View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Feeler Gauge for Valve adjustment
- clutch and flywheel issues
- ball joint.
- CRX Idle problems with B16 w type r intake manifold/throttle body
- might be gettin a shortbusCRX
- Main relay?
- wing raise
- Project crx red and yellow
- Rack End Bushing - installation
- 88 CRX Si clutch install hours
- obd0 and obd1 computer question
- Just baught a crx si.. Suspension problems galore
- Hasport H Series Mounts Now Out!!!
- Wings West Mugen Kit experts...which of these is the one?
- integra ecu in SI crx
- tokico adjustables for 88 crx
- who has hasport's shift linkage
- header
- axle seals
- rocker panel rot, wont pass inspection
- ECU Gurus: Will a PNP ECU work with a d15z1?
- what makes more power
- where to buy rear hatch and rear side windows for 89 crx? "lexan"
- CRX weight
- What do i need for rear disc brake swap for 89 crx hf?
- blower motor not working
- Exhaust question
- 88 to 89 seat mounting different????
- ef engine swap
- Hi Everyone' :D
- i have a dumb question
- Weight reduction, what more can I take off?
- b16a1 sWaP into 91 crx,need to know what i'll need to buy before swap is complete
- How to replace clutch on an LS in an EF?
- CRX Wiring Gurus Needed!!!
- z6 swap using p28
- need JDM 91 ef parts (4 door)
- Put a new alternator in today...
- Alternator or ???? on my 89 Si
- firing order question ...need to know before tmw
- need help with rust behind gas fill door
- Anyone Have A CRX Blueprint Drawing Like This?
- Will a 90 crx si dash fit in a 90 civic dx 4dr?
- Headgasket worth replacing on a D15B2?
- zcrx question need help
- Woke up with a wet coin tray!!!
- about 89 SI rear brakes ?
- problems
- OBD0 ENGINE MANAGEMENT OPTIONS FOR BOOST
- newbie ( exhaust question)
- dual catback exhaust
- which bearing is it
- Crx B16 0bd0 w/type r intake mani what fuel rail/injectors?
- Driver Side mount installation help!
- Throwout bearing
- h22 question
- Why are some B motor crx's slow?
- Annoying problem
- Which Exedy clutch for turbo? found a pretty good deal
- heater control head
- ENGINE DIFFERENCE
- STOLEN 90 CRX Milwaukee WI yellow cf hood
- grinding or squeaking noise from clutch pedal in my 2004 civic LX
- OBD1 swap
- car doesnt hold idle
- Tons of EF parts for sale. Chicago land area.
- D-Series OEM build up in my CRX, need opinions!
- crx and civic si seats inerchangeable
- fmu???
- Can you test compression without the engine being installed?
- 99-00 SIR Cluster in a 90-91 CRX
- B16A high flow cat?
- Two problems with my hatch, one thread!
- 88 CRX Si Stalled, Wont Start, Need Help
- oil in spark plugs/headgasket???
- shift linkage, clutch, or shift fork?
- mini-me specifics.
- help installing shift light only...
- Scraping the head gasket poo off (searched already)
- SOHC ZC PISTON RINGS???
- 90 Hatch Headlight Stopped Working
- AC noice
- :crook: HELP NEED TO FIND!!!
- Dropping my sedan???
- Anyone rockin a cage in their esedan?
- oil pressure gauge question
- Axle spins after timing belt replaced?
- It keeps beeping...
- after b16 swap found plug?
- password jdm cross member?
- MINI-ME EXPERTS... PLEASE HELP!!!!
- new skunk2 suspension
- Iwant to know if the header of a d16a2 fit on a b16a1 ?
- Where did you get your axles?
- JDM D16 ecu--OBD1-- probs
- Rear window ALWAYS foggy?
- Slow JDM B20???HELP
- 88 CRX Si seat dilema...
- Help....EF sedan sometimes has no heat....what could it be????
- What and where the heck is the ACG(s) fuse???
- Lots of obd0 parts for sale... trying to these parts where they need to be
- __ Noob __ First post --- Car runs but doesn't move too well!??!
- Captain's Log!
- tps sensor
- dpfi-mpfi..wiring
- NORCAL EF SQUAD ANYONE?
- Oil pressure switch dimensions, B16A1
- crx b16 wont start
- HELP! FUEL PUMP NOT PRIMING!
- Pacman's k20 crx racing vid?
- DA INTEGRA KNUCKLES ON A B16A REX W/YS1
- I NEED THIS!! (RHD PARTS)
- Integra Spindle Question
- Help on my friends CRX
- B16 single Cam?
- Civic Hatch Water Leak In Trunk
- mounting fuse box???
- 15b or d16z6 camshaft
- SOHC zc swap and vtec head?
- The boucy tach is back
- 88 CRX Question HELP Please
- EF9 Front End Issues (Missing Key Stone)
- Using 90-93 Integra driver side mount in B-series swapped EF?
- >>front end conversion<<
- CRX seatbelt conversion
- Fuel pressure wount drop... searched
- Gauge assembly wiring- 91 std hatch
- D16a6 rebuild for turbo setup questions *searched*
- need help
- head gasket help...
- ECU code problems
- Help w/ Suspension
- F**king siR - Multiple Cock Ups- Help Please!
- DA Bushings?
- Cutout diameter on these foglights
- Something wierd on my CRX
- ZC motor vs B18 Motor
- Stock vs. Aftermarket
- Back tail-light question
- Spool Valve Pressure
- EF1 question
- MY ZC MINI-ME..... PLEASE HELP!!!!
- DOHC ZC backfires in the intake
- ???88 civic revs by itself???
- *Peeps with 89 teg lips*
- Honda Civic 94 EJ1 4 Sale!!!!!!!
- vin numbers of my car
- Somebody BUY this quick!!!!
- Mudgaurds
- is there a obd1 pm6??
- CRX with new air intake? which to run?
- RRR ITB's worth IT!!!!!!
- jog my memory: Fuse box in engine compartment
- B18C1/4 SWAP Options...
- 89 dx gauge cluster
- LS tranny or B16 tranny for boost...Which is better
- dpfi to mpfi swap
- Adj timing on ef with B16
- questions about jdm d15 and d16
- Broken Switch = Death
- where to get a mugen cover for your b16
- integra ecu
- Just purchased JRSC, have a few quick questions.
- car almost dies
- 1.5 and 1.6 engine compatability
- 88 crx pressure plate bolt up to a obd1 d series flywheel?
- im a new guy with a 88 ef
- The most anorexic EF on H-T
- Brake light keeps blowing...any ideas?
- integra dashboard w/center console, etc. on crx....wirin probems
- Lower ball joint, front. 56k, go learn german.
- knock sensor Q?
- Si-r Cluster Question?
- Tips and Advice on ef with zc engine
- cold start sensor?
- Is this CRX worth the time or cash?
- CRX SIR hood question??
- d16y7
- b18b crx
- carrrrpet
- Koni Yellow Shocks ??
- front end viberates like no OTHER
- side window deflecors- crx
- start button
- clutch 88/89/90-91
- EF Sedan?
- any body heard of or using this clutch
- OBD O B16 swap in '90 DX throwing code 15, no spark. conv. from OBD 1
- PM7 Auto to manual
- EF luck
- obx exhaust
- Car is missing
- 1989 Honda CRX Hf Just starting out
- question about exhaust
- AN-R header clearance
- Hepl! RPM bouncing up and down
- weight reduction
- Supercharger CRX VTEC
- engine cooling problem
- 91 teg steering in a 89 CRX
- look at my traction bars
- JDM Parts !
- I need new wheels... Help me choose
- Project: CRX LS/Turbo Swap
- XM radio question.
- What clutch do I use for a 21 tooth input shaft?
- ef curb weights?
- Close to death
- Master cylinder
- help me with my car please!
- What else besides bad syncros can cause grinds?
- Something Bad Happened!!!!!!
- what model civic do i have
- help with swap
- ok so the rear bumper reinforcement is next to impossible to find, any Ideas
- DX seats VS. Si seats
- ls /vtec 1/4 mile ?
- ef splash guards?
- what is a mini me?
- d16a6 head
- wuts the site for these? (searched)
- CRX Roll Cages
- Slammedcivicsi's winter Project ZC 88 Hatch **PICS**
- Who all is rocking the Mugen style wing on their REX?
- problem with crx. wont start.
- Starter question
- Which headers for H22 swap
- The hot new swap for all you DPFIers!!
- LS/VTEC
- tranny question
- wiring main relay
- Honing?
- 88 DA parts car. What parts?
- CRX brake lockup, need help
- loooking for eg6 hb rear speaker set
- Compatible parts
- Steering wheel hub, fit all Honda's?
- already searched...alot!!! but i need a little bit help
- can a d16 crx beat a celica gt
- beau gotti project log
- head gasket
- CRX interior weight
- just picked up another crx
- zc questions about swap to hf
- Dream EF civic
- ZC swap to HF...sorry for the long post
- vtec oil pressure switch help
- 88-91 Civic/Crx Dx(Dpfi)to Si(Mpfi) wiring service avaliable in So Cal
- New to EF's, quick question
- what tools do i need to remove interior harness???
