View Full Version : Honda CRX / EF Civic (1988 - 1991)
- idle to low!!!!!!!
- My EF'n Braking Problems. Your help is needed
- What engines will fit in my car?
- b16a in a b18c?
- climate control trouble
- HELP!!!!!!
- problems to look out for b16 swap 89 crx si
- throttle body spacer
- a hammer and a screw driver, this isnt going to work
- cheap coilovers vs, skunk2 coilovers
- Drivetrain Issue
- sohc or dohc
- Park Lights when cold
- lower control arm bolt problems
- Lost car key
- CRAZY RPMS
- auto manual help
- Putting AC on a B16???!?!?!?!?!?!?!?
- Si trans pops out of 3rd, 4th and 5th
- Got a question
- 88-89 civic hb seats vs 90-91 hb seats
- sunroof problem
- Wrong parts or am I a nub?
- EF Wing question
- Need help wiring sensors.
- ignition system
- CKP sensor problem, already searched.
- new civic lol
- zc starter?
- gas tank question
- intake manifold need help
- Turbo b16 in a crx, What to tune with?
- my build! ef sedan
- Help hose on intake mani
- My EF Hatch Build
- 89 civic si how too...........
- oil leak
- ep3 seats into a crx
- Looking for a muffler in place of cat...
- what plug goes into this eacv ?
- QUICK SWAP QUESTION
- tranny code
- a6 crank pulley & z6 crank pulley the same?
- K24 project car on Speed Scene Live net TV
- DA FRONT SWAY BAR
- help!! code after boost
- pump shot?
- crx suspension
- tanabe exhaust
- power problems
- '91 Si rear brakes into '88 Si = e-brake cable issues?
- CRX ECU HELP!
- Red 91 Civic Si Hatchback stolen in San Diego area
- ef sedan 90 ex
- need some help with my ef
- Car died while driving, already replaced alternator.
- gauges
- Rear Wiring diagram
- Hybrid JDM S20/L3 transmission
- A/C harness goes through firewall.....where?
- Identify this part from the obd0-obd1 conversion harness
- no vtec
- LS NOT STARTING
- DIY/How to: Odometer Swap for 88-91 Civic/CRX
- Hood
- CRX Carbon Fiber Sunroof Panel
- Base map help. B16 with I/H/E
- VERY clunky/resistant feeling shifting in my civic
- distributor problem?
- sohc zc distributor question
- H&R sports
- can ls rods fit in a b16
- idle
- drop for crx
- 90 Civic DX dizzy - TD01?
- best tranny fluid for 91 hondamatic tranny with high miles
- hello new guy
- b18b swap help
- Question about CRX bumper
- how to identify fuel injectors?
- bumper lights, custom foglights
- Horn malfunction, any ideas why?
- can anyone id this clutch disc???????
- Alternatives to replacing the sunroof????
- different clusters
- Water Leak
- Building an LS with ITBs
- o2 wiring dilemas and other codes :-| (HELP!)
- code 15 and 16 *HELP!*
- ac bearing going out
- weirdest clutch pedal
- stupid dist. question
- how do i get these door trim things off?.. trying to get this painted!
- Offset, and tire question?
- Car is on the road again
- 88' civic horse power tips
- i have a 88' civic need horsepower help
- Bad wheel bearing. Easiest way out?
- Need help with B-seires hood clearenss!
- exhaust question
- stikcy throttle - did everything i searched and found
- ef four door w/ crx front
- Bent rim....will it work?
- good place to get patch panels
- I need a source for 1st gen CRX performance parts... eg. dual carbs, header, cam.
- light throttle check engine light
- starting and idle problem
- LS SMOKE NOT STARTING
- where can i get a lip 90 ef hatch?
- VW ARP head studs, on a Honda?
- DOHC ZC Building upper half
- take off bumper
- dash wiring hardness question
- fast idle wire, where does it go?
- another rear disk conversion question
- 89 civic hatch dx backseat "QUESTION"
- can get my crx started
- head unit wire dont match up.
- need wiring diagram
- track times
- Strong gasoline smell near filler cap
- oil pump reserach/questions...
- Leaking Radiator (DOHC ZC)
- 91 HF w/ B16 wiring question?
- no power at the blower motor fuse ?? any body have wiring diagrams ?
- quik question plz help
- i dont have any heater, plz help
- sohc zc mid shaft
- 91 crx smoking BAD! I'm very boggled. Please help if you can
- Jdm climate control
- Help this guy out
- Best Bang For Buck Mods.
- 90 std model 2 d16a6 turbo
- emmision prolbrem!!!
- A6 header fit zc?
- camber kit for 91 civic hb dx
- what kind of intake mani is this??
- crx dash problem
- Brakes Lock Up
- what o2 is closest to #1 on b16a?
- dc sports header gaskets?
- problem with my crx
- clutch slipping
- Teg rear brake swap years which will work for 96 hatch
- whats the difference??
- OBD2 D16y8 swap worth it in EF sedan?
- Taillight center garnish: Can you seperate it?
- Stamped body panels?
- Would this setup work?
- RSR ExMag exhast and sway bar clearance issues?
- cant get it started
- crx b16 axles? weird
- CRX worth it?
- ---Auto seatbelt trouble---
- Turbo D-Series question
- MPFI Swap..info...any links/pages to a step by step on this swap?
- 91 CRX DX Tranny Dying
- NEED HELP WITH BRAKE LIGHTS
- location of FITV on D15B1
- mirrors?
- number 9 cel code
- Quick question...
- B16 Axles
- quick question
- b18a1 swap
- rear brakes
- Does anybody have a wiring diagram for a obd0 pm6?
- rod and main bearings... help please!
- what is the best trans for a gsr?
- Ok what engine is this?
- sidemarker
- HELP!!B16:crx
- Rear Bumper Body Kit thoughts?
- Which Is Better b16a b18c
- Swap Question INFO Help......
- Which exhaust?
- RELAYS WIRED UP TO FRONT BUMPER LIGHT TO SIGNAL N STAY ON AT SAME TIME
- Car running wierd. sounds like 3 cyl.. help please
- n00bie exhaust question
- B18C swap
- Door moldings?
- fog light relay?
- accord shocks
- *What do i need for interm. wipers???*
- ??what axels to use on a y1??
- tire size question
- crx si b16a turbo build
- CRX wont start
- IS THIS SWAP POSSIBLE??????
- Help on Trade
- CRX quarter window rubber
- rain gutters
- CRX tail lights
- what the drifferents between tranny??
- DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor?
- 92 integra dash??
- Question-CRX and Hatch are they the same from fire wall frontwards???
- location of iacv/eacv on D15 motor
- A quick D-Series Swap w/ pics
- 90 (four door) ex hub replacement / interchange
- EF civic oem parts ?
- Chargespeed EF spoiler
- rain channel moulding ??
- Should I do a build thread?
- psi
- is the upper control arm in the front passanger side on a 90 civic the same as the 89 crx?
- Condensation building up on the inside of my 88 CRX DX
- Stocked 1991 Crx HF Motor Problems
- Looking for a Air Intake for my b18c swap
- Predictament. Stupid people.
- Can't put it into any of the gears
- 91 CRX with D16: Which motor mounts to use?
- EDM suspension
- Clutch Problem!!
- Mugen Chipped P28 Good for ITR/CRX Swap?
- ???EF COLD AIR ????
- quick question!
- rotten eggs
- lly any one selling an ef
- 1 wire o2 sensor
- EF rav's HIGH!
- tranny problems.
- crx with EK sidemarkers...anybody seen this or have pics? post up!
- cluster diagram?
- Help EF Swap
- What engine combo for CRX b20z with b18c1 head or b16a head
- wont start
- aem Alternator pully ?? any experince anyone?
- Zc axles and int shaft on Si trans?
- what is the stock bore of b and d series fuel rails?
- EF to EG Front end conversion ??? Any pictures ?
- factory tach quit
- firing order
- Flaming Opportunity!!
- Acceleration troubles
- EF with GSR swaps, what air intake for California smog?
- Battery sparkes, now NO POWER !!!!HELP!!!!
- 50k Miles and going in 1 year bad?
- b16 lower alternator bolt size?
- What parts will fit a 84' CRX
- need critique asap!
- Car Keeps Dying On Me
- DOHC ZC Part questions
- is there any way at all to use a teg harness in a si?
- can an engine and tranny out of a 91 crx si be put in a 86 hf or 87 si?
- When pulling a trans
- d15b1 vs b15b2
- How to remove rear bumper?
- Need some help. Flucuating idle!!
- fender rollers?
