View Full Version : Honda CRX / EF Civic (1988 - 1991)
- brake pedal travel only when driven for more than 1 hour
- CTR PULLEY WITH BALANCED ROTATING ASSEMBLY
- wiring: "Toggled Ignition/Push Button Start"
- Will 13 in. steelies fit an 88' Si?
- Strange fluid residue on the firewall??...
- Seat Question/Positive Engine Shop Feedback
- dohc zc -nitrous
- wtf black honeycomb looking piece?
- DTC problems
- header question
- Brake upgrade suggestions
- Burning belt or almost a break smell.
- What's better h22 swap or h23 vtec swap?
- nippon blues?!
- dx to si dizzy?
- D15B Clutch Chatter
- magnaflow exhaust?
- The REMIX is the CRX
- obd0-vtec-mpfi-pr3 ecu
- ef cranked until i hooked up tranny cable
- Hot Flix!
- Filling new AC sanden TR70 ac compressor with ester oil
- i need help for my 89 hatchback with ZC sohc swap!!
- Engine won't start
- anyone in virginia or north carolina
- Question, size and kind of wheels?
- passwordjdm corner lights for CRX
- how to get rid of a cel from turbo
- DIY Cargo Cover?
- RESTORE
- es oval muffler?
- Running eg radiator
- 92 teg to 91 civic dx
- need help asap............crx wiring question
- 91 Civic with a fresh B20 swap is only getting spark too two wires.HELP?
- 90 Civic SI Accelerating Problem! Please Help
- OBD0 DPFI --> OBD1 Distributor Wiring?
- Steering Joint Cover Effectiveness
- WHO WANTS TO HELP ME WITH MY CRX :D
- code 9 question
- New to Honda-tech & in need of JDM SiR EF Hood
- 90civic and 89crx si driverside underhood wiring pinout
- 12's
- 13's possible?
- gsr head, si block, ls tranny...help please
- throttle cable
- Quietest CRX Exhaust (Other than stock)
- Good link for an auto to manual swap?
- 89 civic hatch radiator question
- Battery Relocate, not in the trunk..
- Tools: anyone used the Snap-On YA6010A tool on the crankshaft pulley bolt?
- crx with a b18a1 no start problem. need help
- knock sensor
- Oil pressure light flickers at idle?
- wiring nightmare!!! omg someone help 91 crx with the b18c1 (1995)
- 91 civic, dies randomly
- what ecu should i have?
- CRX w/ B16A
- crx roll cage w/ stock interior
- Ignition Switch?
- 200+ Hp B16A
- already searched...stock wheel size and offset?
- brakes rub - just replace booster and soft lines
- Hardlines
- Thoughts on Seibon Carbon Fiber Fenders for CRX
- Quick question on my mini-van...didn't know where else to turn....Help
- im looking for a clean si ef model
- look at this build up crx k series carbon fiber dash
- Crx Rear disc conversion
- im needing help with my exhaust
- Is A.C. possible?
- serious battery relocation problem
- what fuel rail fits on b16a
- All cable ZC tranny's have half shafts?
- Best place to buy Function & form's
- ek front end on ef? where in the bay area that knows how
- what do you guys think of my new 88 civic interior!! also have question about E-test pass
- What bulb for a ZC headlight?
- smoke from valve cover?
- need help fat car wont start!
- OBD0 to OBD1 conversion problems
- d15b2 block d16z6 head, timing belt issues
- Are these wheels anything special?
- SSR Header in EF8
- EX FRONT DISC ASSEMBLY
- anyone have an opinion on Master Pro(MPB) hub assy's?
- MVM's Wagonvan
- Coilover rattling??
- my '88 crx si build
- Vitara questions
- Reverse Trouble
- OBD1 injectors on OBD0?
- I NEED A RHD CRX DASH PLEASE HELP
- I am looking for Mugen Parts for my EE9 [EF9]
- need to know if i am making a good choice...
- Tie rod stuff!!!! EE-WAGOVAN STUFF!!! help me asap....
- Motor Question
- honda civic shuttle
- ef9robert build thread 56k Maybe :-)
- shift linkage question
- New guy.....pics.......
- front lower tie bar help
- strange problem
- HELP! WTF is going on with my EXEDY
- WHAT WOULD BE BETTER ON A CRX?????
- Which map sensor for LS Swap?
- lookin for a complete ls swap for an 89 crx ?
- performance mod chip
- NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!
- First production: My RMS GT42R CRX/EF topmount w/ 4" dp
- types of clutches
- crx bumper on civic?
- crx carbonfiber dash kit
- b16 swap obd0
- MY IDLE IS MESSED UP
- CRX project - Input welcome
- I NEED A ANSWER
- MY OIL
- koni yellow questions
- which msd coil???
- Blox rear LCA clearance question
- seatbelts......
- backfires
- :| Swap info?
- 2nd gen crx swap help
- transmission diagnosis
- b16 swap HELP ME!!!!!!!!!!!!!!!!!!!!!!
- auotmatic ecu or standard
- Wiring Vtec into non vtec si harnes
- Bad headgasket?
- b16 obd1
- ITR Cams help
- Car won't idle/run out of the blue...
- DPFI to MPFI problem.
- engine light.
- 91 DX, B20/Vtec.. quick hubs question
- setting timing on 88 crx si???
- This isnt cool...
- 90-93 teg axles in a crx dx with gsr hydro trans(used to be auto)
- 2 small problems: Brake noise and exhaust rattle
- Civic Hatch Hood Hinges on a CRX
- CRX Interior Pieces
- Field VTEC controller question, CRX
- spark plugs for high compression?
- w.t.b. hx rims 14's
- what new Brakes on 4dr EF???
- civic/crx jdm speedo gauge question.....
- cylinder head question about smoke in exhaust
- Adjusting valve clearance
- transmission fluid change
- 91 civic won't start when hot
- whats the difference?
- Halfshaft questions!!!!!
- 91 civic si? need help
- OEM-style carbon fiber fenders?
- Wiring help, for Round JDM fogs
- oil leak around head, what could be wrong? plus how can I make my exhaust more quiet?
- Front Bumper Support
- EF WAGON
- Tips for removing my exhaust silencer...
- Tokico HP Blue question
- 91 civc hatch part out question
- quick question
- clutch fork questions!
- Civic autocross project
- Wiring Bumper lights
- Help Me Please !!!!
- Need Help Cel #9
- need some help...
- I feel like a jackass asking this, but....
- CRX Exhaust Questions
- help me make a huge a decision.
- trouble shooting help
- question: will the a/c parts from a 87 civic sedan all go onto a 91 civic 3dr/HB?
- 1990 H/b Build up and 1991 CRX Build up EF's!!!!
- Transaxle installation procedures
- Engine mount bolt source?
- engine-tranny question
- headers
- engine heat
- 85 hf crx swap
- DA suspension "?"
- What to expect from DPFI to MPFI
- new motor in my bros car and....
- HELP 1990 rex wont start
- need rear pads and rotors for my hatch, need help
- b16a in my crx dx
- have a gas leak? fuel vapor in cabin? read
- 90 Civic DX Wont Start
- header suggestion
- My (apartment regulations limitated) Project crx
- HASport's H22 EF kit continues to be a POS.
- Neeed Help Fast~!!!!!!!!
- Better than stock direct replacement radiator
- Need help: not getting fuel
- Body shop needed in Phoenix and vicinity
- B20 Vtec question
- 1.5 inch Tein S-Tech Drop (pictures inside)
- Need help w/ Rear Engine mount.. extremely frustrated.
- help: how to take off plastic seat lever....
- Strut bar question
- Need help fast! turns over but wont start!
- b16 crx bogging
- Transaxle Reassembly Questions!!!
- SI cluster on HF
- Wiring diagram for adjustable headlights?
- sensor search
- CRX's that are older than drivers....
- For those that need the ES hyperflex and trailing arm instructions please look
- No CEL blink when I use a chipped P06 !!
- IAT-color wires?
- Problem. How do i take out the rear seat belt?
- would this lip fit my 91' DX?
- clutch problem EXEDY!!! ON EF 1991 SI!! PLS. HELP!!
- Trying to identify this wheel i found
- 1980 Civic Options...
- rockers ?
- breakdown
- firing order and wiring help
- 89 civic w/b16 start-up issue
- Idle problem HELP ME
- Need Help Quick
- crx sir???? the difference is....
- Insight on rear lower tie bars needed
- DH Racing Question
- Hondata
- nitrous question???
- alright very fast question, nooob !!!
- Seat Restoration, How to take out headrest mount?
- anybody in northern virginia wanna be buddies? haha
- it was nice outside..
- 88-89 cluster swap to a 90-91 cluster. please help!!
- runnin lean
- 91CRX Si wont start
- jdm side moldings
- cut out at 2k
- Help with buying this motor!
- MY car has BUGS
- LSD in a GSR hydro tranny
- built rods on stock pistons? Polished shotpenned rods any good?
- Need some quick help
- axle is loose should it be
- anyone running a dohc zc supercharged??
- obd1 ?
- I think my hatch is sitting higher than stock height.
- rear shoes
- ****need over help with b18c1 swap****** crank pully/altenator/ xmemeber
- 92 Civic Too much Brake Pedal
- How to take out rear side panels?
- I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!!
