View Full Version : Honda CRX / EF Civic (1988 - 1991)
- any sugestions on what motor i should drop in my EF
- ► ► for sale / would like to buy 88-91 crx/civic parts only◄◄
- axles
- Anyone else get this in their private messages?
- hi flow cat
- mini cooper rotors for big brake upgrade
- Black brake fluid
- D15B2/D16A6 Camshaft
- ZC Question
- 90 si suspension cpr
- transmission oil?
- TEMP GAUGE not workin after swap
- 91 Civic SI stalls at medium rpm (loading, detonating, flooding)
- 96 gsr cluster in 91 sedan
- z dyne help
- jdm sohc ZC motor...constantly running into problems?
- sensor help please
- 2 questions about fan switch and temp gauge sensor
- D16A6/JDM SOHC ZC lower spark plug tube seals installation?
- Energy Suspension Bushing set
- Help with Gas gauge/meter...
- Brakes Upgrade??
- Temp Gauge Sender
- 1989 EF Sedan start up Whine
- crx hf
- Front and rear suspension torque specs
- EF rear end dynamics?
- OBD1 ecu jumper wiring ?
- Help
- Car dies while driving, RPM drops to 0
- installing password JDM 3pt bar, relocate stuff on firewall?
- What's Up With The EEWagon Squad?
- 1st Gen Crx 87
- vtec problem b16a
- New member to the site
- Rare CRX Vtec seats?
- 1991 Honda Civic Hatch Rear Panels
- Parts numbers???
- Help With Hood Please!
- Turn signal mounting clips
- CRX GSR no vtec HELP please
- single popping noise when braking?
- ls vtec crx 0bd0 pr3 blinks 17 ?
- How do I remove the bottom alterntor bolt on a 90 CRX????
- Cat conveter help
- Need help finding whats wrong with my CRX. 20$ to the one that finds it.
- d16z6 swap in ef
- Fresh Z6 smoking a lot
- civic coilovers
- Anyone know anything about
- Mpfi swap
- radi wiring
- Very weird no start problem, not straight forward
- Time to start looking
- project Mu vs Hawk(Brake Pads)
- Emacie272 make room in your inbox. lol.
- UNDER CONSTRUCTON
- Looking for new EF
- 5-Speed tranny fluid...I know Im not a complet retard!!!
- PM3-2 head code
- 88 EF distributor question
- Custom Crx Tail lights[Hidden OEM Light SOCKET]
- crx build w/pics
- Fog light help!
- dpfi to mpfi problems
- ZC DOHC compression ratio
- 215/45/16 tyres on 16x7 wheels offset 40 on crx
- Getting on stands
- 5-Speed Questions Fast Replies would be very nice!!
- What B series engine fits in a 89 Honda civic lx sedan?
- rear trailing arm bushing size differences?...
- 89 CRX HF misses/pops 'bout to take it to the crusher
- 1990 Civic will not start possible fuel issue.
- 89 civic si wont start?
- Front Engine Mount/Crossmember help (pics)
- Nickelz34's 1990 EF SI Build - B16A-B18 YS1 Tranny
- EF Hatch Splash Guards
- Having trouble with my swap :(
- Please help! Integra brakes on my CRX
- Need help from a EF genius please!!
- idle drop when braking suggestions???
- Gauge Cluster Lights
- B18c1 88 DX
- Is there a rear big disk upgrade I can do with oem parts. ??
- CRX engine harness help!
- can an alternator 1.5 16v work properly on a 1.5 8v ????
- Putting a hydro singlecam trans in a EF
- Weird EF9 Problems
- frankenstien question.
- Advice on B18 build for CRX SI
- Pulsing Idle Problem. Wont Pass Emissions
- Crx fog lights?
- Cam gear Question?
- My EF build ... Got Mugen ???
- b16 wiring question.
- My 91 si build..
- 20yrs in the Midwest with no issue, 1 year in AZ = STOLEN
- My 91 Honda Civic EF9 build thread
- 89 civic si wiring issues?
- hydro locked engine.
- under dash
- Crx power windows help
- Throttle body problem?
- HELP ASAP. Front brakes keep "locking up"
- CRX Swap! Help please
- No low blower fan speed-why?
- CRX wireing help!!!
- smoking and backfiring from tailpipe
- Loose Cable?
- knocking noise coming from driver side wheel well?
- ECU chip for 1991 CRX si
- B16B or B18CR in Civic 87 (AF)
- 90 civic hb dx fan wiring
- mini me timinng question
- (SEARCHED) Which A/C Bracket do i need??
- Seats compatible with 91 Civic EF Hatch?
- possible bent valves on 91 civic
- 1991 CRX SI Dash in 1990 EF SI Hatch PHOTOS - Will this work ?
- Looking into getting a CRX.... advice and such please?
- is there hi-temp paint for plastic? so i can paint timing belt cover?
- Bad shifter bushing possibility?
- d16z6 EF old fuel question
- Where to buy fuel sending unit????
- please read
- b17 wont start after tryed removing vafc2? need help
- Harness question
- I'm losing window control
- Is the front of my car sinking?
- Great my clutch pedal broke, this oughta be fun- anyone have one?
- I need help with a 1990 civic
- crx turns off at stop lights
- 89 EF w/Z6 swap timing problem
- Ef seat belt warning
- Part question
- Would I be able to mount 1990 rear civic seats in a 1990 crx si?
- i added a 5th injector
- crx nose mask on SiR front end
- Ground control question: 92_00 on crx?
- crx project 5oo+ hp
- 89 CRX HF misses at all RPM's until A/C is activated
- negative batter post gets super hot
- PLEASE HELP :]
- 88 crx with b16a2 o2 problem
- tail light/ instrument cluster/ license plate light fuse blows everytime
- D16y8 running limp?
- k20a2 swap questions
- D15B2 pulleys on D16z6?
- HELP crx wiring adapter
- Bisimoto Tuning of a K-series Ef!
- 89 ef si with b18 idle problem
- 89 ef9 si front bumper question?
- ef si hatch with b18 swap idle problem
- MC AND BOOSTER ????
- Intermittent trouble
- Trailing arm bushings too small, need expert advice.
- Need alittle help from the experts. Dumping gas, backfiring
- Help!!! Both A/c and heat both make noise when turned on. No A/c & very lil heat.
- coil pack going out - how to test them ?
- anyone seen my old car? j.w how shes doing been few yrs
- IACV and Brake questions.
- 89 civic lx z6 distributor help
- battery Light comes up while driving, HELP!
- 1990 EF Hatch - B16a - YS1 LS Grinds in third in high RPM's
- can someone tell me what this is?!
- d15 to d16 vtec help?????
- Skunk2 manifold issues
- high idle trouble
- First CRX, how does this deal look?
- crx doesnt have fuel
- 3 wire IACV...converting??
- 90 dx z6 swap help?
- Civic EF With Different Engine..any ideas?
- Kay's Dutch ED FJ-Vitara d16
- no start fml!
- Center console help!
- ef missfiring help
- Do 92-96 Prelude seats fit my 1991 Honda Civic Dx
- MT 88 civi engine
- 1991 Civic DX won't start after messing with fuses
- building a mini me and have a few questions
- how to tell dpfi and mpfi TO obd1 jumpers apart
- mtdelsols 88 ef build
- Timing Belt/Water Pump Tools??
- 1991 Honda Civic Hesitation on Accel
- my vtec half way done!
- Refabricating ef seats?
- need help identifying this plug
- Help Relay Wiring Crx
- 91 CRX Si with DA integra Rear Disc Conversion.
- crx dx blown valve seals? or rings?
- 220k. d16a6: oil pump replacement needed?
- head swap
- 89 ef si for sale tons of goodies
- 90 si jumps wen taking off.
- B16a idling at 3k need some help please...
- HF w/DX trans - Wider exhaust to increase MPGs at higher RPM?
- Starting Problem
- what harness to use?
- What vehicle did my ZC come from?
- head gasket blown? D16a6
- re-building a 91 crx
- Brake lights
- wtf. Went to test my fpr , car shut off wont start, pump doesnt turn on
- transmission swap question
- 90 crx blue wirer on dizzy
- HELP! Want to make my 88 crx with 818b smog legal!
- d16a6/z6 swap ?
- car off, brake pedal feels fine. car on and running, no brakes whatsoever?!
- trannsmission help!!
- would these mounts work with my car and build
- What hub bearing do I need?
- Dropping AC into a DX
- H22 crx axle issue
- help me identify these 2 plugs
- Power Inverter Install
- HB center tail light bolts/tabs
- bbs ra on ef
- Koni yellow problems...
- Oil light stays on but oil is full?
- rear fender flaring
- any way to secure aftermarket shift-knob so doesnt spin round in circles??
- Getting Code 43, Running Rich, Missing
- Dizzy Question
- 89 CRX Si Restoration
- High Idle ZC
- will 91 ef civic doors fit on my 89 si
- mpfi swap
- Transmission Help!
- mpfi swap
- d series fireing problem
- sqealing brakes/ebrakes?
- multiples questions (with pictures)
- EXCESSIVE PRESSURE BUILD-UP!!! Cracked head, cracked block, or something else?
- dpfi to mpfi zc swap code 1???
- 1987 CRX dx Cranks, won't start
- d15b2/z6 mini me fail
- Fuel spewing out of my gas door....
- pin out question
- help 90 civic si wont pass smog
- GOT THE PARTS TO FIX MY CAR!!!!!!!!!
- Brakes not working properly on '88 CRX SI!
- Front End
- NEED HELP! gsr cluster in 91 si
- Purely aesthetic...D, B, H or K?
- Timing belt tensioner question?
- 87' Honda CRX Si starts sometimes???
- EF not performing to potential.
- Cleaned FITV and it got worse!
- 89 CRX Si Paint Correction
- Dash recover
