1990 Civic w/ D16Z6 - alternator replacement
Old Sep 27, 2015 | 01:06 PM
biff206's Avatar
Default 1990 Civic w/ D16Z6 - alternator replacement
Hey guys, I have a 1990 hatchback with a D16Z6. The voltage regulator died. Today I got started on replacing the alternator but I ran into a problem. The alternator is loose but I can't figure out how to get it out. When I had an EG I could pull it from the top, but with the EF there are many things in the way. Same with pulling it from the bottom. I was trying to do this without taking apart a lot of other things. But it's looking like that will be the case. Any advice? Thanks!
Old Sep 27, 2015 | 01:29 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: 1990 Civic w/ D16Z6 - alternator replacement
I pulled one from the bottom on my 89 Si before, takes some effort but doable. May try removing the Alternator bracket though.
Old Sep 27, 2015 | 02:25 PM
Sikocivic's Avatar
If I remember(it's been long time) you drop it down on the axle and slide it toward the wheel. Then it will lift over the axle and come out.
Old Sep 27, 2015 | 05:34 PM
FOMULA91's Avatar
Removing the lower alternator bracket will definitely help.
Old Sep 27, 2015 | 11:08 PM
biff206's Avatar
Alright thanks for the input, guys. I'll be giving it another go in the morning.
Old Sep 29, 2015 | 11:17 AM
CRXyes's Avatar
I remember doing this a while ago. I removed the driver's side engine mount and jacked the engine up a little bit which helped tremendously.
Which was better than my second option (removing intake manifold). Not as attractive...
Old Sep 29, 2015 | 12:30 PM
biff206's Avatar
^ I tried that. Jacked it way up. Still couldn't maneuver it out. Today I'm going to pull the driver side CV. Should be easy after that. I was hoping I wouldn't have to do something that drastic. The air intake crossed my mind too but I really really did not want to do that. I think the axle is the lesser of the evils. #engineswapproblems haha
Old Sep 29, 2015 | 01:54 PM
v4lu3s's Avatar
RTFM
i drop it out the bottom on all b and d series. never saw how you could get it out the top at all..
mosagalzeta
Jul 20, 2015 02:31 PM
MR_Se7en
Mar 25, 2008 10:04 AM
PnkRokCountryboy
Aug 1, 2006 12:06 PM
jdmCivic925
Aug 24, 2004 11:55 AM
Street Racer
Mar 15, 2002 11:43 AM
