View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Jdm gathers bass tubes for rex
- d-series piston question
- D16 VTEC questions...
- ««♂♀ºI need to DL the 'VTEC Supplement' .pdf ASAP!º♀○»»
- ZC motor bolt ons
- d-series motor setup
- a.i.e
- i feel like a dumbass but...
- ATTN: SOCAL AREA PLEASE BE ON THE LOOK OUT!!!!!
- bent valves??....
- TEIN COILOVERS
- blower motor replacment (HELP)
- Where to buy JDM front clip in Canada *already searched*
- brake rotor question?
- ZC connecting rods
- msd ex. coil in civic
- quick axel question
- Will any crx hatch fit any year crx?
- 1990 Red Civic Hb swap question
- OBX Cam
- Wiring help
- Hey whats up?
- Stock 91 CRX Si stock ECU 4 sale!
- help for my mounts
- Interior parts
- Just installed some new ground wires... car only starting sometimes?
- valve adjustment while engine is still warm
- EF9 resurection: Everlasting Flavor 9'r
- ecu not getting power, d16a1 swap in 85 crxSI
- Does a 96-99 civic Si motor fit a 88 crx Dx?
- 91 CRX Si brake calipers
- P28 or PR3 Mugen?
- what color should i paint my 89 crx
- Need Advice on Tranny for Crx.
- Which shifter bushing do i order?
- can some one tell me what the hell my ecu codes are throwin out
- EF Hatch QUESTION!
- D15B turbo or B16 all motor
- CTR Pully will it work on a B20 crank?? Need Answer ASAP!!
- wth is wrong with my tranny?
- Need a hatch diaogram
- constant glowing CEL problem
- oil in my b16 manifold.
- suspention for a rear brake conversion
- traction bars for handling?
- ride height post pics! tokico hp w/tokico springs? 15-50s?or 16-45s?
- 86 and 89-91 suspension compatible
- anybody with pics of 91 hatch with 91 crx dash.
- timming belt
- Code 15, Ignition control module, but......
- dual point engine dying then no probs at all???
- D15b?!!!!
- okay i need to do this now
- another one bites the dust!
- Tranny problem please help!
- good compression?
- CRX emergency flashers / alarm activation of them
- crx b16a trouble HELP!!!!!!
- changing clutch on b16 rex
- RCA outputs?
- b16 or d15bvtec
- Please help... removing glue from glass
- Help me stop my hesitation
- will a jdm front bumper work with a usdm
- ef8 swap 90 crx
- white smoke from exhaust
- b16 tranny question
- is it?
- About to paint(Prime) my car.
- jesus christ.....
- si tranyn with zc motor
- PLEASE HELP!!!!!!!!!!!!!!!! CROSSMEMBER ?S
- Interior Question: CRX
- chamber fix
- quick mini me swap question
- HELP car wont start Help
- What should I do?
- fellow CRXers in El Paso, Texas?
- Need Transmission Help - is it blown?
- Mounting 94 + integra cluster
- backfire through the intake
- ls for sale
- CALI legal swaps
- Day @ the Dyno..
- CRX DX b16 Swap wiring?
- Anyone put a crx dash in a civic hb?
- suspension question...help me out!
- need to pick a GURUS brain .
- Best Way?
- NEED SOME PARTS !!
- Broken Hood release cable... how do I open the hood?
- jdm front end question
- leaking under dash
- ZC -->obd1-->uberdata?? anyone done this?
- Leaky hatch. HELP........
- lets see those exhausts!
- Mini Me help??
- AN-R header
- mpfi swap-no fuel injector pulse....
- B16A CRX Swap Smog HELP!
- New Project
- think clutch cable is caught one something?
- Rear strut bushings installation help please.
- 1985 CRX Block Heater help needed!
- dual poing wont start!! help
- my new ef si
- fs 91 crx wid 95 convert Fresno, Ca
- alternator question??? odb0-odb1
- Who here has the crx with the most amount of miles?...
- whats wrong with my car?
- 1st gen b16 owners! GSR cam dyno test!
- B18B teg motor to a cable tranny?
- cf cowl style hoods? I need something for itb's to breathe.....
- victor x intake clearance problem
- How to clean up the engine bay???
- MPFI on D15b2
- engine swap whats the best engine to throw in<<<<<<<<<<<<<<
- Rear Quarter Window Replacement
- Curing my rust problems
- sedan rear discs, which e-brake cables? searched!
- lightening up the car - '90-'91 only - how light have you gotten your HATCH?
- need help!!!! OBD2 block swap
- 4 door at night
- F22A Swap into a CRX
- E Manage
- help!!!! b18a with detonation at 5500rpm.
- wiring f up on crx
- CRX clutch Problem
- pw0 cel question
- Brakes92 honda Civic
- 91 Si trouble
- Radiator hose
- crx count
- 89 crx si rack and pinion into 88 civic dx?
- 88-91 hathback hood fit a 4dr?
- which 96-00 hatch come with vtec
- Just got my H&R race springs take a look...
- Tricky Question
- b16?
- mini me swap ???
- crx b16 Plugs obd0
- y8 intake manifold a6,z6 mini-me
- auto swap
- Engine Swap ?
- Question about nitrous?
- Who sells Axle-Back exhausts? I'm want something OEM looking
- crx oem car cover
- 1g crx performance springs
- Whats the best way to fix this rust?-------------->
- B&G 2.5 LOWERING SPRINGS WITH BILSTEIN HD?
- Civic Tach Installation
- anyone else have pro-kits with illuminas?
- CRX Speedometer
- ok so my oil drain bolt is stuck...help
- Draft: JDM SOCH ZC non-V-TECH FOR SALE
- antenna
- Need pic of back of Z6 block...preferably bare
- changing dizzy on G1 B16. Is it like hot rods with TDC? or just put it on????
- This might help some people out CODES
- What kind of bulbs do EFs need for low-beam headlights?
- wierd noise
- b16 alternator replace ment
- 89 crx si....what size oem sway bar?
- 87 Parts
- revised head gasket
- anyone runnign falken hanabis wheels? 11lbs?
- what should I sell a ys1 w/lsd for?
- Don't Know What Year
- What header should I buy?
- MPFI conversion on an automatic
- Wiring diagram of JDM power window switches?
- SIR front bumper lip
- PM8 need info (PGMFI no go)
- si head on dx block...?
- S2000 Antenna & Mount Part #
- 92 GSR brake upgrade
- CF hood cr-x
- check out new video awd civic
- I need a part #
- Help!!!!!!!Dizzy bolts wont come off...stripped to all hell!
- valver cover breather smoking?
- Who here has the crx with the least amont of miles?...
- Locked my door and now it won't open whether it's locked or unlocked!
- Questions about Oil light and oil pressure sensor
- Anouncment - CRX FIA Homoligated / Certified Weld in Roll Cage Kits are Available now!
- Should i grab this RT 4wd wagon?
- crx for 50 bucks?
- What weight oil you use in your EF/CRX?
- 1990 d15a to b16a jdm wiring diagrams
- 1 piece front end streetable?
- Draining coolant question.
- 1990 CRX DX main relay clicking and code 16
- ~*~ PARTING OUT AN 89 4-DOOR EF DPFI ~*~
- motor swap??
- CRX Targa Top
- Ok crx guys help me with possible blown head gasket.
- Brake Proportioning Valve Differences
- ecu code
- wipers
- B16 CRX Parts Wanted!!!!
- MPFI or DPFI?
- JDM EF Rice. Most of you may not have seen this before.. lol.
- trial user
- Popping The Clutch?, Causes?
- 89 civic 4-door
- tb spacer?
- windshield wiper control arm/lever broke.....swappability Q's
- Searched: registerring RHD car, but this isn't a typical registration question...
- Heres the 2nd gen CRX in gran turismo 4(good wallpaper)
- Custom CF intake
- putting a b16 in my 87 si
- Looking for a Multi Point Obd0 Ecu in Northern WA
- Hawaii Smog Check????
- Question about these rims??
- Climate Control Swap
- It aint got no Heat!!
- Hood
- so i was driving today
- Replacing headgasket, have questions.
- ECU question..........
- replacing e-brake handle and window washer don't spray
- flaky black flim on motor
- interior swaps
- D16Z6 head swap...what ECU should i go with???
- block guard removal
- building a B16 CRX
- zc swap in a 91 DX
- Weird problem with my CRX.
- TDC problem...please help
- Quick question, overheating.......
- Need help with swap!!!
- Good price for a GSR SWAP????
- Just got a 90 Civic Hatchback
- head swap
- another axle question ..... sorry
- ROTTEN EXHAUST
- is this a good combo to use ....
- help... d16z6 swap in CRX... p28 ecu problems with BAR
- Gauge Mounting
- swap hf motor to si motor?
- type r motor and tranny swap
- My 85 Accord...
- Very Strange Axel problem
- parts
- Need help quick! (engine help)
- 84 crx (possibly sell) or keep and b18 swap?
- FAQ request
- polishing sunroof deflector
