View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Short ram install
- Quickie: Si brake booster on my dx?
- Need to know how the throttle cables go on a cruise control car
- New steering rack or what?
- ok im confufused on what tranny this is i baught a b16a off sum kid an check this out
- Some fucker try to steal my car!!!
- dx harness for ls swap?
- Auto retarding during rev... any ideas why?
- jdm b16 throttle body?
- Wiring problem??? Brake light switch, any help would be appreciated.
- Review my setup
- Help with zc swap, not starting 91 crx si
- Turn signal fuse blows when fuel pump is on
- CRX project
- Sir Civic (90-91) Cluster question
- d 15 build
- Will a crx cluster fit in my 90 dx?
- What Mount To Use???
- tranny q 'sssss
- used hatchie Si-help!!!
- Bucking & jerking @ low rpm--WTF?
- How do you remove the headlights?
- 89 si tranny in an 86si???
- The diff. Between the 88's CRX HF, CRX (DX), and CRX Si
- Type R throttle Body anyone?
- will these rims fit my car??
- jdm y1 tranny shift plate
- used o2 sensors
- tranny question !!!!
- need help p/s !!!!
- losing vtec help !!
- SHAVED DOORS? ANYONE....
- Would a 92 integra type r gauge cluster fit in a 89 civic si if so how?
- Fuel level gauge
- Code 30???
- Sound Deadening Tar. Almost Completely Removed Under Carpet. What Suggestions To Remove The Last Bit
- Whats The Blue Box Under Driver's Seat?
- trany swap question
- OBD0 Sohc distributor price?
- diffrence between ef8 power folding mirror and ef9
- crx yearly difference
- H22 swap into an 91 dx hatch what ya think?
- b16 head port n polish
- Gains and Problems
- WHAT CLUTCH DO I USE FOR 89 CRX B16 S1 TRANNY
- WHAT TIRES?????
- turbo rex
- ls intake mani. on b16?? how too
- Steering Issues on my sedan.
- Differential SWAP
- what to do about a clutch...
- Pilot bearing found in flywheel!
- jdm civic rear center tail light
- Hp gain from AC removal??
- 89 front bumper question
- head swap???
- What to build?
- DOHC ZC for Sale!!!!!
- This body kit
- NEED HELP NOW..Info inside..
- Wheel bearing how to ?? 1991 CRX
- Can I mount my tranny now ??
- Are D15s Interference Engines?
- Climate Control Pin-out?
- b20a5 prelude motor into 90 hatch
- What is wrong with my Tranny?
- rally crx?
- can somebody please help me?
- Suspension questions for an 88 CRX HF. What will fit?
- Random starter problems - only clicks
- *Spoilers for ef hatch* post pics plees
- CRX awd possibilty
- LS S1 cable tranny how to tell by counting gears.
- Look what I finished
- LS Vtec
- axle or rack?
- gauge ????
- first time
- B18C5 Swap
- Sidemarkers
- help!!!!.... I cannot not find ZC parts online...
- just swapped zc in hatch...idles at 2000rpms???
- Central Texas guys???
- license plate hole cover help
- what are some easy was or tools
- crx problem
- Boost D16 or ZC?
- door panels
- Need Help A.S.A.P. How to make my new engine run leaner...
- Side skirts for an EF??
- crx b20 swap question...
- Interior Painting
- Hooking up my new cluster
- map sensor?
- Need part # for CRX side triangle hatch glass weatherstripping
- Hitting starter makes car start?
- Stainless steel header bolts?????
- header bolt ????
- Newly purchased 1984 CRX 1500, carb/idle questions
- why are my threads getting deleted?
- electrical problem needed solved
- help out a newb plZzZzZz
- smoke coming from breather.
- CAR FOR SALE!!!! must check out!!!
- Need help, using raxles in a 1990crx b16 swap, having issues
- How fast can your car go 0-60 in.
- Time to rebuild my B16
- I need to know everything on ZC Motor Swaps into DX's
- how do i remove (without breaking) the trim that runs down the center of the door?
- ZC giving code 9: No. 1 cylinder position and runs like sht
- seat alarm wont stop going off, please help
- OBD0 b16a converting to obd1 help!
- nology power core???
- Power Door Lock Switches
- no power on takeoff crx dx with a d16a6 swap
- 88 suspension different???
- injectors
- What is the fastest D16a6 All motor ef that u know of????
- 89 hatch progress log ... 22 pics
- swap help
- Need Help with D16a6 into EF......
- I Have A D-Series Engine!
- Is this even possible??
- Can some one let me know just by looking wut kind of motor this is ?
- Couple Questions
- no dash lights help???
- d16z6 sawp in a 89 crx si havin problems!!!!!!!!!
- B16a1 head Gasket
- jdm d15b bogs when i floor it just changed i to obd1 no codes
- help: d series in EF??
- d16y7 build-up
- what wires are what for fuel pump?
- shifter bushing question
- installed Toda header today...clearance issue
- How do I get rid of code 23 ?/
- Quick clutch question
- *PIC REQUEST PLEASE*, 88-91 SI/HF Rear Manifold hoses location ONLY.
- Suspension setup for rear disc conversion?
- brake question
- white face gauge problem
- ecu ?
- installing some 5 point harnesses
- white gauges
- clutch cable?
- HKS civic exhaust modified to fit CRX...Where to modify/cut it?
- will a cat converter off a 92-95 civic fit a 89 hatch?
- ATTARCO sucks!
- crx engines
- what cv joints for ls swap??!
- questions bout my honda crx
- Oil leak only when car is started
- 11 to 1 compression LS CRX
- c-pillar crx
- starts early in morning but not late in day
- d15b2 head on a d16a6?
- Remember Me? Well, here is some pics of my car finally.
- best ecu
- dont know where to start...
- dizzy question
- anything else i need for a suspension job..please help.kinna long
- C&R Radiator
- pulled speedo cable out of firewall, how do i fix it??
- after market gauges
- Need help Finishin the swap!
- brake master!!!
- Best place to buy Body Kits??
- big brakes
- recaro seat question?
- anyone heard of Feel's Fuel Controller?
- trouble codes
- TPS sensor replacement for Pre OBD B16A
- fuel pump or what
- different dyno's ? Dynopack / Dynojet ???
- Whats my CRX Si worth I got good deal what do you think I paid
- Headlights
- Stock SI Tail Lights
- help obd0 to obd1 extra wiring
- Pre-salvage yard questions
- B18B LS ???
- 91 crx dx w/94 jdm sohc time slip
- door light.
- Finially got the mpfi up and running
- CRX SI build up
- Bent Rear Subframe
- stripped lug nut/studd.
- For those of you using a d16y8 head what dizzy are you using?
- PM7 ECU on MPFI Conversion
- Gauge location suggestions
- B16a 90 civic DX
- B20 alternater?????
- EF Sedan One piece headlights
- 1988 CRX HF ECU Codes?
- UHHHH...PROBLEM I THINK
- Car dies until it warms up
- idle questions, TPS reading .77-4.55, is this enough to throw off my idle?, also my car only has 1 o
- throwing codes after swap
- starter clicks rapidly and wont turn the engine -- help!
- AEM and Toda parts
- Shifter makes a rough clicking noise/feeling when shifting into 3rd gear.
- good price?
- NEED HELP ASAP!!!!
- cv boot
- Found picture of my fathers 1978 Civic back in the day.
- Fuel tank sendin unit problem
- Help w/ new cluster
- B20 into CRX chassis????
- Placing the B20 BLock in a CRX chassis
- Bumper Removal
- CF hood
- Are DA LCAs the same as 89-91 CRX/Civic's?
- new car
- who has rota torque rims on there rex
- 210whp on stock b18c in my crx tonight at the dyno!!!!
- 1994-2001 Acura Integra Centre console in 88-91 CRX
- 1994-2001 Integra GS Throttle Body on B16a1
- Charging System Issue
- has any of you boght this?
- boost gauge and turbo timer install
- Is This a JDM ZC tranny or a USDM Si Tranny ? ? ?
- Ignition problems
- zc engine
- which civic is heavier?
- DOHC ZC or ls?
- weird cel #7
- Harness Match-Up Question.........
- engine swap ?
- Anyone have more pics of this ef?
- how much are these worth?
- The point of black hoods?
- gettin rid of injector resistor box
- changed timing belt, now have bad idle and code 7 what is wrong
- should i do this? what do yall think?
- OBDO-OBD1 problem
- ecu compatibility question
- I LOVE the junkyard. And some questions!
- Carbon Hood
- Help PLZ anybody
- Rear Swaybar???
- Does the 88-91 crx have a gas light?
- Installing Alternator in B20 CRX
- Installing shift linkage in B20 CRX
- Makeing the sleeper From hell
- will a 1.5 sohc vtec bolt right up to an 88 crx dx?
- Vibration under braking. Steering rack?
- tach and rpm switch question
- Car shutting off while driving
- Need JDM Tailights?
- 3 months to go...
- About harness (please help)
- Password CRX front lip pics??
