View Full Version : Honda CRX / EF Civic (1988 - 1991)
- bumper question !!!!
- i need a wiring diagram
- f22b?
- ef cranks but no start
- A/C Question for my B16a crx
- D16A6 v. ZC crank pulley
- coilovers on wrong?
- crx ac question
- CRX seats in a Civic hatch
- help checking CEL light, using obd1 ecu- cel wont flash
- The Chronicles of my Sedan
- bbk for front vs stock
- aftermarket temp guage
- 1990 Crx Hf B16a Build Thread
- simple question
- Noises
- GSR Calipers On EX knuckles didnt fit, Please HELP
- Car stays cooler than normal while driving
- Engine harness help...!!!...
- 90-93 Integra front and rear brakes WITH ABS
- keep obd0?
- What if?
- car won't start and lighting is being weird!?
- Two 91 Tegs
- LS swap IAT sensor code
- Rims on crx
- ls motor worth putting in 91 civic?
- pinout for o2 sensor
- headlights problem?
- b20b in 90 crx running lean
- b18 ls swap help pls
- Oil on sparkplugs - 91 Honda CRX Si
- Roof Removal??
- 89 crx engine swap sohc to dohc cz
- Having trouble gettin car to run right. poss. gas issue?
- *Help* ECU Light is Blinking *Help*
- Honda crx Vis Mugen Replica
- hub wont turn
- dont kno were to start
- replacing timing belt.wanted to make sure i have all the parts
- distributor help
- FS new holley airmass 4-2-1 headers ceramic coated
- For Sale Gude Bullfrog hood for ef
- questions about a 90 hatch
- Strange b18a swap, is this right?
- 89 civic - please recommend head gasket
- Today i was followed home.....
- Suspension techniques sway bar issue on crx
- Honda Crx Mugen Body kit
- Bike rack / trailer hitch rack
- Why no forum for pre-1988 CRX's?
- ef2 mpfi swap
- B16 swap in a wagovan?
- What type of Lug Nuts for Civic Si Rims ???
- do you think this idea will work ?
- another starting issue....fml
- big brake kit help!!!!
- Another Overheating question
- HELP! 90 civic dx fuel injector location and install?
- D16z6 swap questions
- crx pulls
- LSVTEC EF HATCH ISSUE! PLEASE HELP!
- Are these bad cracks? (pics)
- want to put AWD need advice
- crx hybrid problem
- electrical problem! (searched)
- Swapping the prop valve... worth the trouble?
- New to hondatech, a couple pics of my ride
- pics
- ef doing some odd things
- Need help!!!! b18a1 in a ef with BS Misfire
- 88 4dr headlight question.
- CRX WITH GSR SWAP... TRANSMISSION HELP!
- cel and loss of power
- TB out of a D15B1 work in a D15B2?
- eg6 steering wheel in 1990 civic
- stage 2 cams in zc
- Will K24 fit under the black widow wide body hood?
- Having issues with vtec
- Crank Pulley I.D. - JRSC Setup
- need help
- rim feels like its going to fall off
- TACOMA WA, STOLEN 88 HATCHBACK B16 and SiR front please read
- head question
- need help ecu not getting power
- B16A Intermediate shaft help
- spedometer off???
- installing a/c in swapped ef hatch
- ef b16 bucking
- Cracked Block?
- Good clutch kit?
- Si-R Housing Bulb Type
- WHAT´S THE SiR 1990 ENGINE?
- crank position sensor problems
- K-Tuned K-RX Drag build,numbers and video. Torq? We haz sum.
- rhd dashboard
- b18a1 code 43 problems
- Vtec engaging problem
- '90 Civic Si, need info on the brake system.
- Quick Question about windshield trim
- A/C expects need help..
- da harness in a ef hb ?
- head swap and ecu problems?????
- Dual Point Throttle Body Prob - Will Not Start Anymore
- If you wANt to work on your CRX/EFF/efD
- Neon Radiator 89 Hatch
- d16a6 no spark
- Mean wheel hop problem
- (Help) need a wire job for b16 crx socal
- i need a diagnosis..
- no start
- B16 Injector Missing
- VSS wiring driving me CRAZY! please help
- IACV bad?
- fried ecu fixed now nothing??????
- 90 crx si wont start
- b16a issues!!! ecu or wiring or wat?
- DC GSR Brakes in a 4door EF
- Help, Idle issues
- No spark, please help
- d16y8 in a 88 crx hf?
- My EF boggs in low gears.& battry light problems
- help wiring problem helppppp
- CRX wheel fitment ?
- Any Good Headers to reccommend on a B16a2
- 90 si....still wont run please help
- need suggestions for motor swap
- questions about a d16z6 boost build
- dpfi-mpfi swap question
- bad luck
- help please with my 1990 honda civic dx!?
- toggle switch for turn signals?
- Routine Maintenance: 1988 Honda CRX DX 1.5
- few questions (engine swap)
- CRX HF JDM d15 wont start :(
- Distributor Help PLEASE!
- sir front bumper on a sedan
- crx dash
- whats up ef/crx ppl!..91' civic si
- maybe noob question
- CRX TRANS (HELPPP!!!!)
- the ef hatch cheap build 500whp??? hoping
- just put a dohc zc in my wagon and now it wont rev past 2k? please help?
- sedan bumper interchange with HB?
- I need something you may have =D
- sway bars!
- lookn for ef9 front lip
- Digtal boost controller install
- Can someone tell me the flange size of a garret .50mm?
- Compatible front suspension for crx?
- question ordering from majestic honda
- Which shop in N. Cali would you guys recommend for ZC swap?
- Ls swap in 91 hatch need help bogs stutters and hits rev limiter around 3k
- VSS cable question
- what timing belt in a y8/a6 mini me
- Hydraulic clutch retrofit?
- I need a car bra
- 91 Civic STD wont start, what do you think?
- question about these valve seals im about to install
- main relay over heating?
- oil on spark plugs questions
- new to the site just sayin hi
- New to CRX world
- Les Schwab Lowering Rear Tire Rub
- code 4 and limp mode after mpfi
- Which wheels?
- dirty injectors?
- I screwed up, need help BAD. ASAP. Please!
- ef9 HELP!!!!! Throwing code 15-ENGINE FILLING WITH FUEL-ignition lights staying on???
- send me your garbage suspension
- Things to check when buyin an ef?
- ECU code 12, '91 Civic 1.5l
- D16A1 into 1990 CRX DX
- my ef keeps dieing
- Axle seal Keeps leaking!!
- Need opinion about a future CRX purchase....
- 10th ED civic, b18 swapped have some questions
- exhuast buying help?
- strange "clanking" noise when the engine is under load please help
- EF or CRX
- hood problem someone know wats up?
- If You Have A Boosted EF W/ Full-Race Radiator Chime In
- Need a little help/advice with leaking M/T (pics)
- fuel pump test?
- High Idle Problem
- CRX SI B18c1 HELP PLZ!!!!!!
- What to check
- fuel/temp gauge and clock no longer working
- Cheap jdm front end
- B-Series turbo CRX build questions?
- What belt and slim fan for B16 swap to keep a/c
- Going to sound stupid
- confused with my ecu situation
- Cooling and A/C experts need some help and advise.
- crx sohc zc swap... rpm problem
- EF9 rear fog lights
- R-63 Paint Code...
- car starts then dies
- What's it worth 1990 CRX Si
- CRX build, Wiring issuses, ect.
- EF8/9 JDM Cluster Aftermarket Gauge Faces...do they exist?
- anyone trace floormats & cut new carpet & sew over old ones?
- !*Intake Air Temp Sensor Location*!
- problem with my crx swamp axels i think??? pls help
- gsr swap
- Montana CRX build thread.
- 89 EF Hatch
- DC complete front spindle on a crx?
- have some questions need some help
- B20b basemap chip?
- Wiring issue?
- dpfi intake manifold
- Are you a 2g crx Guru? Come here!
- is this accurate comparasion?
- crx motor mounts help..
- i have another problem
- The boosted zc
- head gasket question
- Another "loopy" idle thread...
- need help on 91 hatch with jdm b16a swap
- ARP Head Stud Question Searched
- Havign problems starting
- OBD1 and OBD2 fuel injectors
- fuel problem with z6
- SOHC ZC Headgasket - Composite Material?
- engine swap trouble
- whats supposed to go in this bracket ??
- doing a swap need help with jumper harness'
- 2000 CIVIC SI CLUSTER SWAP
- GODSPEED TYPE-SS COILOVER SUSPENSION?
- WHERE DOES THE JUMPER HARNESS GO LOL
- shift knob?
- engine harness
- 88 Hf with JDM DOHC ZC swap
- does anyone know what this wire attaches to ??
- 90 Si Hatch Rear Disk
- d15b2 head bolt hole... block fubar?
- nowthatsG Crx Build Thread!!!!..........
- Need help Code 9 No.1 cylinder position sensor
- 1/4 mile this friday night in the crx.. what should I run?
- Bogging and smell question
- correct lug nutz for rims help
- 88 civic sedan motor torque problems and gear shifter moves.
- Can you use stock seatbelt with aftermarket seats?
- Whats the best ecu for a Honda crx
- Help ! DPFI wont stay running
- OBD1 Dizzy Issues on 88' Crx...
- jdm d15b vtec swap in my 1991 dx hatch questions
- axle seals
- What color is this?
