View Full Version : Honda CRX / EF Civic (1988 - 1991)
- my '91 crx si turns over, wont start, need help please
- Help with b16....
- Why can't I post?
- Main pulley making contact with cross-member support under right hand turns and bumps
- could someone please tell me what vtech is?
- DYI Govner removed ?
- apex n1 on crx
- Car up on Jack Stands.... open door = pushes in fender panel!??
- 1992 integra RS= ys1 transmission???
- the ridiclious prices on honda-tech
- Rebuilt Transaxle
- possible parting
- Help on b16 alternator belt
- ZC slugs with LS rods
- AN-R header on b16 civic/crx?
- I'm still alive!!!
- do i need super premium?
- opinions of the honda tuning D series t25 turbo by Greg Leone
- Alternator pulley bolt...NEED HELP!
- preferred ECU chip for decently modded B16 crx?
- What is the best suspension set up?
- necessary to remove hubs to install extended lugs?
- Camshafts for b16a CRX Street driven
- 90 si seats in 88 dx??????
- b16 swap into a hf question
- are these flywheels the same?
- Custom exhaust done.
- buy rear fender online?
- Automatic to Manual???
- A6------>obd1 what distributor?
- my tach is crazy again...
- obd1 distribuitor or obd2
- Are these HX wheels?
- tie rods?
- 91 CRX First Test Passes on the 1/8th Mile.
- cable 5spd speed sensor broken
- Hey
- Fixed ZC wiring, now car revs to 4000rpms at idle and stays, what is the issue?
- Whats the big deal about a ZC Motor??????
- good ef sites
- CEL help!
- 88 HF parts to a 88 SI
- Neuspeed springs or H&R springs??
- SI seats?
- New cats on the import scene, we need help with VTEC.
- identifying ecu
- B16a axles are not spinning?????HELP
- Drum brake diagram!!!
- Are the CRX Si seats wider than HF seats?
- Quick question about exhaust....
- Question on MPFI swap
- ZC trouble shooting
- 87 PG7 for MPFI swap.
- key for speed not working
- What timing belt has 106 teeth
- EF shirts!!!
- recovering seats.
- Need help with V-AFC set-up (B16a2)
- tranny question- need help
- thieves F'n Suck!!!
- why do si tranny's suck??? what can i do to make it better?
- heater core weight saver
- Lookin 4 16 0r 17" Rims
- Zc build up... one more ?...
- b16 tranny pops out of 5th gear... (?) tranny problems
- Civic running bad!!!
- ECU Plug wiring configurations (how do they go; across or up and down?)
- Mouse Belt Fuse? 91 LX
- Prices on these parts.
- Help, Need to know the year of my LS
- FS: HASport Mounts
- Nor Cal Group Dyno Day May 10th, cheap!
- SI & HF Injectors?
- Just got my OBD1 ZC motor.
- ctr cams
- Which EF should i buy?
- CEL Engine Codes: 4, 7 and Oil Pressure Light is Always on
- What exactly do I need to get this chassis ready?
- Directions for ZEX purge kit
- most effective modification to b16???
- ***Post your B20Vtec 1/4 mi. times***
- EF for $3k or less-possible?
- Rear speakers in an 89 hatch ????
- Crank Agle sensor code
- B17 swap info???
- 15" steeles.. what car has them
- Timing Belt Tensioner
- heater problems
- Front Bumper...... need opinions on what to choose
- after b series removal my exhaust is 6" shorter damn!!!???
- ZC vs d16a6
- anyone looking for a rare PM9 ECU?
- do all YS1 trannys use the same clutch
- main relay cutting on and off
- Need help from some tech's, what's wrong with my car?!?!?
- 3 rd gen zc swap tech needed
- question about 93 ls swap????
- P2P Chip?
- terrible tranny noise?????
- Pic Request: Ractive Upper Strut Bar
- please help!!!! code 9 and boggy low end
- Newbie needs HELP!!!!
- CRX mugen spoiler....
- best ECU for LS swap in 90 SI
- question about a JDM EG.....
- b-series pistons possible?
- Part numbers for D16A6 valve cover gasket, ....
- POLL: Cold Air Intake vs. Short Ram
- 96 ex rotors..do they fit 89 dx?
- Ideas for a light weight hatch with stock functionality (CRX)
- anyone from SWEDEN on here? or is it uss resident only? looking to buy crx (maybe SiR) in sweden.
- Crankshaft position sensor ECU code 4 CIVIC
- Settings for Tokico Adjustables...
- need help on removing...........
- jdm freaks!~ this is when i wish i had money........
- Valve Cover Gasket Fix
- Wiring questions for a Multi Point EFI conversion on a 1.6L 90 Civic DX hatchback
- ZC Build Up
- is an IM OUT!!
- need help
- question about installing a tach.
- -- Weight differences between different year crx's, Why? --
- MPFI question, what plug goes to the EACV? A white one or a green one?
- dizzy bearing
- engine problem.help
- Question about CRX hoods
- a/c question
- Starter clicks but wont turn the pos over..any ideas? [90 si hatch]
- check it out!
- Mini-Me update (got a GSR and I dont even have Vtec hooked up!!)
- zc code 8.....tried search with no luck
- part number needed for 1991 CRX SI engine wiring harness
- Anyone know where I can get these tail lights?
- guage cluster..........can I?......
- Hydrolocked?
- b20 question
- Crx B20b/vtec swap
- mpfi swap problem/?'s.... please help me
- *****Help*****
- B16A RED MESH HOSE?where does it go to?
- VW lip on crx ??
- Stock CRX Tach innaccurate?
- Crx B20b/vtec....
- gear oil
- anyone have crx dx/si hubs and knuckles for sale?
- Engine swap
- D14A1????
- ... cigarette lighter... always on... wtf... what can i do?
- are all d series oil pan the same??
- ***Hatch or Crx: Better for a drag car???***
- Where can I find some of these (crx tan leather)
- CRX Si HKS Super dragger
- Honda vs Nissan on Super 2NR TV tomorrow at 12:30
- jdm tail lights were to get?
- j's racing lip?
- b16 on 93 ex
- quick! canadian EF drivers help!
- HF gauge cluster question?
- ebrake light
- what your opinion
- Will d15b7 Throttle body fit...
- How close are 4th gen hatch / sedan bumpers?
- Tranny rebuild. Grinding noise--mainshaft bearing?
- compression results
- compression check
- y8 manifold on obd0 d16y8 setup
- ZC alternator belt problem
- JDM crx in NJ....omg
- 89dx to first gen. b16a
- yo yo yo , obd-0 to 1 problems.....need help!!!!!
- How to balance dual carbs???
- Does Hedman make a good header for the Civic?
- Useful info on Benen bars for 88-91 CRX owners
- What Pistons>?
- Throwing a code 14 for Electronic Air Control, how to fix?
- need quick answer - civic std. - do i need diff. front lca's to install a si front sway bar (more)
- Who's the fastest crew in the bay area,ca?
- obd1 distributor on a obd0 harness will it work
- Mt Washington Hillclimb
- RIP David Ryan Jackson
- O2 Sensor
- what do i need to put a CR-VTEC into my 91 hatch?
- Project 87' Si
- vacuum hose problems
- Anyone else with subframe problems
- Estimated 1/4 mile time
- what engine for 85 crx
- nitrous on b16
- Tricks for getting off b@stard old head gaskets from the block???!!!
- Z6 IACV.... wich one bolts to this manifold...
- cyber/mugen flared wing, Light
- First time driving a lowered car...
- Can I convert a D16Y7 to run NON-OBD?
- $1000 for a motor, what should i get?
- B16a wiring??????????Help
- need help.. what distributer do i use on my dx with si motor?
- obd 1 question's
- hasport v-tec wire harness help!~ for jdm b16a
- Found some Black "JDM" corners for $25
- anyone running skunk2 ss in their 88-91 civic?
- cluster & mpfi swap question
- 89 dx - $900
- b16 sir 2 cams
- Using 10w30 SL SJ motor oil in transmission, not SE or SF as honda recommends...
- sohc v-tec into 89 ef hb dx
- b16 to b20????
- what do you all think
- 2hged736xmh519224 CARFAX PLSAE
- b16 gurus...where did you wire the 2nd o2 sensor?
- crx+t3
- Who was that guy...
- 92-93 obd1 integra b16
- BEST way to drill a hole in the fire wall....and What oil do you use?
- 91 CRX - I just bought one, and would like some suggestions.
- b16 crx w/ drag kit(pics)
- need exhaust and header advice
- DX TO MPFI, Need help right NOW car is hesitating
- start up problem
- I got another crx for $300
- What intake solution should i choose....Please HELP!
- and the building continues...(ZC motor)
- another 4g civic site and a lip that fits stock 4g bumper.....
- best OEM to SIR hood replacement:
- which tie-rod ends to replace OEM
- b16a engine setups??????
- Anybody have luck with an Integra suspension?
- V-TEC OIL pressure switch wires?????HELP
- stock si shift knob
- does any one where to get some cheap motor mounts ?
- hood problems need help
- 88 Center console same as 91...?
- Rebuilding d16
- introduction and a few questions
- steering rack boot?
- help me choose my brake setup....
- code 15 on Obd0 to obd1 conversion ?
- I'm looking for 91 Integra brakes. Anyone looking to sell?
- Possible Issues with vtec actuation on mini-me HELP!
- What should a B18A1 be running in a full interior 92 CX
- oil pressure drops after 2500 miles... why??
- D15a3/w vtec head, can I do it?
- What engine is in the 89 CRX DX carb. Also other questions about engine tranny combo's
- What kind of power and compression can I expect?
- CRX Flush Mount Spoiler
- ZC pistons in d16a6 block... how high will compression be?
- ZC vs D16Y8 head flow charts (thanks to Earl)...
- anyone ordered from iapdirect.com?
- Can I reuse headbolts?
- D16 head To D15 Block?
- do you have to use a GSR throttle cable for b18c1 swap into EF??
