View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Smoke problems from D16A6 CRX
- which ECu is best for b16a
- axel removal
- car only hits vtec one time.
- wanted CRX \civic\
- 88-91 civic right hand drive conversion
- new red-line
- dual point to pgm fi.
- Question about the way my tires sit, searched :)
- spare fuse for igntion guages
- wtb: ANY EF SI MODELS ONLY
- JDM B16A FOR SALE
- valve cover ground not bolted...wat went wrong?
- did some brake work...now rear won't do a thing
- Need help with HID's..
- looking for a stock hood and si wheels????????????
- Crx b16a swap help!!!!
- Can I use my Z6 head studs for my mini me swap???
- si / dx brake pads the same?
- buddy club exhaust modded for EF hatch.
- trouble with removing speedo cable from tranmission
- yoyoyoyooy
- is it exhaust question
- help
- New to the crx and having a problem!!
- dual point to pgm-fi
- how do you put pics up ??????????????
- Motor Swap need some info
- 89 CRX, question about B18A Swap
- ef hatch lip???
- start up problem
- Should I paint my wing mirrors black?
- my 89 crx si show car need help wiring the gsr cluster PICS
- Turbo ZC "kit"
- o2 sensor?
- more speed
- ZC needs a tune!!
- D16y7 Turbo Questions
- pull in a camber kit. easiest way!
- 89 zc No oil HELP!!!!!!!!!!!!!!!
- taking rear hub off
- Fly wheel and clutch tourqe specs
- EF tie rod/font LCA ball joint thred size
- cable 90-93 integra tranny and b18a vs b18b and hydraulic tranny 94+
- need help with timing on d16a6
- cluster is dead
- idle surging
- quick dpfi-mpfi question
- obd1
- Issues with the body shop....
- what is the best harness for a 1990 honda civic dx with a b18 a1 in it?
- What kinds of seats bolt into a 91 civic dx?
- my rex feels like its out of gas
- EVO 8 turbo stuff install (tips?)
- cigarette lighter relay??????
- oil pan bolt stripped out what can i do.
- ZC swap quick question
- MPFI Swap headache-need help/adice *PICS*,*VIDEO* included.
- TURBO ZC??
- JDM SiR Cluster????
- Window Mounting
- jdm d15
- Honda CRX 1.6 16V 90' with only 12.900km done !
- Need opinions. PLEASE....
- What dizzy is this??
- worth it to pick up a SI tranny?
- is it illegal to tint tailights black
- Poor Man's ITR first impressions
- b18 a1 head is it trash?
- rare ys1 tranny?
- Idle Air Control valve question!i!i!i!i!
- How Much Boost ??????
- can i bolt a stock SI axle back to a cx exhaust?
- dropped an d16a6 in a 90cx, need a little help
- FREE EF!
- HKS hipower exhaust on their crx?
- anybody else think this car is ruined?
- car wont start sometimes....
- thermostat ground
- boost question??
- B20B or B16A
- NOOB question on JDM d16 motor.
- uneven ride height
- Removing the rear bumper?
- Will 90 Prelude 4WS Struts Fit in a 90 Civic LX Sedan?
- z6 tb onto crx is it possible ???????
- QUESTIONS ABOUT HARNESSES
- Randomly Harassed?
- b16 seems to shut off @3000rpm
- odb0 turboedit?
- Alternatives to JimFab Crossmember???
- New project. 1990 CRX HF with rust.
- bench bleeding a MC.
- Has this been done befor and does it work???
- pr4 or p75
- Bass tubes??? *searched*
- where is the kill plug on a YS1 tranny?
- What did you do to your EF today?
- part numbers????
- Car wont start after intake-battery had a fight
- Preserve/Restore Unibody - how involved?
- HELP!?!?!?!?
- help quick fuel pump b16 question
- Replacement Motor Mounts ?
- new clutch question
- Not another sunroof question
- crx backseats?
- VSS in ls swap?
- were can i find some zc pistons?help
- what ELECTRIC vss will work in 90 crx dx AUTO tranny with 97 teg cluster swap
- '89 Crx CEL on
- need help with swap
- what intake to use
- si pm6 pinout
- What does everyone mean get your motor tuned what is there to tune???????
- Quick Supsension Bolt Question
- obd 0 codes
- Doing a mini me swap just would like a couple questions answered not covered in how to's?
- B16a1 bogs at 6 grand
- Need a hatch opinion plz guys
- Doing a JDM B16a Swap into my 89 EF Hatch
- is it safe if i move my battery back?
- stupid molding clips (pic)
- Operation black again has commenced!
- jdm b16a issues
- strange starter issue (91 dx)
- B16 won't go. DIZZY???
- 91 civic special edition 1.5 liter no compression?
- B series manifold on D series?
- CA people How much more should a BAR'd b-series EF be worth?
- Help: D16A6 Skunk2 Intake Mani Problem
- EF CRX GLASS SUNROOF.... ANYONE DONE.. NEED TO KNOW...
- hydro d series transmission into 88hf crx conversion kit!
- i currently have some Tokico Illuminas with skunk 2 coilovers...
- punch
- My Civic, Now.
- FUEL PUMP
- Problem with Blinker
- crx window visors.... searched
- what electronic vss will work on my si tranny w/jdm cluster?
- Getting rims, quick offset and tire question
- how do i installed the
- help removing cooling fan switch/////
- Battery help
- I AM STUPMED. PLEASE HELP ME
- seats in ef civic
- EF9?D15B2?
- rebuilding cable transmission
- 90-91 crx door panels
- integra cluster night pics
- Differences Between the 2nd generation CRX's
- tuning specs
- Question about CRX Seats...
- b16 cam timing problems
- suspension help?!?!?
- Anyone tried to put the sunroof molding back on?
- will crx bumper and fenders fit on hatch?
- swap advice on 85 si
- vtec just killed my car
- what jdm engine will fit in my crx without having to change the wiring harness
- DIY: Push Button Start
- gauges in center heat vent..?
- Crx wont start, please help
- cyp code 9 ?
- 4 spd hubs/axles and 88-91 si trans
- wheel studs
- I need help on my rear defroster
- B16 engine parts info request...for 91 Civic Si HB
- turbo question!!! help
- auto to manual 88 crx cant find the hole!
- Was Knocking, now it is not knocking and not starting
- Using TPS off 92-95 DX
- Need Advice or PART - '89 CRX Si Passngr. SEAT BELT LATCHING MECH.
- 90 civic dx backfires when i turn key wont start?!?!?!?!
- Throttle body question... 91 std civic
- Smoke? Searched, need some help!
- Coolant temp guage install.
- H-T help. A/C belt question. need help asap
- ef si sunroof replacement just replace the glass
- Ignition problem?
- WATER IN HATCH
- CRX Main Relay Part #
- Having shifting problems
- tranny question
- 91 si obd1 gsr problems please help!!
- PM9 ECU Diagram Needed.
- knuckle and hub question
- how can i tighten my clutch?
- b18 swap question
- speedo off
- Y1 LSD help
- Will 89-91 hatchback corner lights fit on a rex?
- VAFC Wiring for STD Harness ***5$ paypal for help***
- bad mpg for a civic?
- HOOD GAP!
- Tps signal output wire?(HELP)
- My CRX with Lambo Doors!
- Installing SAFC into STD.
- No 12v power to injectors..
- will a h22 fit in a civic/integra/crx??
- DX to ZC Swap
- d16y7 head
- help diagnose 91 CRX making weird knocking sound (audio/video included)
- 1/4 times
- brand new b16a idle fine sounds fine but no power HELP!!!!
- Thermal Research and Development Exhaust
- obd0- obd1 dizzy wiring(from dpfi to mpfi obd1)
- Is it legal?
- i'm clueless on this start up..engine rotates but doesn't want to start
- b16a swap in 90 si throwin a code 21
- D16 block- posts/sleeves
- 91 ef obd0->obd1 car ran, then shut off and wont start
- where do the vacum lines go on a d16z6 manifold with a b18a1 tb? PLEASE HELP
- Seats??
- B&M shifter with b16 swap?
- Door mounted seat belt swap? Any info?
- electrical fire in my engine bay last night.. =/
- car wont turn over
- b18a1 into ef dx hatch question about wiring....help!!!!!
- d16y7.....
- e-brake handle
- picture request..sideskirts!
- Where can I buy a new front core support for 91 CRX?
- oh, snap... i broke it all
- d series bolts into b series
- advice on a motor
- Code 3. Any one know what it is real quick??
- 00 civic si seats? pics
- Quick redline problem
- Tricky Swap Help - Hydro tranny in 89 CRX
- front clip & rhd conversion
- should i sell???
- quik questions
- quick zc question
- Where can I get a cyber glass roof
- girlfriend going 2 japan
- pegged heat gauge
- Crazy night...accident then problems...
- squeeking near wheels?
- when driving 10-65 mph you could feel like the axle are shaking..need answer..
- d16y8 in 88HF CRX no vtec wanted
- ZC tranny
- sways bars?
- auto to manual conversion for ecu
- tranny or shift linkage HELP!!
- turbo ef
- b18 shift linkage problem
- fuel pressure for b16
- Painting lower parts of the bumpers
- Part number for 88-89 CRX OEM bumper lenses??
