View Full Version : Honda CRX / EF Civic (1988 - 1991)
- will this alternator work?
- d15b7/d16z6 in crx si
- jdm zc trans suggestions
- Code 43
- 89 si ac wiring diagram
- 91 civic si with ls swap, runs bad!
- seat belt buzzer problems
- D15b1 problems
- Can I use this for my ground cable?
- 90 crx
- mini me burning lots of oil
- Real quick help..
- will beaks tie bar clear awd
- Air Bleed Screw Question?
- car feels like it has no hp.. help please
- 90 HF wiring fan
- 91 ED with B18 axle reccomendation
- Gas guage sending unit?
- what did you guys tq your head studs at? what should i tq it too?
- 91 CRX... Help?
- 91 CRX... Help?
- Map Sensor
- Crx spark issues, sombody help please
- need info
- transmission internals JDM y1 same as YS1?
- Gas gauge not working?
- My 1990 CRX Build
- 90-91 crx defogger switch and hazard switch?
- 2nd Gear Scratching sound HELP
- ek 4 rear seats in a ef hatch?
- where could i have lost 900 lbs?
- Zc motor
- whats this wire?
- car overheated theres water on the sparkplugs
- 90 crx dohc zc
- Y1 trans. and starter help
- Need HELP - How do you test ICM or Ignitor '88 CRX ???????
- noob question regarding the clock!
- gas leak
- what to do with crx shell
- Steering rack interchangeability?
- Stock USDM CRX foglights? Help me identify please...
- gsr swap need help!
- In need of sum serious help
- Fair Price For CRX?
- stupid hatch question.
- Si Cluster in 91 STD
- sir cluster swap info, all links are dead
- z6 cam in a d15b1 motor
- 89 CRX ECU
- Brakes losing Pedal.
- B20 Vtec Bad gas? Fuel Filter what do you think??
- mini me injectors?
- wat struts do i need ??
- unknown ecu..
- OK TECH GUYS!!! ANSWER THIS PLEASE...!!!! (ZC/SI TRANNY INFO.)
- Where is the ELD!?
- Identify shifter
- DIDNT KNOW WHERE TO POST! SORRY!!!
- Horrible idle
- sohc zc idle
- Cant get alternator out of 91 crx
- 89 CRX SI won't start
- Mini-Me swap help!!!
- Questions about swap
- 1989 civic hatch front right wheel hub replacement?
- ef swap, so original
- Seat pans?
- 98 Intergra Seats in 90 CRX
- Check Engine Light on.. after cruisin for about 30 mins???
- fit hatch exhaust on wagon?
- J's racing front lip
- CRX H23A PGM FI Main Relay Swap
- MiniMe in a 90 si
- 91 SI Stupid window track
- I'm getting horrible gas mileage..
- !!!B-Swap HALF SHAFT HELP!!!
- newbish
- Comparing B-series mounts
- Looking for right ECU
- 2010 Honda CRX Sir
- D16a6 with y8 pullet jackson racing setup
- 91 B18 CRX Help ( pics attached )
- zc ef rear bumper?
- b16 crx help
- b18b1 91 civic hatch
- crx conversion harness?
- putting ac back into the crx
- Vtec wiring for EX sedan
- Power window off track
- steering column swap?
- VTEC aint kicking in??
- Help!
- crx with a d16z6 motor
- dumped efs
- DPFI-MPFI/OBD0-OBD1 ALL IN 1 HELP
- location for the transmition fluid?
- Looking for my old car
- Transmission swap questions???
- obd0 - obd1 no spark issues
- ignition switch problem
- what plugs go where?
- . . . . . Kaldenbine's Kakhi Rex Build. . . . . Lots of pics. . .
- Where's my oil going?
- wiring diagram
- d16 oil pump on d15 block
- 89 crx wont start, no fuel pressure, no spark, but engine cranks
- dc headers
- Battery light comes on at idle?
- How to install wallbro fuel pump??
- converting ond0 to obd1 vtec
- Battery Relocate help?!?
- EF Sedan randomly dying. Help?
- EF LS PROBLEM PLEASE HELP!
- quick question
- My B18a1 swap seems a little "unparallel" or tilted to a side.
- What traction bar should I run?
- crx dash swap
- cluster help
- vtec chips.
- rear drum brake help
- b16a1 rev problems
- b20z swap in 91 ef help
- what vtech head can fit on a d15b??
- Temp gauge repair for d15b1. Newbie to Civics first challenge
- Restoring an abused 91 B18
- which headgasket?
- D15 Vs D16 axles
- Spark, Fuel, Compression, but not Starting...
- B16 in 91 ef..gas problem plz help
- CRX Passenger Mirror on a Hatchback
- oil pressure light on
- b16a into 91 civic hatch with hf harnesses
- Fan problem
- No Power To Raido/Dome Light
- dash harness?
- swapped 00 y7 into ef now it wont stay on??help
- LOUD humming sound on right side of car
- need help whit my b16a turbo crx
- ek to ef suspension
- EF wire tuck
- 91 ef si idle jumps
- Couple of NOOB questions..
- Belt tensioner broken?
- B20A5 swap on the crx
- Cable to hydraulic question
- where to put dowel pins?
- Rear engine mount question
- Questions about a 1990 SI that I might buy?
- Another SOHC ZC question...
- how to find tdc
- Door Latch on my 91
- Who has AC with a B series swap?
- Blown Third Gear
- b16 swap; not charging
- honda crx rear window cover name?
- 1990 Honda Civic (4door) Dies when I press on gas hard. Please Help!!!
- 91 EF with a ZC
- Question 91 EF ZC SOHC
- DA muffler vs. EF hatch
- Possible blown oil pump?
- Side molding clip help please.
- crx help!
- will these axles work with my swap?
- '89 CRX Brake Work
- will this dizzy work?
- Replacing Mitsuba starter
- 91 Civic with DOHC Died and Wont start
- Detailed B-series into CRX/EF civic parts list, and more!
- B18B crx will not start???
- Questions on putting AC back in 91 SI.
- db7 master cylinder of ef
- water on the floor
- Seatbelt DIY
- TPS Problem
- I would like to say hi to everybody
- Whats the diff between skunk2 pro and tuner valve springs??
- battery light stays on
- 89 crx hf mini me need help
- b16a2 rex questions
- Door Panels
- DOHC ZC??
- Sluggish acceleration and misfiring. =(
- need some help
- tranny swap question.
- $800 AC Compressor replacement??
- quick trany question.
- Where can i find OEM tail lights?
- Multi point wiring harness obd1 stuff
- 91 civic Front bumper lip install question
- cant find the info im looking for on this setup
- Need some help!
- NEED HELP!
- EF SEATS..NEED HELP...
- NEED SOME HELP!
- NEED HELP!!
- Some help please.
- i need help
- What color should I paint my car?!
- D15B7 Swap inot EF HELP!
- What are some rare Crx parts?
- brake line tuck
- b swap mounts difference?
- EF impounded today
- Convert cable speedo to electronic?
- DPFI 2 MPFI won't start
- brake lights wont brighten please help
- ZC DOHC
- cigarette lighter
- f22a6 in a ef?
- CRX rear seat?
- engine sputtering?? help
- crack3d subframe help
- ls mesh rims authentic oem?
- is there a write up
- HELP ASAP! Trailing Arm Bushing doesn't fit!
- A Dumb question
- Fuel cell set-ups?
- Converting my 91 Base to 91 Si
- Converting my 90 dx to rear brakes need help!
- suspension
- Strange beeping 90 Wagon
- Y8 mani question
- 4g4d's two sedan builds at once!
- d15b7 block/d15b2 head: What timing belt?
- 91 civic dx help
- 4dr DX-no change holder
- 3 inch downpipe off turbo for an 89 hatch? crossmember question...
- do 91 civic si brake calipers fit 89 crx si??
- CRX rusty quarters?
- 91' Civic DX (D15B2)-Turning over w/o pressing in Clutch? No Start?
- Help with cable tranny rebuild!!
- Okay Question Bout D Series building?
- 89/91 interchangable? help
- deleting fitv and iacv
- ecu fuse blows
- Alternator Whine???
- gas pedal/clutch pedal
- Break in necessary?
- Rear LCA Bolt Broke
- 1 wire to 4 wire conversion
- No start
- 91 hatch wont start at times
- 88 civic sedan questions.
- help!!!!
- e-brake light
- This problem is got me stumped. please help
- 88-89/90-91 Dash differences
- CRX eats iginition coils
- Question about my EF
