View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1st time @ track last night.
- Greddy 92-95 kit on a d16a6?
- Hatch Rear Speaker Brackets
- Alternator
- FS or WTT: 91 LS b18a 100k complete
- more trouble w/b16a in the crx
- d16a8 internals
- i have no turn signals!!!
- B16 gas hog?
- hard wired radiator???...(i want a relay back)
- jdm front bumper on crx usdm front
- MY NEW EF!!!!! (shitbox inside, help needed)
- Grouding Wire Help!
- USDM ITR Header for my B16a
- WTF IS GOING ON!!!!
- question on fuel gage
- Power windows in CRX? All power?
- way to roll up power windows???
- 88-91 Front Strut Q: What the the size of the "housing" that fits in the fork?
- battery relocation kit
- B18a in a 91 civic, smog?
- hood issues
- d16 swap?
- What will my friend run?EF
- auto to manual.
- testing waters
- parts indentification and compatability
- Most crazy JdM suspension setup for ef9
- DA suspension on a crx
- I have an 87 Crx need a new ECU?
- how do you get rid of that black lining on the body under the carpet????
- 89 crx dx - 91 hb si seat swap (not goin well)
- JDM D15b slower than D16a6, could this be the problem.....
- Cargo panels w/ rear speakers PICS! Crx or Civic Hatch?
- 91 crx si black jdm head lights
- Rear Drum/shoe question!!
- fittment of parts
- Ground?
- OMG
- oil and filter
- white lensos and MH 23x8-15 rub like a bitch!
- how to wire vtec with a push switch...
- L-con traction bar HELP!!!
- tube in between heater and fan???????
- quick battery cable question
- paint
- need help finding parts for my dohc zc rebuild
- code problem
- Honda CRX V-tec door panels for sale (from a german v-tec ee8)
- clutch fluid
- shifter wants to go from 3rd to 2nd..loose linkage?
- Timing is off need help quick
- heater not blowing????
- ef civic wiring
- crx/civic $1,000
- FS 1991 Honda CRX Si with a JDM B16A in Michigan...I need help posting...
- 2.2L V-tec........To swap or not to swap is the question
- 5 speed tranny swap....
- JDM crx front bumper fabrication??
- where is the best place to get my car dyno tuned in san diego
- shell for $500
- car overheats?!
- Rear Disk Conversion
- civic ex sedan project - what do you think?
- Lests see some crx sir conversion pics
- AC/heater control Lights Out!!!
- My Ceramic clutch is Slipping with Toda flywheel setup
- CALLING ON ALL B16 PEEPS WITH BLOX TYPE B CAMS
- 2007 crx
- A nice OEM mock up. Is it really that bad?
- Automatic VSS for Cluster Swap
- yay its a b16
- Lets really look at the pros and cons to the block guard
- Help, quick question?
- H22 into an 91 hatch civic what would i need how complicated plz help.
- help with this pic
- WHAT A DEAL!!!
- ZC tranny mount question
- muffler tone
- d15b swap help. need help asap..
- heater
- I want to know if i could drop a ls block with a cr-v head
- b16 civic hatch is about to go back on the road!!
- IACV???
- coolan hoses?
- damn tranny fluid need HELP
- **Please tell me what these plugs are for!!**
- zc running rich
- wiring for b16a
- radiator
- Okay no power to left headlight help....
- Car runs but steering wheel lock is on?
- b16 swap not starting
- TRICK for removing LCA balljoints EZ
- Help where can I buy replacement bulbs 90 hatch???
- Cable to hydro in a EF what axles?
- obd0 ecu with obd1 injectors? and a tranny question
- eg radiator
- 84 CRX Vacuum hoses
- gsr swap need help
- ASAP yo ahhh
- Chronic O2 code
- Pics and History of my hatch (I was bored) over 100+ pictures
- shift linkage questions
- 91 dx hb sputtering
- hasport cable to hydro kit
- Seatbelt light flashing, buzzer going crazy, and horn doesnt work! Help!
- 92-93 GSR Cluster
- wiring siR turnsignals to dx HELP!
- Not starting!!!
- locash wiring
- What seats for a crx should i get?
- rear disc brake problems..HELP!!!
- What suspension for a 91 civic wagon AWD!!!
- hard buzzing sound when cranking 91 ef
- I just got done with my CRX Rear Seat Install!!!
- CRX and Sedan bumpers......
- Ls Vtec
- Possible RHD Conversion on Hatchy
- FPR for zc
- what is a good tire size for stock 91 CRX wheels?
- rotting floor
- WOW buddy is putting a B16 into a 79 hb!!!!!
- crx exhaust fit a ef9 ?
- Is it OBD0?
- would a 90-93 exhaust fit a 89 civic hatchback
- give me confidence!!!
- Dizzy Problem?
- any one every put 92 ls seat in a ef?
- Anyone know how to Wire tuck there Wiring Harness in the Engine Bay
- 89 B16A CRX - Stumbling
- the wiring diagram for a 88-91 honda crx hf vtec harness how to wire
- 205-45-16 good??
- Which tires should I buy for my hatchback???
- FS JDM PR3 PW0 Honda Civic CRX Integra ECU with HONDATA Stage 4B with Boost and with RomEditor Softw
- v-tec controller instructions 2000 b16a2
- Ignition Lock question....
- Crx not enough room?
- HELP! b16 Vehicle speed sensor electric to cable
- block notching?
- Sir Conversion deals?
- Need Help With Tire Options. Which Falken's do I pick?
- tick, tick, tick tock
- place racing rear mount ????
- Bucking first gear at 2,000 RPM
- EG cluster into EF CRX
- Picked up a set of Recaros from the junkyard
- (WTB) 84 CRX Part (where to purchase)
- rim fitment
- D16Y8...what to build?
- CRX HF w/ b16 and CRX Si weighed on the same scale:here are the results
- Starting to build 91 Civic autocross/ light rally need help
- Searched for like an hour.
- car wont get in gear
- what kind of power would i get out of this
- RHD
- Replace wheel bearing when the hub gets pressed out? true/false?
- Swapping B20vtec in CRX need tips.
- Resistor box!!!!
- Car wont start occasionally....starter or main relay?
- tranny shifting problems...already searched..
- Flashing Oil Light
- i think my fuel lines are leaking...omghi2u2!!!
- HELP! No power at all below 4000rpm
- Engine Stalling while driving?
- anyone useing a 96-200 civic radiator in their ef civics?
- oil burning problem on recent rebuild
- How To Fit 4AGE Throttle Body in B16A ?
- My Ef Build Project
- won't start.. ECU code 15
- Wrecked my Rex. Pic
- redline problem
- Thinking of swapping the D16Z6Del SolSi engine into my CRX, how much would this cost me?
- How can you tell if you have a vtec-e head
- what should i do..
- 5 Questions, about car parts and car terms
- dc2 type r shift boot in crx
- full race manifold
- Quick noob Question
- i'm smelling gas coming out my exhaust pipe from about 25 feet away
- what will make my rpm gauge go up and down when i get to 6,000 rpm
- brakes and suspension....?
- Non EF(D) Lip on EF's
- CRX B16 OBD0 wiring HELPPP!
- 1st or 2nd gen b16?
- 83 Civic 1500S
- d16 block questions
- SEARCHED: Which Radiator hoses to use?
- zex/comp 59300 ok to use with stock valvetrain
- 89 civic hatch ls turbo.......need to booooost more / how much
- My $600 CRX........no-56K
- ngk or bosch wires?
- aftermarket fog lights
- What happened to www.autosonic.com? Need Vision Corner Replicas!
- Reactive D series header
- HELP.... CODE 9 AND 4 ..... HELP
- Stock ride height on crx???
- What is a ZC engine, is it fomrthe D series engine, from what car?
- Engine problems swap a b16 for d15 and engine dont fire-up, cranks but thats all it does
- Need a Car 2500 or less!
- 91 Civic Gas Problems!
- What head on CTR block?
- ek/ej front bumper on a crx?
- steering wheel with its own brain
- where can i find a mugen body kit for...
- Help me please
- How do you Change Blower motor for heat/ac
- 1990 STD Doesn't come with front sway bar... right? Is this a mount??
- so everyone knows LEN is the man!
- FLUIDYNE 1/2 radiators are CRAP!
- D-Series head gasket Question...
- Power for the resistor box ( ecu pins )
- engine swaps
- swaping out lights
- what spings should i get
- what ecu do i have?
- Battery Relocation Question
- siR bumper red lining
- Speedo doesn't work
- uberdata question
- lsd on a D series tranny.....possible?
- cant get rid of cel 41 after melting o2 wires, obd1 d16z6 '89 hatch
- How do you remove a 1990 CRX steering wheel?
- [FAQ] How to install Heads Up Display into a 88-91 Civic/CRX
- Timing belt 87 CRX SI
- ef9 siR bumper on 88 DX
- Help
- Performance figures
- Assistance in wiring the variable valve timing system
- Oil on flywheel
- Hasport DPFI-MPFI vtec harness to obd1
- acura rear trailing arm
- desperately seaking the real 2point2...
- Interchangeable Gears??
- Sedan Bumpers
- CRX DX and i was thinging about putting a CRX SI engine into it, is it worth it?
- CRX SiR Performance Upgrades.
- 1988 ed civic engine conversion d15b4 to b16a or any other performance tips for d15
- =[ Check Out The Motor
- D16Z6 head on D15b1?? (I searched)
- VTEC-E engines
- NEED STOCK ENGINE
- paintless dent removal question
- need help with cooling issues
- CAR MAJORLY OVERHEATING
- started to clean up my engine bay a bit before BARing my d15
- pic request: ecu on an 87 crx si
- wiring auto to manuel help
- D series limited slip JDM
