View Full Version : Honda CRX / EF Civic (1988 - 1991)
- body kit question
- smog failure...NO measurements 3x amount allowable...need help
- for the y8 owner in 4th gen civic
- What is an S1 tranny from??
- sensor question obd0
- Swaps in San Diego
- Anyone Know any links 4 H23/22 into CRX?
- EW-1 block and A1 head?
- the dam tps
- changing the clutch with a swap
- Random CEL.
- exhaust
- what do I need to remove this bolt?
- pls help, swap confusion
- Engine rebuild questions
- need everybodys opinion. check it out
- will my headers fit ?
- 450cc injectors install??
- engine swap info?
- obd2 injectors with out a resistor boxon 88-91 civic dx???...
- Easy way to get OEM like and OEM quality fogs for a crx 91-90
- Will a D16A8 header fit a D16A6?
- Why is there little known about a 88-91 CRX si auto
- needin tips to go faster
- good online shop to get parts ?? coilovers lighting seats etc.
- Smoking Problem
- crankshaft ?
- PR3 ECU for a ZC engine
- L3 rebuild; maybe
- decent body kit for the 91 civic si hatchback.
- When you installed the alarm in your ef...
- Need an appraisal within 60 minutes, help???
- Tranny prob
- Bicycle-Car
- trouble again
- does any one have a diagram of a shift linkage?
- Free CF rear-side window kit for 2nd gen crx to anyone in Salt Lake willing to test?
- high rpm tranny noise
- how fast could a 91 civic si w/ b18c turbo and nitrous do the 1/4 in ?
- ecu help
- Interior fans occasionally fail - 90 Si
- L3 Tranny specs
- thermal exhuast and fi quesiton
- anyone got pics of there custon interior for their hatch
- Quaife fast ratio rack update
- 5th gen civic... seats
- Troubleshoot CODE 15 on 88 Civic sedan
- New paint on my CRX HF B16
- Si or ZC transmission??
- 1st time at the track with the B17
- turbo question
- Rear disc brakes??
- mpfi swap question
- b18C Spec R in EF8
- Pass headlight dead fuses and bulb are fine...
- Red lug nuts that fit stock wheels?
- car starting problems...
- what LCAs can be used....
- Which CAI with b18c1 swap?
- B16a or B18a ? 91 civic hatchback turbo nitrous going all out.
- front end swap
- ok finally D16a1 is ready for build: need some help first
- 88 civc dx suspension question?
- B18B into a 89 civic
- What would cause the CEL not to illuminate? wiring gurus see inside...
- b18a/b lets get the truth out here.. what tranny is the best?
- 89-90 accord radius rods fit CRX perfect?
- b16a1 major problems
- Repost of Annoyin B16 problem!
- Simple turbo questions
- honda clothing
- Do all LS tranny's have same outer case?
- HELP RYANE Motorsports lowering Steering Knuckle !!!!!
- ITR JDM Cluster CF
- CEL on... Code 6?
- Martin Chen aka on AOL as: A4DUBS
- Another EF on Super Street.......its about time.
- How to wire horn for Ek JDM Non-SRS steering wheel.
- save fuel/milk money
- what engine fits into a 89 crx and does 5lug conv fit?
- what motor does the 1991 civic si hatcback have in it ? thinking of buying one...
- Need to replace thermostat... OEM or aftermarket low temp?
- oil pressure gauge installation.......
- oil leaking everwhere......
- b18b into my 89 Si - wiring info?
- shifter problems....
- 1991 Red Honda Civic 4wd Wagon
- Just ordered this....now what...(b16 4-2-1 header)
- Tranny Fluid fill bolt is stripped...help...
- will 92 dx sparkplug wires work on a 90 si
- oil feed bolt broken off in engine....suggestions
- APC Coilover good?
- Making custom splitter. You got specs?
- JDM Models
- need help to fined B16
- Close call
- Can ECU's be repaired??
- CIVIC WAGONS REVEAL YOURSELVES
- where do zc's come from? tried search but didn't find anything!
- zc on a6?
- crx h22a mounts
- 1/4 mile times?
- Just picked up a 90 DX for 400 bucks, blown motor. no rust or dents.....
- a6 block in a 94 si ?
- Noob to EF
- CRX guru's, got a question
- 87 SI 2.0 Prelude injectors
- Motor swap problems...please help!!!
- Took my B16 hatch to the have the head gasket replaced
- ac bracket b16a
- 88 sedan questions
- Clutch chatter??? what's the cause?
- I'll kill a F****** theif.
- I want to know.....
- crx ac question
- opinions on my build-up d16z6
- aftermarket lip for 90-91 hatch front bumper?
- where can i fined a air bag set up for my crx 90 si ?
- FAQ: GM Synchromesh (tranny fluid)
- why can't I use instant messaging?
- car is heating up, whats wrong??
- Im looking for sites or someone who has pulled apart an S1(did a search with no results)
- Looking for a crank pulley that ONLY has an alternator belt groove?
- shiftknob?
- anyone know where to get an sir c/f hood?
- Wtf Code 16 Suddenly After hitting vtec Fuel Injector
- 92-95 civic rear lip install?
- Custom Valve Cover pics:
- S1 tranny any good?.....(dont kjnwo much abouty tranny's)
- Searched with no luck?? 88-91 CRX Sunroofs all the same??
- Ghetto fabulous engine removal
- B16A in '86 ReX HELP!
- Fabricating rear luggage divider ?
- timing signal? explain please
- damn noise! help!
- what intercooler fits a crx wings west bumper?
- energy suspension bushings available for 88 CRX SI lower control arms?
- HELP! Fuel filter replacement
- my crx is being really slow lately
- Cusco lower tie bar installation + pics
- trans internals swap?
- Question about cluster bulbs
- what size gas tank do i have
- What tranny do i have?????
- B16 Cost?
- Clutch questions
- rear disc conversion question
- Final Gear Help !!
- help me decide on wheel size
- finished installing ground control in crx,kinda...
- hcp mounts clearance
- L3 curse?
- Speedometer Fix for 1988 CRX HF with 98 civic EX Engine???
- '89 Si axels won't fit into my 88 DX hubs.
- NO2 installed but not sure on a few things?HELP!
- mods for 96 civic dx
- Turbo Cooling???
- -New member-
- Painting and Exhaust with high temp paint? Any benefits?
- *91 EF cat back question*
- CD player cuts out while car is running
- 88 CRX SI rotor diameter? I can't find it anywhere!
- wings west body kit
- dx stock headers fit on si?
- y1 LSD fitment question
- replacing the brake shoes on my 91 HF? Help me !!! Need help!
- is really worth replacing d16a6 rods with ZC???
- making own plexi-glas windows
- New member
- Braking question
- Swap Shop Loacations
- Clutch Question?!
- just wanted you guys to see my car
- h22 in a crx?
- ran 13.9 on new set up!
- 96 DX front brake swap
- making obd2, obd1...?
- Dont Wanna Feel Too Dumb!
- wind deflector
- Correct headers with a Z6 head.
- does anyone know how to remove the upper A arm ball joint?
- coilover springs ..... quick question
- how to identify OBD0 injectors?
- TRUST EXHAUST for 89-90 crx
- ef b16 swap parts
- biggest Front Mount Intercooler that will fit in stock bumper
- Need spark plug # ASAP!!!!
- FINALLY-- ZC head performance parts solution
- Tech question
- taking off head
- WHere to buy the "good paint"
- cold air intake for a poor boy
- ~!4-1 headers for b16a!~
- which B-series VTEC's came with red cam covers?
- Blackened Moldings?
- Integra LS Head (ZC DOHC head) on D16A6 block
- this is a dumb question-oil leak opinion swap?
- B16 rex guys, wut u think?
- which thermostat gasket do i use?
- Another DX to Si wiring question.
- Organizing a group buy of ViS carbon fiber hoods! All makes, models, and designs.
- anyone have pictures of HX rims on 88-91 Civic?
- jdm front end question?
- need websites to get parts for my ef
- 450cc DSM Injectors
- ES Bushings
- exhaust loud at 2750-3250?
- Can someone please post pic of CRX with DOHC VTEC decal on it!!!
- stock 90 Si...engine light how to fix ?
- b18 swap not running well, wont hold idle
- clutch problems.....need help
- jdm front end....usdm front end....
- how do you "feather" the clutch?
- This might sound stupid, but I am thinking on taking out the B for a D
- RS*R exhaust question, please help
- koni yellows vs tokico illuminas for 90 civic
- question about the crx oem lips..
- Springs
- Fast Idle Dashpot problem?
- EF9 frontend install Need help asap!!!
- Couple quickies...
- ***My Idle wants to stick around 2000 RPMs***<<<Help<<<
- rpm needle up and down
- Ignition Trouble... Where's Sparky!!!???
- d series electronic VSS different than b series???
- need suspension torque specs asap!!
- code 15...
- Installing A/C in DX
- Do all Y1 tranny's have LSD....
- people with hydro tranny....how does your pedal feels...
- D15 bottom VTEC head
- turbo bseries civic/crx? anyone?
- what is the correct way to wire the distributor (mpfi)
- what psi for the tires for dragracing?
- b18b vacum line routing in EF
- what are the spring rates for h&r's?
- Yo, Got some questions over here!
- does your CRX hatch rattle?
- ef and eg brake lines the same?
- rsr invidia for 88-91 hatch
- Car won't start.....
- injector order???
- D16Y8 Mpfi swap...
- strut question
- Estimate on a LS swap?
- b16a2 using ALOT of oil, no leaks or smoke, driven hard. to worry, or not to worry?!
- SMIC on stock crx front bumper
- mpfi help
- mpfi injector power problems
- cluster short
