View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1984 honda crx.
- Alternator Issue?
- What exhaust system should I get for 1990 ef sedan?
- B18C Innovative billet hydro mounts and hood wont close properly
- CEL issues: code 16 fuel injector circuit open or malfunctioning
- Mugen Pro.2 kit install
- having steering problems b16 ef
- 88-89 sedan headlight question
- Throttle sticking
- 88 rhd ef gas related problems
- Trailing arm Swap... W H Y??? crx si to DA
- CRX (RHD) Clutch cabloe
- Where to find a water outlet housing?? Part discountinued
- Hush Hydro Conversion HELP NEEDED ASAP - VIDEO INCLUDED
- JDM engines
- Honda CRX Fuel Tank Removal Write Up (With Pictures)
- Aem cold air with swap
- Rywire obd0-obd1 conversion package unused vtec pressure switch plug
- ef hatch b18 swapped cable trans issues ?
- Rekey door lock worth it?
- Is this thermostat casing okay to use?
- need help on project KRX
- vtec wiring issues
- major issue, engine cut out while driving! please help!
- EF sedan lowering questions
- Sedan front brake upgrade
- crx thermostat temp? d16a6
- Del Sol Cluster [EF Civic]
- First project :D
- Low RPM/idle issue
- Z6 swap and fan not working
- 91' Hatch HELP
- Crazy overheating problem
- 94 ZC hatch starter/electrical problem please help!
- Dpfi to Mpfi ecu wires dont match up
- 1988 Civic Speedo
- Most effective kill switch? Security?
- very specific cooling fan switch question
- need help asap ef horn
- 1991 Civic DX horn relay location
- 91 si wont pass no visual o2
- Head gasket kit for DOHC
- 1991 Civic Si Power Steering
- simple sedan
- Momo Steering Wheel Horn Connection?
- where can i find this gasket? (pic included) DC HHC5002 4-2-1
- Can't find a part for my ef
- DPFI Coolant leak
- crx si running cold all the time
- DPFI to MPFI
- What kind of gasket will this use? Picture included
- damn b16a2 cant run right
- My '91 CRX Si
- b16a swap questions
- Making a reliable car
- wiring harness for a b16a obd1
- What else do I need for the stock intake?
- 91 hatch rear side windows removal
- CRX HF issues with rpm check engine and catalytic question.
- 88 civic 1.5 running rough
- Corner lights and tailights not working
- special gasket for DC header/downpipe?
- Does anyone know if these upper control arms are any good
- B18A1 Swap into my 91 DX; Wiring Questions
- upper radiator hose is swelling!
- What is causing this? Pic inside.
- Dome Light Stays On
- 1988 HF CRX o2 sensor wire
- Long distance Civic Wagon transport
- AC problems again
- 91 si b18b swap how to wire?
- Sawybar endlink; OEM vs aftermarket
- Newbie: Help removing a 1989 EF Civic Si Front Bumper
- Horrible idle and weird throttle issue.
- no hazards no flashers no speedometer no odometer 1988 civic
- Need torque specs for B16A1
- wiring issue... kill mahself
- problem bleeding brakes.
- 89 crx d16
- Installing rear sway bar and have a quick question
- Put manual transmission into gear outside of car
- b16 ef in limp mode with no cel
- The little red rice ball
- CRX A/C questions
- Pegao ~ '89 hatch project
- CRX taillight differences?
- Reverse light wire color for B18C-R in 88 SI
- d15b2 falt code 16
- Battery negative ground wire.
- Fixed Code 14 issue
- starting problems
- Automatic transmission questions
- 1991 DX Ignition Issues // HELP
- ALREADY REPLACED MAIN RELAY NO FUEL NO SPARK
- Pictures of my omnipower tach
- climate control lights do not turn on
- fumes coming from valve cover breathing tube
- Dashboard alternatives?
- side hatch window removal
- Door window hatchback
- The unicorn, Whited's JDM SiR
- Why OBD1 and stuffs
- idle problems with d15b2
- dang, temperature and fueling problems
- 1990 honda Civic DX sedan
- After MPFI swap CEL Code 4.
- How hard is it to swap a dash harness in a CRX?
- Single Din in an EF hatch?
- have two rare headcodes???
- speedfactory drag radiator work with 3" turbo up-pipe?
- INLINE FUEL PUMP
- ALB & Intrac/4WD error codes
- identify plug and ignition problem
- Lowering Springs
- Crx d15b to b18
- CV axle opinions
- clutch adjustment problems; might be aftermarket clutch?
- valve ajustment screws not turning
- 1989 CRX Swap
- Coilover Question!
- Endless Idle Surging once Warm - VIDEO*
- Once stolen. Need it back together.
- pm7-b020 ecu,need help.
- New wheel issues
- Jim Fab Traction Bar Oil Pan Clearance Issue.
- dpfi to mpfi...91 crx dx-90 b18a1
- PM3-7 Head on D15B2 block. Moving forwards.
- Budget strut/spring setup for 89 si hatch
- Coolant temp sensor
- Best stage 1 clutch kit
- car doesn't start....
- Electrical short
- Capacity for 88 CRX Automatic Transmission
- d15b rev trouble
- B16 fitv question
- 91 hatch D16z6 project failure and mess, HELP!
- Diagnosing a bad ecu?
- 91 civic hatchback AWD
- d15b2/7 difficult start, runs, stalls.(with video)
- rust help
- Killswitch/Theft
- front tranny mount, bseries swap
- MPFI wiring wtf
- d16a6 mpfi intake manifold
- Will any D16A6 engine work in an RT wagon?
- Odd electrical issues
- everyone is feeling
- and potentially require
- The Life History of my First Car
- head gasket failed soon after rebuild
- stock ef tranny cable for b series
- D15B2 turbo + z6 head build help
- new hubs for 91 ex knuckles
- Is an 89 crx dx obd0 1 or 2
- new spark plugs are black alreay
- D15 Transmission questions
- MAP sensor - D15B2 engine
- civic 91 broken timing belt
- 1990 ef hatch zc motor
- Crank rubbing Radius arm
- Not your common CRX No Start problem
- Genuine Spoon Sports ECU
- Turboing or building a D15B2?
- When is radiator fan supposed to kick on? (D15B2)
- how do i turn off the key chime?
- innovative linkage has play at the roll pin end
- No spark
- D16Z5 distributor cap
- 90' CRX door mounted seat belt making sounds *pic*
- No fuel in fuel rail?!
- Auto to manual conversion
- turning off the seat belt light on my gauges
- chargespeed wing for under 50$
- What the hell is going on!
- 92 b18a into 91crx ecu issues
- 90 CRX Si Drivers Window Regulator
- insight on obd0 b16
- Car overheats at high rpm
- ef w/ d12b1 engine?
- Dizzy mystery
- Engine swap?
- 1.5 91 CRX b18a1 swap
- rear garnish blocked off
- Making sense of ECU's, OBD's, Dizzy's, and Jumpers
- EF build or 240 Build?
- 90civic wont start
- ls seats
- head gasket set?
- jdm ek9 parkpole wire it up ?
- Axles for b series ef
- Amber cluster
- Ef issue
- dpfi to mpfi swap
- 91 Civic Bogging Low RPM and Dying at Idle
- Lots of issues 89 hatch
- b18a1 timing belt replacement question
- timing issues
- EF SEDAN CAT BACK
- Looking for cheap but semi-reliable suspension
- z6 engine harness in a ef?!
- TPS grounding issue
- ec7 ef wrong year?
- d16a6 no start bafflement
- Check Engine light not on, but reading
- jdm sir seats in 91 si
- I don't know what chassis my CRX it is and my VIN is wrong???
- b18 ls/vtec build help,
- need an upgraded alternator. how to?
- motor mount 88 civic wagon
- Need injector advice asap!
- O ring on oil pump, the FMS confuses me
- Swapping exhaust manifold. Should I go with headers?
- B16a wiring problems
- Turn signal relay in ee2 wagon?
- D15B2 vs JDM D15B non vtec
- Anyone used this suspension setup before?
- Civic HB From Mexico
- b16a2 motor in ef questions
- CRX transmission is stuck in second
- D16Z6 swap, but injectors not working
- 91 EF Sedan Won't Start
- 1988 marker light question
- Oil leak front drivers side
- 90 civic hatchback won't pass 73 mph
- Walbro 400lph or 460lph intank pump in crx ????
- D15B2 to D15B7 multiport--EACV hookup?!?!?
- What other fuel pumps can cross reference with a 89 Honda CRX si fuel pump
- Need help!! D16z6 swap in ef sedan lx
- 89 hatch won't start!!! Help!
- Can't get car to rev up after engine swap
- 1990 CRX ENGINE SWAP OR REBUILD????
- EG suspension into CRX
- After market brake booster problem
- 1991 Honda Civic DX Sedan ED3
- ECU wiring 1988 Civic DX with B18A
- 89 CRX wiring issue
- Limits of the CRX chassis on big bhp setups?
- Crx Fuel Cell Questions??
- wiper motor colors
- what are these two plugs?
- how canister works ?
- 89 civic si sunroof help!
- EF Civic Battery Grounding Problem Need help
- What would you do?
- My never ending build thread. Ground up restoration
- Front vibration on right turns
- Rear seat folding button broken.
- ITR throttle body on CRX B16a
- ECU code 15
