View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 89 Std civic 4spd Mini Me Help!
- Integra armrest
- Help!
- jdm hood issues
- I Need Help Finding Some EDM Parts
- erratic on my rhd h2b crx. tried everything need a second opinion
- How to realign steering wheel?
- really bad idle? white smoke from exhaust.
- sohc vtec for a crx?
- Tranny problem
- zc vtec?
- ticking noise, what should i do from here
- wiring issue. help needed!!
- 1990 crx si issues...
- Red Vacuum hose ?
- looking into engine work...
- battery light with a mind of its own
- my car wont start...no spark..HELP!!!
- Checking Main Relay, with pics!!!
- Wiring for ELD
- Weird oil light issues! Please help!
- There is a ghost in my tach needle! NO!
- CR-X vtec Stickers
- Battery problem
- fried rings? or headgasket?
- 1990 civic dx hb
- b16 bogs at WOT
- Suspension problem on 90 EF
- code 17 keeps comming up
- ef9 rear lip Q?
- sunroof expert needed
- Six degrees of separation - Civic CRX dilemmas and FAQ update plead. and
- 450cc injectors in a stock crx?
- zc timeing
- Dim Dome Light
- sedan door wont open
- exhaust
- question about sedan hood
- idle problem
- need timing and valve adjustment wich shall i do first?
- Gas Tank Question
- Crank pulley removal tool not fit????
- O2 Sensor obd0 b16 PW0
- ebay lip
- 88 hatch bumper vs sedan
- 1991 hatch build
- "Contest" Who's shown their rex the most love?
- my battery keeps dying
- Brakes are locking up????
- pg7 runing rich
- Super quick question...
- HELP... 1991 Honda Crx Si HELP...
- automatic to manual tranny converstion
- does anyone know...
- No power or rpms after 1st gear, help
- Need to know
- Distributor problem!
- Odd Starting Issues!!!!!! Please help
- question about wire tuck and ecu
- h22a1 in 91 crx
- Pinout
- D16 tranny; seperate bellhousing from gearbox?
- Question on offset clearance on ef sedan
- B16A2 Engine Mount Question
- s2k stock stereo
- were is the Thermostat on a B16a
- crx front on 91 si hb
- can i use these axles?
- dohc zc?
- civic problem
- car doesnt want to turn on
- on/off fan switch
- automatic crx d15b2 problem
- 91 ef si zc...
- probs with sputtering b16
- Which Rear bracket for b18 swap
- need help hooking up oil pressure gauge
- seat fittment
- Need to ask 2 things about an swap in my 91 Honda CRX DX.
- Problem!!
- need help converting obdo to odb1.
- B16a
- 90-91 to 88-89 crx front end swap?
- Strange Gas Mileage?
- check engine light comes on and she hauls butt??
- Swappin Inards
- Tps help
- Civic sedan and hatchback headlights the same?
- 90 civic hatchback seats
- **the official ef suspension thread**
- maybe a stupid question
- motor was timed, now lags
- anybody know why my EF takes so long to start?
- jdm heads, quick front end question
- Password JDM powerchamber Intake review?
- cannot find timing marks
- where can i find???
- B18b1 Help!
- Code 17 VSS with a cable not electronic
- Taking off mirrors
- std discs on gsr knuckles?
- crx glass roof install question.
- ok people, I really need help this time
- Suspension Thread
- need some boost and v-tec advice
- EG rear Anti roll bar on a CRX
- Passenger Mirrors
- removing interior panels
- 90 civic vs. 90 crx bumper
- 1990 honda civic si bared need help with p30 ecu help please help please help help
- dohc zc
- swaybar ?s
- garnish question
- shifter question
- What size light
- corner light/bumber light wiring harness?
- o crap i broke it...
- Replacing Alternator on D series. need help
- dohc zc with lsd tranny?
- Dohc clutch cable ( or ) Sohc clutch cable ++ B series swap ++
- steering wheel
- Pass. Side Engine/Tranny Mount: Torque Specs?
- Tranny fluid on clutch plate
- Differences in stock headers
- b16 wiring
- how to change tranny oil
- best obd1 conversion
- ft/fs 88 crx si b16 gsr tranny
- 1990 Civic Lsvtec Track times
- distributor fits?
- EF7 Rebuild pic intence
- throttle body cable - wont fit after dohc zc swap
- small radiator in rex
- 88 CRX with 91 motor running rich
- still touble
- Engine Oil List?
- Finally back in the EF scene
- Foglights for CRX
- wiring question
- new car b16a with pr3
- b20z swap help
- bogging issue
- overheating issues
- Squeaking noise??
- gutted hatch, floor selant removal?
- Rear crx glass on hatch needs fixn'
- Odd CEL
- d16z6
- need to fix before tomorrow!
- is it decent?
- d15 valve replacement
- rear bumper removal?
- trans for b16 and shocks/struts
- swap..
- A few 91 CRX Si problems....helps appreciated.
- Coil Spring question
- Clutch or Tranny problem
- Need a swap guide for a b18 into my ef hatch
- tbi
- dohc zc water pump
- crank oil seal
- oversize intake valves
- SI Trans Identification?
- Revoluton/Evolution camber kit??
- anyone ever raise a civic before?
- d16z6 swap Qs
- oil leak and idle problum
- wiring help. should be simple...
- crx si vs civic si sway bar
- jdm window visors on 91crx w door mounted seatbelts !WILL IT WORK ?? PLEASE HELP!!
- new ef owner
- Does anyone make Carbon fiber or fiber glass doors for the CRX?
- Another MPFI debacle
- innovative mounts h22 crx, wat axles??
- Re-Timing a Sitting Motor
- jdm hood
- clutch cable problems
- Smoking + burnt rubber smell
- Need!!
- 13" hx rims ?
- Amber light question
- Disk Brake woes!
- ef mini me swap. need help!
- My car is SLOW.. lol. Put my b16a1 in my crx.. now slower??
- does transmission x fit with motor y
- ls swap -speedometer gear???!! help
- Turbo or all motor?
- struggling after stops DPFI wagon
- Interchangeable subframes
- lose weight?
- Weird Problem
- need quiet muffler and exhaust
- b16 oil pan
- Timing belt/waterpump
- Mpfi
- b16a1 dizz
- apexi safc into 90 hatch map cel wtf
- No spark no fuel.
- MPFI help
- who has done the auto to manual ecu conversion? need help
- How can i hardwire my Fan to always run
- What is this *pic* and where does it go?
- Help please. Slow acceleration.
- itr into a 89 crx si searched
- question about performance (b18a)
- itr mani on b16
- How do i remove this piece?
- muffler options
- 89 lx civic sedan ( cooling fan always on )
- help ppl plz about shift link into my ef
- 90 civic sedan question???????
- b18a1 spun rod bearing
- Squeaky noise
- crx rpm dosnt work (HELP OR INFO)
- Strut to use for lowered suspension?
- Are these 2 hoses necessary?
- CRX seats, quick question
- What cam
- 90 crx si with Y8 head- need suggestions
- Car wont start
- Starter Question???
- Car starts then shuts off instantly
- Cracked AC Controls?
- b16 swap
- Need camber kit asap
- code help!!
- Problems with Crankshaft Pulley Fitment
- T Bracket bolt loose?
- 88 civic running rich, stalling at idle, ideas?
- Should i buy this EF?
- Can stock d16 ef injectors manage 75 shot
- ZC question
- Fuel pump/ ecu problems
- How to remove fabric portion from civic si /crx si panel
- dash cluster help
- best d series motor for my ef
- HELP! EF hatch questions bumper fitment..
- Help identifying third wire for side marker
- Smokin' hot exhaust
- what does it mean if there is white smoke comming from tail pipe?
- how to install oil catch can?
- Question about CRX 1.6i-VT UKDM cluster
- zc z6 or y8
- wheres the best place to order a motor from?
- Need Opinions! 90 Civic Si, Rear Bumper, Side Moldings, Red Pinstripe
- mini-me question
- why does not radio work
- is this worth the money?
- Need help on swap
- Aftermarket sunroof question
