View Full Version : Honda CRX / EF Civic (1988 - 1991)
- WOW! MY CRX with models - fotosession.
- whats this jdm thing called
- CRX Swap question?????????????????
- what brakes?
- Oil problem.......
- boost ?
- gsr fuel pump in a ef????
- wheel ? for ef's (CRX)
- need alignment?
- Misfiring, Clogged Cat, or what?
- Post up pics of dash/cluster swaps in your EF
- code 15 car not starting
- I need window visors
- Bushing replacement
- new door question
- 300hp crx.do i have what it takes to get there?, let me know.
- Any one know were....
- Twinloop exhaust on CRX/EF ??
- b16 obx header
- b16 wont start, hb,88 auto DX
- OBX LSD Install Trouble
- Finally finished mini me swap A6/Z6 head but ran into some problems.
- Can someone help me out?
- feels like boost kicks in at 3250 rom on NA b16
- After wreck hood bulge...?
- 99 si civic Type R
- stupidity
- jdm front end for sale
- h seires bracket for b seires tranny
- Key stuck in ignition HELP!
- What's this car worth
- vtec controller.......
- ITR tie bar on 88 sedan
- need help
- DIY Mugen/HKS Style Exhaust
- JDM Mirror Wiring
- Never say Never: S2000 cluster fully fuctional in EF
- need pinout for hatch wiper motor
- Changing clutch for the first time need help!!!
- Wadup everyone
- battery change on 1990 civic
- Cluster were to find the ''E'' connector
- why does my 89 honda civic.. hatchback.. have poppy exhaust??????
- wires for new cluster with tacho
- STD CLUSTER REMOVAL hlp..
- I have looked everywhere
- b16a spool solenoid valve
- CRX and Civic HB suspension?
- Radiator is out of the car, what to use to clean it?
- my Home made $4.56 Camers bracket (PICS LOOK)
- :::::CRX Lower Control ARM/rear suspension setups-Pics and prices please::::::
- 99-00 Civic F/R suspension in 88 CRX Si
- Break Scratching??
- Good suspension?
- b16 dohc 1st gen head on a b18a1 ls block code 23 knock sensor?
- Parts list for D15b vtec? water pump,timing belt,oil pan,etc.
- ignition timing on my 91 crx with sohc jspec zc d16a6 replacment
- minime on d15b2
- 89' crx hf.. b18 or b20..all motor nonvtec
- wont start
- rsx dash in crx ne one how to do it?
- 91 honda civic blown engine
- bad idle?
- In Memory of Hans W. Nothen
- sound from right front of car?
- Clutch problem?????
- Want To Be Sure You Are Going To Heaven?
- B16B2 or B18C1?
- couple questions
- roll cages?1?
- JDM front CONVERSION
- Drum Brake Help! I hate life.
- Drive line vibration??
- can 89-97 miata shocks fit on a 91 hf crx?
- Any suggestions
- how often do things break in you ef/ed?
- JDM b16 motor swap
- gauge face Question !!
- 91 CRX B16C swap.
- Newbie..
- my 91 hatchback project
- 1988 lca
- list wanted
- CIVIC "D" GReddy STYLE TD40H-15G TURBO KIT (SSautoChrome)
- fuel level gauge on a ef
- 91 Crx ZC turbo
- dizzy took a shit... what to do
- Swaps in the DFW area !! Help!!
- delsol disks
- steering wheel adapter/hub question
- want to buy a jdm crx?
- Radiator Fan Paper Clip Trick---When done correctly, does it turn off when engine is off?
- skunk2 manifold on ef w/gsr
- Hey dose this look like it would fit?
- L-Con Traction Bar HELP!!
- how can i clean the in side of my headlights?
- 197,000 miles pushing it????
- what do you think my crx in worth?
- trying to post pics of my crx? need help?
- my new EF project!
- ignition output signal Code 15
- Need help with TRANNY
- engine swap not starting
- DOHC ZV valve seals
- Honda CRX--Radiator fan doesnt turn on when its hot
- J's Racing rear wing/spoiler for EF
- Weird Sputtering/Stalling - 88 CRX
- vtec problem
- 22'' resonator fit on an ef?
- 02 re-wire...i have a miss
- Anyone ever buy from performancepartz.com?
- ECU question
- Stock japanese b16a1 vs. Vr6
- Bumpers Question
- Car will not start!!!! plz help
- GC coilover model 4245.1
- More fuel for DOHC ZC?
- mini me ecu Q
- Got a Honda HB with b16a1
- RC injectors install issue
- My 1991 CRX SI with ZC motor/tranny swap for sale
- Integra (dc) strut bar into hatch?
- flex-a-lite fan for an EF with a/c. do they make one? any other manufacturers?
- Top Speed: J1 + B18C1 + CRX = 147mph@8000rpms.
- Need help still getting a code 5
- need wings west body kit asap 88-91 civic!!!
- Integra brake conversion ?'s
- crx temperature control
- FYI - New 4-1 D Series Header
- Different ECU's
- ecu for d15b
- will a 21x9x3 intercooler fit on my crx?
- Serious problems with axles in ZC tranny swap
- Want some opinions about my ride....
- What do you guys think of Drop Zone shocks?..
- Should i put a kicken stero sytem in my 91 crx?
- battery relocation issue.
- ITR or CTR cams
- Need help B16 HF swap
- starting problem
- Used search, now have some quick nitrous Q's...
- Just bought a 90 Dx tahiti green (or however u spell it)
- CRX and 90-93 Integra interchangeable parts?
- Thinking of selling my Rex
- when i step on the breaks...........
- dude, WTF is goin on with this transmission?
- code 7
- Where did you purchase your suspenion parts?
- Clutch problem....Please help..
- crx B-16 swap Serious problems PLEASE HELP!!!!!!!!
- Newer Crx Dash?
- Rpm problem (already searched)
- Center cent gauge holder??
- rpm problems help!!
- brake lights stuck on
- Best fuel pump for 88 crx
- which lower timing belt cover for DOHC ZC?
- tach is going crazy?
- Strange interior noise...
- cel #9 after seafoam??
- LS or GSR Motor Swap
- Where can I find a DIY on how to swap a b18b into an EF?
- motor swap
- attempted breakin, how do i fix this?
- one bad ass crx video
- 2 O2 sensors on b16a1???
- 91 Civic DX Radiator Fan Question
- z6 manifold on multi swap
- need help replacing blower motor on CRX. can't get it out searched
- Black breather box, PVC system with AEBS manifold
- setup question?
- Throttle cable ??
- help..flyhwheel question
- My new shoes...
- 88-89 headlights into 91
- 1g CRX who all has one? Who all has a swap in it :o ??
- Got my tein basics and mugen bushings
- JDM Hood help
- Mini-me won't hold idle - possible electric probs?
- Tuning with hondata
- adjustable fuel regulator
- engin codes ??
- question regarding cats: epa and carb approved ones for smog
- Question for a school project.
- 91 Si running too cool
- Would EK rear lower control arms fit into EF?
- ecu interior harness?
- Si Tranny vs. DX Tranny
- clutch question.....
- swap
- turbo or vtech witch would be better
- hub question for b series
- need help car runs like crap
- 1990 Honda Civic SI Non-Vtec SOHC Worth doing anything to?
- My EF At the Track
- hp/tq
- just want to know where the best place or easy place to put an sender unit...
- need urgent help
- Clutch cable removal and installation
- crx throttle cable
- Tom Powell - Who are you?
- v-tec for y8 head a6 block mini me conversion
- crx JDM Mugen Bumper
- gsr throttle body on a d16?
- p28 on y8?
- dc sports universal muffler on hatch?
- Getting my EF8 front end
- Smokin pads ?>
- flat balck question
- Need Help
- B16a CRX starter problem
- who can i get amber bumper lights from 91 crx
- tech help needed for battey relocation ...
- differences between a6, dohc zc, b2 cranks
- Rear wiper not working - out of ideas
- Help me fix my smog issue problems (I failed :(
- Brake Upgrade??
- Car making whinning noises 91 civic si mini me swap
- were to get the front lip that comes stock on the si?
- dsm 450cc
- GSR cluster Not working in 89 SI
- sohc vtec swap into EF SI dizzy question
- No spark!!!
- Is it true?
- Quick help: installing stabilizer/sway bar (over or under?)
- HELP !!, car cant start.....
- piston size?
- 00 Civic prices?
- Getting ready to swap d15b vtec questions
- Removing Camber Kit
- TWIN Cam ZC swap into 91 hatch si problems
- mini me question???
- Does D15B2 distributor work on my D15 VTEC???
- Engine revs on highway
- anyone with Ef civics with a pic of exhaust angled sideways?
- 89 CRX HF Headlight?
- Your opinion!!
- swap help
- Body work and paint job...
- Clutch Quality
- Which parking brake cables?
- oil pump install question
- What's this worth??
- are jdm civic plastic headlights same as jdm crx plastic headlights?
- I got projector halo's for my 90 civic hatch back but don't know where to wire them???
- check this out...
- energy suspension bushings?
- bouncing Idle, will not idle in gear
