problem mpfi swap
Hello
As first my english is bad but i try to post here.
I hope that i am not post in the wrong topic.
I have a civic ed dxi automat and do the dpfi to mpfi swap, from d15b2 to d16a9 manual
Now have i am the problem
The motor have only spark on cyl 1 and 3, 2 and 4 have no spark from te distrubutor.
The cyl sensor are on c1 and c2 on the ecu.
The ecu have no errors
what do I overlook that there are only two sparks
Thank you,
Sorry sometimes i used a translator.
Thank you,
<p>C1 and C2 get moved to B10 and B12.</p><p>New wires are then to be added for C1 and C2.</p><p>Don't forget to flip your TPS wires! (not shown in this writeup.)</p><p> </p><p><img src="https://cimg4.ibsrv.net/gimg/honda-tech.com-vbulletin/707x799/80-dpfi_mpfiecudiagram_a358100cdefeeed31278e83db99877 d1cf2fae13.png" title="" /><br /><br /> </p>
4drEF as first thank you for the answer.
i have done what you say in the post, but same problem.
https://www.youtube.com/watch?v=TVAn...ature=youtu.be
yes i have change the ecu and the Distributor.
I have buy a complete car and build in my civic dxi.
cyl 3 and 4 have no spark
Sorry for my post again, its not the mpfi swap.
As i am start the car then are it 2 seconds good.
After the 2 seconds coming the error 3. (map sensor)
Today i take a another map sensor but the error go not away.
i hope that you me understand.
best regards
best regards
civiccpedx
10
Feb 1, 2005 02:56 PM
