View Full Version : Honda CRX / EF Civic (1988 - 1991)
- JDM front on CRX
- low buck racing?
- AC conversion to R134a
- cluster lights went out... where to buy?
- *did a search* b16a dyno results with similar parts.
- No CEL or Cranking
- Header that fits with A/C?
- Where to buy helms?
- WTF... code 16-- fuel injector after hitting vtec 2nd gear redling 3.5
- Stupid Question
- stock crx seat belt assembly
- anyone know about this?
- Cruise control and / or power andtenna transplant?
- B18A in 91 DX Civic no spark????
- Here's a challenge...
- will 87 crx seats bolt into my 88 civic hatch w/ no fabrication?? HELP!!!!
- My friend just picked this up, good deal?
- WTB: EF seats, cluster with tach, new oem b series parts, etc
- DOHC ZC PM6 ECU Code 3 - WTF?
- whats the real scoop on B16 pistons in LS block......
- Overheating problems...
- Is there a good write-up on how to make a vtec sub harness?
- d16z6 reliability?
- I DIDNT KNOW THIS COULD BREAK!!!!
- Custom Piping+Univ.Muffler vs. Aftermarket Big Bucks Exhaust
- subaru hybrid part
- what can i do to bypass pushing the clutch in to start my crx si?
- Ground control spring rate recommendations for a b16a crx?
- few mpfi swap questions
- Any OBD1 B16 users Here?
- OMG! My brakes have locked up and are smoking. What did I do???
- Using EF9 JDM axles/shift linkage in swap. can i use them!??!
- popping out of gears
- Sloppy shifter got you in a slush?
- B18 Block/B16 Head
- 95 SOHC vtec Turbo motor for sale - COMPELETE
- wiring problems anyone, tips tricks know how
- Dizzy repin instructions?
- 454 chevy engine in 1991 honda civic
- Installed Integra MC and Booster, car won't seem to bleed...
- KYB GR2
- spoom lip on ww bumper
- seatbelt recall on honda's
- ecu question
- Need Some Help...
- 88crx w/ ZC need help
- Where to find Lips for my Hatch
- Best Rims and Tires for Hatch?
- does anyone know a good place to buy d series tranny synchros?
- Starting to get pissed............ hesitation problems!
- what diameter is the heater hose for a 90-91 integ
- why is my car doing this?
- EF9 rear disk brake swap
- wont rev past 4k?????
- ok guys i need help geting a crx
- battery relocated to trunk, wont start occasionally,
- water prrof engine bay....
- installing shocks/spings
- VTEC dont work B16A2
- Jim Fab crossmembers...
- Do you have to have Autometer tachs calibrated??
- 84-87 1st Gen CRX
- Introduction.
- d16z6 possibilities?
- adjustable
- Question about Z3 Fenders?
- Gunna get a B16a1 soon But.........
- motor mount inserts???
- How can you tell a si cam from a dx cam?
- ECU upgrade problem
- swaping out the the door handles.......need help.
- Aftermarket fan?
- where is the ecu located in the crx?
- JDM EF9 rear bumper install help.
- Shift Knob and Boot
- What Kind?!?!??!
- sir ef8 front end conversion questions
- Erratic Stalling DOHC ZC
- Clutch Cable too tight?
- Tuner Lug Nuts
- b20?
- Sunami Blow-Off Simulator?
- what should i do.... **OFFICIAL** broken jdm tranny post
- what you guys think of crx cowl hood?
- What cams are bigger than type r cams
- Can you guys do me a favor really quick
- engine suppliers
- zc help p-leaseeeeeeeeeeeeeeeeeeeeeeeeee
- Need motor opinions for 89 dx
- y1 tranny capacity
- EF9 and EF8 how different are they really??
- lug nut tech....need help
- What Kind of JDM cluster is this? Can someone tell me?
- Painting Urethane did i miss anything? WW Kit related
- endulge me with your JDM knowledge
- Help with CRX
- how much do you think?
- GND of the ecu and EACV
- Need help with some vacuum hoses???
- Spark Plugs (B16a)
- cts for a b16a?
- short shifter
- i am stupid...can you help me?
- SoCAL EFs HELP ME OUT!!!!
- Anyone got a b16b in their rex?
- clutch install?
- Idle Problem for 89' CRX HF.
- lsvtec issues
- How to separate tranny from engine???
- Nos for B18C6 Need help!!!
- Fast Brakes question?
- anyone have any specs on the d15b2?
- CRX sunroof question
- Just bought an EF civic w/ a B17 swap, got some questions.
- anyone running ST swaybars on stock springs?
- Tire pressure?
- Skunk2 Exhaust
- Daytime Running Lights: Which lights should be on?
- auto to manual
- is there any easy way of removing the star drives on the rear hub assemblys?
- 96 gsr rims
- Good news/bad news : Found oil leak!/Can't fix it!
- Zc clutch fit z6 with 91 cable tranny???
- led shifter install
- anyone notch their block? let me see!
- Will running PG7 w/ ZC shorten 02 sensor life?
- Ignition switch question, w/pic! (EF)
- Symptons of this problem
- HELP! 90 civic wont start
- CAI for B18C5 powered CRX....
- 89 CRX troubles.
- Holley AirMass header Vs DC sport header
- B18C5 CRX
- ZC crank pulley?
- b20 91 hb si
- D16Y8 oil pan
- Coolant hoses popping off!!
- Gas Guage Problems
- Rotton / Broken seat mount points
- my ef9 got broken into
- Need help mounting Recaro style seats
- Suspension setup question...
- Urgent Help Please: JDM SiR Ignitor
- Passenger door clicks~!
- 96-00 D-series axles fit in 91 hatchback w/ D16A6 ??
- Monarch Trading Co?
- 3g teg seats in an ef
- ZC SWAP... WHats GOing WRONG????
- The 'Super Beater' is ALIVE!!!
- Real street racers help me out.........WHAT CAR SHOULD I BUY?
- Does an oiljet have on o-ring?
- B16A and D16Y8 valve springs interchange?
- WIRING problems 88 hatchback
- are rex Si front discs bigger than Dx?
- Need some help on my Ground Wire locations on my b18c1
- B16...engine light...no speedo...???
- Will the distributor of a d15b1 work on my d16a6?
- sir gauge cluster help!!!!!
- shift boot / console
- Wierd sound!!!
- anyone else break this?
- Clutch Installment Easy or Hard
- Fuel Pressure Regulator
- body repair
- Bubbling coolant ?
- best place for steering wheels?
- cel 16, car won't start
- crx dx a-arms
- car wont start
- How do I move my battery out of the engine bay?
- crx smoking
- racing harness install, already searched
- How to clear DOHC ZC with factory crx hood.
- anyone wanna buy a clean crx?
- hydro tansmission
- carbon goodies for JOO !
- Tranny question
- Intake manifold brace and the black box behind it on a 1st gen B16
- taking the whole dash out:(
- which is better
- throttle body question
- Code 9, CYL sensor, what may actually be wrong..??
- How do I wire the fans to a switch ?
- i need help with JDM headlights and cluster install
- Reverse indiglo gauges/indiglo gauges ricey?
- ECU throwing a code 17, WTF!
- Crx forks longer than accord forks?
- SIR font end, wiring the fog lights!
- HELP! Stripped Tensioner Bolt, Any Ideas???
- Headers or Cams
- Hard Tapping from Engine? HELP!
- WTF?!
- CRX years, and differences.. mainly wirring.
- Need some help on Honda OEM colors
- motor swap question.....
- what dose an engine cost?/what makes a b16 so good or popular
- Took the hatch to the strip today...(b18c1)
- fiberglass sub box
- Custom oil pressure sensor bracket
- crx steering problems
- Fuel pressure question....
- bosal and pacesetter catbacks for crx
- How to put 89+ Rear AGX shocks on 88 CRX
- si dizzy plug pic request...anyone?
- ITR Master Cylinder/Brake Booster
- cheap rims
- how low should i go
- where can i get a cusco roll cage for my hatch?
- newbie needs help with grounding
- dx to zc back to si wiring>?
- eg mirrors on ef?
- b16 or b18
- WTF Car cranks on second dot???????????????
- b16 swap.. drop it off or try and do it myself..help
- how important is a dashpot
- SiR bumper turn signals same shape/size between CRX and Civic hatch?
- weird sensors on LS motor swapping in DX Hatch..........?
- ZC motor hitting the hood ??
- tranny problems, need HELP A.S.A.P
- autozone axles
- Emergency break light stays on
- Help with motor
- will 88 dx body parts fit on my 90 si (civic)
- crx hf ecu work with d16a6?
- B Series Swapping Internals
- need carfax, possible scam
- my front window broke, how much it cost for replactment
- Anyone know any good glass repair shops in Illinois ?
- What oder are the wires?
- Brake swap STD Civic to Si CRX parts..
- Blue Smoke
- CTR crank pulley questions..
- Whats a fair price for a Y8 head?
- fan?
- $50 gets you a 85 civic!
- Brake lights staying on
- Member Status? Please HELP!
- After Market Door Mirrors - 89 CRX
- would this make a difference???????
- I got 35 mpg today on the 88 Si
- Just got back from the track!
- crx stuff for sale
- WTB injector resistor box WITH injector plugs for DPFI to MPFI swap
- Stock tach help..
- b16 wont rev past 7200, no codes
- Foglight wiring diagram?
- axles question, b16 motor in crx
- to boost, or not to boost?
- Who wants in on a group buy of the best hood you can buy for your CRX or Civic?
- How to make headlights clear again instead of foggy?
