View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Air Conditioning problem please help
- i have a honda crx si with a b18a1
- old skool shifter question.... pleasssse help !!!!
- testing vtec soleniod.
- Check Engine Light Unplugged?
- Wiring Q - What's always drawing power?
- fender question
- Adjusting Doors on Civic H/B
- Rebuilding JDM S1 Transmission
- fuel pump question
- Radius Rod replacement
- d16a6 rebuild questions on parts I have and can swap around.
- Need Help with Wire shortage
- suspension help
- serious question
- 1991 Civic HB Ignition switch problem... HELP!!!!
- good place to hide a kill switch...
- start up ?
- 91 CRX SI-R motor swap ideas
- broken bolt help
- where is the main relay located?
- b18b into ef hatch si
- Whale Penis Fitment on EF?
- help with interior vents?
- Injector prob after swap.
- GIRL NEEDS HELP GETTING POWER TO ECU
- supercharged crx d16
- D15b non vtec block D15b Vtec head
- what problem is this?
- apexi
- Strange electrical problem...tips for troubleshooting?
- Body Kit or Stock Sleeper look?
- 91 civic fuses ????
- OEM Honda old parts ?
- crx dash removal ??????
- 91 crx/same hood as89 civic?
- head cylinder?????????????
- suspension problem...
- sedan hood/headlight question. +speedo cable
- Brake Line Popped! Can I Pinch The Brake Line To Get My Car Home?
- b18a in a 91 si
- Was there a B16 made specifically for the EF or 4th gen cars?
- Dont know if its worth it?
- Tail light not working
- new syncros causing grind ?
- 89 civic si problem
- APEXi Civic Turbo Kit
- New to the site.
- TD-22U dizzy on B16 wired to 90 LX sedan
- cv shaft popped out. doh!!!!
- how do i rig my wireharness from a 91 civic dx to a b18a?
- Need help- going turbo crx
- what speaker size?
- Can I use an SAFC 2 on my EF hatch?
- B18 temp.
- easy question, D16A6 stock fuel injectors
- Apex I turbo timer, 91 crx
- Can ZC pistons and rods fit in my d16z6 block?
- will 98 civic hatch springs fit crx?
- TO BUY THIS EF OR NOT TO BUY? this is my question
- car shut off while driving???
- how much can i get for my car?
- fidanza flywheel
- I'm a noob and want to learn a bit more here's the question
- rhino camber kit
- Brake/Horn fuse pops when brake touched ?
- Flex exhaust piping
- passenger axle frustration....
- what to swap??? so many choices...
- Steel Braided Brake Lines
- fuel pump question?!?! need answer asap!
- 88-91 civic dx rear disk brake conversion
- survey about some jdm rare parts
- car wont start
- sensor (what is it)
- axle question-searched
- OEM civic Si Floor carpet !?!?!?!
- ac lines from firewall
- bag melted to my exhaust
- DPFI, conversion, wiring help
- FRONT WINDSHIELD (WINDOW/WINDOW SEAL LEAK)
- D16z6 swap question
- ECU REMOVAL
- Hood doesnt close with a DA radiator?
- Fitting question
- sterring colum color code chart
- skunk 2
- dx to dohc zc problems
- !!!!>>>> Help 88 CRX Si ECU Showing A Code 4 <<<<!!!!
- VTEC Solenoid
- b series distributor question
- b16a pinging/detonation issues...major hesitation
- vtec stutters....
- Tranny Swap Question....
- CIVIC hb vs CRX width
- Turbo b16 question.
- Motor Stumbles
- dc-sports header question
- quick axle question for b16 swap!! please help
- need HELP!!!! 89 civic si, b16
- what does this mean?
- Broken Clutch? What is this part called
- rollcage for 91 si crx
- LSD is locked
- has anyone here swapped a gsr into a 91 dpfi dx?
- so i did my cam seal today and was excited to find................
- ep fog lights
- I need help, flooding!
- MMR Mounts?
- Check This Honda Myspace Out
- crx b swap--wiring diagram
- Will ITR Front Brake Lines Fit on EF Civic/CRX?
- 91 dx hatch wiring diagram needed for zc swap
- d series cam
- Clutch pedal assembly??? FUN removal???
- Car dies???
- dpfi 2 mpfi now corner lights stay on when battery attached
- transmission problem
- Sedan Bumper Question
- need suggestions for touge
- 1990 Civic Sedan Rack Replacment????
- O.E. Temp gauge...F.U.B.A.R.
- itr caliper upgrade
- windshield wiper problem
- GSR Seats in CRX
- can somebody teach me how to read the codes on the ecu
- starter or short ?
- B18a in a crx
- Air Conditioning system weight.
- NEED HELP FAST
- Need some help, car broken down on side of road!
- CRX cigarette lighter
- halfway done with d15b1 swap
- wireing headache
- omg this is good
- advancing timing
- suspension questionaire! m factory parts, top of the line build
- Intake on B20
- Can't rev past 4k???
- Fiberglass doors and hatch for 1989 EF hatch.
- CRX JDM b16 header, Can you identify???????
- ef9 round foglights rubbers piece????????????????
- fast
- New Suspension!
- GSR tranny quick and easy question
- !!!!!!!Super DEAL!!!!!!!
- In process of buying CRX, some issues id like looked at
- car won't start after a long drive
- Looking for MPFI information
- 1991 Civic DX - seatbelt not retracting and sensor is beeping
- 1990 Civic DX Not Starting
- Engine Swap
- need help on my auto to manual ecu project here pr4
- doing a a6 cam swap
- Hatch-E's CRX HF build-up *Lots of pics*
- CRX lowering springs
- can i get some advice
- Bolt On D Series Mods
- Replaced fuel pump after car sat, will not idle correctly
- Oil Pan Drain Bolt Size thread for RE Threading..
- CARB components. Time for smog.
- WAT WOULD I NEED??????
- Confusing valvetrain noise....
- finally done with my swap! some pics for viewing pleasure. 56k no way
- DA rear engine mount work with D16?
- 91 civic dx mpfi converted...getting fuel not getting spark
- New Engine and Other Parts
- traction bar bolts are STUCK! show me da way
- 90-91 Hatch Corner lights on a 90 Sedan?
- sedan or wagon??
- should i upgrade the fuel pump
- Distributor wiring... cousin needs help to get his car going.
- crx gas gauge doesnt work....
- b16a1 or b16a2
- just want to get something off my chest. about my swap
- Automatic seat belts to "normal" belts conversion
- CRX
- lightened flywheel for 91 si
- any lips that fit ef sedan
- Brake Fluid LEAK(PUDDLE)
- Pics of my buddys girlfriends crx build
- need help, problem with swap
- ECU CODE 43 TROUBLE HELP!!!!! OBO 0
- crx is finally boosted, and now a little smashed up..
- crx revs slow
- I am losing brake pressure....
- CRX sunroof rust free working condition FREE
- obd0 harness to unmolested obd0 harness
- crx with d16y5 motor(cx)
- wanted honda civic complete body
- Need Help quick!!!!
- car wont start.. starter doesnt click over.
- dash conversion
- engine swap
- Running Issues
- Did a lot of work on the beater crx...89 SI w/ B16
- HF engine question
- ef wagon swap
- Suspension.. tophats? KY/GC? LCA's?
- crower camshaft question
- Leak onto pedals and fuse box!
- Finally, a new CRX
- b16 swap. coolant sensor question. i searched! but found nothing
- Weather/Dew Strips that run across top of door (SEARCHED)
- worried bout burning oil :(
- Wagon started to shake pretty bad
- v-tec without p28
- rev limit at 7.5
- where can i get straight exhaust?
- CRX - GSR Swap - Extra Coolant hose to where, Valve Cover, & Mystery rear hose??
- Radiator + Fan setup, hope this works!
- da b18 into crx
- ??? B20 Head ???
- timing issue
- It's 2:33AM... I work @ 11:15AM... I locked my keys in my car.... Someone Please Help Me
- intermediate shaft
- b17a1 swap
- HELP WITH ZC BUILD...
- ef9 b series swap trans cable dont work???
- 91 civic HB not starting
- car dies in middle of traffic!
- unusual problem, code 43
- wut do u think..
- hf head replacement question
- why dont my illuminas fit in the rear?????????/
- need dizzy hel asap...
- 94+ Integra Cluster into 91 CRX......searched.
- 90 SI fuel injectors not working
- idle problem
- infamous jerking during accel problem.
- thermosensor & fan relay .... problem fixed
- HELP ME PLEASE!!!
- Clutch engaging point
- turbo dohc zc
- where can i find information on a k24
- EF SEDAN QUESTIONS... PLEASE HELP!!!
- what is a good price for d16a6??
- i need hellp on swap information for an 85 crx si
- retrieving obd1 codes
- type-s tl wheels on a ef?
- 90 bumber on 89?
- question on a tranny code
- ob2 to obd1 engine conversion
- obd2 distributor in mini me?
- Car died going down the road...nothing comes on when i turn key...headlights still work...help
- blox shit
- finishing off my exhaust need some help
- JDM bumper help
- Pic wanted: CRX SI FMIC and bumber! what to cut?
- Need help , front clip related.
