View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 91' civic LX axle replacement
- did search, no good. Need rod bolt tq specs for GSR
- EFI systems
- My first post here, please read Thinking of getting a 90 Crx Si
- totaled my car
- I have a 88 Civic Wagon 4WD... Will i be able to swap a B18B1 or B18A1 in without any modification??
- EVERY ONE WHO PLANS ON DOING A ENGINE SWAP SHOULD READ THIS!!!!!!!!!
- Seeking prototype vehicle in Utah-Free 88-91 Sunroof plug kit
- 88 CRX DX FUEL INJECTION PROBLEM - HELP!
- Is this a good trade? My CRX for this Prelude? Help me decide the pro's and cons.
- Please comment on OBX exhaust
- engine set up help
- VAFC/SAFC's in a 88-91
- Alternator Smells
- Need brake help fast!!!
- ***already search... too much info about sohc vtec in EF...help
- Tire alternative sizes for 91 CRX SI
- Replacing Front wheel studs???
- Pondering a PM7 ECU for my '90 Si...
- Question about Launch control with Mugen N-1 program (on PM7 ECU)
- can someone tell me or show me a pic of the idle screw 89 civic LX
- thermal catbacks loud?
- H&R spring question
- Woohoo New CRX Owner :D
- OBD0 to OBD1 harness question
- PLEASE HELP: OBD1 Distributor wiring on CRX
- any cheap jdm b16a1 block
- wheelstuds...
- best modd for $1500 b16a..91 civic si
- ITR Gas Tank question!!!
- Where can I get a set of CRX Factory Floor Mats?
- REALLY UNUSUAL code problem.
- i need some good old h-t member imput
- no heat, why?
- o2 Sensor wire to ECU
- 83 Civic Suspension question
- get rid of brownish-orange varnish in engine?
- MPFI?
- <--confused trial member
- Injectors, Spark Plugs, and Wires
- Movie
- anyone have a diagram that shows what colored wires should be in which pin on the ECU?
- Door
- what would you pay?
- reving problem.....need help
- ELD - Electronic Load Detector? what is please help
- 88 crx wtb or help finding
- wtb: 9006 HID kit
- Bad b16 gas mileage?
- need a CARB legal intake to fix my ticket...
- 1990 CRX dx1.5 read.........JDM
- Front fork pinch bolt stripped out...should I worry?
- New headgasket and still smoking
- H22 Being Ordered Tomorrow!!!
- T3 turbo too big?
- Master Cylinder
- Finally went to the track
- DropZone camber kit modification?
- How do you change syncro? Taller gear?
- 89Crx SI with greddy turbo trade for CBR 600 What you think?
- Could something involving the alternator be causing a ticking noise while accelerating?
- Help with engine hoist
- obd-1 pr3 help!!
- please help with injector order on a crx dx/b16 swap
- D16A6 catch can questions...
- F/S JDM EF9 signal lights
- transmision, clutch, shift linkage? what's wrong
- JDM EF8 Front Conversion.
- temporary replacement for intake?
- i kinda miss my stock dx engine....
- mpfi question
- Found an 1989 Honda Civic CRX si for sale
- Half red Half clears for hatchbacks????...Help please
- CTR in a CRX OBDO which Ecu to use???
- Really high idle with B16a.. need help...
- who has a sohc zc engine? can someone please check the stamp on the head!!??
- idle high, oil change, then idle better wtf?!!
- Possiblity of Bagging a 1st gen CRX?
- 150k mile ls motor, if I put a 30-40k vtec head on it, how reliable will it be?
- CRX outlaunch a VR-4?
- ecu clip diagrams?
- *HELP?* Need the pic of the NSX motor in an EF hatch
- Help: Place Racing Crossmember Install
- can someone help me find???
- tail lights...
- i'm a newbee!!!
- need d16 z6 pllllllease
- SiR Headlight Install
- Dual Point "restrictor plate" in intake
- 89 integra pistons for crx
- setting cam timing
- mini me vtec activation
- zc or si
- generation 2 zc motor
- crx body damage question
- 92 ls motor into 91crx dx....helpp
- main relay
- DOHC ZC Turbo build help
- Anyone ever burn the relay on the sunroof?(crx)
- Car wont start
- Where in the hell does this O-ring go?...ZC head...
- Where do I get fuel??
- Clicking noise from motor while driving...help...
- Which ECU should I get ??
- Looking for DOHC ZC to LS cam swap company
- steering knuckles
- crx V-AFC
- How Do I Remove This??? ASAP
- Is there a difference wiring PM7 VS PM6 ECU's
- WTB: DC JDM ITR 4-1 Header
- FS: Brand new oem stock si lip (ebp)
- Question about Gauge Cluser swap
- d16z6 ecu...
- Rev limiter ?
- Engine with a knock
- starter clicks once then nothing
- F/S.....ZC!!!!! and other 90 hatch parts
- got some NGK plugs today...
- Is this worth it?
- D16y8 with d16y7 pistons and head?
- 255 walbro fuel pump
- Will a 90-93 Integra Fluidyne radiator drop in to an 88 CRX without major modifications?
- FAQ: D15 OBD1 SOHC VTEC Mini-Me : Massive Write-up (56k No Way)
- CHP "safety checkpoint"
- d15b vs d16z6
- Swap your stock suspension for my lowered suspension in a 1988 CRX Si in MD/DC/VA?
- Low beams take a while to turn on...
- I don't know if this is a repost but PLEASE check it out.
- my starter?
- ST Sway Bar Mounts for 88 LCAs?
- NEED..complete 2000 dx, or d16z6,d16y8 swap,
- V-AFC Tunning?
- how exactly does the charging system work?
- rear window defrost prob...help
- wtb... lagg/spudder prob
- How does e-brake work?
- B series A1 cable tranny specs.......
- Is the Honda scene really fading away???
- oil is leaking into my dist., wtf?
- J & C Import Car Care
- b16/ef stock clutch cable too short
- Aftermarket motor mounts for SOHC.
- ZC Headlights in 1991 CRX...
- garages in 916?
- I can get one?front lower H-brace
- EG stock exhuast fit EF rex??
- what do you think is a fair price to sell my car
- b16a1 just shut off tonight coming home!!!!!!
- how do i tell if it is a zc
- will 40 offset work
- something loose?????????
- engine start button install
- will a zc tranny bolt to a d16z6
- need help installing indiglo gauge layovers please ??????
- WOULD THIS FIT?
- Pictures of the turbo and new block being put in!
- Coilovers Squeaking
- zc problem
- teg R lip on CRX?
- need pics of 91 hatch
- dual point to multi point
- $300 for port and polish good deal???
- tips/tricks to remove little pin dowel thing that hold shift linkage to transmission?
- Engine Torque Dampner
- cam questions
- pics of exhausts
- NEED HELP FOR SCHOOL PROJECT
- Rattle from timing belt area?
- lowering
- 88 crx si question?
- So...Skunk2 Coilovers don't fit over Bilstein shocks. Nice to know that NOW!!!
- Bull frog cam?
- 94 integ cluster in 89 hatch
- What kind of gains from a VAFC?
- alternator and belt are bad
- b16a or b18c~ Whats the pros and cons if any? i need help.
- 2nd gen civic
- ZC overheating problem
- Valve cover filter question......
- oil in spark plug port in head
- random track question
- rpm switch ?
- Anyone want a JDM center console?
- Rear Jacking point bent... what to do
- Quick question (gear oil)
- ZC aftermarket q?
- Got theived at NOPI....
- Difference in '88 and '89+ knuckles?
- w00t! my new $250 EF
- Where Does the Rev Limiter Hit on Your DX???
- car prob.
- Hydro tranny
- Mini-me power loss
- which heel-toe method do you use?
- Oil pan question .. A6/Z6
- need some info.
- d15b2 mini me more questions
- mini me cam gear? fpr?
- SI distributor into a DX motor?
- place racing mounts??problems
- crank angle sensor
- help with a mini me swap for a cheap ass like me
- Bisimoto D-Series header with A/C
- Question About Spark plugs and Oil.
- rollcages for crx.......
- Road Race Suspension for an 89 CRX
- ls motor into 91dx need help searcheedddddd
- 90 civic std...zc...ecu code 4 in limp mode...
- NO spark! i seriously need help
- VTEC controller question
- My SOHC Dyno Runs
- B18c into a CRX?
- body kit ?
- Can a timing belt be too tight??
- Head rebuild help??
- wtd 88 crx door
- OBD2 in my CRX?
- JDM Cluster in 89 Htb Help
- Skamadics
- B16 and B17 timing belt the same?
- Cheap Mods
- B16A timing
- Opinions please...
- Help, WTT intakes for a day to beat smog, SF southbay
- starting problems, please help
- Best intake size????
- ZC vs D15 Vtec
- kyb agx lowering help
- ALRIGHT I NEED SOME ADVICE!!!!!!
- WTB: D series engine W/ Low miles
- Is this 85 CRX worth $1,000
- b16 question...i know i know...i searched
- b16 sputtering and misfiring at 3-3.5k rpm
- Quick question about climate controls..
- DX to SI conversion but what about fuel pump plug? its diff/
- FRONT CHAMBER KIT
- How To Get Flywheel Off...???
- FS. 90 CIVIC HATCH,PARTS OR WHOLE!!!!!
- Debateing on a ZC tranny or si help!
- what engine to get?
- GSR armrest in CRX pics...!!!
- strange engine mount bracket on my D16A6...
- CRX ITR swap...
- if someoen has ur vin can they steal ur car?
- d15b2 and d16a6 blokcv differences
- CRX SI Tranny or 98 EX tranny?
- What material for clear sunroof?
- which drivers side axle for JDM 92 xsi ys1 intermidiate shaft?
- battery question
- Suspension upgrade questions
