View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Excessive idling. stupid loud
- Electrical Issue, Dizzy?
- 91 ef cant open hood need help
- NEW EF KID
- Post pics of your CRX's lowered 3" or more
- engines
- how to get an alternator 1990 crx
- Moisture in Headlight
- Rim Width On CRX
- Hondata Calibrations
- miracle x bar for ef hatch?
- Headers heat shield
- 91 si motor into an 89 civic
- DB1 dash into ED6 chassis???
- D16z6 Warm Idle, Drives Cold
- Turning A 4 speed trans into a SI trans
- d16zc dual cam?
- Throttle Body ??
- Blower problems
- OBD0 b16a into a 89 crx si......
- Honda crx
- Winter Time Modifications
- heated seats in efs????????
- pls help
- JDM front install picture set
- 88 hatch taillight problem
- CRX Battery relocation?
- Civic Tranny Swap
- Should I get the SSR MK-1 rims or the MK-2?
- 1991 CRX with B18b swap
- will trade my ef9 for a hydro tranny
- dpfi to mpfi problem code 16
- in need of serious help
- electrical issue
- Timing Bolt problem on the B16A
- WANTED - 90 CRXs (Yes, 90 running CRXs)
- d2 calipers what do u think
- pricing question (d15b6, tranny, axles, hubs)
- How about these?
- Starting issues!!!!! Please HELP!!!!
- 89 CRX chassis code
- Cannot get his DX started
- b16's vs Evos/Sti's
- jdm ef front bumper help
- Help, rear brake conversion for 1989 civic ef
- Pic request BBR competitions on ef
- Honda CRX Body Kit (which one is this)
- Hi there folks
- cylinder #3 not firing,help needed(91 Civic)
- Serious shifting problem
- What would cause these symptoms? Random stumbling?
- What about a diesel swap?
- is this injector trash?
- Turbocharging a OBDO B16a
- crx b16 exhaust question
- ECU Questions
- b20 obd 0 or obd 1
- Help with defroster/heater!
- Best place to find plastic trim/panelling? EF hatch
- 91 ef smoking
- Injector?
- tranny
- to pass IM asap???
- Rywire Mil-Spec harness question...
- Hondata
- whats your mileage?
- PDF FSM for civic with D15B4 Dual Carb
- Cleaning Debris from the Evaporator Case?
- ***Pics of my EF9 B16a and EF9 B18c (JDM Models)
- ***My K20 EF9 (JDM Model)***
- will 96 civic struts fit on a 91 hatch ??
- crx for sale
- 100thow km b16a2 rebuilt from a 2000 sir worth selling for 1300$
- dohc zc turbo or b20b all motor
- Whats a direct swap?
- CRX IDLE WIERD?
- trans for b20
- sedan help
- fwd wheel bearing tool
- Need intake for winter weather
- Traction Bar/Sway Bar
- HOW DO I KNOW IF IHAVE A Y8 MANIFOLD INTAKE?
- Clutch Cover & Torquing Oil Pan Bolts
- trying to put a del sol dash in a crx hf
- 91 civic 4dr headlight??help asap
- 92-95 Civic DX Hubs/Wheel Bearings in 88 HF Spindles
- Running ls crank ls rods and ctr pistons in gsr bottom' will i have clearance issues
- body work??
- body work?
- Axle help
- b20b swap???
- keep low beams on at same time as high beam?
- tranny problems
- how do you remove the rear mount on a d16a6
- Turbo a d are a b ??? please help me ?
- cost to sleve an H22?
- OBD II Alternator into OBD 0 91 CRX
- 1990 CRX tail light problem
- My V8 crx build! yep its real
- Stripped lug nuts.....
- upgrading my 88 crx si?
- obd0 to obd1 firing order?
- A Number of Problems here that may be related, Need your help!!!
- Ring/Valve issue?
- 89 crx si tranny in 91 ef hatch
- rear motor mount?
- B16 Timing Question and yes I've checked faq.
- starting problem...pls help read...
- mpfi to dpfi help
- I just bought my first Honda
- B16 cable tranny's
- Y7 Pan on a D15B2?
- D-series OEM LSD?
- 91 crx hf/si tranny swap
- throwout baring going out!
- steering wheel wobble/movement?!
- Need help finding a part.
- whats this cluster out of and where is it from?
- CRX INDIGLO GARNISH! FIRST AND ONLY "THE RISE OF BRIDGEPORT"
- mpfi swap help
- CRX security compartment in a hatchback?
- What are typical race spring rates?
- Another
- ZC SOHC VTEC IN MY HF ~some questions~
- Steel Braided Plug wires???
- dizzy
- EF coilovers
- ep3 RED H logo on a CRX???
- Brake Light Help!!!!!!!!
- Oil
- Starting problem: 89 Crx Si w/ dohc zc swap.
- Need Some ELD Help
- D16A6 90 Civic EX motor options
- All-over-print skulls on my wagon!
- MY MUGEN B20 CRX PROJECT.(very pic heavy)
- D16 Nitrous, is it Worth it?
- axle question
- type r Rex
- ??? ABOUT THE JDM SEATS ON A EF HATCH....
- Auto to Manual questions.
- shorter shocks for a crx?
- 88 dx transmission problem
- JDM CLUSTER
- help
- Rota grids with honda center caps?
- wiring harness question 91 CRX Si
- brake differences
- how to- paint interior panels?
- purchased crx..
- Trans leak after swap
- Fog Lights Installation Pix, Please
- fuel gauge stopped working!
- Jdm D15b Vtec Swap: NEED HELP!
- crx charging alternator help...
- EF USDM Front End HELP!!?
- cant go farther than 4-5k rpms, sluggish
- crx climate control with h22
- post up your boosted enigne bays!
- 1st Generation JDM B16a Fuel System questions
- b16a into crx pass side axle
- obd0 turbo questiOn..
- DX idling issues
- What size throttle body am I suppose to use 66-74?
- swap vid
- A little help w/ wheel bearings...
- 5k rev limiter
- Problems with ls vtec in 89 crx si!!!
- CRX b16A Won't Start HELP!!!
- si outer rails integra inner rails, WTF!!!! help
- What removes carbon in manifold?
- how bad do you wish?????
- crank questions
- E85 daily driver
- Chilton CRX Scanned copy??
- problem with b16 in my crx hf
- rear disc brake swap
- eBay steering wheel hubs -- anyone used one?
- Oops I totaly broke my tranny... PIXs inside
- EF9 5in Tach HELP!
- what do I need to put on a crx front bumper onto a 90 civic dx?
- OEM wheels on your ef
- car tops out at 70mph
- b16a crx shaking after swap
- ignition switch interchangeability
- Cv axle snap!
- Rear Sub Frame?
- How wide can I go? 15x8 or????
- SOME FUEL PUMP TRUTH/HELP
- Sway Bar Suggestions
- URGENT: DPFI TO MPFI CONVERSION
- D15b V-Tech Longblock
- 91 at tranny wont shift???? plz help
- HELP PLEASE!!!!!
- HELP! How To Wire Crank Angle Sensor to OBD0 ECU?
- What trucks have similar spring diameters?
- anyone know is 89 rear shocks are longer than 88 rears?
- Poor running D15...yet again.
- D15 not running. Help...
- NEED NEW ENGINE!!!help with sites and places to find good engines for cheap
- long or short im for b20 crx
- Bad wheel bearing...or steering rack?
- rapid click in main relay.
- TB spring problem?
- CRX Vibration????
- 89 CRX Si has intermittent blower operation
- Rolling odometer
- Roll cage for an EF Sedan?
- is a integra b16a head better then a 2000 civic sir b16 head
- Just bought a '91 Crx-Problems
- 89 Civic LX gas gauge
- crankshaft question
- Smaller brake booster than 7" HF?
- EF hatch front lip?
- Quick noob question
- CRX wiring harnesses
- b16 tranny problem
- ef hatch parts compatability
- FREE ! DA rad and mint crx sunroof
- JDM Amber Side Marker Install???
- AEm fuel rail for crx, will it fit a 92-95 civic?
- surging, leaking, etc
- So what would you do in this situation?
- 13" wheel fitment question
- Honda Civic D16A6 check engine light and code
- Rear DA seats in EF?????
- backfire problem
- Alright problems with my EF Hatch
- A TREE FELL ON MY EF!! DAM!! WHY ME!!
- need info on manifold install; blox or skunk2
- OBD1 DOHC ZC Into A 91 Civic/CRX
- Head gasket problem!!!
- Need help with 90 crx
- clutch issue
- Foglights
- help please
- ignition issues
- battery dosent hold charge...
- Accident damage?
- Help ASAP
- CAR BOGS OUT..NEEP HELP
- Loopy Idle: Throwing Codes 10/14
- code 16
- OH no limp mode
- flashing battery light
- 90 civic sedan alignment?
- Jdm b16
- need help!!!tranny issue
- headers wont fit! help
- camber
