View Full Version : Honda CRX / EF Civic (1988 - 1991)
- b16 swapped 88-89 CRX
- 88 EF swap
- Best Setup for HID's
- crx b18swap axles
- Need advice on value of beater 88 EF Hatch w/B16a swap bad tranny
- b16 for sale any know where 2 find 1
- my CRX RESTORATION project...
- 83-85 civic shift knob on an ef std oem shifter?
- CRX Rebuild Under Way
- need help with brakes
- Crx to EF sedan exhaust ??
- autocross
- ecu help.pm6 chipable?
- WHO HAS DA INTEGRA BRAKES ON THIER B16A HF CRX?????
- Coolant leak need help finding source
- mtf capacity on a d series tranny?
- URGENT!!! Loud "POP", then white smoke from vacuum plug!? URGENT!!! Please help!!!
- 93 gsr shift knob on oem ef std?
- Weird Ignition on 90 HB with D15B7.. Car won't turn off??
- D15b vtec timing belt??
- correct idle Q
- wats better a b20 block or a b18b.
- 89 Civic dx sedan AC components same as 90 Civic Si HB
- spoon mirrors for ef
- plug wire question
- Stock high compression b16a?.
- Carbon Fiber Spoiler
- i need to know how to install a eg rad on crx
- 90 crx dx d15b2
- b16a1 bogs any where past half throttle
- Car running very very very rich once it is completely warmed up!!!
- B16 in a DX 4dr
- calling experts, serious wiring help needed
- D15B7 Timing Issues
- HF manifold
- gasket between header and cat
- Heater controls (block off plate)
- torque on jdm d15b v-tec?
- Popping sound on front end on turns 90 Civ Dx Auto
- Crx door panels... help!
- Tranny Mount Question
- Looking to swap my d15b dual point to a d16a6 mpfi
- OK im a little baby, please help me make a decision.
- non reclinable bucket seat question
- crx clicks flashes all indicator lights on gage cluster but wont start????????
- dizzy cap for b16a?
- custom gauge cluster?
- B-series swap...linkage?
- crx armrest?
- d16a6 into 88HF swap help.. car wont start
- dumb idle question
- downpipe on b series rex
- ok ckp sensor on a multi point conversion somthing simple i hope
- help with cluster swap pleease
- FAL slim line fan?
- Blown Shock Noise?
- ls/vtec engine coolant temperature sensor
- tucking help!!!
- update on crx rebuild
- zc mini me
- differance in si and dx head?
- 1.5 DX Engine Problem, Need Some Help
- cv axles driving me nuts!
- Crx starting problem
- which manual to get for b16a
- need some help replaceing my throw out bearing, not a noob, its fuckin stuck
- where to get a new crx steering rack??
- Broken shift fork?
- A/C issues
- Registration
- Hondabond, Ultra Flange II??
- picture request... sedans with Pewter Grey Metallic and Vogue Silver Metallic paint.
- 88 CIVIC DX GAS TANK REMOVAL?
- Anyone know if any EF car came with an armrest?
- Paper ID tag on Tranny ?
- looking 4 crx around the OC.
- Wire order on obd-1 dizzy? Need help please!!
- motor identification
- sl3 ratios???
- Tail light picture.
- Take a look at this head, are the valves bent?
- Number Bulbs for Display
- LSD Transmission from HMO
- OT: CRX WTB Forums?
- leaking main relay
- 1991 honda civic owners manuel
- d15y?
- 90 dx mpfi swap out of 94 civic. do i need a resistor box
- difference in axles?
- 90-93 DA integra radiator fittment problem
- How do u take off the lil corner pieces>??
- Turbo Oil lines!
- serious transmission inquiry
- crx VS. the bettle on PINKS
- b16a to a dx, downpipe question
- what do i torque my head bolts to
- what tire size for a 15x7 rim???
- Strange Brake Wear...
- will it hold?
- Best road racing suspension setup?
- Give up on the CRX?
- Hey guys
- struts?
- unusual swap...need guidlines/ opinions plz.
- wheel bearing replacement
- looking for a new suspension for my EF
- std/b16 harness crap
- Help, starting problems.
- Resevoir Leakage
- my car wont start it making me mad now
- d series dizzy...
- climate control, vents not working
- Did a compression check on the d16z6 today.
- Long term vtec use
- anyone know STD spring rates for EF8 Ohlins spring/strut kit??
- 99 si motor in dx 88 hatch, wat wiring harnesses
- need new bushings...
- WHO KNOWS ABOUT B16A AXELS? LOOK IF YOU DO.............
- 90 Civic Hatch Rims....blades or spiders?
- Map Sensor
- Civic/CRX w/B16 Helms Book
- 89 CRX HF seats
- wont crank just winds
- Muffle / exhaust question ... requesting pictures !
- Just bought a crx and dont know a damn thing about hondas WOO!
- rear disc swap
- Windshield wipers = backwards + crazy :O
- Anoter POS for sale on Ebay
- CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK?
- Problem with zc to si swap
- Brake drum won't fit new brake shoes
- 87 civic -> 88+front swap?
- NEED HELP WITH MPFI SWAP
- what type of pistons to use when building a n/a engine?
- Car Leans Out - Turboedit Cells Are Maxed - What Can I Do?
- Extended top-hats...who makes them?
- MPFI in Louisiana? Anyone?
- Need a better picture/part name.
- Dear Grant Products: I hate you with all of my soul.
- My four doors sunroof leaks!!
- Pulley Size - D15 Alternator Pulley Inner Diameter NEEDED
- 90-91 si transmissions, how to read codes
- b16 Throttle cable ?
- code 9
- i need some mf'in help
- ZC DOHC hp potential
- anyone know how much a ZC flywheel weighs?
- hf to Si tranny
- Performance Head Parts for d15b2
- Best D-series engine... for SC'ing?
- DOHC ZC ADJUSTABLE CAM GEARS HELP!!!!
- b18a1 swap questions(into 91 hatch)
- Replacing CV shaft Question
- Explicit Speed Performance Crx back from paint (Rio Red)
- 96-00 si fuel pump, will it work in a crx?
- Good price for B18 swap
- car wont start
- Silent exhausts?
- 99si radiator in crx?
- about spoon engine
- HEEEEELLLPPPP
- How much fuel mileage will I loose? DX trans in HF?
- Crx a/c systems, sanden or matsushita
- will a da intake fit my rex
- D15 mini me turbo?
- crx b16a no oil to head
- 99 gsr cams into obd0 SIR head? that shouldnt be a problem right?
- crx/d15b???let me know wats up!!!
- d16a6 & d16z6 RODS THE SAME SIZE?
- Auto to Manual transmission question.
- just did a multi point swap on a ef dx idles up uncontrollably?????????
- need help? obd0-obd1 converting d16z6 swap
- 88 crx clutch/flywheel options
- turbo timer, do i need it?
- how do I keep a/c , cruise and power steering
- Crx Si Seats into Hatch: Swap pans or Weld rails?
- DIY JDM style civic spoiler
- my problem with crx seats
- Ls/Vtec Four Door Build.
- auto trans question.
- Code 3 and 7
- New guy
- B20 and Y21 tranny?
- ls swap in 91 dx
- rearview mirror
- Mounted up my guages
- Need Help With Swap?
- 1990 HoNDa CiViC
- best header for zc dohc
- How can you tell if a fuel filter is clogged
- D16A6 buildup: All-motor Non-Turbo Non-nitrous "Budget Build"
- anyone interested in some parts... VTEC!!!!?
- What USDM Starter is used for B16a jdm Motor?
- OBD0 OBD1 OBD2 Definitions.
- WTF... brake lights stuck on?
- B16 oil pan and swap?'s
- radiator hoses?
- civic dash in a crx
- grrr...failed smog...need advice
- Steering wheel/horn HELP!! SEARCHED!!
- Check Out This Piece -0- Shat !!!!
- obd0 b16 knock sensor question
- b18 head for trade (Massachusetts n sorrounding areas)
- 90-91 front lip for ef hatch? need one asap, where to get one look...
- jdm style??
- need info on the OBD0 SOHC ZC
- How do I get my head clean like this?
- what is the brass colored pipe under the throttle body go to on a b18c1?
- jdm hood
- 205/50/16 to big for my EF8?
- shifter bushings for a b16 swap in a crx si ?
- Sunroof Doesnt close
- Is my clutch and flywheel for a Z6 or SI?
- da abs brakes, mc, and booster question!!!!! please help
- can i use 90-91 teg axles with a 94-00gsr swap?
- the wires you send of to rywire?
- Tokico Blues: Are you happy with them?
- There is gotta be an easier way (tranny fluid)
- questions about b16 head swap on b18a block
- CRX sir Front end for sale!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 92 civic intake/head on 90 crx?
- will a b18c5 fit a 90 crx?
- LSD tranny?
- makes a winding noise doesnt start
- d16a6 dc sports header - lengthen O2 wire?
- Anyone use the FAL rear hatch lexan? (CRX)
- dohc zc intake mani, a6 mani..same??
- rear wiper wireing
- Sedan FMIC, the right way to intercool an EF
- ZDYNE ECU's??
- CRX - bogging in low rpms. humidity inspired?
- why is it slow
- tuff to shift after hard rain.
- removing dash harness
- 9005 headlight conversion
- rear struts ???
- Looking for a DA GSR
- Civ 1.5 D15b4 Dual Carb Help
- Should I risk it? (gas mileage)
- yep another thread like this. "not starting"
- jackson racing?????
- i need help with the b16
- help me pick parts
- What b-series should i run??
- swaped a b16 into my ef, turbo or all motor?
- my compression test results. need help
- waterpump???
- any one have a d series timing belt and tensioner pic(s)
- Just did my first swap!!!
- steering wheel help!!!
