View Full Version : Honda CRX / EF Civic (1988 - 1991)
- hydro tranny in ef
- Cheapest B18C'ed CRX hood option...
- replacing camshaft seals
- B16 Problems (PLZ Read)
- what kind of side skirts are these?
- anybody out there from south jersey (atlantic city) or baltimore???
- Is my feul pump going bad?????
- Sun Roof Rust. help me
- Front suspension swap????
- spun cam bearing? worth my time/work?
- Integra tranny + 86 CRX stock engine... can it fit>?
- clutch cable install??
- aftermarket calipers???????
- What would you do with 10k?
- Need 90 crx Climate control ASAP, its VERY cold getting colder and can't select HEAT
- Anyone running a b18c5 in a crx, looking for 1/4 info. Think you could hit mid 13's?
- Wheel Painting
- Mugen Door cap Install???
- full B16a swap for sale, complete CRX setup includes header, exhaust, intake, HCP mounts, etc
- del sol seats in a ef
- Best Fitting Header for B16 in CRX?
- can you use 92 civic struts FRONT?
- 2005 CRX!!!!!
- anybody rocking a side mount IC?
- Intake Issues....
- axles for b18a swap
- North East MPFI conv., make 70 bux
- CRX and Civic headlights. Differences?
- troubleshooting EACV...where does black/yellow wire go???
- 1990 civic 4dr dx
- 96 ex RAD!! Suggestions, what to look out for?
- still having a idle problem
- putting crx si cam in dx head
- b16 pw0 into crx dx......no start condition
- Y1 tranny leak
- ls swap ?'s
- Which OE Intake manifold swaps to a ZC?
- Question about Oil Guage
- How much would you pay for a 89 crx si drag car?
- I bought a crx!
- Electronic vss wiring help.....
- Milled head?
- My Car is using up alot of oil
- 2000 D16 into 89 civic??
- help with install
- Question on Wiring Vtec into an STD harness
- car making clank noise when moving...what could it be?
- Tein S-Tech's installed, my opinion inside...
- hi just registered (and pics)
- GM Synchromesh, yes or no? Vote please.
- Crx Pattern?
- i think i may hav a slight oil leak.... not sure, pic inside
- Got a Question considering a B18A
- wtf my car overheated and my heater dosnt work
- everytime I shift gears I hear a rattling noice from the from right side of the car.
- Obd1 injectors in obd0??
- s2000 antenna on a 89' CRX Si?
- CRX with B16 porential!!!?>????
- jdm ef 4 door tail lights
- Mini me setup and questions!! Good build? info please
- mpfi swap- cranks but no start.
- 88 main relay question
- Largest Wheel & Tire width on EF 88 Civic Hatch?
- SAFC II on a 90 D16Z6?
- crx with b16 without changing hubs
- Which bumper lights w/mugen front?
- ZC intermiate shaft in crx?
- What dizzy do i need?!?!
- LS Rods in D series ... will it work ?
- 90 CX - Which cluster fit ?
- 89 accord Lxi FR struts for EF???!!!
- who knows????????
- b18a?
- Just replaced my PGM-FI Main Relay
- wiring diagram for a b16a2 ecu???
- man, b16 ecu's from dealers are alot
- swapping ecu's
- what do u think about this deal?
- Pics. of my car and turbo setup.
- New here
- Different between D15B7 and D15B2
- Camber kits...
- CRX Help
- White 5Zigen 17x7 --- 650$ comme neuf
- Power to Manual steering... anyone try it?
- interior advice (to those who gut)
- Broken TPS...does it matter?
- Injector Q's
- size of b16a obd1 throttle body? mm
- Where do I buy ZC intermediate shafts?
- need a suspension opinion fast
- What year comes with this?
- How much should Oem Bigger Brake upgrade cost
- tach problem...possible ground?
- taillight questions
- crx
- check my setup plz.. will it work?
- Power Steering
- axle woes!!
- where can i find an underhood vaccum line map/emissions sticker??
- how do i check my EACV sensor for wire breaks??
- fan heat woes continued. found out my problem, now how to fix it?
- How to convert PM7 ECU from Auto to manual
- 88 hf doors on my 88 crx si
- throttle cable?
- Question about EF tail lights
- Question about an 89 civic hatch standard
- Type R master cylindar in crx?
- VTEC Point on first gen b16 heads? b16 head questions?
- obd-0 to 0bd-1 help!
- itbs on dohc zc
- jdm d15B swap into CRX auto anyone?
- 4 door lovers
- 85 Civic DX questions
- zc help needed
- What mounts can i use? b18a in 91 dx hatch
- Availability of D16a6 motors?
- Compression with a d16y7 block and z6 head?!
- recomendation...
- MUGEN FAN SWITCH
- Can someone
- Is this true...DX and SI have the same automatic trannies?
- a zc ? that might make u laugh
- mugen radiator cap
- eg sausage intake fit in crx?
- Just got my JDM B16A From Osaka....Good news! Check it out
- Hed Stud Question. Help Please!!!
- Question for na_crix
- '90-'91 CRX dash into '89?
- My sunroof won't close on one side!?! (Pics)
- CRX side panels on a hb
- URGENT!!! need Si rim
- chatter coming from under the hood?
- vtec
- anything besides a b16?
- What plugs wires and rotor for 1st gen B16A?
- JRSC'ed B18C w/ auto LS tranny CRX questions...
- best place to get a mugen style kit for a decent price
- HELP! I need to get off my momo shift knob...
- 88 rear konis in my 90?
- Light weight hatch for crx
- cltuch! mb crossmember
- Buying some JIC coilovers. What spring rates are best for daily and autox.
- CRX ZC Swap
- phantom oil loss
- WTF, got new hood, NO LATCH
- Anyone know where to get syncros for b series trannys?
- Anyone using Zdyne?
- Y1 tranny question
- Will a clutch used with a cable tranny work with a hydro tranny?
- coil-overs question
- B20Z2 in my Rex done!! Small Review n Question
- bright lights/car dies
- does AC bower/underdash components affect my heating?? what i can i remove??
- d15b vtec or sohc zc for 1990 4wd wagon
- Random non starting 1990 si
- ZC DOHC valve stem seals?
- 89 Crx Si HELP!!
- crx starter still crazy?
- Need advice on parts for 90 CRX Si
- DX to Si swap question...why not OBD1 injectors?
- ideling problems
- coolant problem
- 1st gen crx dizzy..
- Just picked up a b17,A couple og Q's for you guys
- J1 Transmission exploded, any one know why?
- Best exhaust for CRX?
- Auto tranny problem...could it still be fixed?
- throttle bodies , can i use my own ?
- *UPDATE* Is this worth keeping and fixing?
- oil pressure test help
- Crx motor mounts
- d16a6 in a hf, problem
- Tranny Question
- kinda OT but..question about welders
- hey guys....more mpfi swap problems...and integra to civic throttle body compatability
- SIR1 injecotrs work in stock HF?
- Happy Holloween/Pumpkin smash
- sohc vtec or dohc zc non vtec in honda crx 91 si. will turbo it latter
- Drop-in EF/ED fuel pump?
- A few small things I need help with?
- What motor mount kit do you recomend for a B series motor in a CRX?
- 95 civic tranny in my crx?
- little confused on final drives.
- transaxle bolt question
- how to convert ecu pm5 auto to manual????????
- put zc in my crx now idle is up and down ,up and down. why?
- Do eg axles fit into our EF?
- D15b wiring
- CRX cam gears with ZC swap
- mini-me timing advise
- 19 blinks from the pm5?
- D16Y8 Question
- camshaft seal?
- need help
- JDM CLUSTER
- Thinking of swapping a b18a into 89 crx hf.....(is wiring hard?)
- Camber kit opions
- I need to know where I can get a b20 turbo kit without the turbo
- Hasport rear crossmember mount
- buzzing muffler??
- i need a knock sensor asap
- cost of swaping....
- problem w/ LS conversion in 91 hatch
- 4speed to 5speed conversion in 88 hatch base model???
- Fuel Injection Prob
- p28 ecu
- Shift Stabilizer for B16A/S1 and Bushings
- question about "flex" in the exhaust system
- SHORT-SHIFTER...which one do you recomend:need ASAP!!!
- 4dr ex, lx, dx?
- d series auto to manual...any welding/new brackets required?
- what is this?? ac component??
- Anyone in Maine, NH, or Mass with a vtec crx?
- Energy Suspension short shifter bushing... diagram
- help! car misfires now above 5k rpms
- MPFI Problem
- Heads up CRX guys and gals... Doing a disk brake swap on your CRX?
- Ist gen LSD for B16 in Las Vegas?
- how do you take out the inside of a crx power mirror?
- what struts for a gsr susp.on a 88 crx
- dohc zc tranny in to crx 91 si please help
- 89 sohc ZC struggling at low RPMs
- anybody know who makes this hood?
- how to tell a si tranny
- what the heck is that donkey
- Web cams
- ITR rear sway bar
- 88-91 EF civic CRX spoon style real carbon fiber mirrors
- Watch out for this Kitty....and laugh a little too!
- diff. in front ends
- NEW
- Injector Order
- Turbo Dirty rex build up link
- code 4,16,17,43 engine stutter at 5k rpms HELP!!!!
- How do I go about puttin a H22 in a crx?
- Crx starter gone crazy????
- driver's side mount, putting 98 d series into 91 EF hatch, which mount? how?
- 92-95 EX Flywheel fit 89 CRX Si Tranny?
- replaced everything.....still smokes
- 84-87 pocket rocket
- 300 a good deal for a shell?
- what is the best camshaft
- Engine swap question...
- d16z6 cam
- quick O2 sensor question... threading
- Compression
- HELP! pressed in clutch cable and heard a snap!....
- water damage.....help
- STD suspension help (H&R Race springs)
