View Full Version : Honda CRX / EF Civic (1988 - 1991)
- amber tint
- Fastest ZC motors on H-T???
- Need advice!!
- To ppl have Field's SFC-Vtec Controller
- how many miles do you have on your crx / EF?
- lsd for ls tranny, which one do you like?
- Factory stting for fuel???
- auto accessory reviews
- Mitsu T25 in a CRX
- if u had 5000 dollars would u still buy a rex? or would u move onto eg body style?
- posting pics?
- welding on front clip? anyone here done it before?
- what knuckles can use SI axles?
- I need opinions...
- AC.....Vents a smoking?
- b16 shift linkage in crx
- Car overheating after A/C is on
- B16A/B Ran at track 1/4 mile time.....
- did search... need engine codes
- Just found out today- CRXs get HOT in the summer
- adjusting valves
- EF big brake upgrade
- Converting rear drums to rotor's
- funny power wiring?
- 1.8 non vtec , who makes good cams?
- Sway bars
- Hi I need a lil help on making my dream car for about 15k canadian.
- hood troubles
- which cam should I pick...
- Which Delta Camshaft is best for me???
- Brake Fluid dripping from rear drum???
- Where can I find a X-brace?
- Engine Swap
- non buzzy exhaust
- HELP, Throttle Body sticking...........
- How to remove heater
- b16 IM mated to d-series flange?
- rack and pinion boot
- New and improved C-pillar bar for ef's!!!
- y8 headgasket fit on d15b7?
- M.S.D.
- piece to match up b16 header with stock exhaust.
- keep 'em or sell 'em
- How much to take off when milling a D15B2 head to get 10.5:1 - 11:1 compression??
- squeeky squeeks, front suspension. annoying as hell
- pr3 ecu vs. pr4
- gas mileage?
- b16a1 into hf question
- Well it's time to say goodbye to the crx
- Zdyne tuning question
- i need a 88-91 d series block bad!!
- Painting My CRX
- OK to run without thermostat?
- CRX si $600 running(Auto>MAn-conver) worth it?
- ZC Tranny Questions
- Installer Needed in LA/Orange County Area D16Z6
- clutch pressure plate baffeling any ideas
- SI Head on HF Block... Any troubles???
- d16z6 speedometer issues
- Which PISTONS in a Z6??
- I'm stuck!!
- High Compression Pistons
- Sticky green shit on Spark plug #1
- exhust for my 91 hatchback
- *Suspension Guru's* Will a 90 CRX subframe and rack bolt to a 91 HB?
- What is the Correct way to do a Compression Test On A Motor?
- wtb
- Suggestions for 88-91 hatch reference sites
- WTB: DC 4-1 header for B16 in 91 hatch
- N/A CRX, 13s, Cheap
- B18a swap questions
- can you get front lips for jdm front ends in n/a?
- jdm cluster wiring
- how long will it last
- how can i make a good car for under $20,000 Canadian
- Cheapest price for Hasport EF AC kit?
- looking for for a fiberglass hood ext..... for my 91 hatch
- Any linit on compression with a chipped ECU?
- Woooo Hoooo! I passed Emmisions!
- term paper on d series honda engines.
- turbo,hondata,pr3,o2 sensors question
- Turbo Install Pics.....
- swapping blue interior for black
- CRX Ecu Year Question...
- question about mini me (dont mean to beat a dead horse )
- crx/civic rear bumpers...
- 99si with JDMH22a-come along for the ride
- Glove box ?
- '91 Integra rear disk brakes?
- Help with code on ECU
- Specs on 1990 SI Hatch
- best head and cam packages?
- ROll bars , and roll cages for 88 CRX, what are my options?
- what throttle for itr intake manifold
- Glovebox for 90 Si hatch
- Dual Port Civic Help????
- This Rod That Rod
- CRX Head info
- Wiring Toggle Switch for Windshield Wipers? Tips, or anyone do this before.
- What's a good do-it-yourself turbo setup?
- DOHC ZC: stock specs??
- no spark, need help
- LSD Y1 good for my set-up? (b18c1 in 91 Si)
- need some help
- Links for the EF crew.....
- ecu problems? dizzy problems?
- Florida Mini-Meet
- d16a6 ported head
- no fuel pressure... brand new relay!
- Compression ?'s
- crx dash in a 90civic si?
- Vin Number
- how to tell the difference??
- Need to replace molding strip along bottom of windows. Where do I get it?
- Running a SIR II without a working Coolant Temperature Sensor Effects?
- Sensor Cleaning
- obd0 dohc zc vs. obd1 dohc zc??
- Need help, want ideas for security for my car in Phoenix, AZ
- rear disk brakes?
- exhaust
- 92-95 civic hb gas tank in ef?
- working on removing my axles now....
- What would cause the idle to fluctutate on my 90 CRX Dx??
- Where can i get a good ecu chip.......
- B-series mounts
- b18a in 91 civic which alt belt are you using and wiring question
- s2000 steering wheel in a 88 CRX?
- Alignment issues
- List of OEM ZC part numbers? Need one for the new owner.
- Changing a/c belt ?
- 1989 CRX for sale
- Si head on Hf block
- Help why won't my car start.
- What a ripoff JDM crx seat!!
- this may sound stupid........
- Will These Work Correctly? (DOHC ZC)
- Hmmm Can She Handle It?
- A/C Suckin Power
- O2 sensors questions.....
- anybody put cruise in an EF?
- hks exhaust
- rear 4dr EG/EK door handles for keyless entry?
- crx lightening tips???
- 1/4 time estimate
- there is no way this can be possible ..can it?
- integra brakes on my90 civic hatch help?
- max recomended boost on a t25 simi built zc
- where's the best price for WW RS kit?
- Is it possible to swap a 92-95 VTEC head onto a '91 Si Motor?
- 89 crx dx - b16a1 wiring conversion??
- paint before selling yes or no?
- What are the valve adjust specs for a ZC?
- new engine in *56k beware*
- Carfax request
- Whats the biggest nitrous shot for a ZC?
- Helms shop manual for 89 3-door
- Headlight upgrade how-to
- delsol Si D16a6 ?
- ES rear swaybar bushings?
- Whats this
- dpfi to b18b where to get the fuel line?
- My baby's coming together...
- good place to order B16 from in VA area.
- Differant dash into a sedan?
- std overheating need help
- need to do nething 2 headgasket before install?
- taking off sunroof?
- wtb sir bumper
- In the b16a1 stock header, which o2 is primary and which is second?
- do all crx si have
- Wiring harness questions>>
- is it possible??
- bogging problem with my EF
- Do Crx Seats Bolt Into a 90-91 civic h/b
- GSR Cluster in an 88 CRX?
- b16 wont start distro??
- CRX Height question
- Help my poor b16
- will these springs fit?
- Wait wait wait wait wait, THIS is fuel injected?
- Starter going south
- are stock spark plugs ok for the zc piston/d16a6 combo?
- Head Problems
- can ef lights be baked/painted??
- More Axle ???
- how much should i pay for slightly used endless(zeal) coilovers?
- dohc zc bolt into 91 crx si? obd0 and obd1?
- Can I get rid of some of these lines on the Throttle body/Intake Mani?
- Anyone with a CRX HF with D16Z6 please reply!
- Swaping out a '89 Hf motor (d15b6) for a 90 Si motor (d16a6)..I have a few questions?
- help help help!!!!!!!!!
- altenator install gone bad!!
- Help...No Spark!
- Mount ?
- looking for the right sized socket for my axle nuts
- how much horsepower?
- What do you think is faster????
- Can seatbelts be adjusted?
- Tanabe GF210 or DF210?????
- Zc or D16z6 ? decision...
- Hey... 2 things
- dohc zc / d16a1?
- how to wirea gsr motor in a 1990 crx dx with dual point injection
- Header Fitting
- Okay, it's decision time: OEM sunroof replacement or Fiberglass plug?
- Axles for B20Vtec?
- SIR headlight question
- Year of B18A Motor and ECU
- B18b sway
- Will DOHC ZC head work on my D16A6 block?
- it works!
- Crank Pulley Tool?
- car tries to roll forward when starting
- Master Cylinder rusted? Change out? What kind? Help.
- Does your CRX ride like crap??
- B-series..should b stand for "buddy"..well please help me out b-series b16a buddies!~
- Best shox and springs setup
- Reasons as to why my car seems unevenly lowered
- B18A1 distributor... same cap as d16a6? same distributor?
- DESPERATE for DOHC ZC help............
- Camber Kit cheapest where to buy and which one
- D16A1 pistons/rods N D16A6/performance?
- anyone in southern california w/ a 1st gen b16?
- rotar bolts
- crx owners i have a question......
- b18a swap question i need help
- weirdo tranny
- How do I know if vtec is working in my car b16a second gen?
- i wanna repaint my car red, but dont know which one, help me pick....
- Quick question for the EF guys....
- how can i get faster?
- place racing motor mount kit any opinions 4 mount setup
- ***How different did the LS feel after your d16a6??***
- ef spoon/vision mirrors?
- jb weld
- Got a CRX, ran at track last night, how was my time?
- '89 crx springs question
- Niagra meet?
- cleaning your own injectors
- b16/CRX Si Went 14.76@87.85 MPH???? Somthing wrong????
- are there 15" 4x100 rims ??
- What would you do...Please look...
- 91 crx forsale 250 obo...
- !!! I NEED A D16A6 imediatly !!!
- igniton rotor question
- code 15 on my 89 hatch with b20z, help?
- why iam i blwoing my fuse?!?!?!
- the word on R1 seats
- which ecu?
- Anybody put a vortech on a b16 in a crx/civic? Found stuff on the Jrsc bvut nothing on vortech
