View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Mini project log: Blade Silver CRX Resurrection Lots-o-pics.
- How to identify a ZC transmission?
- Hazard Switch? Do I need to go to Honda?
- New or Used Body Parts? what is better
- A little write up on painting body trim
- 90 CRX .. 4 Lug - 4 Wide Lug conversion?
- 88 DX Spindal/hub assembley same as EG EX assembley
- 90-91 CRX front end swap to 89 DX CRX, what's needed?
- Are 1990 CRX HF brake pads different from other models?
- Where can I get...
- 91 civic dx/ civic si
- pic request for rollcage in a crx
- Just replaced 90dx Brake Master Cylinder with Prelude 15/16 and have a question
- harness bar?
- RIMS
- Nachi Bearing. The part number is 6001/012-2NSL.
- My honda civic with two engines. Now i need to swap.
- Have an EF seat question.
- Rebuilt B16A / break in process and hose connections
- Just starting out, what should I do Start from scratch or buy?
- Check Engine Light Kicked on while driving 75-80mph
- MAGNAFLOW Catalytic Converter: Comparable to stock????
- IACV help please
- nostart. this is a toughie !!!!!!!! need help
- camber kit
- i having a hard time understanding turboedit and BRE, ect help please
- anyone else seen this sight.... its kinda funny
- All The ECU Codes You Will Ever Need
- 2 questions.....(brakes and seatbelts)
- Another Tach Question
- my car runs like crap when i have water in it? headgasket????
- blown fuese
- Red Mouldings for a crx??
- Is there a differance?
- fuel pressure regulator causeing rich and lean problems?
- CARBING 5MM STRUT TOWER BAR 89-91 CIVIC JDM <-- any good?
- couple question on my minime progress!
- 2 layer gasket?
- Vtec!
- lip question
- parting out a 91 si rex with obdo b16a
- lookin for trade
- how much hp would i get if i put a skunk 2 mani on
- Relay below the radio on 90 Civic?
- door mounted seat belts to pillar???
- Leak through Door Speakers
- Looking for bumpers
- d16z6
- new project
- skunk 2 intake not giving me more power, did I do something wrong
- B16A1 Motor surges @ cold and warm temp, but no engine light.
- need help on ls swap...
- CrX with 93SI Knuckles now positive camber ???
- Just got B16..RSR header with no downpipe?
- will civic si sunroof fit crx si?
- I believe my RHD rack and pinion is going out
- boost on stock axles
- I know this is not the place to post but......WTB civic si interior except seats and luggage shade a
- CRX Si tranny
- idol problem
- Overheating When Idling
- motor swap help
- B16 and Transmissions
- parking brake pin
- avid shift linkage ? 88-91 civic b series swap
- easy favor from someone w/ a 90 Civic Si hatch
- turbo/ecu question??
- GREDDY SP2 PIX on a CRX!!
- My 87 crx :D
- what does this tell you ?
- is it worth it? crx?
- Tq spec for cam caps??
- whites on crx, if anyone has pics
- 98 civic seats in my 88 crx dx?
- Suspension and Exhausts problems for my 88 CRX
- crx interior into 91 hatch
- CAR DIED!! 2 Major Codes - crank position sensor , top dead centre sensor #4 / #8
- Neuspeed race spring owners, please help
- Where should I get a stereo sleeve?
- Just ordered this exhaust for my daily....
- 91 Si emissions problem...
- just got my ST sway bar (suspension techniques) and its green??? WTF?
- what are these wires?
- JDM ZC hatchback wing (what is it worth?)
- Mother expletive son of a expletive. Help please?
- no reverse? shift fork? tranny open.
- CRX RHD conversion bay area
- slipping clutch or cable???? help
- b16a revs to 7800
- how easy is it 2 put a 1st gen b16 in a 88 civic dx
- fuel gauge
- CRX seat rails / tracks help...
- Researching A/C looking for help and feedback.
- headlight Q
- Questions From The UK... CRX siR Associated
- civic front bumper on crx?
- pm5 vs pm6
- pp4 ecu.... for which engine\car is it?
- Which LIP for an EF9
- Some help Choosing colour!!!
- integra type r throttle cable for ef swap?
- need help!!! 99-00 si cluster to 89 crx
- 99 civic seats in 88 crx will it fit?
- oil pump for turbo?
- Best place to find OEM ZC hood?
- Salvaging a radiator support
- amber for 91
- 88-91 civic suspension fittings
- basic question about seating
- gsr or lsvtec
- ok, temperature help please
- GENONE at PERTH AUTOSALON 29/30th July
- clutch cable
- ls in my crx, which tranny best for n/a setup
- questions on my new (to me at least) crx
- 900 RPM squeek
- searched this chassis code???
- help with nitrous on d16a6
- need some advice.. tell me wat u think
- gas leak in 90 crx
- Anyone heard anything about this?
- any body got seatbelts
- seat brackets for Momo seats in an ef
- no start problem
- quick question please help!
- b20
- Pillow Ball mount / Caster Plates Anyone running them?
- whats up with my rex?
- Suspension question
- 1990 Honda Civic DX Smokes after replacing head.
- how to store a block?
- question on compressors for my ef.
- Integra Radiator into CRX Si
- dizzy bearings?
- crx with b16-check engine
- help on b16 a
- brake master cylinder replacement procedure?
- price for my crx shell ? ?
- body kits..
- Wheel nuts for Sparcos...
- Is this possible?
- Electrical Problem, need theories.
- which part is the main relay
- civic body parts
- What happened to Jimfab?
- Idle problems!!!!!!!!!!!!!!!!!!
- Turbo CRX, what size slicks?
- Need Help! Ignitor?
- Calipers for '90-'91 EX Sedan Uprights
- b18c1 into 90 crx mated to 92 gsr cable tranny, which clutch kit?
- Gabriel or KYB GR-2 for CRX?
- H4 Headlight Mod anyone tried it?
- jdm fog lights
- dizzy question
- is an ls swap even worth it in a 88 si rex?
- Officially, what body-type is a ED/EF CRX?
- Performance Upgrade?!?!?
- code 4, 6, 7, & 10 wtf?!?!?!
- Any EF owners have these corner lights?
- Quick exhaust question
- you put what motor in your 89 hb
- ECU?
- Want to Turbo my DOHC ZC!
- Can This Be Done?
- Main relay with 4 wires?
- 90 CRX HF valve adjustment specs??
- Can a Eg sway bar fit into a rex?
- A/C and tranny questions
- Power window problem NOT THE SAME OLD CONVERSION QUESTION
- car wont start
- b18a1 mechanical vss problem and the car has a limp (ha ha)
- Seatbelt Harness Mounting help
- Where to mount the anchor bolts for my 5 point harness?
- Whats your take on Header Wrap? Also post some pics if you got some.
- TPS SENSOR QUESTION
- SOHC non VTEC to VTEC?
- Pulled spark plug wire, now no start
- APC Fog Lights
- d15 b vtech
- Shifter leans to the left..
- EF harness, P28 with boomslang conversion, need to check cells... how????
- dohc zc overheating....why??
- REPLACING CRX FUEL PUMP NEED REAL ANSWERS
- Alternator help, please.
- what header can i use
- Antenna replacement
- oil seal replacement
- climate c0ntr0ls
- Piggy back computers for 91 CivicSi non vtec?
- stumbleing on brand new engine, need some opinions
- Grinds when I shift...
- SOHC vtec with DOHC vtec ECU obd0
- Vt cluster in 88-89 EF
- 90 civic loses power
- head gasket
- Figure out problem, Win money!
- Can I install 88 CRX Si seats in my 90 HF?
- what hood do i need
- B18 axles
- Searched~ Excess oil on plugs!
- holy smokes
- DOHC ZC Question
- fill plug tourqing
- Deal of the day! Progress Sway Bars
- ( Sold the Civic & Bought a Civic ) CHECK OUT MY New Civic Wagon
- Anyone Experience release bearing return spring problems on 88-91 civic clutches?
- need help! front bumper question for 91 hf crx
- Ignition timing
- Electrical Load Detector problem
- MC Help
- 91 crx head lights dont work ?
- BRAKES Barely Work - Fresh Swap, What Happenned?
- CRX (EE8) EDM VT 1.6L Axles?
- black housing jdm headlights?
- Wiring
- Anyone got a progress group rear sway bar on their EF
- Will eg sway bar fit?
- ok so i installed a new intake manifold car doesnt start and new code........
- 1990 civic hatch with b18b
- what shuld i run?
- how much nitrous???
- question on jdm d15 sohc vtec motor
- started my wire tuck
- side molding clips.
- engine damper???
- D16Z6 for how much?
- how hard is it?
- how much is this worth
- Dizzy?
- i lowered my ef and now when i turn left the car vibrates. help. suggestions
- oil pan????? need to know!!!!
- just looking for some swap feedback
- Passing inspection with ghetto climate control?
- Some noob questions.
- Help '91 Civic Hard starting..
- turbo laggisH?/fmu??????
- mpfi harness plugs
- can a cam leak?
- who has a plx m-250 wideband o2 on the crx/civic i have some questions please help
- oil leak....???
- Help me with 91 ZC SOHC running like crap between 2500rpm-3000rpm help?
- motor sparks when the ignition is on and the motor isn't turning over ??????????
- early B series
- wiring is correct, first gen b16 vss problem
- fast reply need. OEM # for rad relay
- WIRES ON THE LOOSE....LOL
- ARE YOU DISSATISFIED WITH YOUR GEAR RATIO ?
- Anyone have a EACV picture?
- Air Fuel Ratio Problems .. Turbo'ing B16A
- will 88-89 teg axles fit into a 90 crx hub
