car violently shakes at 30 mph and over
Old Jul 23, 2015 | 11:21 AM
Bseries91si's Avatar
Default car violently shakes at 30 mph and over
Car is a 91 4 door sedan with coil overs. Was going to pull out of my drive way when i heard a loud pop and thats when yhe shakes started happening. I replaced everything from my axels to inner and outter tie rods and upper ball joints on both sides, as the bishing were completely shot. I dont know where else to turn. Only other thing i can think of is my alignment, which i know needs to be done. My wheels and tires were balanced before i even put them on the car. My motor mounts are fine.
If anyone could shed some lighg on something i might be over lookin, it would be very appreciated.
Old Jul 23, 2015 | 11:44 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: car violently shakes at 30 mph and over
Did you replace all those components before or after the loud pop?
Old Jul 23, 2015 | 11:56 AM
4drEF's Avatar
Keyboard Humorist
wheel bearings?
tire issue?
Old Jul 23, 2015 | 11:57 AM
I replaced them all after the pop... wheel bearings are good and the tires are brand new
Old Jul 23, 2015 | 01:48 PM
24TEN's Avatar
PHANTOM MENACE
If it's speed dependent and everything else you stated is in good shape like you say, my next guess would be centered around the differential. Difficult to say without having heard or felt anything first hand but thinking logically through the drive train that would be next.
Would you be able to guesstimate where the pop came from? And have you checked that the arms themselves have no movement?
Old Jul 23, 2015 | 01:55 PM
whited's Avatar
CRX God
I would re-balance the wheels and also make sure they are true.
Old Jul 24, 2015 | 07:21 AM
The pop came from the passenger side... it almost feels like my wheel is going to fall off.
Old Jul 24, 2015 | 07:23 AM
Everything is tight with no movement. Everything is literaly brand new. I think ive had this car up on a jack stands checking for movement in everything more times then ice driven the car.
Old Jul 24, 2015 | 07:57 AM
whited's Avatar
CRX God
BALANCE THE TIRES!
Old Jul 24, 2015 | 12:48 PM
24TEN's Avatar
PHANTOM MENACE
Have you checked to see if the wheel hub has play on the passenger side?
Old Jul 25, 2015 | 02:06 AM
Ive tripple checked everything... thats when i started replacing things. I even took the whole hib to get a new wheel bearing pressed in, old dude has been doing bearing for 30+ years told me my bearing and hub were fine... everything is new. Tight as can be. No weird movements at all.
Old Jul 25, 2015 | 07:28 AM
whited's Avatar
CRX God
I understand you already had them balanced. Do it again.
Old Jul 25, 2015 | 04:20 PM
KevinEF7's Avatar
A slightly out of balance tire isnt causing his wheel to feel "like its falling off" this is a more substantial problem
Is the car running equal length driveshafts? If so I would flip each to the opposite side and see if the vibration moves to that side
Are the rims stock rims? If not, are you running conical lugnuts vs the stock acorn style?
Old Jul 25, 2015 | 10:54 PM
whited's Avatar
CRX God
It is the tires in general. A bubble in the tire, a completely thrown weight, or a bent rim. I'd hope they would find the issue when balancing.
Old Jul 26, 2015 | 03:37 PM
4drEF's Avatar
Keyboard Humorist
Originally Posted by whited
It is the tires in general. A bubble in the tire , a completely thrown weight, or a bent rim. I'd hope they would find the issue when balancing.
I've had a bubble before on a tire with less than 2,000 miles on it. I've also had a chunk of tread go missing for unknown reasons.
Doesn't matter how old or new the tire is, go have them checked.
Maybe that 'pop' was a wheel balancing weight flying off and smacking into the wheel wheel.
Old Jul 27, 2015 | 12:16 PM
whited's Avatar
CRX God
In general if everything is tight, you don't need to go throwing parts at it. You need to ease into it. First you want to sit her down, and talk softly to her. Then lift her up a little and pull her shoes off. I mean TIRES, BALANCE THE ******* TIRES.
^This also.
Old Jul 29, 2015 | 11:56 AM
Deleon91's Avatar
sounds like the wheels aren't right for this car.
Sxynerd
Honda CR-V & Element
Aug 13, 2011 08:35 PM
jkm211
Sep 7, 2009 12:53 PM
streetglow116
Apr 17, 2009 08:57 AM
blackie
21
Dec 7, 2005 09:12 PM
Jolf
Mar 13, 2003 09:21 PM
