View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Want to learn more about working on CARS in SOCAL
- Need Help With head gasket problem!!!!!!!
- What type of deck do you have in your EF?
- ef9 front end, on crx
- Tachometer problems
- How low can I go???
- STD calipers the same as DX/SI calipers?
- Which T-bracket for 89 civic si w/b16 using yonaka mounts?
- help!!!!!!!!! crx hf with si tranny
- CRX Brake Line Size
- MAJOR PROBLEM WITH TRANNY (bad day at the races)
- left turn rubbing
- Help me regain intrest in my hatch
- accord intake tubing
- Q? edm cluster into 90 dx?
- Stock Jdm Lip for 88 Crx
- wtb dseries intrnals
- Is this the right combo for a throttle body
- clutches to get for b16a???
- Head Swap Done, Has spark, no knocking but won't start
- any 1 ever put these rims on a crx?
- what should i use for trans fluid?!?! 1990 civic dx
- ZC studders at WOT
- motor will not start!!!
- SCE Copper Head Gaskets
- JDM Tail lights
- wtb sir hood
- Help with CRX d15b swap
- dash ideas?
- crx lip?
- Where could I find a rear bumper reinforcement???.........rust sucks!!!
- part number round up, everyone check this out
- integra 5speed / auto ECU differences
- HELP!! Quick Walbro install question
- d15b turbo clutch ??
- good gear ratios for high revs?
- weight?
- mini me on a 91 civic 4dr
- d16 swap into a 91 dx?
- looking for a 1.6 dohc for 88 crx dx
- B16a1
- ej coils on ef?
- Need Help!
- should the starter motor be hot?
- GTS Solarwing install - Keep or delete?
- Our CRX Dynasty
- 89 HB - ebay car questions
- B16A WILL NOT START
- Si Wheel Question
- is this right? 91 si vs 88 std hatch weight?
- which o2 sensor to use?
- 1988 crx si rear shocks????????????
- Ef has been sitting for 2 years now its has white smoke
- My CRX project (complete)
- car wont start, wont crank. HELP!!!
- jdm SIR frontend v.s. USDM frontend
- does ne wun have the torque specs on ef-8 stock motor
- i have a motor swap? it might funny to u...
- B18a into 91 EF, Mount Kit a must?
- quick speedo cable question
- will my 88 dx traNNY bolt right up to a zc 1.6 dohc?
- my car is sputtering what do i do?
- Sputtering and wont start.
- Crx Springs Problem
- Stupid Timing question, someone pls help me out!
- tire question...
- exhausr shop ?'s
- anybody know where i can get/buy amber corner lights?
- type r in a crx?
- how much to get exhaust piped?
- CRX SI Heater/Blower in a Civic HB DX with CRX Dash**SEARCHED**
- does anyone have a mugen kit on their ef?
- Alternator Dying?
- looking in junkyards for B16A
- Fuel pump voltage
- Broke axle
- B16a1 distributor O-ring Part #?
- EF B16 swap
- 89 crx wheel question??
- swap
- FUEL FILTER/FUEL PRESSURE GAUGE BANJO BOLT ADAPTER SOLUTION
- Specific head gasket question...I know there are alot of these but...
- FUEL FILTER/FUEL PRESSURE GUAGE BANJO BOLT ADAPTER SOLUTION
- NEED HELP FAST for my crx mini me swap!!!!!!!!!!!!!!1
- is this a good deal?
- disturbing noise from a/c
- Is it useless to Rev Ls/vtec out to 7500?
- info on all motor
- AEM 21-5001C
- Fuse Diagram question
- Questions about Clutch's and Flywheel's
- OK..........so i've started my valve work..............and nobody told me the valve guides have rubb
- car wont start, relay clicks
- Turbo Questions
- Driving without a hood
- where is the engine coolent temp sensor (ect) on my b18a in my hatch
- STOLEN - 89 HF in SoCal
- cluster question
- BLUE AND BLACK SMOKE
- running a bit warm, need some help
- RHD AT EF8??
- CVCC need info, websites, etc. Looked at one yesterday tell me what you think.
- Brakes are Locking up!!!!! in the FRONT!!
- 88 civic speedometer cable
- RHD CRX SiR
- ZC motor build
- Were to find JDM headlight sliders for coner lights.
- spark plug wire question
- Mini vtec x-over point
- LS/Vtec Wiring ecu
- Brake light issue
- wireing
- Integra seats into 90 civic?
- What hardware do I need for rear Sway bar on my 89 DX....
- New bumper cover from Honda -- possible?
- Gearbox Rebuild.
- cams setting on B16A
- Retro fitted lights into CRX? Ideas?
- Wings west sideskirts, Door wont open! DOH! Please help?
- JDM 4-2-1 header clear stock crossmember
- Hello.
- Need help with speed sensor...code 17
- Pics Of Headlights Housings
- Full suspension bushing set
- HELP please ASAP!!!!!!!!!!
- Anyone know were I can get a 4DR Civic CF Hood???
- DISTRIBUToRS
- Question about tach and speedometer cluster
- B16A swap question
- Valve spring tool????? (removal and installation tool)
- 90-93 b18a or b search
- 93 ls what dizzy??
- sudden loss of compression, car wont start
- Swapping b16 gears
- 91 hatch with H22A
- will a 90 si tranny cable work on a b18a motor in my ef?
- GSR in hatch, questions about the rear mount
- what do i need to ref a 1991 b18 in an ef?by the way im in cali
- 91 hatch with LS engine
- New guy.
- '03 Civic Si 15" rims on my '88 hatch?
- 90 crx b16a1 low rpm stalling
- someone do me a solid?
- 91 Si Engine Questions
- Your CRX Engine
- 89 CRX Si problem
- Seat pan Question
- Vacuum nipple on the bottom of B17 intake manifold?
- Engine swap with a/c
- resistor box help!!!
- CRX Mk 1 Engine Swap
- hybrid intake
- 84 crx swap?
- idling problems
- Mushy suspenion
- fuel rail
- TRANNY
- Custom LCD for CRX
- IS the EF8 conversion worth it?
- Ignition
- HF exhaust difference
- how much horse can i get out of this set up?
- d16y7 into 89 civic hatch...help
- d15b2 block, d16a6 head
- 90 Civic stuck door handles
- Glass roof - How much?
- Advice please
- sticky steering wheel...
- Where to buy Thermoswitch for 91 CRX???
- Exhausts that will work???
- gsr cluster
- Track Times and Dyno Stats?
- Momo steering wheel - How to wire horn?
- cable b16a transmission rebuild kit
- zc dohc intake manifold
- wiring on b16 swap in 88 crx si????
- Need advice: My car is stuttering on acceleration.
- How to check MAP sensor?
- Can i use the stock distributer off of a b20b with an obd1 pr4 ecu?
- CRX Engine set up..Ever Been Done?
- BODY KIT HELP
- Which cat-back exhaust should I get?
- 91 Civic Si Transmission Question
- WHat kind of injectors can i use for my obd1 b20b??? please help
- ECU pin out
- 91 Ls in 90 hatchback... weird vibration.
- HELP! Brake lights problems 88crx
- obx limited slip...yes? or no?
- Si ecu
- Repair Manual for 90 CRX SI
- Macco
- Gears Grinding
- HX rims+EX front brakes= what spacer do i need?
- clutch cable problem
- Dallas Street Racing
- Anyone know who owns/owned this crx?
- Replacement steering column for 89 CRX Si
- injector help
- Anyone here bought aftermarket carpet?
- CIVIC CRX 90 91 SI TRANSMISSION NEEDED
- b16 swap n 91 civic si what throttle cable do i need
- d15b into 88 civic dx? i have p28 ecu and ecu obd0 to obd1 harness. now what?
- fuel cut? and what does it do?
- How do I rewire the 02 sensor on an 88 crx si? Weird yellow wire?
- help
- looking to purchase motor...but where?
- Dashboard swap
- performance shops in Colorado?
- CRX LIP!
- Brakes acting up...
- speedometer cable
- crx front conversions
- USDM ITR header on first gen b16.
- vtec problems
- Hydro tranny in CRX question
- EF-8 importers in canada?
- Will b18 fuel injectors work in a b16?
- TPR Magazine Tests Headers. Spoon made over 25whp!!
- Thoughts on KYB AGX's
- Peak and Hold or Saturated
- axle hitting shock fork
- Vibrant Cat Back?
- CRX SUSPENSION (?) AND ELECTRICAL PROBLEMS H E L P!
- Can't decide, 10 more hp and YS1 or LSD
- b18c5 crx - what car parts match for this engine in my crx?
- ((((((((((!!!!HELP!!!!!)))))))))))))))))BLINKERS DONT WORK!
- JDM CLUSTER PROBLEM
- 89 crx SUNROOF problems.... what else is new
- main relay clicking, not starting need some help!
- information regarding replacing my seat
- motor swap wiring question
- Help! CRX not starting after moving battery to the back
- my b16 will no longer rev past 4000!!!
- Bleeding the brakes on my '90 Honda Civic DX------[HELP!!]
- surging fuel injection
- Cam Question?????
- Replacing Window Tracks
- Alt. Solenoid Valve Fuse keeps blowing after Walbro fuel pump install
- how do i lower my 85 civic hatch???
- Temperature problem
- 7500 crx project under way CRX si is purchased , now onto the motor b16a or ls/vtec swap?
- FS! B16a motor in a '91 Civic Wagon with MANY extra parts. $2500.00
- 88-89 & 90-91 are most of these parts interchangable?
- ef shirt (for real)
- Rear suspension help
- head?
- D series block similarities
- Removing axles for engine swap?
- what sensors are these and how do i get them out?
- i need others Input
