View Full Version : Honda CRX / EF Civic (1988 - 1991)
- my 88 hb dx. SWAPPING?
- Help with JDM Map Light Size and Dimensions
- axle help 91 si
- Racing seats/seat belt buckes question
- b16a
- 91 civic crank pulley tool
- need help and advice
- Front & Rear sway bar kits.
- rear window visor
- eF my ef..
- removing a cheap steering wheel
- EG rear disk on EF >?
- will
- Lots Of Pretty Common Questions (NOOB Status)
- STD Hatchie Cig lighter
- ef b16a jrsupercharger ?s
- heater problems
- fuel pump cut off switch question?
- Problem with my EF gauge lights
- D16A6 Manifold onto D16Y8 Head
- Need help with Si tranny for DOHC ZC
- *** DIY *** how to put on coil over sleeves with out a spring compressor.
- (obd-1 conv) had code 41, replaced oxygen sensor, car bogs out @3.5k rpm...can u help
- all of a sudden i cant read my c.e.l. codes, why?? (obd-1 conv. crx)
- CEL/ wideband
- 90 civic need help please
- tolerance on ball joints on ef sedan?
- tps problem please help
- ARC Winglets on CRX??
- clutch question
- WTB: 88-89 CRX HF
- zc strang acceleration VIDEO!
- b16a swap failed emissions testing
- Camber kit, funny noise?
- EF Squad Guys....
- Sunroof motor
- Sunroof stuck
- INFO on seats into a crx: Evo 9, recaro, buddy club
- Just bought another CRX, having issues...
- D15B2 8 valve. How much can it handle?
- will a d16a6 throwout bearing fit a z6 trans?
- Is CRX and Civic SI HB Exhaust interchangeable ?
- LIP on 91 DX HATCHIE
- problems with my 1991 honda crx
- d16a6 bottom end question.
- b series crx motor mount bracket help
- looking to buy my first honda. what u think?
- Question on a chipped ecu?
- CRX axel making clunking noise?!?!!!!
- corner lens blinker doesnt work anymore
- crx spark problem....
- obd1 distributor conversion help
- 1990 civix lx - fan problem
- mounts for H2b. help
- OBD0 Jumper
- EF hatch suspension on crx
- Advice need on parts to replace ( Doing Timiing Belt)
- installed sohc zc
- crx hf auto????
- 89 DX sedan
- 90 DX sedan-attempting to do a DC center console conversion-WTF?
- upgrade
- 90 dx hatch
- Road Trip
- d16z6 in 91 civic hatch wont start no fuel
- Check Engine Light Problem Please Help
- starter problem
- Leaking Tailight?
- lowered the 4door and other things
- weird brake problem.
- first dpfi mpfi help
- running rich problem
- hesitation problem
- Unusual oil leak
- jdm ef rear center seat belt???takata corporations on tag
- Convertible CRX!
- Raceland coilovers?
- problem with a 91 lx
- Door Pillar??
- rims
- Rear Seat Rust
- Overheating Cure
- STOLEN CAR!!!!!!!!!
- MASSIVE ELECTRICAL PROBLEM! HELP!!!!!!!!!!
- Wires
- brake problems
- Burning Oil!!
- zc head on a d15b2 block
- can i still run and drive my car if i have a code #9?
- solenoid cover
- dpfi mpfi car dies
- PIC Bushings VS Energy Suspension
- We Want OEM Repo Door Panels and Rear Plastic Thread !!!
- new motor! sohc zc in ef sedan
- hydro tranny on an ef 4d
- 90 DX Hatch: Car won't start in the rain? Why?
- won't start, suspect low fuel pressure
- zc manifold
- quick ?
- dpfi to obd1 help
- 91 std ls swap
- 1991 Civic Engine bay detailed
- A6 Block/Y8 Head Help
- Mini-me low end sputter?
- New Quarter Panels needed!!???
- 91 Civic Hatchback Cigarette Lighter
- CEL After 99 Civic SI Cluster Swap...
- OEM vs Aftermarket
- HELP dpfi civic wont stay running and purges fuel from TB
- wireing problems please help
- 89 CRX Si. Backfiring in engine i think.
- 1990 sedan: brakes seizing up
- Temp gauge is bouncing
- car idles fine but step on the gas and it dies
- alternator help
- repalcing the roof skin
- B16 IACV QUESTION...
- LOOKIN FOR 91 SEDAN AMBER CORNERS
- need some help h-t
- 88 civic antenna alternatives
- cluster cover question
- b2 block/b7 head
- Bugs in my car!
- engine bay cleaning products sugestions?
- dizzy help with no luck
- 89 civic hatch
- CRX - missing and hesitation
- d16y8 swap into a 91
- CRX clutch cable and clutch..need help now please!
- innovative lc-1 problem
- ooooohhhhh cr-x fans....I have a queston.
- What size CV Half Shaft do I use
- EF9 JDM SiR gauge cluster pinout diagram and installation directions
- Spark plug wire resistance too low?
- egr is bad will f22b1 wrk
- What the EF? $14,295.00 for a CRX
- Crx gauge cluster
- 91 crx running light issue
- B18a1 question
- d16z6 in ef wont start
- Almost complete build...loads of pictures...one of a kind interior/exterior
- 1991 Honda civic vibration problems
- need help ordering bearings
- ef sedan ksport conundrum!!
- few technical questions about my plans
- CRX HF Vacuum Control solenoid and CVC interchangable for other models?
- quick question
- OBD0 B16 distributor question
- HELP!! WHAT STAGE IS MY CLUTCH
- auto to manual and swapping DOHC ZC into EF hatch help
- fuel filter
- need help with tein
- b16a cable transmision help
- rex wiring ???
- BAD IDLE TROUBLE BOUNCING UP AND DOWN---HELP TECHS!
- Smoke from #3 cylinder sohc zc
- i need 2 cluster pinouts. (tried searching)
- SWAPPING TRANS? HELP =[
- Crx Coil Resistance Specs
- Ever took harness out your ef hatch?
- 1991 6-speed 4WD Civic Wagon, ZC swap
- 89 crx si fuel tank
- 90 CIVIC EF RADIATOR PROBLEM
- 90 ef starter or ignition problem
- 90 ef starting problem
- hard start, wont rev past 3500, code 13
- *pic request* tow hooks ef
- A few turbo questions
- 7 symptoms, one problem?
- Rhd clip Question!!!
- new to honda-tech. pics of my car
- STATE REFEREED HELP!!!
- going turbo need some help
- axle
- L1H1 wire colors
- 1990 ED2 sedan (USDM) style :D
- 'Donut" spare
- removing dash
- D15b2 MotorSwap
- useful honda/acura page
- dont kno wat kinda exhaust on my 89 EF
- Ef9 In freNch
- ARE 91 DX CRX SUSPENSION COMPONETS COMPATABLE WITH A 89 SI HATCH
- wago van fuel tank question...
- How many miles do you replace the oxygen sensor?
- SiR B16A swap
- water in combustion chamber / no start
- saving a crx!!!!
- My 89 Dx hatch build
- 90 SI obd1 help!!plz!
- H22a ef problems
- My First Build ever. (help me out)
- Timing question using conversion harness
- a6 clutch on y7 engine?
- anyone know where the accessory ground wire is on 1991 crx si?
- New Y-49 Si
- B16 won't rev past 5k
- Ef motor HUGE PROBLEM HELP HELP HELP!!!!!!!
- h22 91 civic fuel overload
- mushy brakes steel braided lines??
- 90 CRX Si Blower Motor troubleshooting
- 1990 lx sedan..need help with jdm onepiece lights
- starting problems ughhhhh please help
- 89 Si Climate Control Not Lighting Up
- push start (cigarette lighter)
- Wiring Issue, big headache
- help please
- Just Broke Down
- crx jdm front
- 90 Civic std...mini me swap obd1 questions!!!
- what to do a mini me swap on my crx dx
- rear disc e-brake cables
- gsr and ls tranny specs
- bout to build a mini me...
- Is there a meet?
- 1991 crx
- D15b Parts Question
- EF Dashboard Swap Stupid Question
- idle speed?
- NEED HELP
- ef9 seat pan swap onto 91 ef
- H22 EF..Take a LOOK !
- Wheel Bearing Install without air tools
- fuel pump hum
- Cable to Hydro
- Stuck throttle body plz help
- crx jdm cluster?
- EF Cabin Harness Questions.
- Help please my 89 hatch isnt running right
- painting valve cover-need some advice/help
- 1990 lx 4 door need help
- B16 battery light advice
- obd1 conversion
- NEVERMIND
- throttle cable ?
- Door Defroster Vents
- don't want to sound like a ricer but...
- Can someone run a carfax for me?
- '90 civic
- obd0 to obd1 problems
- b16 injectors into a dohc zc??????
- Do you lube threads of arp headstuds going into the block
- anyone selling D15 head!? Complete non vtec
- ANYONE KNOW WHERE THE CHEAPEST SITE OR PLACE TO BUY A NEW RS-R EXMAG EXHAUST?!?!
- Replacing the external door handle on a 90 Civic LX
- F22b in 89 EF hatch?
- NEED help squeaking sound
- Alternator issues
