View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1990 CRX SI Wiring Issues
- CRX INVIDIA EXHAUST ON EF HATCH???
- Help me diagnose!
- B16A Thermostat
- EF: Stupid Question Amnesty Thread
- Bouncing idle saga continues...continuity on plugs
- OBD1 Timing Jumper...
- trying to remove head, but stuck.
- Intro and help thread
- charging issues
- HOW TO INSTALL SPOON CALIPERS IN AN EF8
- Help me see my dying grandmother.
- 89 crx si gauges problem
- Need to find a Vehicle Speed Sensor or an alternative
- 90 Civic Battery Problem
- 89 Honda Civic sputters- won't crank
- Starter Part Number confusion...?
- OEM parts for Ef Civic 88-89?
- WTB: JDM CRX BUMPER SUPPORTS
- misfire at idle
- Intake manifold gasket leaking coolant into engine
- KriegerEhre's 91 EF Hatch Build Thread
- 1991 Honda CRX 1.6 16V (Build)
- 91 civic Heater Problem
- sunroof swap crx
- Wire Fog lights to turn on with ignition?
- Got free seats lol
- Replaced 91 DX cabin harness with 89, can't figure out where these connectors go.
- Drained battery or something else?
- need pinout for mirrors and climat
- 1990 civic dx seat swap
- '91 EF7 CRX Rest / Slow Build / Daily
- 1988 CRX - bushes
- where to buy rear wiper arm?
- Hard starting: Cycle the Key Multiple Times to Start....
- Car randomly dies while cruising
- exhaust size question
- Performance options for clean 91 dx
- 91 ef hatch build/resto/dd fun
- timing will not stay
- Hatch Problems
- Can I use a d16y7 on a 1991 honda civic dx?
- AUDM Civic FI Swap
- 91 Civic K20
- Distributor again?
- Sudden drop in mileage
- Sunroof rear drains
- 1990 Civic SI No start after timing belt replacement.
- seatbelt light issue/battery drain
- First Gen B16A Power Steering
- main relay trips only when starting
- d15b1 coolant temp sensor and intake air sensor
- mini me swap witch clutch and flywheel
- CRX B18a1 Swap question
- Engine stumbling
- Anyone Know what kind of bolts (size,length,thread) I need?
- d15b1 in 89 hatch problems
- 1989 hatch dx timing question and other question
- will this work?
- 88 hatch temp gage problem
- Need help diagnosing a missfire issue
- Amazing steelies... What are they from?
- Car getting no electrical power and battery gets hot
- Replacement Parts
- 91 ED daily
- added a rex to the garage
- Merging jdm cabin harness to USDM (HELP!!)
- need help y8 into sedan problems
- 90 crx dx rear defrost wiring
- What year Ignition cylinder is this?
- 89 Civic Si lost power on highway!!!
- *VTEC-KART* BUILD THREAD
- value of car after painting. not inside doors or hatch
- fixing door stopper in door jam
- My first EF 1988 lx sedan build thread
- first gen b16a cable transmission question.
- Random bogging
- K-Tuned Shifter vs fastline shifter
- sputters/bogs @ 3k CEL tuns on
- Installed my b16a I have a few questions
- b16 swap questions
- White smoke/brown gunk
- Need Help!! BROKEDOWN....
- obd0 injectors to obd2 swap?help?
- Is it possible to put a clutch on backwards?
- 89 HONDA CIVIC ENGINE LIGHT / NO ECU CODES
- 89 crx si shuts off
- B series swap in a 88 crx si...axel problems!!
- JDM First Gen B16A Cylinder Head Question
- Cluster lights. 88 CRX Si. newbie needs guidance
- Project OG EF build thread
- glasspack question
- Part Number Needed
- b16a 1st gen timing belt cover
- Motor temp. and Rev Issues
- 1988 Honda Civic Dx hatch
- Troubled ZC
- ef ls problem
- ECU not sending injector signals
- AC Heater
- Wide Fenders VS Overflares
- MPFI sanity check
- What are these parts worth?
- JDM fenders on USDM front end
- Jdm d15b carbed to mpfi cam&spring options
- obd0 to obd1 ecu harness pinout
- CRX D16a6 SOHC ZC head swap ...engine issues?? HELP plz
- 91 civic hatch 1.5L Throttle body injector
- 90 civic si booster leak
- crx2000... it moves.
- 1991 civic EX sedan possible ECU issue?
- Old Cat - how do I know if it's still okay?
- cluster and fuse questions.... help asap
- OEM type r header in 91 rex
- ef with jdm gsr trans
- Fuel pump randomly stops working
- Help to upgrade engine
- 91 Civic Hood Stuck Closed
- Questions on Wiring over to OBD1
- how do you remove headliner on underside of sunroof on 90 crx si ?
- Building a motor, opinions welcome
- CRX B16. Trying to eliminate wheel hop
- transaxle help please
- what motor is this ?
- Stock 91 Civic DX automatic - Questions about engine swap to make it faster
- Transmission Issues
- 1991 civic build
- Minor Civic Mod/Improvement Suggestions?
- EF Blower/Fan Switch Replacement
- Replacing a timing belt...
- How to Spot Generations on a jdm b16a
- JDM B16A Gen
- JDM 1st Gen B16A Vtec Solenoid
- Civic EF Water leak on floor behind drivers side seat
- Obd1 intake manifold on obd0 block
- 89 CRX Si restoration
- 91 Civic - injectors don't pulse
- CRX climate control heater a/c switch assembely?????
- Help me diagnose my noise
- Del Sol Skinny 5
- Can i hook up a z6 mpfi intake and p28 ecu without vtec?
- How to replace b16a Vtec Solenoid Gasket
- 91 Civic JDM B16A Cylinder Head Oil Leak
- 90 CRX DX Automatic with CEL code - Limp Mode??
- Honda Engine specs? Not wiki
- Having trouble with 1990 Crx B16
- '91 civic dx with d16y7 swap
- cluster out in ef?
- unknown wire harness's need help
- 91 dx hatch. D16y8 & p28 need help!! runs bad! :crook:
- need alternator help
- B16A swap in a ef having some issues
- 90 sedan/b18a swap - pass radius rod is right on my tranny
- Need helpful info on d15 vtec head swap
- Power Steering Pump and Alternator
- Best time to smog?
- led lights speedo?
- How to Adjust 91 Civic E-brake Handle
- loves and hates of my first honda
- 91 crx/d15b2 -- motor mount snapped
- Auto Transmission Whine from Reverse? Need help ASAP
- fuel injectors not firing
- Idling at 1500-2000RPM and Gas Guzzling with my new B16A
- Towing with a J swap?
- d16y8, dx 5speed cable trans and p28 ecu. dizzy wiring.
- help!! 2.25 exhaust mani to 2.5 exhaust
- Faulty Master Cylinder?
- 90 crx si tie rod too short
- clutch bearing??
- B20 vtec fuel pressure regulator question???
- Hatchback Base Model Transmission
- Need Ac help
- EF bogs when I give it gas help please!!!
- 91 Civic won't pass emissions
- 89 crx si seats
- Exhaust Too Loud?
- zc to b16a swap
- question about short shifter
- will 92 civic hatch lowering springs work on a 91 civic hatch?
- 91 civic with 93 vtec head-fuse 14
- Will The Exhaust Fit?
- Wheelspin in Vtec
- 91 civic hatchback blacked out tails.
- New to this, need help please motor swapped crx
- Rear Disk swap
- 91 LX (L4) torque converter source?
- RSX seats in EF....
- How can you tell difference between hi comp valves/stadard comp valves?
- No Fuel Pressure?
- tegiwa brake master cylinder stopper / brace, anyone used these before?
- Weird overheating problem
- RHD crx brake line routing
- Fuel pump not priming on ignition and car not starting.
- dpfi to mpfi odb0
- H/F into 1988-1991 Civic/CRX: How to use stock EF Speedometer
- Crickets from my engine?
- 91 Civic Will run until turned off, then won't start
- Main Relay Rapid Clicking?
- obd0 dpfi to mpfi obd0 turbo code 9
- 1991 honda civic - what to do now?
- Transmission conversion - problem with driverside axle
- b16/crx alternator bracket bolts won't budge
- 90 Civic - EACV problem
- 91 ef with gsr issues
- Crx dies when stopping and after taking off
- help with wiring
- Any differences to various year L3 tranny housings?
- Does anyone know what body kit this is?
- B20VTEC VS 11:1 B20VTEC VS B16A Turbo
- 90civic std won't start after swap ...
- 91 CRX. need some answers/tips
- Anyone have the dpfi and mpfi ecu plug pin outs if you got them post em please
- Spark plugs
- Decent price for all A/C parts?
- OBD1 89 CRX Z6 Weird Spark, No Start Problem
- 91 si project
- Head Gasket - Coolant in water jacket
- How to Remove 91 Civic Heater Vents?
- does anything local mix with dw-1?
- 50A ignition fuse
- quick harness question, dpfi obd0 to mpfi obd1 vtec
- Rebuilt Calipers, still sticking..
- window trim
- Do I have transmission problems?
- OBD0 to OBD1
- d16z6 swap help
- Speedo cable housing at trans ..
- g on what was happening
- hoose to react
- Radiator fan caused dead battery?
- Worth it to rebuild a6, or just buy ZC?
- window trim
- Brake hose
- Half Radiator
- What happened to my engine???
- B-series crank sensor wiring question
- B16 overfuelling
- crx rear disk ebrake cables, will eg coupe cables work??
- 1989 CRX DOHC ZC "blip" in powerband?
- Swap from hell mpfi waek spark help!!!
- Wagon bogging???? HELP!
- Door locks don't use same key as ignition.
- stitch welding a 89 wagon? street use
- 91 civic si hesitation problem
- obd0 > odb1 extra wires question. PLEASE HELP!
- D16z6 5,500rpms 3rd gear, misfire then limp mode...Help!
- 88 crx Limp mode
- Anyone know places that sell Hard rubber Bushing kit
- MY 90 Dx Project-baby steps
