View Full Version : Honda CRX / EF Civic (1988 - 1991)
- DA dash conversion
- New guy 91 Teal HB
- lip and exaust system
- Type of paint honda used???
- trying to lower my EF hatch a few inches
- D16A6, No Spark. Different problem.
- JDM D15B cel codes and VTEC problem
- Video - Loose wire found behind block. Knock sensor?
- Replaced ETC sensor, No results, Video of CEL, and more
- fuel prob
- disassemble si trans
- JDM B16 Build
- 88 CRX brake issues
- back firing and missing help
- Quick question about b16 swap into crx
- TRANNY PROBLEMS????
- Radio, blower, etc. electrical wtf (Solved)
- Do you still have A/C ?
- RHD EF9 part same as RHD EF7 part?
- ECT sensors for b16
- LS CAMS
- here are some pics off my EF Before and After some body work
- SI muffler on a Dx
- Having trouble with code 4
- Left crx overnight, doesn't start in the morning
- Long first and second gear or final drive in Y1 tranny
- 88 crx mpfi
- Driveshaft Oil Seal Sizing Issues...
- rev problem
- Suggestion for replacement for EF SI 1990-Next car to get?
- How to fix engine temp guage?
- dx to si dizzy plugs SEARCHED!
- Help with gauge install
- Vacuum and unkown wire ?
- i did a d16 swap now it wont start
- crx suspension question
- d15b throwing code
- Turn Signal/Light SHAFT part number?
- wiring issue or other?!?!?!?!? confused
- car cranks doesnt start and no dash lights
- gauge cluster 88 crx
- my b16s throwing out black smoke please helpp!!
- post mounts screws snaped
- 91 d15b2 starts fine breaks down helpppp
- 1990 civic dx hatchback rear speaker wires location help?!?!
- d15z1 swap help
- Car shakes when braking and at high speeds....Its not a warped rotor problem
- ls tranny question
- no spark b17a swap
- Crankshaft to flywheel dowel pin...do I need it?
- Poor EF; Deadly Tornado in Missouri
- Speedo cable VSS to work JDM Sir cluster?
- Dealer Parts ordered Online
- 91 ef sedan mudflaps
- is $500 a good deal for a ef shell in decent shape?
- 89 crx si lip fit on 91 crx si?
- New to the honda scence Need Some help!
- EF to DC Dash Swap build pics needed!!
- New crx, confusion
- crx b18a1 block b16 head. help?
- 91 civic d15b2 head torque?
- b16a with buddy club
- My jap ef-6 glassroof resto :)
- Doing DPFI-to-MPFI conversion, have some wiring questions.
- EF Hood Hinges
- 90 struts/springs
- CRX LS swap, AC question
- CRX TRANNY SWAP
- 4 lug conversion to lager lug?
- CODE 15- CAR WONT RUN WHAT DO TO
- Removing 1991 Civic Hatch Front Corner Lights
- d16a6 will not get spark...... help
- electronic speedo in cable trans?
- need help!!!!!ASAP
- si cable tranny axle line up issue
- Skunk2 pro s coilovers
- Rim question
- D16 fuel rail and injectors question
- Upper Control arm, which has most castor?
- car makes a squeeling sound?
- Bad shaking in front end...
- Using A/C - Water dripping into cabin???
- Front Bumper help
- Climate Control problem
- brake problem help?
- 91 Dx from Quebec
- z6 vtec solenoid on b16
- Tire sizes
- obd1 swapped b18a1 gsr dizzy injector trouble
- dc integra rear seats
- $Value Sticky$ What's It Worth? Should I Buy? What's the Cost? (COMMENTS ENCOURAGED)
- Few questions about speedo cable
- Erratic idle and temp gauge stays below cold
- Quick question about neutral..
- 90 Civic Base
- conflicting sides ls vtec
- need middleground on blox crank pulley
- My ef Hatch b18c1 swap parts list(anything missing)?
- I Need CRX Guy Help
- WANTED: CRX FRONT BUMPER. and other
- Where the tech heads at?
- ECU codes 1 & 14 after head gasket change?
- CRX rpm fluctuating problem
- Another civic wont start thread.
- dohc zc
- i need help! no spark code 15
- 1990 RT4WD Head question
- stiff clutch remedies?
- is there any meets around the baltimore area?
- competition bar or just front crossmember??
- 1st gen b16a misfiring
- suspension tire rub question with 15 +40 195/50/15
- what's the easiest full swap upgrade?
- help with parts for slight build???
- New guy B16a swapped crx
- Need help diagnosing
- CIVIC SEDAN PROBLEM... HELP!!!!!
- 91 CRX rear brake upgrade
- EF8 EF9 fog light brackets??
- help corner lights, taillights,instrument gauge dont work
- Little DPFI Help guys??
- JDM si cloth seat repair
- B18a swap issues
- CRX... SIR vs. VTI
- 91 crx si b20v Some vtec issues
- Squeak in the steering column
- BRAKES
- 90 CRX ignition lock body wires???
- hey can any of you tell me what suspention parts i should use
- DUMB GAS GAUGE!
- starting help
- EF 3 Piece Front End Kit
- First post from a lurker/AC help.
- what clutch to buy crx zc with l3 trans?
- progress is slowly coming
- Which relay is this?
- running poorly after mpfi swap, help please
- Energy Susp rear trailing arm bushing, Loose dog bone??
- WTB: 1990 ef hatch amber bumper lights
- 1990 RT4WD Failed Emissions
- Replacing front wheel studs on '90 DX hatch.
- Odometer help
- anybody know the differences between steering knuckles on 88,89,90,91 models ??
- Help! my B20VTEC has no VTEC!
- need oem crx fron rear bumper n side skirts
- Wiring up a Wideband
- Completed some much needed maintenance today
- need help recaros njoy in 91hatch
- "Whirring" noise in all gears
- rear window visor?
- Can this bushing be replaced without removing the rack?
- What is it and size of plug??
- s2k seats in a 91 crx??? possible??
- j spec obd0 to obd1 pics inside
- Slide pin grease on disc brakes?
- can someone post a pic of a d15b1 and a d15b2?
- 88 civic obd1 no resister.driver side plug wiring questtion
- MINI ME HELP!!!
- Quick electrical question
- Is it possible?!?
- After 8 years (build thread)
- 88 crx si temperature gauge not working?
- 91 CRX Mini-Me (d16z6head/ d16a6block) Questions
- Just acquired a jackson racing strut bar, rare or no?
- Overheating, Headgasket issue
- oil leak near sparkplug
- Starting issue
- Headliner removal
- 2 injector harness convert to 4 injector
- D16z6 CRX Chokes at low rpms... Help!
- function and form type 1 help ef sedan
- 1990 civic 1.5l/ no acceleration past 3000rpm
- very simple 88 crx radiator swap question?answer needed asap
- 90-91 civic ex sedan spindles
- what do you think of this?
- Help me with this Relay.. which is it?
- K20 Crx Headlights Won't Come On
- Fuse box Diagram efsedan need HELP!!!!
- needing steps to install trim/garnish thats on door ?
- CRX IDLE at 4K?! HELP!!!
- Stock 1989 SI trying to get Vtec with D16y8
- B20 pulley hitting radius rods?
- Won't start/replaced thermostat!
- 91 civic standard mpfi swap no power to the fuel pump. Please help :)
- Help: Installing side markers on an ef
- Thermal Switch PN please
- BRAKES GOING SOFT ISSUE!!!
- Knuckles Si vs. Dx suspension?
- Stay cable or convert to hydro?
- odd lighting issue
- Dash Clock Problem *PLEASE HELP*
- Fuel System?
- EF Tail light problem
- b18 swap terrible gas mileage
- Losing coolant
- 91 Si Build
- Exhaust manifold Removal???
- z6 in a 91 hatch idle issue
- 91 civic hatchback keeps blowing main light relay.
- no power to injectors
- EF civic Need Help!!!!!
- Crank pulley question
- upper control arm question.
- MOTOR QUESTION
- does any D series tranny work?
- Upgrading exhaust system
- can't pull out oil seals from tranny
- Loss of engine power, Overheating, Leaking water
- 88-89 CRX Cluster swap ---HOW_TO---
- FULL A/C SYSTEM OFF 95 CIVIC?
- HF, hesitation in first and second
- grinding.
- halfshaft
- 1988 CRX DX OBD1 b16a wiring
- 1.6 sohc vtech?????
- B series swap crx 5k rev limit need help8(
- what would cause this...?
- knock sensor problems!!!!
- CRX HF CODE 12 EGR HELP??????
- Will a rack off a 87 CRX work on a 90 CRX?
- Is it the 91 civic 4 door ex master cylinder and booster that will work in the crx?
- Charcoal canister question
- cel 15, runs but bogs. help!!!!pic!!!
- DIY battery relocation problems
- Lower Control Arm bolt.
- alignment
- ED8 CRX seat into an 88 ED3 Sedan help
- 86 d16a1 head on a 89 jdm zc dohc
- dot3 vs dot4?
- si mpfi conversion or obd1 mpfi conversion
- Manual Conversion Help!
- ZC Dohc TRANNY PROBLEMS!! Help needed...
- EF STD HATCH IDLING WAY TOO HIGH LIKE 3500
- 1991 lx, built dohc zc
- 91 hatch shutting off while driving
- need some help with idle issue
- Having problems controling my sedan at high speeds
- new at honda tech - here's my CRX
- 91 civic starting issue
- vtec knock sensor
- EF Sedan Problems
- Dpfi to mpfi question
- Car sputters on startup
- Help 89 si speedo went out
- seats?
- mini me rough idling no throttle response
- ef problems starting?
- Horrible, Horrible Gas Mileage
- D15 B2 Head Removal?
- What to do next???
