View Full Version : Honda CRX / EF Civic (1988 - 1991)
- VTEC Spool Sollenoid Valve replacement?
- 90-93 INTEGRA exhaust on 90 CIVIC ???
- cutting fender wall for upper arms?
- o2 sensor problem !!!! this is weird
- JDM Bumper Lights?
- building gsr!
- Differences between a SI head to a DX
- help!crx turn off everytime the fan goes on
- ??????question??????
- Apexi World Sport on an EF? Pic Request!
- JimFab
- Temporarily fixing a slipping clutch?
- traded 18's for sliver '91si crx
- Shops
- Bolt size for LS tranny to block
- tranny input spline question
- wiper n sunroof no go
- Attention JDM backseat owners
- What type of lap top to tune?
- B16 Intake manifold thread size
- car is giving problems with starting up...need advice
- HELP: Shifter question
- Clutch question
- need help
- Looking for Wiring Diagrams? Here ya go...
- Car won't crank over....wiring?
- obd-1 stonger then obd-0
- Buying an '87 Civic Wagon...
- Tachometer, EACV randomly not working.
- civic type R pistons
- Custom intake ideas
- low manifold vaccum
- valve lash spec
- 91 civic si d15b swap questions
- CRX Studders and Dies after 6 Gallons? Fuel pump?
- Want to hear some suggestions for my REX.
- Need help with my EG radiator. Pics and explanation is best
- EDM Vs JDM question
- o2 sensor problems
- Clutch Cable Situation
- wiring a rad. fan threw activater switch
- "Wire Tucking" in my 91 Rex si.
- wiring to mpfi
- Are the seat belt latches the same on a 91 CRX as a 91 civic SI???
- Main Relay?
- Idle problems
- 91 CRX Si swapped with a SOHC ZC, not starting.
- Fitting full-race crossmember to CRX 1989?
- alignment problem, steering wheel quarter turn to right when going straight
- B16 mount bolts/bitch pins questions??
- How do I prep a valve cover for paint\powdercoat?
- Z6 vs Y8 Cam Sprocket??
- Intermitent Alternator Light
- My First cars time line. Its 3rd year aniversity with me...
- D15 to ZC?
- help i have a si wiring harness is round but my zc one is different can you repin
- no spark no fuel
- p28 or Zdyne ecu
- Help!!!!
- ????Torque specs for pressure plate to flywheel bolts????
- The Official EF Security Thread | Read Disclaimer.
- chassis hinge bolts are stripped
- 89 CRX FOR SALE "CLEAN"
- 86 Honda Civic SI ... first time PROJECT IMPORT CAR.... need help feed back and comments
- b16 or b18a1 in my EF???
- wishing for a sir interior swap
- dpfi to mpfi ??
- Avid motor mounts...good or bad?
- drive axel question
- ways to make the shit box more balanced
- Symptoms of a bad main relay?
- tps with motor swap
- Hatch accident. Help
- mugen skirt package on my ef...opinions
- chasis code
- what will a bad Cam sensor do on a zc motor
- STARTER BOLTS!! What Size Are They!! BOTH!
- ef wiring masters NEEDED !!!!!!!!!!help!!!!!!!!!!!!!!
- 90 crx dx (stock motor) Which Tranny's are compatible?
- will rhd fit? (seat rails)
- Cam sensor or distributor i have zc problem
- Need opinions on sunroof delima.
- my wire tuck!!!few pics
- Code 13 HELP
- bottoming out
- Wheels
- JRSC?
- Electrical problem, car not getting hardly any power.
- Which O2 sensor to use in CRX HF w/D16z6?
- OBD to OBD1 distributor wiring. SEARCHED!
- Flashing Code 8! Help!
- s2000 steering wheel in crx or hatch?
- How to install a used OEM rear sway bar SI
- 86 CRX SIR TYPE R
- how to use a timing gun?
- let me see your hatch
- 88 CRX DX-SI Cluster question
- what part is 1st gen B16 Vtec solenoid gasket (upper gasket)
- radius rod bushing, help
- WTB Stock CRX Bumpers and Moldings (SOCAL)
- Cam specs...........
- car wont start for new guy
- i have a zc motor in my 89 crx si the wiring harness is the si the plug are different
- Fresh Build wont start
- Smoking mini me!
- B16 or ls/vtec
- Funny smog story....
- car died randomly! (SEARCHED)
- civic front wheel hub assembly
- Pick Request: EF Sedan with Sir Bumper + Mugen Lip
- ARP head studs...
- cheap hatch
- What techniques do you guys when it comes to taking out a heater motor...:P
- Anyone know how to do valve adjustment on d15z1?
- Please help car wont start!!
- Thanks to HT.
- Front lip Question
- FIBER GLASS HOOD FOR SALE!!!
- Quick Vid of my junkyard d15 motor
- ls starter in a B20z
- What is my transmission doing ('grinding' noise when in gear and coasting)? Shifter = hard also...
- OBD2?
- Wind Direction of the Radiator FAN?
- Please help me with my B16 swap
- Where can I get a pin for the Shift Linkage on a B16 Cable Tranny, also...
- Anyone know Part number for roller pin / Lock pin??? (shift Linkage)
- Wiring a zc sohc to a dx
- how to get the reverse light switch off tranny
- Break Fluid leaking from inside my calliper
- Should i get this for my EF.
- car for sale
- How to mount Mugen ProII rear spoiler?
- reverse light turns on when on 5th gear!!! HELP!!!
- turbo my d16z6
- Stock '91 DX automatic problem.
- Fuel octanes?
- fuel pump problem
- WHAT KINDA CLUTCH SHOULD I USE FOR A TURBO d16y7 set up?
- b18 vs k20
- need help with brakes
- dc 2 center console..what exactly do i need
- Bolts for rear cargo/speaker tray???????
- D Series tranny mated with b series Engine ?
- Engine wiring estimate
- j's racing
- fan stays on?
- putting a d15b7 into my 89 hatch
- spark problem
- What type of rims do 90-91 Civic HB's Dx's....
- Stock Speaker Sizes?
- Quick Question - Exedy Stage 1 Clutch kit 92-93 Integra
- I have s2000 seats welded to 90 crx rails.... BUT....
- o2 sensor color harness?
- Civic ignition diagram
- What Do Ya Think......
- Any one replace their carpet without the help of a pre-mold kit???
- 89 civic?
- check out this cheap crx
- More security for my car
- Pedal to the floor and no go!
- Wheel PIC's
- 1991 cluster HELP needed (wire problems)
- how long?
- Good Header for the D16A6???
- Another crx totaled
- Mini Me Swap
- Starting problem
- B18C1 w/ JRSC into CRX possible??
- Swap trouble Need Help!!!!!!!!!!!!
- Feasability and work required: Stock VTEC-E D15Z1 swap into 91 Civic LX
- wat seats look best in an ef?
- The infamous Home Depot Lip! A question about mounting hardware!
- crx seat into hatch?
- ??Help; will eg or ek steering wheel hub fit ef??
- 88 CRX
- clutch question
- Swap for an 89 crx
- HMotorsonline: Complete changeover or no??? Swap parts? Please Help
- crx seats in hatchback???
- Anyone have a Bseries swap with a/c ?
- 91 Civic >> 90 CRX AC parts interchangable?
- Where to find intake pipe flanged for a greddy type s?
- Stock Honda Radio Wire Harness
- Checked out some bad advice-- AutoPower-- gutted car.
- where to get nipple caps ?
- what header options are there for a k20a/ k24 in an ef?
- yay or nay
- any options with a d15b7??
- Seat Covers for CRX Si
- valves loose>?
- clutch problem
- Destroyed my windshield wiper control....
- engine swap
- p28 code 43.
- Question about 88 tranny and Y8 swap...
- ANYONE FROM CALI SAN DIEGO, HELP LOOK FOR A STOLEN 89' BLK CRX.
- Jumped on the wire tuck bandwagon....need a little help now
- What about these SEATS?
- Compression test on an EF with Mini-Me swap
- 205 tires ok?
- 1991 civic Si Hatch Bad idle
- New CRX owner -- Needs troubleshooting help..steering?
- CRX SIR-II spoiler?
- My 1990 hatch is only running on 2..
- Court in 2 hrs, DAMNED EF RUST, bright ideas ? ?
- fugitsubo rm-01a for the crx
- Where are all the D.I.Y. on this site???
- zc head
- obd1 question
- h22a1 turbo crx
- Engine?
- 1988 Honda Crx DX-Fuse Diagram Needed
- How to close my sunroof with the wiring harness removed? 1989 CRX
- gahh..axle won't pop into tranny
- Trans Swap questions
- jdm acura type r head and intake manifold
- D15B? Can some one give me some info on his engine?
- What Kind of Wheels Are These??
- jdm headlights?
- rsx seats in a 4door
- crx si leaking water
- Chevron with techron works?
- 1989 to 1990 Cluster Help (Civic Sedan)
- gritty timing belt tensioner?
- WTB: OEM Honda CRX floor mats.
- anyone know how to chip a autometer shift light?
- radiator question
- intake mani?
- a few questions about going turbo on my 89 civic hatch with ZC someone please help me out...
- 1980 civic bigger radiator?
- issue with code 1( oxygen sensor)
- B16B swap
- ls swap with ac
- b16 wiring. . . . .am I in for a lot of work??????
- obd1 or obd2 ? obd1 or obd2 ?
- MEET?????
- Front end damage, replace bumper or take it to a collision shop?
- Question throttle cable
- Big @$$ hole in the hatch!!!!!
- help just relocated battery
- junkyards
- fuel line ideal
- 91 honda civic Main Relay Location Please!!!!!!!!!
- New to hondas, need good sites to look at.
- Blinking battery light.
- new hatchback
- buggin bout camber!!!!
- car keeps cranking and cranking(searched already)
- Another Civic w/ B16 (VIDEO)
- D series clutch help!
