View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Complete OBD2 JDM B16 Sawp....
- power window from integra or lude
- dpfi-mpfi power feed
- MPFI wiring question
- steering hub
- Need pictures of JRSC install
- crx pillar bar?
- Give me some input, planning my engine.
- Exhaust: Low Tone OEM Crx Place Muffler? What brand?
- Clutch Problem, need help
- Need help, wondering about best engine swap...
- where to find caliper brackets
- 88 CRX CV axle problem
- Look at the shifter I made
- 1991 civic hatchback 1500 fuel injection
- Swap troubles
- Wind noise on the windows of my hatch...only 70-80+, very annoying!
- crx side mouldings
- sohc zc redline?
- Dimensions of Cat on 90 Civic?
- EF transmission codes question.....
- need help: my car is making weird noises'
- H22a crx turbo
- 95 civic cx, need helpppppppp
- WTB: ST rear bar for Civic
- post those clutch install guides
- DOES ANYONE KNOW
- Anyone here have a one piece header?
- does code 7 make the ecu run in limp mode?
- whats the difference between sohc zc vtec and d16z6
- Made a ED Squad Shirt for myself to wear around town what do you think?
- Who knows their D-series?
- BROKEN CRX WINDOW HELP! ASAP.... ITS GETTING REALLY REALLY HOT OUT!!!!
- ground problems???
- stupid question but, how do you put pictures on here????
- What size tire to put on 15"/ 7" rims on 88 crx?
- My car got smased
- Do the CRX SiR (front end) headlights shine oncoming traffic?
- exhaust decision
- how can i remove this
- 4 wire o2 what goes where
- Question on Ford Probe GT
- stupid newbie questions.
- T&T wants 3700$ for a CRV Block
- Dashs
- Header problems........ BOOOO!!!!
- window rattles when...
- vtec won't kick in ,, help, help
- Craftsman motorcycle jack?
- what fan do you use for a eg radaitor in a crx
- what head gasket
- B&M short shifters
- idle at 3000
- Rear Seats
- Junk yard find and great deal
- What cold air intake do i use for a dohc zc in a crx?
- Slamin and jamin?
- What should I get next?
- tranny / clutch problem? .... take a look.
- Nitrous help....
- New Clutch...Big Problem, Pls HELP!!
- $$$$in need of a front end in the BAY- ef9$$$$
- B16A2 Throttle body On DOHC ZC WRITE UP DIY 56k go order dsl and come back.
- CRX got rear ended tonight :(
- hood wont stay down
- aem pulley for jdm b16
- Fiberglass Door Panels for a CRX???
- obd 0 b16 distributor
- Civic #2 is almost done (56k beware lots of pics)
- Questions on busted timing belts...
- straight bolt in motors for ef3?
- Lookin for 1991 si tranny, trial user stiill please help!
- B20A in a 90 civic si?
- Any IACV compatible to fit a Hf
- Question for all b-series swap
- High compression pinging problem ??
- rear speaker cover plastic??
- Is an EF hatchback considered a station wagon?
- Car wont turn over
- LS TB + Y8 IM = Vacuum??
- washed my engine bay, now i have electrical problems
- who says 17s are too big for an EF hatch?
- BATTERY IN TRUNK - EXTREME PROBLEMS :(
- B16 EF Intake Question
- Anyone put a different horn in your car?
- Going to buy a crx.... what motor should i drop in it?
- TenzoR seats.
- Camber Kit Advice
- question about torque
- car overheating?
- Where can I find jdm bumperlights for a crx?
- sunroof
- Car keeps dying in a Carbureted Civic Any suggestions??
- Help with code 17--VSS
- Where to get JDM folding mirrors?
- check this fat car out
- Lower Radiator Hose temperature
- b16a help on 88 Si
- TurboEDIT 2.0.10 (Try10) Now Available
- i'm looking for a b18(GR-R)or a CRV block With a Gsr head hit me
- Removing charcoal canister with stock D16A6
- couple questions about b16a
- DOHC ZC?
- Over Heatin
- z6 or y8 head?
- 90 hatchback coilovers in 89 crx?
- How to wires VTEC to my shit light.
- zc losing power?
- code 6 only in reverse gear???
- B16A2 for CRX
- FEELS fenders on a CRX
- CRX, OPEN TOP???
- dc sports exhaust piping size
- urgent please tried searching, diagram of ecu wiring of b16a swap
- Wheel stud size '91 civic?
- Who has installed the Hondata Intake gasket ?
- WTB Apexi WS catback for 91 CRX Si
- FS: 3" Thermal exhaust for 91 CRX in Md
- $500 CRX?
- help, popping noise when braking also when accelerating
- Post Rim/Rim Size!
- Ride hight with 17 inch rims
- Need help on b18a swap
- code 20 electrical load sensor
- What valves can I use for an aftermarket cam?
- 1/4 time help
- Ebay Recaro style seats Q
- axle question
- cross member torque specs
- Rear Calipers
- CRX front end on hatch?
- 1990 crx boggs down threw low rpms. can anyone help me
- air intake for B16A or CRX???????
- hi, i'm new and about to purchase a crx. what swaps can i do?
- fuel leak after fuel pump install
- 1990 Honda Civic Si Info
- Fuel pump not working after OBD-1 LS swap...with JDMSHIT.com harness..
- cable to hydro tranny
- crx w/ h22a swap, is this possible?
- Help Me Contact TAG!
- HELP putting fenders back on
- lost fuel pressure
- B16 into crx Q's, AC, rad hoses, and hasport sub-harness
- Has anyone ever done a dohc swap on a crx dx
- Cluster question
- need jdm cable trans with lsd?
- delsol d15? intake manifold question
- d16y5 to d16y8
- any suggestions on a SOHC ZC motor in a reX??
- Install help with 4 piece Strut and Tie bar combo 4 '89 CRX Si
- hf wiring harness in si
- NEW KYB AGX adjustable shocks 88-91 Civic/CRX for sale MIAMI FL
- Turbo a 1988 crx dx model
- 92-95 lip on an ef?
- Seat belts/4pt Harness Buzzer
- Anyone done a CRX front end conversion (fenders/bumper) on a Civic?
- 88-91 Civic HB/ B-series swap parts
- somebody school me on transmissions
- erratic idle when warm
- Honda Twincam Works
- integra suspension
- 87 civic with bad tps
- 89 civci si looking for the best eng to put in my car?
- FS: 88-91 crx blitz front bumper and side skirts
- RS_Limited Limix 16" - Do they even make these?
- need help tuning ls vtec turbo, anyone in or around philly area?
- radiator hoses for 91 b16 swap
- cam gear universal
- 90 door moulding on an 89???
- just venting ... passed up a good deal..
- EACV pin swap for MPFI?
- 90 Integra parts car (brakes, etc. for your EF)
- bought a 1st gen CRX (87)
- What cluster looks better in person? DC or EK
- help me identify this front bumper please
- clutch/flywheel
- 89 Crx HF b16a swap but axles not replaced?
- alternator?
- DX engine into HF
- question about weather stripping and trunk?
- axle questions..please help tho?
- Confused about tranny.
- Difference between automatic gauge cluster/manual from an '88 civic?
- mini-me compression, whats safe?
- Headlight Bulbs for 90 DX... i need opinions
- engine beam and steering
- EF hatch Mugen wing
- lug nut wont come off. pls. help ASAP
- Carbon Fiber wing for my hatch???
- LMA upgrade for Dseries
- I have a crx i want to sell and want to know
- any1 else?
- help plzzzzzzzzz
- Radiator fitment in a 90 civic lsvtec turbo????????
- B18A1 in an Si....
- Got any pics of EF with 1.6EL rims???
- My Turbokit has com =)
- b16a1 swap help?
- dropzone coilover
- what honda/acura seats fit my civic?
- NEED B SERIES SWAP GUIDE
- NOOB help
- ZC swap help
- usdm 5lug setup bolt onto ef?
- Civic and CRX door panels interchangeable?
- turbo
- eg to ef
- I'm so sick of wiring problems - read please
- Just picked up my new baby, and I found a nice surprise!
- electrical problem
- Zc internal manufacturers?
- automatic b16a
- Cant shift from neutral to first
- Where can I find carbon fiber lips???
- timing belt. how much is too loose?
- Rear Bumper Support for '89 Hatch NEEDED
- running wires from through door?
- need help to wire ecu on a hf with b16
- Recomendations
- 90 hf swap , HELP
- ANY BODY KNOW WHERE TO GET CARBON FIBER TRUNK FOR CRX?
- Loose sounding suspension, driving shudder
- Who makes bolt on exhaust systems for the EF hatch????
- need help, 90hf swap
- quick question about zc/si transmission/clutch
- C&R Radiator Install pic
- ***b16 help***
- CRX swap...?
- just got another crx great price
- ------>army green<--------
- engine weight
- HELP FINDING JDM CRX PARTS....BAY AREA EF8
- HELP: hood cable
- thinking abt selling my car
- obd0 to obdI
- 97 civic ex power door locks and dome light
- How to Break in your motor?
- valves stuck opens
- Civic wiring harness?
- no 1 piston at tdc
- what non vtec valve cover fits a d16z6
- need quick help: EACV wiring
- Old seats = wear... anyone tackle fixing them?
- CRX HF on ebay
- Anybody that put AC in a non-AC ef before?
- how to wire ecu for lsvtec crx?
- problem with my Hasport cable to hydro conversion
- My ZC gear box = really strange
- Fun with shaving... no razor required.
- Wondering how to replace the float on my crx
