View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Need a torque spec.
- motor rebuilding...
- water pump????
- Can I replace my 4 speed manual tranny with a 5 speed manual
- Re-painting moldings. Color match to car or Molding black?
- ED Running Rich
- tried search..will 90-93 integra rear shocks fit 90 civic si?
- Anyone ever try to put LHD rack+pinion in RHD Crx?
- DA AXLE FOR A JDM CRX SIR?
- SWAP ZC ON THE WAY (WHAT ARE ITEMS NEEDED)
- crx b20
- Seat swap...
- Looking for new suspension, help!
- crx with prelude si rims?
- Help! Heater fan and controlls not working 88 Hatch
- Do they make a supercharger for a 91 CRX DX???
- WTT WW CRX kit for stock bumpers/ skirts (NJ)
- custom exhaust-what size piping??
- My EF... just a preview
- Looking for suggestions for a commuter car
- Hf motor with multipoint in hatch with dualPoint?
- zc in midwest
- door panels
- Has anyone ever put 92 accord seats in their crx?
- p72 or pr3 ecu for engine swap
- gsr on pr3 will it work
- itb inake manifold
- pulling and installing energy bushings??
- Will someone explain to me why a d16a6 is so praised ???
- Do any1 know how to convert ls harness to vtec harness?
- PR3 ecu in to HF
- Mini me swap
- is the crx gas tank and civic gas tank the same???
- grounds???
- Si front seats in sedan, Possible?
- Trannie Question
- 94 Front GSR brakes
- TurboEdit Tuning - EVERYTHING - From Start Up To Finished Street Tune *MAKE $$$*
- 92 gsr seats into a 1988 hf crx
- what gauges and dashes fit into a 88 crex???
- new motor wont start
- motorswap in a STD hatch OBDo b16
- what just happened to my rear brakes?
- EF Hatchback B16 Swap Problems
- 91 crx si yellow for trades 92 civic hatch
- 90 CRX hf is shakeing violently
- pm6
- jdm sir cluster install?
- please help map problems on an obd1 crx
- looking for adj upper camber arms
- Starter Problem ?
- 88-89 and 90-91 molding clips. Are they the same?
- need help
- Headlight Question
- TDC sensor.. code 8??
- need a secound oppion
- hvac buttons always have power
- start up problems
- front sway bar bracket
- engine running hot
- Civic 1991, 1.6VTEC, B16A1, 150hp
- 91 EF Hatch Back Front End Fit 89 EF Four Door
- WTF??
- omg last thing left!
- tourque specs
- FS ef 1/2 size rad for track bars Z10 ect.... i know this is the wrong fourm
- motor mount kits with hydro conversion
- Just bought a DOHC ZC!
- Whats the most snow you've driven your rex through?
- will a 7/8" master cylinder out of 94 civic ex fit my EF?
- em racing c pillar bar into crx
- Using ZC tranny on my 91 CRX si (sorry, i'm a newbie)
- radiator question
- Carbon Fiber JDM 4 door Hood... Who would like one ????
- ls/v-tech
- question about YCP suzuki pistons(searched)
- JDM 4 door 1 piece headlights
- just purchase a 88 civic hb white for $975
- eCu
- Clutch Problems
- d15b Vtec Links
- I hate RUST!!!!
- 88 crx seats into 91 hatch....write ups?
- Need info on jdm d15B NON vtec can't find any specs
- crx bogs at very low rpm's trying to accelerate
- EF9 Ohlins
- no vtec
- turn signals don't work
- Silly Ebayer....
- WTB: 88-91EF (si dx std doesnt matter)
- will d16y8/z6 aluminum oil pan fit d16a6 block
- 2000 gsr cams
- Car Turns off when i step on breaks
- crx si b16 distributor help, plugs dont fit, 7wires-5wires.please
- eibach sportlines
- 17 inch rims
- LS/ LS VTEC Head Clearance
- i need help with my hood here
- CRX SiR seats into a 90 USDM CRX.......Please help!
- Need some opinions...
- want more power, cam upgrade
- 4 wire heated o2 sensor
- Cleaning floor mats?
- PasswordJDM sideskirts
- oem LSD into non lsd equiped tranny
- SAFC Install - Any Write Ups (OBD0)
- zc rev limit
- 91 sedan with 28,000 miles
- NEED HELP TO CONVERT FROM 2 INJECTORS TO 4 ON MY DX CRX
- CRX front lip question
- splitting si tranny case.... how do i do it? asap
- Does this seem right? Trying to order a new rack & pinion.
- FIRST GEN 84-87 CRX????????????
- need help!!!!!!!!
- has anyone done the right hand drive conversion?
- d16a6 into EF civic hatch?
- clutch?
- D15/D165 Differences
- itr trans
- 14" wheels in crx
- 5th And Reverse GONE! Shifter Just Wont Go Over There WTF!! HELP!(car hasnt been moved)
- n00b here, to the EF/ED platform that is, need advice.
- what header will fit??
- b16 heat prob
- New CF EVO hood...need help installing
- need info on best motor swap for the $
- NEED a 90-91 crx/civic DPFI engine harness> plz help
- ZC Swap Distributer
- Identify tranny, Y1 or YS1?
- speedsensor question
- adj upper control arm for crx
- synchro's from a d16z6 tranny fit the 90-91 si transmission?
- no Spark ?
- Idle/stumbling problem looking for possible causes?
- want to swap 95 ls motor in my 91 si?
- dpfi to mpfi conversion help!!!
- H&R Sports Spring Question
- explictness's 91 crx project log
- extreme wheel shake after integra brakes
- CRX timing belt question
- Looking for a dual tip exhaust, who still makes them?
- EG cluster into EF CRX
- 89 crx si brakes
- Searched But No Luck...
- What conversions have you done to your EF?
- Oil pressure ??????????
- Resistor Box
- where do these wires go to or what do they hook up too
- Another coner question
- will a 88 crx rear bumper support fit a 89 crx si
- why does every d16 a6 leak oil?i
- EF Moonroof visor
- is faulty seat belt replacement by manufacturer a law?
- Temperature gauge acting strange
- DC console help
- Motot swap help for my EF!!!!!
- Autometer water temp gauge ...Help!!! ---Pics!!!---
- SOHC-V into 1st gen crx
- b20 head on ls block
- Need SiR bumper lights, where can I find them in stock??
- Starting My 4 Year long project 1991 CRX Si
- Sunroof Problems...CRX 1991
- clutch switch
- Honda CRX SiR gunmetal paint code?
- seats
- d16y8 EF owners, Feedback?
- ef9 need help with wiring
- crx b16 upper radiator hose question
- Will the seats from a 90-93 Integra bolt up into an 88 Civic Dx????
- Aftermarket peak & hold injectors?
- Help! Door Swap
- 89 guage cluster face on 91?
- running a test pipe instead of a cat
- Rpm/Idle problem at stop
- LCA for ef?
- h22 in a crx hood clearence ?'s
- alternator belt fell off need help asap!!!!!
- Quick code help...du
- Stolen: Edmonton, AB, CANADA: JDM CRX SiR
- need help on code 43
- ECU PINS
- Please help me with engine managment!
- early and late model pm6 ecu?
- engine light help
- SOHC vs. DOHC. Is there a difference?
- short throw shifter
- Wiring up SiR Guages! 1991 CRX Si
- CRX hood fit in a CRX???
- VTEC power wavers in & out.. problem.
- what kind of exhaust is this?
- WeIgHt???
- springs not compressing enough
- Gsr Cams
- Huge Suspension Problem, Need urgent help please
- ex fuel pump for minime turbo
- h22 with a b series tranny?????
- i think my cars been stuck in limp mode for the past 2 years!!!
- EF9 B16A VTEC NOT POPPING GOOD
- what clutch do i use?
- Clutch Performance Inc.
- ES bushings in EF
- No third gear? help?
- Ksports for the EF
- 2ND BLOCK GONE in 2 weeks!!! help
- HOW DO YOU PULL THE HEAD OFF THE BLOCK ON SI SOHC
- Spark plug wire trouble...any hellp!
- starting my crx (newbie)
- black and white smoke?
- 1988 CRX HF ?is it a deal? PICTURES
- turbo b18?
- is this normal?
- 40/40 proportional brake valve ??? & Civic Ex knuckles
- quick jdm sir crx head light question
- Question about final drives in Dx and Si trannies...
- dpfi to mpfi swap parts questionaire
- pre-boost internals b18 c1
- DIY amber/orange corner lights. (56kILLA)
- whats the best vtec head and ecu for my d15b2?
- what shift linkage do i use?
- Bad gas milage, no horse power, motor bogs after tune up
- help with si front seats?
- cars boggin down with no CEL
- Good gauges for watching warm-up?
- My 1990 STD Got Wrecked, So Here's the UPGRADE Replacement...56K DIE!!!
- Need some wiring help
- What sunrrof will fit?
- APEX-i Super-AFC people (searched)
- ys1 parts qustion
- Adjustable Cam Gear (searched)
- female end for jumper harness?
- Springs/Shocks Installation - What to replace???
- EF ABS...Stock???
- buy my motor
- SOHC Non-Vtec ZC swap on the way. Got a few questions...
- idling problem
- JDM D15B vtec into DX
- Wings West kit, fitting INSIDE a crx?
- lookin to put 93 civic seats in my 4door...
- Need info on head swap
- Question about D-Series Rods...
- Best site for B16a1.
- im wondering????
- Sedan rear center peice
- Fuel line size?
- Want to upgrade engine for 89 civic HB Si
- Front bumper questions. 88 CRX front bumper cover with foglight cutouts?
- will prelude 4x114.3 hubs fit on an integra da knuckle
- who makes a harness bar for a 91 crx?
- nsx taillights on a 88 rex?
- b20 in 88 rex. good or bad idea????
