
- Wanted: Help with DIY ECU project
- anyone have experience doing a compression test???
- jdm front bumper need help
- stuff for sale...
- anyone have a stock dx wire harness they will sell?
- I need a rear mount! b-series
- WTB: civic hatchback si console
- 89-91 crx Wing West body kit urethane for sale or Trade
- Like the song goes="Today was a good day"
- ZC factory 4-2-1 Versus DC 4-2-1 How much difference in Power?
- vtec problems, still
- sohc timing cover
- what size ball-joint tool?
- Heated O2 sensor install
- Drivers side motor mount
- I need info on a y8 mini me swap
- removal of door panels
- oxygen sensor help
- Need Smog Help
- any good tires at NTB?
- ----> How did this person do this????????
- Honda Rain Guards?
- Quick question: D16A6
- need injectors
- top speed no a dyno????
- anyone wanna make $600. cash in one day
- which way does the oil flow through the 2 nipples just behind oil filter from block???
- A/C WITH THE B16A AND PLACE MOUNTS????Pics anyone??
- Our traction bars are almost done...... 88-91 Civic/CRX Tester needed!!!
- Del Sol Wheels....
- shift boot question
- 95 engine swap questions.
- How good are the Place Racing Motor mounts?
- What do i need for a B16A swap into a 89 DX?
- 89 CivicHB buckets
- Needs help on tire size???
- 87 CRX hf...how hard to swap in a D16a6?
- JDM SI Bumper?
- Please photshop me a 2.5" drop please..........Somthing in it for you..
- need to trade tires
- Wiring Help???
- B20-91 CRX DX
- 2002 civic cd player??
- I went out and bought a beater today
- crx hf with dx motor
- does this work
- quick qest does a b16 drop strait in a 88-91 cr-x dx
- mini me question
- Anyone have or seen an APC carbon fiber hood??
- CRX with 3" custom mandrel bent Apexi N1 exhaust
- Fields SFC VTEC/Fuel Controller and it's MAP sensor affects?
- best place to buy a motor?
- do you have a B&M?
- GSR in 88-91 CRX?
- Squeaks and groans
- Removing factory gauge needles. (important)
- Non performance related engine swap. '92 CX D15 into 91 CRX SI. Pros-Cons, pls.
- Someone please give me accurate numbers!
- putting a sohc vtec in my ef
- how do i use this high temp black paint
- YAY! Got rid of the BEEPING!!!
- air not coming out from vents only from defroster vents..help
- B20 block and B16 head what kind of power at the wheels?
- what are the best rings to shot nitrous?
- WTB: Greddy EVO or Apexi WS exhaust & DC Sports 4-1 headers
- where can I send my dx harness to get converted!!??
- need help on painting my housing
- How much on average to get your rings changed?
- B16 prep work
- Help wiring B16A
- Type R tranny
- D series into A DX help
- maintaining paint after 10 years...
- jdm crx backseat?
- Compression (d16a6)
- civic HB peeps!!
- anyone got a 88-91 5spd 4dr for sale?
- Racing harness on stock seats
- Will the Y8 oil pan work with the A6 block?
- Swap in a HF or an Si?
- ok heres a big one N8 overhead shot
- Attention So Cal EFs
- Homebrew exhaust
- Im sure someone can help
- Interior passenger side fan making noise after 15 minutes
- What! No rev limiter?
- I think I've narrowed down my A/C fan problem...
- My Rex is Toast...What Should I Buy Now?
- Engine Stand
- When you do a ....
- help on a crx please
- Exhaust header???
- Need a little exhaust Info.(Tried search, No luck!)
- D16Z6 and D16Y8??
- Crazy Ass Tach
- free parts
- suspension for 88 crx
- Do you have a shift light?
- Me Getting Roasted...
- Question about AC in a CRX w/swap (from an EG owner)
- 89 Civic Hatch Setups...
- problems with mini-me
- y8 head on y7 block?
- shift light installation?
- sohc or dohc zc?
- pics from N8
- I'm a traitor...well sort of :)
- its finallly done.... pics
- Phatwhippin_CRX is he home yet???? (problems)
- Mini Me on 90 HB ... PLEASEEEEE READDDDDDDDD!!!!!!!!!!!!!
- anybody selling?
- LSD Tranny
