View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Identifying mugen/spoon cams and retainers
- New Guy here...
- Am I totally and completely F(%&Ed???!
- 4040 proportioning valve connections
- Cluster Swap HELP!! with PICS
- 89 CRX Si Project/DD
- b16a problems
- CRX Headlight Options - What's Best, Prices, etc?
- Code 1 HATCH WTFFFFFF
- exhaust question
- Help with engine decisions F22,B16,B18???
- sluggish crusing at 2k -3.5k
- battery relocate ??'s
- SERIOUS alignment/camber issues. need help soon this is my DD!
- Cole89EF's Hatch Build (56k BAD) (Swapped and BOOST)
- crx bumper for a ef
- Engine stand bolts???
- need help itstaling 4 point harness
- shift linkage prob
- NEW CRX???
- boosted LS
- manual door locks
- question for wiring guru's....code 6
- b16a
- battery light randomly came on then car dies
- trubo kit info
- mini me question on timing
- 91 CRX Stolen Dallas TX Area
- how to bring in the wheels a little?
- EF Manuel Rack
- Da shift linkage
- ED9; PM7-X04 ECU won't work properly :(
- civic or integra???
- 90-91 CRX Si seats vs. Civic Si seats.
- fixed backup light problem after swap
- surging idle. please help
- Rally suspension
- RAYS LUGS on ef
- 91 civic no battery light when turn key to acces
- SHOULD THIS WORK...
- Keyless door handles.
- Lapbelt
- CEL
- impossible alternator nut, help plz!
- code 21......
- Quastions about a DOHC ZC in a 91 Si Hatch
- camshaft upgrade d16a6
- Seat Swap Question!!
- headlights wont work
- wat is this coming from
- wiring issues.....
- b16a need help
- 91 EF Sunroof, experts only please!! 2 questions, tube and fitment
- HF bumper supports question
- electrical prob
- Need more power,Help me with SOHC
- RT4WD
- Hatch, spare tire cover..
- Will an obd1 coil work in a obd0 dizzy?
- Pics Request: Championship White CRX w/ JDM FRONT END?
- Edm rear fog lights
- NOT A TECH Q!!!!!! but help plzzz
- what disc brakes will fit my EF?
- ELD PROBLEMS....need help..?
- HF to Si question
- Is this normal?
- 89 ef civic starting problem
- obd1 engines
- ek hatch exhaust on a ef hatch
- need new tank!
- dpfi to mpfi d15b vtec vacume lines pics
- crx wont start! Need help!!!
- 89 si tranny
- Question about D16A8
- MOVING NEED REGSTRATION AND INSPECTiON INFO FOR AZ
- quick dohc zc tranny question
- Swap issues
- mpfi question
- 90 Si Hatch w/B18C Project...
- fuel injector problem!
- dimmer woes
- [B]Seats for my 89'hatch.???[/B]
- B16a Ef
- console?
- d-series tranny unknown not stock for sure
- fan not kicking on..
- Refilling R134 freon question
- shifter bushing question.
- Problems
- Narrow replica and Full size radiator in CRX (pics)
- What rims?
- H22 EF vs. H22 EG
- WOuld 90 ef seats fit my 89 ef hatch?
- EF8 / EF9 radiator support
- crx si and eg hatch headers work
- Will injectors from a 1996 Civic DX work in a 1991 Civic DX?
- eg dash into ef??
- How tight to tighten lug nuts on wheels??
- '91 Civic Si Speedometer troubles
- Anybody Have CA BAR'ed Ef9 with B16A?
- b16 new dizzi help...?
- BUmper quest 89 civic hatch
- My ef9 pic
- HIGH Idle issues 2500 rpm
- Seat ideas and pics?
- CRX Wing question???
- 93-01 Integra Springs on 91 Civic
- PW-JDM 3point front strut bar fitmant issues.
- D15b7 on P06 in EF help me code scan
- high idle and timing belt noise
- NEED HELP INSRALLING BOSS KIT WITH THIN VERSION QUICK RELEAS
- alternator - PCM - Batt Wiring diagram needed
- Need advice on swap!!!
- Gauge Cluster issues
- HELp! check engine light turns on
- check out my ride!
- hARD time starting car ??? help
- CRX HF gets 118 mpg
- mini me help
- what fuse to disconnect to do compression test?
- mirrors
- mini me running on 3 cylinders
- Swaps whats your opinion?
- My new CRX project
- Importparts.com - 88-91 Civic/CRX EF w/ B-Series Shift Linkage
- ::help!!:: b16 crx not running!
- few random but important questions
- v-tec swap in crx
- axle? trans?(video)
- B16A swap: steering knuckles and hubs from a CRX DX
- crx sun roof
- b16a starter
- swapped my 88 civic cluster with 91.. trouble?
- Seal???
- 17" XXR Rims question?
- Wheels for my Civic
- underdash fuse box?
- selling my honda cive EF
- OBD-0 chipped???
- DC2 center colsole conv. How to get cig lighter to work?
- piggyback ecu?? recomendations?!
- dizzy question...
- Ef9 T-Bar
- Searched.. DC2 Steering wheel in an EF.
- lowering EE4 (civic wagon) chassis..
- crx body parts
- IHI TURBO ON MY EF?
- Painting rubber vinyls on my ef??Help
- What this CRX worth??
- swaps
- Buring oil after build
- fue pump relay buzzs, and code 20 WTF! HELP!
- 90 civic won't run
- d16a6 pistons vs d16z6 pistons
- d15b2 vs d16a6 flywheel, are they the same??
- 88 crx bolt on to 89 hatch.TRANSMISSION ?
- Help! Bolt Stripped!
- D16Y8 (I need dizzy pinout to use Y8 dizzy on P28)
- Post Ur EF hatch pics!!!
- timing issue!!!
- MPFI/OBD1 CRX Spark woes! Help me H-T (ICM Wire?)
- Shifter feel still sucks!
- 90 si dash harness help/diagram?
- brake causing bad idle
- d15b2 with hydro tranny, what clutch?
- roll cage in an ef
- sparkplugs damage pics from over advanced timing I thinK?
- Trans ?
- Wiring wiring wiring...lost
- ef9 build thread
- best B series engine block ?
- b and d series oil caps???
- BAD CLUTCH!????
- ef9 lips
- exhaust question for ef
- wiring fog lights on a crx????
- CRX with LS swap having a couple of issues
- body kit or stock with new paint?
- Overheating/Radiator Hose Leaking
- B16 EF WIERD IDLE. SEARCHED NO ANSWER
- ok guys i believe i understand it now let me know
- Just Purchased Oddessy Bat. And Relocator. few ???
- front tranny mount attached to crossmember.
- powersteering removal just loop?
- car doesnt start sometimes.
- Power source question
- How hard is it to install A/C into a B16 EF hatch?
- question about timing
- My 1991 Dx Build Thread
- mk3 supra seats in 91 dx hatchback
- I need a Pinout for an OBD0 PR3.
- Injector question
- DIY: Adding a OEM sway bar to your STD/DX hatchback
- conversion interest
- code 9, driving me nuts help
- D16A, wont take throttle at cold start, bog, backfire.
- help someone i been tracking nothing all day
- tube frame crx build
- had been driving car with fuel injectors wired wrong wtf?
- brake boosbter delete??
- b16 trans install problem
- Help B18 problems
- Help! Hatch dome light and cargo light.
- Dropping Tranny.....few questions
- 90 crx wiring question
- ef9 vs ef8
- d16z6 tranny choices
- camber kit for my ef
- 1990 honda civic build..
- IAC/ FITV gone?
- z6 into ef clutch/flywheel question
- door panels cracking
- Throttle cable problem??
- steel braid question
- dial tone like sound coming from air intake
- axles/ disc brakes
- Tired of this yet
- Civic Sway bar. What others will fit?
- gsr with type-r head!!!!!!!!!!!!
- obd0-obd1 problems
- d15 distributor
- ICU?
- electrical problem
- Clutch replacement
- Blowing exhaust through breather hole
- IACV
- no fuel
- OBD0 to OBD1 no start...no fuel?
- code 43 wat to check or fix?
- best d16 for turbo biuld
- I'm in a Leak...
- EF H22 Swap
- b20b tps adjustment specs please!
- 91 hatch having problems with b16
- What obd1 distributor fits b16a2?
- this is a eazy ?
- obd1 b16 idles high
- how do i install?
- I'm at a loss on my 90 CRX, HELP!!!!
- 91 Civic Stalling Problems (ls swapped)
- steering problems
- Brake upgrade on CRX Hf
- Intake Manifold for zc
- crx wasting alot of gas
- running rich
- how do i know if these racing seats would fit in my 88 civic?
- EF9 Swap Question
- odyssey battery trunk relocation wiring (for cold weather)
- EF Si sunroof/moonroof
- one piece headlights?
