View Full Version : Honda CRX / EF Civic (1988 - 1991)
- compression on motor only 130 all across? runs fine?
- A couple of problems, need suggestions!
- 88 tranny spindle 90-91 spindle
- stooopid question
- compatible replacement for SiR axle boots?
- n00b Q:
- How disable the horns with a fuse?
- Switching Cluster
- Testing VTEC?
- Taillights went out, fuse keeps blowing?
- WIERD shifting problem...
- i have a question
- inlet manifold swap help./info/advice.!
- i need code 7
- Getting Code 6 (Engine Coolant Temperature Sensor) couple days after swap!
- d16a6 throttle body spacer
- ZC trans gearing????????
- easy fix or a headache?
- getting rid of my problem (looking for a new wire harness)
- 2003 civic EX motor D17A2 in an 89 hatchback!
- HI all fellow ef'ers and honda enthusiasts!!!First post about my car:)
- 88 Hatch muffler on a 88 CRX will it fit
- Header clearance "?"
- Where does this hose go? *pic*
- wrong place, but sweet!
- Free Stuff-Rear Drum Brakes, Ac stuff...
- Code problem 21
- Removing the bumper guards
- mount problems
- Few problems with my 88 ED LX
- Idle problem
- Having a problem putting my Crx cable in my obd0 speedsensor doesn't go all the way down but lines
- would a v8 be a good idea for a crx hf
- what do I need for....
- hasport mount looks funny for b20 swap
- Question about what I need for my swap.
- what are you doing to your D16?
- differential fell??
- Will Civic 92-00 IC piping fit my EF9?
- wireing diagram for dash harness
- itb's?
- rhd crx mount problem
- Car vibrates eratically when leaving from a stop in my 91 Honda Civic H.B with coil over springs.
- head gasket leaking
- Car Randomly Dies? any ideas
- 91 Crx Engine Problems.
- Koni Race/GC or PIC Select for CRX
- anyone wanna help?
- brake conversion/teggy shocks needed? yes or no?
- brake calipers stuck??
- Underdash wiring harness question
- does a supercharger come with a throttle body
- what tranny is compatible?
- new dizzy installed on d15.. still no spark
- A little help with my JDM EF9 straight from Japan
- I still think the 4th gen. hatch is one of the best looking Honda's ever.
- AC Installation
- Right blinker=blown fuse??
- off topic question
- WILL this work
- Finding interior for my car?
- skunk2 cat-back piping size?
- Initial hesitation on throttle, missing, and CEL
- Tire Qustions?!!
- ***Check out my half size RAD.***
- converting my 1991 civic dx wire harness to a fuel injected
- 89 crx si sunroof problem
- What pistons in sohc zc block
- Can anyone identify these parts, and hoses for me? *pics inside*
- ***No THermostat***
- Free K&N Drop-in filter! (fit the airbox in my 90 civic dx 4dr)
- I am new. My name is Sebastian and I come from germany.
- Headlights won't shut off
- school me on brakes
- sweet jebus need help quick!
- Got me a ITR type header, now need some suggestions on what to connect it too :-)
- quick b-series intake manifold question????
- HID?
- Door window help???
- dream car
- JDM fog lights on a 90-91 USDM front bumper... mounting????
- 90 crx light problems
- Need help finding bolt part number
- my car idles very wierdly
- zc turbo oil preasure problems
- Looking for a car I saw on here.
- HELP WITH REAR DISC CONVERSION
- best engine to swap into a crx
- d15 transmissions
- d16 internals help
- is the jdm EF9 and EF8 gauge cluster interchangeable?
- cant find the part name/number
- Rim Help?
- E-Brake gone bad
- nitrous question
- crx performance question
- JDM HEADLIGHT HIBEAM WIRING??!!
- Password Js intake
- Hesitation at 3500...
- EF SUSPENSION help!
- B18b Swap into 88 CRX auto HELP HELP HELP@!@!@!@
- ETD traction bar and radiator questions...
- BserieskllR's new project thread lots of pics! 4dr. YO!
- crx and civic interchangeablity
- flickering cluster, headlights, guages
- Ross' own build!!! (56k killer)
- tranny question
- Putting a factory sway bar on a Std. Civic hatch?
- CRX/Hatch sideway mount mufflers are the same???????????
- This Sux!
- messed up dash harness any one able to help?
- so d15vtec or the full swap for the b16
- What headers on my Zc DOHC
- My new cluster.
- ITB Airbox (pics)
- go with clean engine or hot engine?
- cut crossmember???
- 32mm axle nut removal
- Half sized radiator overheating?
- Dual Bend Shifter
- Engine thread???
- tranny swap question
- 91 civic dx
- help vafc
- d16y7 dual point question.
- WOW, this thread will go unaswered. I need a EF proffesors help on this one.
- need help with gauge cluster
- spark plugs
- Best paint for bumpers and mouldings??
- valve adjustment, feeler guages, is this one ok?
- Quick Question Please Read.
- replaced tie rods and shop cant align it...
- duralast clutch???
- dx or std hatchback available in black?
- Front lip options for EF hatch
- odyssey battery
- rear disc swap for crx
- 91 civic DX misses
- crx flywheel
- would some 2004 celica gt seats fit my car
- problems with 91 honda civic dx help me plz
- honda civic dx 1991
- how di i install shift stabalizer bushings?
- here's a dumb question, but....... humour me eh?
- need help
- 87 SI ANYONE
- Think I can salvage this? Lots of pics
- 2 questions bout brakes and building motor..
- turbo mini-me or ls/vtec?
- Just got and ef today!
- d15b I need help with supercharger setup
- b18a will not run
- 1 91 civic dx and 1 weird problem
- CRX JDM FENDER QUESTION!!!
- NEED INFO ON DOHC ZC TRANNY?
- pillar guage mount fitment??
- Compression test results... CRAZY!!!
- got skunk2 lowering springs. show me if you have them too
- 88 crx dx
- CRX help
- farewell crx (56k, get a snack)
- HVAC wiring question
- jdm front end question?!?!
- B 16 1st generation transmission part number list needed
- oem throttle body size
- Planning a vacation.
- Need front brakes!!!
- Finally got my CRX!
- integra side skirt
- B16a1 Parts Question
- Miata wheels?
- o2 sensor question
- Problems with B16 swap into 91 CRX DX
- Aftermarket wheel questions for EF8 SiR
- obd0-obd1 jumperharness from ebay, is it good?
- cam questions need some helllppp!!
- New Exhaust
- Water leak hatch strut
- EF9 Rear Filler piece
- Need Water Pump input from fellow EF swappers: B16/B18 Woes
- H22 or something else?
- dohc zc crx idle problems
- B16a1 Swap for a 1991 Honda CRX DX.
- Checking fuel pressure?
- new jdm parts ???????
- SiR questions!
- What spring rates for Koni/GC combo?
- mpfi ?
- Aero mods
- oil leak
- Spark, Fuel, but NO COMPRESSION!!! help, IS IT A BLOWN MOTOR? CRX 87' Si.
- springs
- B16A1 Question
- B16 fit
- NEED HELP water pump issues
- already searched... energy suspension sway arm bushings?
- spark plugs
- 1990 Integra subframe into 1988 CRX. Will this work????
- Timing belt snapped, check engine light on, need help!!
- Wiring Help.. Newbie to wiring
- JDM POWER FOLDING MIRROR HELP!
- crx sideskirts retrofit
- NEED OF HELP FAST !! 93 civic problems
- Velocity stack
- ARP extended wheel studs
- CRX electrical Shortage!!!
- best shocks for the right coilovers
- i have a 1989 crx hf ....
- how do i take off the torque converter????
- y1 (with broken case) gears into a hydro ls teg trans for my ef
- inc possible noob questions
- Help: Looking for a "short" muffler
- DA door panels fit EF hatch?
- needed OEM Style Upholstery Kit for 90 CRX
- Aftermarket header problem?
- Last few swap questions
- Rust under paint suggestions
- tranny question
- places to buy crx SiR parts.
- HF throttle cable different then Si?
- USDM HB Fog Lights!?
- uber rare jdm crx doors check um out
- Z6 into 90 Si
- Best affordable sleeves for D16 INSTALLED? Also, D15 block... any use?
- Noob Swap Question
- Stuck caliper!!! HELP!
- help with d16z6 swap into 90 si
- cluster dont work
- tail light and instrument cluster fuse keeps blowing
- Anyone know where to get OEM EF8 SiR door decals?
- car runs like shit with a pr3 chipped ecu. HELP!
- my ef si project.
- D15b for my 88 CRX
- NEED ASAP D-series shift arm
- Si Seats???!!!
- Will this swap work?
- ecu ?
- instrument lights
- carpet is out now what?
- look what i got today!!!!
- help me buy a long-block
- tail lights fuse keeps burning out
- jdm rear mount problem
- what are better rotors slotted or drilled or both
- si dizzy
- where in the "bay area" is the best place to tune d-series?
- -_-_- Rear DA Disk Breaks On A DX CRX Problems -_-_-
- quick Q?
- code 7 and 9
- wilwood hydro clutch pedal
