View Full Version : Honda CRX / EF Civic (1988 - 1991)
- fuel pump
- 89 crx si seats in a 91 civic hatch
- New lips coming out?
- intake manifold gasket??????
- 90-91 JDM CRX TAILLIGHTS
- Anyone know anything about ZC motors?
- 90-91 integra suspension on 88 crx..worth it?
- Wierd Miss
- Clutch Combo Help...
- leaking tranny after swap, did search
- JDM hood not lining up.
- switch entire harness? obd0 to obd2
- Will H4 bulbs fit in H4H headlights?
- KW Suspension - Coilovers
- what seats bolt right into a 89 civic hatch?
- slammed crx's or hatchs's pics please????
- Weird dizzy problem (mainly ignitor)
- found a 90 model civic in Korea with factory 4 wheel drive!!!RSI limited
- HIDS???
- Down with passive belts
- 4 door side skirts, cut down OEM off later years?
- best place to buy a motor swap
- Can i use a crank pulley off a a6 for my z6?
- 5 speed conversion
- b16a idle problem
- fuel pump transplant
- Ground control ride height?
- cylinder sleeves?
- anyone know the exact weight of the 90-91 crx si rims?
- That big of difference between PM6 and PG7?
- south cal honda dealers...
- I have tranny problems
- is it my ignition timing?
- weird number on block?
- How to fix my climate settings? PLS HELP!!
- cooling problem 89 DX w/ ZC
- dohc zc wiring
- BAR CERTIFIED
- WTB: 2nd gen b16 swapped crx or ef hatch, i got 3500
- WTB: Ingalls Camber Kit. 88 crx. four corners. poly.
- My Swap Situation! Look inside and help!
- anyone actually keep a6
- crx 88-91 vtec?
- crx si rear bumber?
- Thermal Exhaust
- Integra LS Read Disc Conversion fit a 90 hatchback
- how much is a turbo worth?
- checking trouble codes for non-obd
- What can i do
- Fiberglass ZC Hood
- What center console if any...
- Need help finding a video.....
- BIG Brake upgrade, Will 91 Interga Kunckles fit a 90 DX lowered 2 inches?
- What is the definition of a ZC motor.
- F/S 88' crx dx shell
- will crx si springs fit in a crx hf
- Knocking noise coming from D16a6, help.
- crx si seat disassembly
- Rear Tranny mount on 1991 CRX DX
- getting a 89 si for 500 bucks
- a6 head and a z6 bottom?
- Blue Box under CRX Drivers seat.
- crx si seats swap
- what's the best obd0 ecu (pr3, pg7, etc.) i can use with d16z6 crx si
- Compression Test, are they about right?
- need alittle help on crx si pm6 intake mani into a 92-95 d16z6
- gage cluster question???
- will PG7 ecu (teg) work with d16z6 crx?
- sohc ZC questions
- crx for 1000?
- is it my starter ?? pls help!
- CEL 1, Oxygen Sensor effects
- i would use my stock radiator hoses with an EG radiator right???
- Sound like a motor mount problem?
- Stage 4 A6 cams thats going in Exospeed Project CRX
- Need Help ????????
- quick question about ignitor/coil
- ES rear endlink bushings?
- Completed my minime swap.
- Insurance Questions.
- Does anyone use seat covers? Anyone got pics?
- LS SEATS iN CRX?~!?!?
- D15B6 Piston Specs?
- Suspension
- school project..need a little help
- FREE!!!! need help (exhaust related)
- pics of 90-91 si hatch lip
- Who makes nice fiberglass fenders for our cars?
- 90 - 93 dash in 88-91 civic hb
- will my SI header work for a zc motor?
- found a car
- Moonroof to Sunroof
- 91 CRX si ignition harness/switch the same as 91 civic hatch si?
- HEaders question plz help
- MPFI
- could us OBD0 guys run the 345cc prelude injectors?
- Anyone know where i can find a 1st gen crx SI???
- did i get a good deal for my 4-1 dc sports headers?
- I hate how my hatch creaks and rattles
- What can you do to a 1.5l?
- Moonroof compatability?
- del sol stuff on a crx
- I've heard an 89 prelude sunroof is compatable with an 88-89 CRX...
- Lookin for a good website for ef civic swaps
- My all motor build up d16z6
- Heater is kinda slow this winter...
- Rubber Axle Weight?
- If you can answer this with good meaning I praise you.
- Brake leak somewhere...but where the hell is it?
- Looking at a 90 Civic. Anything to be aware of?
- fixable?
- Just bought a 88 CRX Si. few questions.
- 91 Civic LX Brake Drag Issues
- great!!!!!!!!!!! my b16 tranny is a true pos!
- similarities between US/JDM trannys
- i need cams and valve springs and retainers
- need help with idle!!!!!
- Can you guys help?
- stock tach accuracy?
- KW coilovers
- Quick OBD conversion question
- Guage Cluster's
- CAN YOU FIT TYPE R SUSPENSION IN A CRX
- motor swap in cali?
- 88-89 90-91 crx fenders interchangable??
- Grill for WW front bumper
- Need help with ZC motor
- xsi and sirI b16 engine.
- where can i find a jdm cluster for my 90 crx si
- need help with vtec....(not a how to)
- d16z6 / minime
- black sm0ke
- WTB 88-91 Crx Climate control, need it asap winter is here and cold air is no bueno!~
- VSS code 17, problem ?
- TRANNY..
- how do i tuck my back tires?
- Gude header specs
- just bought my first Crx for $700! Some newbee questions.
- crankshaft seal from del-sol
- help with wiring jdm mirrors to alarm
- 90hf Crx for 1500 good or bad?
- If i were to get 1/4 panels cut off a car where should they be cut?
- Dyno, what gear to use
- B16ed Turboed?
- temp selection light out on 91 rex`
- been torn between the two ideas
- brake bleeding
- A6 crank versus Z6 crank?
- Transmission problem
- chicks with a crx pictures
- why am i still a trial member
- 88-89 crx si quik pic request
- Ideas on custom body work
- 1991 crx si taillights and usdm integra type-r gauge cluster with wireharness...
- Axles Question
- Lost motion assembly
- How rare is this 88-91 Hatch Interior/dash piece?
- 1991 Honda Civic Si Hatch!!!
- Valve Job Question
- adjusting headlights?
- question about a crank pulley
- 88-91 Civic Parts & High Performance Parts Sale Cheap!!
- Cam gears for a B16
- apraise my car
- axle replacement interchangable......
- Valve clearance???
- Passive seatbelt in '91 LX sedan
- # splines in a std hatch 4spd axle
- Looking for some help on a 88crx
- Mugen Flared kit on the way this friday!
- quickest zc?
- which year civic HB have black center taillight piece?
- crx/civic parts swapping
- HELP! how to check timing on B16A????
- Modified Mirrors....
- Harmonic vibrations
- Problems starting.
- ef squad
- Long shot: Anybody using mugen intake for dc2r in their EF w/ bseries swap?
- DC (Integ) radiator in a EF?
- crx is kool
- Need Springs ASAP!
- rev limit ?
- my std runs like shiet
- MIni-me help! Will not run at high rpms
- dragradials?
- B16A1 O2 sensors
- How long for springs to settle?
- Axle popped out while suspension install
- Need Help on Choice
- activating vtech?
- need help v-tech not working
- C.E.L Code 1 and O2 sensor mystery.
- 88 lca's
- will 92-3 discs work
- ex front brake swap, what lines do i use?
- Car won't start ... I ran over a fat ditch .. ?
- car died no restart plz help me
- what size are rear speakers in 91 crx?
- I got my new b16!!!
- car overheating quickly...radiator leaking a little but why the overheat so quickly!!!
- my new EF project
- new exhuast idea
- enter if u have a VIS Carbon FIber hood ASAP!!!!
- What aftermarket lca/rca you using?
- Nail in tire ?
- SIR seatbelt q's
- need help
- Underdrive/Lightweight pulley's worth it?
- horrible limp mode
- CEL code help
- who makes a red clutch??
- pic request of 94-00 integra gauge cluster in crx
- jdm zc cams in d16a1 head
- HELP! I have a '91 CRX HF that needs new brakes....
- CEL Code 15 Help!
- my observation with the short shifter...
- what kind of valve spring compressor for b16
- h-t scammers idea
- 91 civic sedan
- Who has the fastest EF? (1/4 or autoX)
- gsr is std hatch
- 92-95 console in 89 hatch?
- Odometer loosing miles in reverse??
- What kind of seats are these
- fuel pump install problems
- Going from CRX Si to EH Civic CX downgrade?
- New delivery
- B16a1 in CRX Starting issues with the p30? see insisde. . .
- Does 94-97 (?) Accord front lip fit EF's?
- Head Bolts
- MPFI swap...PM6 VS. PG7...worth the effort?
- 4 x 4.25??? wheel question
- Blown Fuse
- 91' CRX INTERIOR REBUILD and ENGINE SWAP
- My Horn Doesn't work!!!
- Still got a low idle. what else can i do?
- Need your help and suggestions....
- question: ef8 crx sir rad support
- How hard is it to install a full dash, wiring, h22 in a eg civic
- wtb: p08 intake manifold??
- bitch started!
- 1988 pic request
- B16 power CRX for sale or trade...
- Do I need my resistor box on this
- Jim Fab Crossmember
- Speedometer At 0!!!
- Brake rotor question
- Adding Harness bar to bolt in roll cage
- hesitation?
