View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Custom UEL Header for B16
- 1990 civic si hatch wont pass smog
- Seats... will they fit?
- Starter issues
- Types of CRX
- Who makes the best aftermarket Floormats
- Wheel Cylinders
- FYI : Sunroof Switch repair procedure
- CRX front calipers: SI vs DX
- B Series Mounts : Ground Clearance
- d16a6 misfire under load
- obd0 CEL codes
- wagovan smoking- valves or rings?
- 88 Sedan Issues with lights
- Swapped motor starting advice
- New project car build thread 88 CRX
- Need help with my 1989 wagon 2wd 5dr dx rear brakes. :)
- About that rear engine mount
- How should I hold particular Idle speed for test procedure
- No start, clutch interlock switch, one penny solution.
- trailing arm question
- b18 civic si 91 shift linkage question?
- Gas tank strap size?
- Wrecked EF hatch
- CRX Rear Windshield Trim (rubber lining) question
- wagovan temp guage issues-cant figure it out
- 1991 Crx Si. Revving goes off the charts then drops. See video attached!
- Why the heck isn't my car starting?
- Starting CRX after 4 years.
- zc crx axles?
- CV boots for ZC axles? (ZC L3 tranny)
- Tranny won't go in ANY gear. Engine on or off.
- Mystery Civic Mudflaps
- vtec not engaging
- Idling Problem... engine stalls D15B1 DPFI... solutions?
- Stance help
- suspension question (pic included)
- 4wd wagon
- ef sedan swap question
- How is the CRX/EF horn set up?
- Rims and Seatbelt Light Question
- 91 sedan seatbelt help
- Drooping front bumper
- Removing paint from ef rear garnish
- D15B1 to B18C1 wiring stuff
- Jdm d16zc obd1 to obdo
- Help reading a ecu code video inside
- idle problem
- Help me identify this Honda arm rest
- Idle problem - Engine quits - Resolder/reflow main relay and/or clean IACV
- ECU Questions
- need help decoding head
- my fuel level changes too much
- help with d15b7/zc wagovan!
- help please ef sedan pedale assembly removal
- obd0 to obd1 wiring
- Motor Swap Question (B18C1)
- Starting issue
- .... where to order new front hubs?
- Its been a long time ... I'm back!! and I have questions :)
- LS-V Turbo EF HB build thread
- B16 Cam Cap Bolt replacement?
- z6 into 90 crx si help.
- 1991 DX Pedal Assembly Replacement
- jdm s1 transmission clunking noises
- JDM b16a obd0 to b18/b20 swap question
- "Home Depot" Lip
- b16 swapped 91 si wont start
- A Rear Sway Bar that will clear 3" Kteller piping ??
- obd0 to obd1 o2 wiring
- help! head bolt hole stripped
- OBD0 Number 1 cylinder position.. 9 blinks..
- '90 EF hatch header/exhaust question
- Window (manual) won't roll down.
- Here is some helpful info when looking for a discontinued Honda/Acura part
- EDM Si-R Vs JDM Si-R ?
- my crx is losing low to midrange torque in base b15
- 88 CRX parts
- Head Removal
- HELP! Shift knob sunk, overheating, steam!
- Axles binding or something causing a thumping/vibration.
- Engine Info---HELP
- Pacesetter Headers Fitment?
- MATSUSHITA AC Compressor Alignment
- 88 crx d15b2 swap to d16z6
- EF Sedan Hood Bra
- Crx taillight/fuel pump wiring harness question
- STOLEN EF - TORONTO
- Wait... What? a man wierd problem
- 91 Civic Si, Random Overheating
- EF sedan auto to manual. Clutch cable questions and clutch pedal
- Mini Me Swap A6-Z6
- 91 crx si/car dies at an idle
- Virginia Pick-A-Part EF Inventory report 6/20/2013
- d15b2/d16a6??
- RHD ef7/ef8 CRX, random wire behind headlight? help!
- Need HELP Cable tranny wont go into 3rd4th gear after fluid was replaced
- d15b7 head gasket job,need some help
- SH3 / EF9 Questions
- 90 Honda Civic Hatchback
- d16z6 swap weird issue
- 91 sedan signal/marker light stays on
- Head gasket blown....questions!!!
- Idle problem? 91 crx
- help with crx code 9 b18a1 swap.
- R-134a freon on R-12 system 90crx si
- Engine won't start. Fuel Problem?
- motor swap help
- Center console options
- Where is the bleeder valve on a 1991 Honda Civic DX?
- wiring help with my hatch
- New Project: 1991 Crx SI b18 powered :)
- D16A6 Head
- wtb from manufacturer, cant get my jdm goodies ef9 jdm
- Engine Swap
- Overheat...making me pull my hair out!
- crx help!
- /sigh. what a way to start the day =(
- Rear passenger door problem
- My 90 civic hatch build!
- Sorry, another AC question.
- D16y7 in 90 ex wont start at all
- Dust Shields on Brakes?
- what are signs of a bad fuel pump.
- 91 CRX SI - CBR600RR Cluster Swap
- Tires stick out after rear disc conversion, will rolling fender lip be enough?
- y8 headers on b2
- Wiring Harness trouble
- Stock b16a with Skunk 2 Cam Shafts
- Dead Dead Civic questions
- d16a6 crank timing pulley questions
- 88 Civic - Oscillating Under Load
- misfire and a few issues trying to figure out need a little help.
- 91 EF GSR swap wont start!
- Sputtering, next day fine, today dead
- 1990 Civic Si : Sticky Throttle ?...
- piston interchangeablity
- Brake Idiot light flickering
- 91 CRX Seat Troubles
- adjusting timing chain help!
- Please Help Me Identify This Header
- Going to buy, need advice
- Steering wheel
- Red all over the valves why??
- Crx check engine light
- need help with piston rings
- cam sensor location
- Niagara CRX meet July 20th, 2013
- EF Hatch Ceiling
- has anyone installed Mfactory 4.9 d series final drive?
- crx has weird problem with spark
- Stabilizer Bar
- New ef, new daily in the making
- cant full throttle?
- Resurface or replace
- Rt 4wd tranny problem
- DIN Radio adapter 89 DX Hatch
- Starts for a second, then code 8
- Door ajar alarm beeper
- 1990 dx with d16a6 timing off?
- cant find brake pads
- obd0 to obd1 wiring questions
- Deciding between 15" and 16" rims
- What error code is this ???
- 91 CRX Si Help
- Help with d16zc swap on crx
- 88 HF CRX rough idle and general mis-fire
- intermittent short or something else ?? 89 DX auto
- Idk what's wrong with my car
- B20b timing issue-
- A1 - A2 driveshafts difference
- 1990 Civic Si Transmission rebuild and Modification
- Will da hubs fit my ef???
- B16 wasting alot of gas!!!!
- possible to bypass brake booster ??
- B20vtec CRX PLM Toda Header install question
- obd0 ef wire tuck harness?
- '91 AWD Honda Civic Wagovan/Wagon Engines?
- D15b2 rebuild not cranking
- ef hub assembly question!!!
- b16a turbo no fuel issue
- crx dies when i take off spark plug wire on #2 cil
- Please help! Having problems with axles!! Swapped ef
- 90 HF wiring issues
- to do a 4 disk brake swap...
- EVAP Charcoal Canister Fumes Smell Gas Fuel
- '90 LX right rear tail light lens plastic. (Cheap)...
- what hub do i need for my lsv???
- please help, CRX si swap
- 88-91 Civic Hatch fenders???
- EX ED3 with Auto DPFI ZC
- my idle is going up & down, from 800rpm to 1500rpm? (90crxsi)
- value of 89 bone stock crx ??
- D16Z6 Map Sensor / idle issues HELP
- Will A Wagon Roof Rack Fit A Hatchback?
- Distributor problems d15b vtec w/ obd0 connections what do i do?
- d16z6 swap help
- OH YEAH I BET YOU DONT HAVE IT!
- axle play can't figure it out
- EF Civic wheel hub problem-help please
- What shift linkage do i need?
- WTB: complete SI wiring harness
- replacement for a rear wiper arm, crx
- HELP ME DECIDE
- HELP ME DECIDE
- brand new b16 over heating issue how do i chech to see if the water pump is dead
- Acceleration Prob
- 90 hb cooling fan doesnt turn on
- 90 CRX hood
- SOLID OBD0 ECU LIGHT.b16....HELPPP!!
- some ef9?
- DOHC ZC STUMPLE ISSUE IGNITION TIMING?!?
- 8valve head on 16valve block help
- To rering or not?
- another commonly asked rhd question
- 90 LX 5-Spd Loses power in lower gears
- Civic will not crank.
- Do MAP sensors go bad?
- how to do a vacum test?
- brand New front upper ball joint is stripping - Bad spindle?
- steering wheel upside down after steering rack change and alignment
- steering wheel upside down after alignment
- 91 Civic with code 9
- steering wheel problems HELP
- 1990 Honda Civic Wagon - Starts Then Dies (Sometimes Idles)
- My 91 Ed7 project
- idling/ sputtering/ bad ground?
- EF A/C Compressors!!
- d15b1 to d16z6 swap questions
- LS VTEC SETUP?
- 88 CRX ac recharge R12
- Code 16 after installing cruise control
- 88 Civic Si Rustoleum Paint Job: Cost $70ish
- Wiring help with Prelude fogs in EF Si
- Need front brake help!
- 1989 Dual point fuel injection (DPFI) fault
- Fuel sending unit ID (NS or Denso)
- Aussie CRX D16A8 with big issues
- Is a B18B motor for $900 a good deal?
- Whats better for a engine swap?
- 90 Civic Sedan EX Tranny vs 89 Civic Si Tranny
- CEL 16 After Cleaning IACV
- All power windows not working
- Ed pedal assembly
- CRX89 D15B6 How-To,Hints,Tips,Ideas,and all Advice wanted
- 91 civic si clutch replacement
- crx probems need help...first diy project for me/first honda
- Windshield/Wiper Cowl EF Sedan/Hatchback Interchageability
- location of power window relay
