View Full Version : Honda CRX / EF Civic (1988 - 1991)
- High nox readings need input
- ef9 parts ? where can i get some
- how hard is it to go from carbed to fuel injected
- quick resister box question.
- need pics please
- where can i buy some sun visors?
- dpfi to mpfi wiring question
- Code 20 ELD problem help PLEASE!
- Quick question 4 door sunroof?
- how do u post a picture?
- which gasket to order
- Koni Reds: Stiff enough?
- skunk2 exhaust question
- pre obd to obd 1 help
- weird CEL issue
- What axels/hubs/knuckles to use for SI motor in HF?
- can i cut this plug off? a/c i think
- where to put the dent? b swap
- Tranny Swap...need advise
- 4-wire o2 sensor clearence (srched!!)
- Headlight Bulb Brand Recommendation
- squeeking sound
- Confused about Axles...
- Best Intake Manifold for 91 CRX SI?
- engine went bye-bye
- How to go from obd0 to obd1 on a 91 CRX SI??
- Temp needle acting funny on my stock 90 crx dx (help needed)
- Annoying Door Buzzer (Passenger Side)
- need some advice
- rt1 here, repairing the Daily Driver
- extra injectors on d15b2 (poor man
- Is the HF clutch the same as the SI
- trans
- What the Best Motor swap????
- ACT clutch
- intake manifold gasket
- 89 Hatch?????????????????
- Zc single bulb headlights
- anybody near San Bernardino i need help
- Camber kit for CRX
- big injectors on stock ecu?
- Question about throttle problem.
- is the door light switch positive or negative on a 1990 crx
- Lets See Some CRX's! CRX ONLY pic thread!!
- dohc zc cams
- pic request...
- OBD1 B16A Emissions
- Swap questions, please help.
- jdm ef9 front bumper
- o2 code 1(stupid question)
- DIY fiberglass front end for 88-89 CRX, questions?
- Weird tranny problem - help!
- zc axles
- NEW to the OLD school...
- 89 CIVCI SI QUESTION
- code 16
- Locking Hood Pins
- Help me identify this part to identify this transmission
- rear disk brakes
- removing my ac help!!!!!
- pedal assembly
- Wheres your camber?
- mounting weapon R harnesses
- dx to mpfi swap !!! help !!!
- B series mounts and alt in my EF...brackets missing?
- Fixing Chips on your Carbon Fiber hood
- CRX firewall same as Civic?
- Neuspeed Springs
- zc help needed here, please help
- sea foam
- How do i flush the gas tank?
- AUTO POWER ENTERPRISE
- horse power modi
- DOHC ZC 1.6L What parts do I need to upgrade.
- how do you connect a apexi vtec controller?
- Oil in plugs
- Which Computer for mini me?
- tractionbars
- Need HELP!
- Anyone Turbo with DOHC ZC tranny w/factory LSD
- Code 13
- thinking about wagovan drivetrain in crx
- All the guages going nuts, lose ground somewhere but where?
- cars hard to put in gear, sometimes....
- can i make dxharness into an si if so HOW?????
- Brake upgrade, can't remember something...
- D-Series Build-up
- SHiFTer
- zc half shaft on hf transmission?? Will fit?/bolt?
- need help !.... wheels
- no time to search, im at work...does it matter what year ARP head studs are for an LS?
- Awsome find in spokane!!!!!!!!!!
- drive shaft hub nut?
- need helps, hints to take out some bolts
- Head problems
- d15b vs d16z6 vs d16a6..
- f1 racing/lite flywheel
- d15b unique or myth?
- Any pics of dark blue civic hatches???
- Ok probly have heard this before.....
- Confused on what kind of engine I have... Help!!
- O2 Sensor Wiring Problem
- How to make speedometer work with a hydrolic tranny in CRX???
- 88 Four Door Civic
- Does a Z6 dizzy fit a D15B JDM SOHC VTEC motor??
- interior paint??
- oem style carbon fiber sunroof panel
- Jonny_Blacks car is back at it again! (LOTS of pics!)
- clutch start question
- rotor size and brackets?
- steering loose?
- Fuel Level Sending Unit Ohms
- need help!!!
- Gas tank
- ef sedan rear seat
- b20 b18 b16 help. please
- crx shakin
- Pics of MPFI harness
- Need some "TRANNY/TURBO" answers
- Dohc zc exhaust ports
- codes 7 10 and 16
- '91 honda crx hf model
- 4th cylinder not firing
- what type of head do i have?
- Crx won't start
- What do you guys use to clean out the engine.
- A big VTEC question!!!
- any one know what ecu came with the zc in the 92-95 civics?
- Okay to seal up window gutters?
- pr4 obd1
- HHEELLPPP!!!!!!!! B swap'd ef hatch
- ecu
- b16a
- Tranny Wont shift
- What are the timing marks on a 92 ZC
- 91 civic all wheel drive
- new motor no temp
- smog cat help
- D16 MINI ME HELPP
- D16z6 plug wiring?? colors?
- D16z6 into ef, running but with problems!!!
- new injectors and fpr car won't start
- Changing a 91 HF CRX Motor to a 91 SI Motor What is needed?
- D15Z1 CRX
- new battery, wont start, code 6
- Smoke coming from valve cover
- Preping Car for Paint
- Si distributor on a 89 dx.
- Anyplace to get an HF bumper support?
- 91HB B16A no spark/main relay clicks rapidly
- Help with a diagnostic..
- Brown plug on thermostat???
- fuel pump HELP HELP HELP
- timing dohc zc
- Trying to put an f20b in my ef
- anybody got valve spring specs on a obd0 sohc zc?
- 88 suspension on 91 crx?
- Carbon Fiber Hood = Higher Chance of Car getting Jacked?
- scratch, paint, ding, dent protection?
- AC lines - will integra ones fit?
- EACV Interchangeable?
- 195/45/15 or 205/50/15 on Fatty Fives?
- d16z6 vs d15b vtec
- goin turbo
- Throwing some codes
- header question
- ECU Code... HELP!
- EF Wagon AWD system into a EF sedan??
- When going turbo?? Whats needed for fuel management?? Ecu,resistor box,injectors??
- 89 honda DX
- wats better a poor man type R or a lsvtec
- What vent-visors fit a Civic Wagon?
- keep crx and swap, or get DA?
- EG/DC2 Console in EF?
- SiR Bumpers
- TPS SENSOR/IACV VALVE
- Innter tie rod / Rack end bushing problem?
- b16b vs b16a rocker arm ratio???
- clutch question
- fuel problem!!!!
- Need new crx clutch
- New to honda... Real quick and probably simple question?
- car paint color
- My First Big Build *85mm B16a*
- Si seat brackets
- Need Help..88 CRX Si
- obd1 d16z6 91 hatch
- Some rattling noise inside my car
- just replaced motor no fuel
- Questions about going from zc to d16z6??? having problems
- CRX Part Number ???
- Is anyone out ther smogged a dohc zc in a crx in cali before?
- JDM D15b aftermarket parts
- bad vibration
- please help me !!!!????
- D15B2 - D16A6 Swap Harness Questions
- PLEASE HELP!! 91 CIVIC HATCHBACK DX QUESTIONS
- need belt mouldings
- DA brake hub and knuckles
- got a console, have a question
- What axels do I need for a b series in a crx?
- RODS PLZZ HELP
- obd-0 converted into obd-1...i have a ?
- Opinions on which turbo set up to go with?? Go ahead and bash me I'm expecting it!!
- cold start idle troubles (afected more by weather)
- anyone have pics of a skunk2 dual bend short and knob in a crx?
- gas
- tell what you think about this ???
- Quickk question...
- zc
- NEED HELP on RHD CRX axle/cv boot...
- Help needed
- starter fuse
- clutch
- Maintenance/upgrading for severe conditions
- sohc hydro tranny in ef is it possible
- tbi to port injection.
- shift linkage question will take a yes or no answer
- axles?
- EF hatch problems?
- Problem (Turbo)
- replace engine or have it rebuilt???
- swap
- is a cable and hydraulic tranny starter are the same on a b-series?
- crx oem rear bumper
- SI interior in a DX few Q's
- EF suspension
- ef b16 vtec diagram need help
- z6 vs y8 head
- which header
- spot weld core support question
- arp head bolts
- HELP my blower motor dosent work
- Is my O2 sensor bad?
- 91 oem fogs on a 89 hatch??
- CRX obd1 o2 sesnor?
- seatbelts
- transmission seal kit
- broken tach wire
- It's fabbing time! Need your help... EF Hatch Roll-bar pics?
- ZC problems
- DA brake hubs and knuckles
- crx rear bumper
- D16A6 Distributor Question
- eacv / iac ? from crx si manifold to 92-95 d16z6 manifold ?
- bad p28?
- main relay
- Rear Defroster - Hacked 4 Wires, help me get it working. Canadian Winter!!!
- My new ef
- D16A6 vs 1.6L DOHC ZC
