View Full Version : Honda CRX / EF Civic (1988 - 1991)
- distributor?
- EK seats into an EF hatch
- harness help
- Accord injectors ??
- clutch let out, car dies, help...
- [DIY] OEM 88-91 Honda Civic Cruise Control Retrofit Install [courtesy TJS Hondas]
- auto transmissions
- 90 CRX DX with B16 swap wont start HELP
- DA rear sway bar on a 1991 Std ef hatch
- DPFI to MPFI swap questions
- Question ?
- Wiper's not working, missing plug to wiper motor HELP!
- i have a b18 motor, looking to vtec
- Help i need to confirm my mini me head PM3-8 on a d15b2 (T Belt???)
- Wont go in gear
- B16 not fast enuf 15.2 /1/4 mile
- steering wheel !!!!!!
- Help! Electrical Problem!!
- A Few Questions!
- vtech head on ef
- Help b18a1
- b16a crx obd0 idle problem!!!
- Help w/whale penis intake fitment -
- 1989 rear mud/splash guards on a 1991 civic si
- fuel pump
- Strut Bars
- After market Carpets
- would a speedometer cable from a 91 crx si work on a civic wagon 4wd fit ?
- CRX Wiper Arms
- Wanting to do z6 swap
- Car died, jumped it, then when put in gear it dies again?
- 1990 CRX Air Metering
- Custom axles for h22a into crx
- civic/crx windshield wiper arms the same?
- timing question
- Knock sensor question
- 89 civic hatch si b20
- Quickie - Whats this called?
- Tail lights
- power loss?????????
- Swap motor wont start!
- integra GSR cloth seats in EF chassis
- zc alternator replacement bolts and bushings?
- Battery Relocation Problem
- Timing issue
- 1990 CRX with G23
- ED6 Corner light question
- couple questions
- CRX si d16a6 bolt on Dyno-Graph inside
- b18a1 timing cover question
- How to remove extended studs when broke down on the side of the road?
- '89 Civic / Replacement Seats?
- no warm up cycle?
- Honda (and car) newb...
- fuel line thread size
- Very Perplexing Problem 90 CRX
- code 14 troubles
- the new guy
- I'm New, Whats Up?
- Transmission mount help
- EF Wagon + EG Sedan Honda day 2010
- 1990 CRX EGR Test
- radiator on a b series wagon??
- Civic fuse questions
- Leak in passenger rear floor. Where to look for first?
- EK A/C in a CRX
- ED Si badge
- full race radiator, what rad hoses?
- Power Steering on d16y8 in EF
- Let's put an sway bar on a CRX that didn't have one.
- Electrical short problem
- new to H-T..but not the game!
- LS webs or mesh on an EF
- d16y7 into DPFI EF
- Diagnostic w/ neptune EMS?
- new to H-T
- 90 hatch, front bumper screw size?
- crx shift linkage
- d15b7 non vtec question..
- fijicrx
- Smoking Brakes Please Help!!!!
- booster replaced...calipers stuck
- CRX Fuel Pump or Gas Tank Problem?
- 4040 prop valve help.
- STRIPPED WHEEL STUD
- water leak by rear hatch strut
- B18C JRSC, what internals should I use??
- How much brake fluid should I buy?
- Upper Molding Replacement - 90 CRX
- ECU/Codes diagnostics
- b16 sleeper exhaust?
- Valve Cover Gasket
- 5 Lug my 90 Si
- b18 ef problems a little help guys
- skunk2 coilover sleeves?
- red light on pr3 ecu
- Engine starts.. But only with a jumpstart
- car wont rev past 2k help?
- Quality Rear strut tower bar that does not require cutting plastic?
- rear sway bar help??????
- Okay looking for ideas
- H2D Help
- DIY:90-91 CRX Dash in 88-89 EF Hatch
- will a four door bumper work on a hatch
- 1991 CRX DX auto hard to shift sometimes
- Electrical problems stemming possibly from thermostat ground?
- B16A in EF - Alternator Issue
- how to tell when a gauge cluster was made?
- civic ef zc
- D16A6 to D16Y8 Mini-Me Write Up
- 30/30 vs 40/40 prop valve??
- need help with head code
- Password JDM 3 point strut bar
- My 88 Sedan
- anyone know how to modify a alternator?
- H22 CRX innovative mounts for sale
- Cluster problem, temp maxed (not engine)
- Oil Pan Question
- help
- d15b2 block + d16z6 head on nitrous????????
- people with obd1 conversions please chime in
- ef fogs/ broken lense
- what manual transmission fluid can i get at autozone or advance auto??
- d16y8 into a EE wagon (Header hitting oil pan)
- why is my transmission grinding on 3rd
- Fuel pump question
- no thermostat fan switch on the housing
- help converting obd0 dizzy to obd1
- Hard start and hesitation...
- Steering wheels interchangable?
- 00 Si front seats in ef??
- Original LHD EE8 CRX and EE9 Civics for sale
- where is the vss located?
- Electrical short, possible ground problem.
- problems b16a1
- ef b18 help
- AC compressor interchangeability?
- B18a1 swap help...
- LX 1990 Window problems
- question on injector problem
- just need some info
- Reversed battery terminals! Need help ASAP!!!
- Car shaking at 30+ mph
- please help
- Ecu chipping?
- 89 crx si engine harness on 88 crx si question
- zc sohc vtec alternator problem
- D16 Block W/ Y8 Head
- Out the top or threw the bottom?
- autozone axles
- Question on speed sensor for 90 civic b16
- No hood latch cable on my 91 hatch how do i open hood
- do you guys know if..
- Using full DA F/R brakes with 13/16th's brake booster and master cylinder.
- rookie question about sohc zc
- ED (Hatch Si) to EE (wagon) Swap Compatibility Q's???
- My sedan,
- Trying to Locate a roof In Illinois
- Fueling Questions
- air leak question..
- Hydraulic Clutch Conversion 1989 Honda Crx with B18c5
- brake problems still
- How long should the fuel pump run? (ED9 - PM7 - D16Z5)
- Is my thermostat bad?
- JDM parts catalog
- e-cut out with tb
- Faild Smog Nox at 15MPH Hour Everything Else Passed.
- EF 1988 From Thailand.
- re upholstering ef sedan door panel insers
- Boost Cutting Help?!
- 91 crx si with obd2 swap
- brake booster question
- anyone know the best place online to buy oem 4dr sedan ef floormats at?
- iacv help?
- car wont start 90ef hatch
- O2 sensor blues.
- D16A6 to D16Y8 Mini-Me Swap Help
- my frensh sushi car^^
- Crx running rich
- painting my engine bay need help
- getting code 6.
- need help with codes
- ebay crx door visors!!!!
- help finding stick-on (non-functional) sidemarkers?
- new here just showing my rides
- Projecting....dirt cheap quickness..
- B16A Sputtering Problem
- Extremely Bummed, Bent Frame Help Please
- D15B7 Help
- 90 civic si clutch problem please help!
- Console Integra 94 into EF 90
- 1989 CRX SI... Sudden Brake Failure...
- Suspension Question
- Timing Belt Jump Car still running Fine..? Cannot Adjust Ign Timing..
- Your Traction bar setup/recommendations
- My EF Sedan (prob. the slowest build on here!!)
- Hey guys bearing choice?
- CRX or Civic VX Hatchback?
- What oil do I use?
- a6 block y8 head what timing belt and tensioner
- Arseezy's EF Sedan (SLOWWW build)
- Aaah- But will it fit a 4DR sedan????
- Civic Si hatch with B18 swap (LS swap) - how hard to maintain?
- how did you run your IC pipes?
- Machine shops in miami
- Body Kit Help?
- Upper Control Arms
- Car bogs under steady throttle.
- How to remove quarter panel trim?
- where to buy door trim and window trim
- head swap problems!!! HELP PLEASE!!!!
- resistor box question
- crv tranny in a wago?
- Plastic "Glass" next to hatch on rear removal?
- Cable or Hydro trans.?
- quick question about b16a timing belt
- BiGDeE's 88 Dx Build
- So, I wrecked my baby, need some help please!
- My Hatch and CRX
- low idleing need some help
- I want to pull 1g on the skidpad...
- help my ride wont start
- Been doing a little research on EF suspension. Here's a write-up.
- KingKoala 1989 EF Sedan Build
- EF Sedan for $150, should I go for it?
- Cooling system questions - 1990 civic SI
- B20 questions
- B series tranny problems
- Suspension
- Ingall's style camber kit question
- ls/vtec no spark
- CRX SIR hood fitment
- need help engine surging and boggy when pedal pushed
- crx b18 swap axles help
- Ok need some help 91 si hatch
- Oil pan gasket replacement.
- B16 Knock Sensor, O2 sensor, radiator cooling fan
- Is the Owner of this hatch on Honda Tech?
- Finishing Economy Hatch
- Prelude disk to Civic?
- mpfi question?
- Grassroots Motorsports needs a nearly stock 1st gen and 2nd gen CRX for a story.
- help my crx is having isses
- 1990 Honda CRX SI STOLEN in Bakersfield, CA
- Will 91 civic corner lights fit on a 89 civic?
- Honda Verno???
- Are integra tie rods longer than civics?
- Ls swap 91 civic dx no spark
- Motor Question...
- turn key everything works. but wont start
