View Full Version : Honda CRX / EF Civic (1988 - 1991)
- j-spec 1990 crx sir
- stalling at any speed or gear
- ok soo...
- odb-1 dohc zc
- crx y1 trans trouble can you diagnose?
- Rear window visor for 4 doors
- oil leak..... help!!!!
- DIY solid motor mounts?
- i need help.
- still eating axles..
- jus bought an 88' crx si need help with some issues!!
- answers to trouble codes
- EK and a CRX frontend
- Crx with D16z6 wont rev past 4k
- Im having clutch problems....
- mysterious clunking noise, maybe a bad motor mount
- can you give me an opinion about how much my car is worth
- Manual Transmission Shifting Issue
- 88 door on 91?
- increase gas milage
- Etd traction bars vs Full-race
- what do i do now - broken bolt AND bolt extractor
- whats???
- HF calipers?
- 1990 Civic Cable clutch not fully engaging?
- body harness?
- map sensor
- need help with smog.
- need help with a wiring issue plzzzzz
- ek side skirts on ef? need help?
- struts and springs questions
- What ECU For B20Vtec???
- bad ecu questions
- Stock 88 CRX: New Clutch Slip!
- What are your favorite OEM rims for 1991 ED6 hatch
- F2B CRX Project
- werid electrical problem
- EF engine bay delete.
- Which FPR?
- Honda Noob - Wagovan
- brake issue or me?
- are 88-91 civic exhausts the same as 88-91 crx?
- LEAKING OIL FROM FILTER HOUSING!! HELP!!
- neutral safty switch problem
- b18b1 swap wiring question
- custom cam????
- What are your views on quick release hubs
- Issue with b16 and IM mount kit. Help!!
- help me motor shut off when driving
- timeing belt
- b16 exhaust question
- HELP
- hf mini me a6 block z6 head need help no fire
- Locked out, battery dead, tried everything.
- Only getting 10.2V to Injectors(DPFI)?
- Identify this crank pulley?
- Cluster Question!
- Frenchie's Civic
- best mpgs in a crx?
- need help asap
- B16A tuning
- B-series, G22, F22 questions
- anyone know these crx tail lights?
- Brake lights blowing fuse
- code 8/9 need help asap! couldnt finish tune today
- D15B7 88 CRX into B18A1?
- cold start
- crx trunk space w/o rear piece
- Custom CRX gauges
- EF Spindle Question??
- transmission gets hung up on P
- 89 Si mushy Brake pedal ? Any ideas?
- 88 crx si ls swap only starts sometimes
- Loosing power Getting CEL
- radiator fan
- Another OBD1 conversion question.........and yes I did SEARCH
- Cutting DA linkage for crx
- Gauges dont work!
- do seats with crx rails fit the 88 civic?
- 89 hatchback running like poop
- HF 5th gear
- OBD0 to OBD1 conversion- confirm?
- mpfi-d16z6
- EF8 PS RACK QUESTION
- B engine, D trans adapter
- GSR leathers in an EF
- Anybody Can Repair Their Busted CRX Seats
- LS-VTEC cannot set timing
- 91 crx si chaking and vibrating
- crank sensor
- eletrical problem
- Flywheel weights
- better springs or coil sleeves
- Do any 1989 Si's have drum brakes?
- 91 civic starting problem when warm Help
- ef9 front bumper on a 4door
- HELP! Code 3 map sensor trouble
- GAHH! i loathe fuel issues with a passion!
- help me find this part? Crx half radiator, traction bar mount
- interchangeable parts?
- battery relocate?
- rear seats
- J's racing front lip
- What D series head gaskets are interchangeable?
- electrical problems in 90 si
- no start. no spark
- LMAO this is so GHETTO!
- Amp wiring/ battery dieing fun
- 91 Civic hard time starting after car is warmed up
- obd1 converted crx dies on cold startup
- dist question
- Bottom D16Y7 non-Vtec with Top D16Y8 Vtec.
- Fuel Pump Problem?
- broken lip.
- Please help, quick dizzy question
- lude seats in ef
- Low idle cause a CEL 9?
- ecu pin out pictures!?!?!
- sohc clutch's all the same?
- DOHC ZC....NO START, Searched everywhere! got pics
- quick ? jdm sir front knuckles....what brakes
- boosted 90 civic
- EF9 wont pass smog!! Need Help
- 89 crx si SOFT clutch, slippage at hi rpm?
- eg parts to keep for my ef?
- 90 crx si suspension overhaul
- b16a obd1 integra xsi swap in 90 crx si
- Help with a hunting idle
- fog light brckets
- pcv
- Electric Water pump for B series?
- B16 With an S1 in a ED
- Side Mirror Differiences
- how to paint engine bay?
- B series swap while keeping AC and PS?
- Ef Civic Need Help
- axel question..
- need a parts list for jdm b16a sir2 in 90 crx si
- Check engine codes and some problems after DPFI to MPFI swap.! Help
- seatbelts
- HELP PLEASE!
- gas tank/ fuel pump help
- Feedback
- Will a bad radiator cap cause a code 6?
- my gas milage sucks. whats wrong?
- D16 Help
- Crx the Everyday Struggle
- CRX SI MINI SWAP PROBLEMS
- Trying to find amber bumper lights and corner lights..
- Installing Climate Control
- want to swap D15B2 to D16A6. need info.
- question about roll bar
- overheating problem in ls boosted wago
- Windsheld spray thing
- Tips/Advise to clean block of old head gasket
- d16a1/dohc zc injectors
- Rear veiw mirror for my EF
- Question changing a b series head
- Mini-Me questions - w/ pics
- dohc zc + light flywheel?
- dc headers??
- ls swap obd1??
- obd0 to obd1 distributor jumper harness
- 90 Honda Civic Auto wont shift slips bad need help plz
- quik question ?
- EF oem tilt wing help
- Great discount on parts...don't miss it.
- stupid crank bolt
- Weird Front Brake Problem!
- clutch cable wire tuck?
- ok this is kinda a dumb question
- help with p28 error codes
- Aftermarket Radiator with OEM A/c?
- ef si cluster into auto ef dx
- ef9 mirriors
- Big Problems, '89 CRX
- obdo to obd1 conversion
- poor acceleration
- #1 & #4 cylinder intake valves stuck open?
- crx obd1 b16 on virgin p28????????help???
- A little bit of ECU fun!
- dc cluster to ef swap?? wheres the write up?
- okay been Looking around but no sense made on mini me swap
- short ram/cold air intakes. few questions
- 2000 civic seat modify into crx
- H-T geeks i need your help.
- Question about car stalling (88 crx si)
- DOHC zc. Need a wiring harness
- 88 crx hf cluster wiring help needed!!
- clutch/break/gas pedal removal?
- 1988 hatch dx / 1991 hatch dx
- 91 civic dx sedan rear shoe size?
- elevation change...car runs like sh**
- obd0 b16 vtec
- 91 civic Si Brake Conversion
- honda crx pics
- Search problem
- Wat To Do??
- Upper control arms
- D16A6 and Y8 part compatibility
- Back in the saddle again
- Anyone know why the '88 d16a6 was rated at 105hp instead of the 90-91's 108hp?
- d16z6 im on a d16a?
- hey i need info on obd0 to obd1
- steering wheel shakes around 60mph and up
- Ignition switch problems?? 91 CRX SI.
- Had fun with my LS-VTEC for 15 minutes, then it broke. Help?
- After Market Front Hub?
- rad and cond fans run w/k.o
- EF Pin-out
- Lower radiator support??
- Yet another CRX build
- D15b2 piston compression psi
- B18c4/B18c1 with a B16 head wiring issues?
- civic wont rev past 4k, help
- transmission help
- what kinda seats fit the 88 sedan?
- Sedan front bumper question
- d15b1 parts for best mpg
- noob with a 91 ef hatch.
- Sunroof replacement
- how do I test my injectors
- rear lights help!
- will a civic hood fit on a crx??
- honda crx ecu questions
- Pickyourpart
- engine build
- metal? or dirt in the tranny?
- CRX Project 1
- engine build
- window help
- 89 Civic Hatch Outer Tie Rod Replacement
- need helping, non starting ls hatch
- Urgent Water Leak!!!!
- Strange Electrical Problem
- busted my gas tank.
- Help : d15b7 engine jerking
- wiring fuel pump
- since pm6 ecu can be socketed... what about pr3?
- Inside of a y3 tranny
- Serious problem need help!
- OBD0 dizzy internals compatible with obd2 VTEC?
- rear mud flaps/guards
- ITR Swap not making power.....
- 88-89 side molding on 90 hatch?
- WTB d15 wiring harness
- Having Trouble...
- CRX SWAP OBD0 B16 Header Questions Plz Help
- need help with RHD
- Need Help 91 civic lx z6 swap hesitation
